Public Member Functions | List of all members
pqProxyPropertyWidget Class Reference
This is a widget for a vtkSMProxyProperty. More...
#include <pqProxyPropertyWidget.h>
Inheritance diagram for pqProxyPropertyWidget:
Collaboration diagram for pqProxyPropertyWidget:
 pqProxyPropertyWidget (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parent=nullptr)
void apply () override
 Overridden to pass the calls to internal widgets. More...
void reset () override
void select () override
 These methods are called when the pqProxyPropertiesPanel containing the widget is activated/deactivated. More...
void deselect () override
void updateWidget (bool showing_advanced_properties) override
 Overridden to hide the properties for proxies in a vtkSMProxyListDomain if requested. More...
vtkSMProxy * chosenProxy () const
 If the internal widget is a ProxySelectionWidget, return its chosen proxy. More...
 ~pqPropertyWidget () override
pqView * view () const
vtkSMProxy * proxy () const
bool showLabel () const
bool isSelected () const
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinks & links ()
It handles a "SelectionInput" property and properties with ProxyListDomain.
Definition at line 19 of file pqProxyPropertyWidget.h.
◆ pqProxyPropertyWidget()
pqProxyPropertyWidget::pqProxyPropertyWidget ( vtkSMProperty *  property,
vtkSMProxy *  proxy,
QWidget *  parent = nullptr
◆ apply()
void pqProxyPropertyWidget::apply ( )
Reimplemented from pqPropertyWidget.
◆ reset()
void pqProxyPropertyWidget::reset ( )
◆ select()
void pqProxyPropertyWidget::select ( )
Only widgets that have 3D widgets need to override these methods to select/deselect the 3D widgets.
◆ deselect()
void pqProxyPropertyWidget::deselect ( )
Only widgets that have interactive widgets need to override these methods to select/deselect the interactive widgets. selectPort(int) allows to specify an output port index and conditionnaly select the interactive widget if the XML hint WidgetVisibilityLink has been set. Default implementation does nothing.
◆ updateWidget()
void pqProxyPropertyWidget::updateWidget ( bool  showing_advanced_properties)
◆ chosenProxy()
vtkSMProxy* pqProxyPropertyWidget::chosenProxy ( ) const
Otherwise null
