vtkSMSourceProxy Class Reference
proxy for a VTK source on a server More...
#include <vtkSMSourceProxy.h>
Inheritance diagram for vtkSMSourceProxy:
Collaboration diagram for vtkSMSourceProxy:
enum  ProcessSupportType { SINGLE_PROCESS, MULTIPLE_PROCESSES, BOTH }
typedef vtkSMProxy Superclass
void UpdatePipelineInformation () override
 Calls UpdateInformation() on all sources. More...
virtual void UpdatePipeline ()
 Calls Update() on all sources. More...
virtual void UpdatePipeline (double time)
 Calls Update() on all sources with the given time request. More...
virtual unsigned int GetNumberOfOutputPorts ()
 Return the number of output ports. More...
virtual vtkSMOutputPort * GetOutputPort (unsigned int idx)
 Return an output port. More...
virtual vtkSMOutputPort * GetOutputPort (const char *portname)
 Return an output port, given the name for the port. More...
virtual unsigned int GetOutputPortIndex (const char *portname)
 Returns the port index, given the name of an output port. More...
virtual const char * GetOutputPortName (unsigned int index)
 Returns the output port name given its index. More...
virtual void CreateOutputPorts ()
 Creates the output port proxies for this filter. More...
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, unsigned int compositeIndex)
 A GetSubsetDataInformation overload that uses composite index. More...
virtual void CreateSelectionProxies ()
 Creates extract selection proxies for each output port if not already created. More...
void SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort)
 Set/Get the selection input. More...
void CleanSelectionInputs (unsigned int portIndex)
 Clean all selection inputs for the given port. More...
vtkSMSourceProxy * GetSelectionOutput (unsigned int portIndex)
 Returns the source proxy which provides the selected data from the given output port. More...
unsigned int GetNumberOfAlgorithmOutputPorts ()
 Returns the number of output ports provided by the algorithm. More...
virtual unsigned int GetNumberOfAlgorithmRequiredInputPorts ()
 Returns the number of non-optional input ports required by the algorithm. More...
vtkTypeUInt32 GetGlobalID () override
 Overridden to reserve additional IDs for use by "ExtractSelection" proxies. More...
void MarkDirty (vtkSMProxy *modifiedProxy) override
 Marks the selection proxies dirty as well as chain to superclass. More...
virtual int GetOutputPortsCreated ()
 Returns if the output port proxies have been created. More...
vtkSMDocumentation * GetOutputPortDocumentation (unsigned int index)
 It is possible to provide some documentation for each output port in the configuration xml. More...
vtkSMDocumentation * GetOutputPortDocumentation (const char *portname)
vtkPVDataInformation * GetDataInformation ()
 DataInformation is used by the source proxy to obtain information on the output(s) from the server. More...
vtkPVDataInformation * GetDataInformation (unsigned int outputIdx)
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, const char *selector, const char *assemblyName=nullptr)
 For composite datasets, GetDataInformation returns summary data information for all blocks combined. More...
vtkPVDataInformation * GetRankDataInformation (int rank)
 Get rank-specific data information. More...
vtkPVDataInformation * GetRankDataInformation (unsigned int outputIdx, int rank)
vtkSMSourceProxy * GetSelectionInput (unsigned int portIndex)
 API to query selection input set using SetSelectionInput. More...
unsigned int GetSelectionInputPort (unsigned int portIndex)
virtual int GetProcessSupport ()
 This returns information about whether the VTK algorithm supports multiple processes or not. More...
virtual bool GetMPIRequired ()
 This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMSourceProxy * New ()
static vtkSMSourceProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMSourceProxy ()
 ~vtkSMSourceProxy () override
virtual void InvalidateDataInformation ()
 Mark the data information as invalid. More...
 Call superclass' and then assigns a new executive (vtkCompositeDataPipeline) More...
virtual void SetExecutiveName (const char *)
void PostUpdateData (bool) override
 Overwritten from superclass to invoke. More...
void SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override
 Overridden to pass the logname to the internal ExtractSelection proxies. More...
void SetOutputPort (unsigned int index, const char *name, vtkSMOutputPort *port, vtkSMDocumentation *doc)
 Method to set an output port at the given index. More...
void RemoveAllOutputPorts ()
void SetExtractSelectionProxy (unsigned int index, vtkSMSourceProxy *proxy)
void RemoveAllExtractSelectionProxies ()
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
int OutputPortsCreated
int ProcessSupport
bool MPIRequired
char * ExecutiveName
bool DisableSelectionProxies
bool SelectionProxiesCreated
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Friends
class vtkSMInputProperty
class vtkSMOutputPort
vtkSMSourceProxy manages VTK source(s) that are created on a server using the proxy pattern. In addition to functionality provided by vtkSMProxy, vtkSMSourceProxy provides method to connect and update sources. Each source proxy has one or more output ports (vtkSMOutputPort). Each port represents one output of one filter. These are created automatically (when CreateOutputPorts() is called) by the source. Each vtkSMSourceProxy creates a property called DataInformation. This property is a composite property that provides information about the output(s) of the VTK sources (obtained from the server)
See also
vtkSMProxy vtkSMOutputPort vtkSMInputProperty
Definition at line 37 of file vtkSMSourceProxy.h.
Definition at line 41 of file vtkSMSourceProxy.h.
◆ ProcessSupportType
Enumerator
SINGLE_PROCESS
MULTIPLE_PROCESSES
BOTH
Definition at line 239 of file vtkSMSourceProxy.h.
◆ vtkSMSourceProxy()
vtkSMSourceProxy::vtkSMSourceProxy ( )
◆ ~vtkSMSourceProxy()
vtkSMSourceProxy::~vtkSMSourceProxy ( )
static vtkSMSourceProxy* vtkSMSourceProxy::New ( )
virtual const char* vtkSMSourceProxy::GetClassName ( )
static int vtkSMSourceProxy::IsTypeOf ( const char *  type)
virtual int vtkSMSourceProxy::IsA ( const char *  type)
static vtkSMSourceProxy* vtkSMSourceProxy::SafeDownCast ( vtkObject *  o)
void vtkSMSourceProxy::PrintSelf ( ostream &  os,
◆ UpdatePipelineInformation()
void vtkSMSourceProxy::UpdatePipelineInformation ( )
◆ UpdatePipeline() [1/2]
virtual void vtkSMSourceProxy::UpdatePipeline ( )
It also creates output ports if they are not already created.
Reimplemented in vtkSMRepresentationProxy, and vtkSMWriterProxy.
◆ UpdatePipeline() [2/2]
virtual void vtkSMSourceProxy::UpdatePipeline ( double  time)
◆ GetOutputPortsCreated()
virtual int vtkSMSourceProxy::GetOutputPortsCreated ( )
◆ GetNumberOfOutputPorts()
virtual unsigned int vtkSMSourceProxy::GetNumberOfOutputPorts ( )
◆ GetOutputPort() [1/2]
virtual vtkSMOutputPort* vtkSMSourceProxy::GetOutputPort ( unsigned int  idx)
◆ GetOutputPort() [2/2]
virtual vtkSMOutputPort* vtkSMSourceProxy::GetOutputPort ( const char *  portname)
Each output port is assigned a unique name (either using the xml configuration or automatically). The automatically assigned names are of the type Output0, Output1 etc.
◆ GetOutputPortIndex()
virtual unsigned int vtkSMSourceProxy::GetOutputPortIndex ( const char *  portname)
Each output port is assigned a unique name (either using the xml configuration or automatically). The automatically assigned names are of the type Output0, Output1 etc. Returns VTK_UNSIGNED_INT_MAX (i.e. ~0u) when a port with given port name does not exist.
◆ GetOutputPortName()
virtual const char* vtkSMSourceProxy::GetOutputPortName ( unsigned int  index)
Each output port is assigned an unique name (either using the xml configuration or automatically). The automatically assigned names are of the type Output-0, Output-1 etc.
◆ GetOutputPortDocumentation() [1/2]
vtkSMDocumentation* vtkSMSourceProxy::GetOutputPortDocumentation ( unsigned int  index)
These methods provide access to the port specific documentation, if any. If no documentation is present, these methods will return 0.
◆ GetOutputPortDocumentation() [2/2]
vtkSMDocumentation* vtkSMSourceProxy::GetOutputPortDocumentation ( const char *  portname)
◆ CreateOutputPorts()
virtual void vtkSMSourceProxy::CreateOutputPorts ( )
Each output port proxy corresponds to an actual output port on the algorithm.
Reimplemented in vtkSMCompoundSourceProxy.
◆ GetDataInformation() [1/2]
vtkPVDataInformation* vtkSMSourceProxy::GetDataInformation ( )
inline
If update is false the pipeline will not be updated before gathering the data information.
Definition at line 129 of file vtkSMSourceProxy.h.
◆ GetDataInformation() [2/2]
vtkPVDataInformation* vtkSMSourceProxy::GetDataInformation ( unsigned int  outputIdx)
◆ GetSubsetDataInformation() [1/2]
vtkPVDataInformation* vtkSMSourceProxy::GetSubsetDataInformation ( unsigned int  outputIdx,
const char *  selector,
const char *  assemblyName = nullptr
However, applications may require information about specific subset of blocks. In that case, one can use this API. Internally, the data information is cached per selector / assembly-name pair. That way, if the data information is not re-gathered unless changed.
  • selector the selector expression
  • assemblyName name of the assembly to use to apply the selector to to determine the subset. If none specified, then default data-assembly is used. For hierarchy, use vtkDataAssemblyUtilities::HierarchyName().
◆ GetSubsetDataInformation() [2/2]
It is only supported for multiblock datasets.
◆ GetRankDataInformation() [1/2]
vtkPVDataInformation* vtkSMSourceProxy::GetRankDataInformation ( int  rank)
inline
Definition at line 162 of file vtkSMSourceProxy.h.
◆ GetRankDataInformation() [2/2]
vtkPVDataInformation* vtkSMSourceProxy::GetRankDataInformation ( unsigned int  outputIdx,
int  rank
◆ CreateSelectionProxies()
virtual void vtkSMSourceProxy::CreateSelectionProxies ( )
◆ SetSelectionInput()
void vtkSMSourceProxy::SetSelectionInput ( unsigned int  portIndex,
vtkSMSourceProxy *  input,
This is used to set the selection input to the extraction proxy for the output port identified by portIndex. If no extraction proxies are present, this method has no effect.
◆ GetSelectionInput()
vtkSMSourceProxy* vtkSMSourceProxy::GetSelectionInput ( unsigned int  portIndex)
◆ GetSelectionInputPort()
unsigned int vtkSMSourceProxy::GetSelectionInputPort ( unsigned int  portIndex)
◆ CleanSelectionInputs()
void vtkSMSourceProxy::CleanSelectionInputs ( unsigned int  portIndex)
◆ GetSelectionOutput()
vtkSMSourceProxy* vtkSMSourceProxy::GetSelectionOutput ( unsigned int  portIndex)
◆ GetProcessSupport()
virtual int vtkSMSourceProxy::GetProcessSupport ( )
SINGLE_PROCESS means that this algorithm works only in serial, MULTIPLE_PROCESSES means that it will only useful in parallel (or it is useless in serial), BOTH means both :-) Default is BOTH. This ivar is filled from the xml configuration. This variable should not be used to determine if MPI is initialized. Instead use MPISupport for that.
◆ GetMPIRequired()
virtual bool vtkSMSourceProxy::GetMPIRequired ( )
It still may only run with a single process. An example of this is a reader that uses MPI IO routines.
◆ GetNumberOfAlgorithmOutputPorts()
unsigned int vtkSMSourceProxy::GetNumberOfAlgorithmOutputPorts ( )
◆ GetNumberOfAlgorithmRequiredInputPorts()
virtual unsigned int vtkSMSourceProxy::GetNumberOfAlgorithmRequiredInputPorts ( )
This value is cached after the first call.
◆ GetGlobalID()
vtkTypeUInt32 vtkSMSourceProxy::GetGlobalID ( )
Reimplemented from vtkSMRemoteObject.
Reimplemented in vtkSMRepresentationProxy.
◆ MarkDirty()
void vtkSMSourceProxy::MarkDirty ( vtkSMProxy *  modifiedProxy)
◆ InvalidateDataInformation()
virtual void vtkSMSourceProxy::InvalidateDataInformation ( )
protectedvirtual
◆ CreateVTKObjects()
void vtkSMSourceProxy::CreateVTKObjects ( )
overrideprotectedvirtual
Reimplemented in vtkSMPVRepresentationProxy, and vtkSMRepresentationProxy.
◆ SetExecutiveName()
virtual void vtkSMSourceProxy::SetExecutiveName ( const char *  )
protectedvirtual
◆ ReadXMLAttributes()
int vtkSMSourceProxy::ReadXMLAttributes ( vtkSMSessionProxyManager *  pm,
vtkPVXMLElement *  element
Read attributes from an XML element.
Reimplemented in vtkSMPVRepresentationProxy, vtkSMWriterProxy, and vtkSMChartRepresentationProxy.
◆ SetOutputPort()
void vtkSMSourceProxy::SetOutputPort ( unsigned int  index,
const char *  name,
vtkSMOutputPort *  port,
vtkSMDocumentation *  doc
Provided for subclasses to add output ports. It replaces the output port at the given index, if any, The output ports will be resize to fit the specified index.
◆ RemoveAllOutputPorts()
void vtkSMSourceProxy::RemoveAllOutputPorts ( )
◆ SetExtractSelectionProxy()
void vtkSMSourceProxy::SetExtractSelectionProxy ( unsigned int  index,
vtkSMSourceProxy *  proxy
◆ RemoveAllExtractSelectionProxies()
void vtkSMSourceProxy::RemoveAllExtractSelectionProxies ( )
◆ PostUpdateData()
void vtkSMSourceProxy::PostUpdateData ( bool  )
◆ SetLogNameInternal()
void vtkSMSourceProxy::SetLogNameInternal ( const char *  name,
◆ vtkSMInputProperty
friend class vtkSMInputProperty
friend
Definition at line 255 of file vtkSMSourceProxy.h.
◆ vtkSMOutputPort
friend class vtkSMOutputPort
friend
Definition at line 256 of file vtkSMSourceProxy.h.
◆ OutputPortsCreated
int vtkSMSourceProxy::OutputPortsCreated
Definition at line 258 of file vtkSMSourceProxy.h.
◆ ProcessSupport
int vtkSMSourceProxy::ProcessSupport
Definition at line 260 of file vtkSMSourceProxy.h.
◆ MPIRequired
bool vtkSMSourceProxy::MPIRequired
Definition at line 261 of file vtkSMSourceProxy.h.
◆ ExecutiveName
char* vtkSMSourceProxy::ExecutiveName
Definition at line 274 of file vtkSMSourceProxy.h.
◆ DisableSelectionProxies
bool vtkSMSourceProxy::DisableSelectionProxies
Definition at line 308 of file vtkSMSourceProxy.h.
◆ SelectionProxiesCreated
bool vtkSMSourceProxy::SelectionProxiesCreated
Definition at line 309 of file vtkSMSourceProxy.h.
