vtkSMPVMoleculeRepresentationProxy Class Reference
vtkSMPVMoleculeRepresentationProxy is a representation proxy used for molecules. More...
#include <vtkSMPVMoleculeRepresentationProxy.h>
Inheritance diagram for vtkSMPVMoleculeRepresentationProxy:
Collaboration diagram for vtkSMPVMoleculeRepresentationProxy:
enum  Preset {
  None = 0, BallAndStick, Liquorice, VanDerWaals,
  Fast, NbOfPresets
typedef vtkSMPVRepresentationProxy Superclass
- Public Types inherited from vtkSMPVRepresentationProxy
typedef vtkSMRepresentationProxy Superclass
- Public Types inherited from vtkSMRepresentationProxy
typedef vtkSMSourceProxy Superclass
- Public Types inherited from vtkSMSourceProxy
enum  ProcessSupportType { SINGLE_PROCESS, MULTIPLE_PROCESSES, BOTH }
typedef vtkSMProxy Superclass
const char * GetPresetName (int preset)
 Get the preset name. More...
const char * GetPresetDisplayName (int preset)
 Get a display name for the preset. More...
int GetCurrentPreset ()
 Get the current preset value. More...
void SetPreset (int preset)
 Set Preset onto properties. More...
void SetPreset (const char *name)
- Public Member Functions inherited from vtkSMPVRepresentationProxy
virtual bool GetUsingScalarColoring ()
 Returns true if scalar coloring is enabled. More...
vtkSMProxy * GetLUTProxy (vtkSMProxy *view)
 Returns the lut proxy of this representation in the given view. More...
bool UpdateScalarBarRange (vtkSMProxy *view, bool deleteRange)
 Updates the ranges shown in the scalar bar. More...
virtual bool SetScalarColoring (const char *arrayname, int attribute_type)
 Enable/disable scalar coloring using the specified array. More...
virtual bool SetScalarColoring (const char *arrayname, int attribute_type, int component)
virtual bool RescaleTransferFunctionToDataRange (bool extend=false, bool force=true)
 Rescales the color transfer function and opacity transfer function using the current data range. More...
virtual bool RescaleTransferFunctionToDataRange (const char *arrayname, int attribute_type, bool extend=false, bool force=true)
 Rescales the color transfer function and opacity transfer function using the current data range for the chosen data-array. More...
virtual bool RescaleTransferFunctionToDataRangeOverTime ()
 Rescales the color transfer function and opacity transfer function using the current data range over time. More...
virtual bool RescaleTransferFunctionToDataRangeOverTime (const char *arrayname, int attribute_type)
 Rescales the color transfer function and opacity transfer function using the current data range over time for the chosen data-array. More...
int GetEstimatedNumberOfAnnotationsOnScalarBar (vtkSMProxy *view)
 Get an estimated number of annotation shown on this representation scalar bar. More...
bool SetRepresentationType (const char *type) override
 Overridden to ensure when picking representation types that require scalar colors, scalar coloring it setup properly. More...
bool GetVolumeIndependentRanges ()
 True if ranges have to be computed independently on component 0 for the color and 1 for the opacity on the Volume representation. More...
void ViewUpdated (vtkSMProxy *view) override
 Called after the view updates. More...
void SetLastLUTProxy (vtkSMProxy *proxy)
 Set/get last LUT proxy. More...
vtkSMProxy * GetLastLUTProxy ()
virtual bool RescaleTransferFunctionToVisibleRange (vtkSMProxy *view)
 Rescales the color transfer function and the opacity transfer function using the current data range, limited to the currernt visible elements. More...
virtual bool RescaleTransferFunctionToVisibleRange (vtkSMProxy *view, const char *arrayname, int attribute_type)
int IsScalarBarStickyVisible (vtkSMProxy *view)
 Checks if the scalar bar of this representation in view is sticky visible, i.e. More...
virtual bool SetScalarBarVisibility (vtkSMProxy *view, bool visible)
 Set the scalar bar visibility. More...
virtual bool HideScalarBarIfNotNeeded (vtkSMProxy *view)
 While SetScalarBarVisibility can be used to hide a scalar bar, it will always simply hide the scalar bar even if its being used by some other representation. More...
virtual bool IsScalarBarVisible (vtkSMProxy *view)
 Check scalar bar visibility. More...
virtual vtkPVArrayInformation * GetArrayInformationForColorArray (bool checkRepresentedData=true)
 Returns the array information for the data array used for scalar coloring, from input data. More...
virtual vtkPVProminentValuesInformation * GetProminentValuesInformationForColorArray (double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false)
 Call vtkSMRepresentationProxy::GetProminentValuesInformation() for the array used for scalar color, if any. More...
- Public Member Functions inherited from vtkSMRepresentationProxy
virtual vtkPVDataInformation * GetRepresentedDataInformation ()
 Returns information about the data that is finally rendered by this representation. More...
virtual vtkPVProminentValuesInformation * GetProminentValuesInformation (std::string name, int fieldAssoc, int numComponents, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false)
 Returns information about a specific array component's prominent values (or nullptr). More...
void UpdatePipeline () override
 Calls Update() on all sources. More...
void UpdatePipeline (double time) override
 Calls Update() on all sources with the given time request. More...
void PostUpdateData (bool) override
 Overridden to reset this->MarkedModified flag. More...
vtkTypeUInt32 GetGlobalID () override
 Overridden to reserve additional IDs for use by internal composite representation. More...
void MarkDirty (vtkSMProxy *modifiedProxy) override
 Marks the selection proxies dirty as well as chain to superclass. More...
const char * GetRepresentationType ()
 Set the representation type. More...
bool IsVolumeRendering ()
 Convenient method to check if this representation is currently rendering volumes, using 2D Transfer function. More...
bool GetUsing2DTransferFunction ()
- Public Member Functions inherited from vtkSMSourceProxy
void UpdatePipelineInformation () override
 Calls UpdateInformation() on all sources. More...
virtual unsigned int GetNumberOfOutputPorts ()
 Return the number of output ports. More...
virtual vtkSMOutputPort * GetOutputPort (unsigned int idx)
 Return an output port. More...
virtual vtkSMOutputPort * GetOutputPort (const char *portname)
 Return an output port, given the name for the port. More...
virtual unsigned int GetOutputPortIndex (const char *portname)
 Returns the port index, given the name of an output port. More...
virtual const char * GetOutputPortName (unsigned int index)
 Returns the output port name given its index. More...
virtual void CreateOutputPorts ()
 Creates the output port proxies for this filter. More...
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, unsigned int compositeIndex)
 A GetSubsetDataInformation overload that uses composite index. More...
virtual void CreateSelectionProxies ()
 Creates extract selection proxies for each output port if not already created. More...
void SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort)
 Set/Get the selection input. More...
void CleanSelectionInputs (unsigned int portIndex)
 Clean all selection inputs for the given port. More...
vtkSMSourceProxy * GetSelectionOutput (unsigned int portIndex)
 Returns the source proxy which provides the selected data from the given output port. More...
unsigned int GetNumberOfAlgorithmOutputPorts ()
 Returns the number of output ports provided by the algorithm. More...
virtual unsigned int GetNumberOfAlgorithmRequiredInputPorts ()
 Returns the number of non-optional input ports required by the algorithm. More...
virtual int GetOutputPortsCreated ()
 Returns if the output port proxies have been created. More...
vtkSMDocumentation * GetOutputPortDocumentation (unsigned int index)
 It is possible to provide some documentation for each output port in the configuration xml. More...
vtkSMDocumentation * GetOutputPortDocumentation (const char *portname)
vtkPVDataInformation * GetDataInformation ()
 DataInformation is used by the source proxy to obtain information on the output(s) from the server. More...
vtkPVDataInformation * GetDataInformation (unsigned int outputIdx)
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, const char *selector, const char *assemblyName=nullptr)
 For composite datasets, GetDataInformation returns summary data information for all blocks combined. More...
vtkPVDataInformation * GetRankDataInformation (int rank)
 Get rank-specific data information. More...
vtkPVDataInformation * GetRankDataInformation (unsigned int outputIdx, int rank)
vtkSMSourceProxy * GetSelectionInput (unsigned int portIndex)
 API to query selection input set using SetSelectionInput. More...
unsigned int GetSelectionInputPort (unsigned int portIndex)
virtual int GetProcessSupport ()
 This returns information about whether the VTK algorithm supports multiple processes or not. More...
virtual bool GetMPIRequired ()
 This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMPVMoleculeRepresentationProxy * New ()
static vtkSMPVMoleculeRepresentationProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMPVRepresentationProxy
static vtkSMPVRepresentationProxy * New ()
static vtkSMPVRepresentationProxy * SafeDownCast (vtkObject *o)
static void SetupLookupTable (vtkSMProxy *proxy)
 Given the input registered representation proxy, sets up a lookup table associated with the representation if a scalar bar is being used for proxy. More...
static int GetEstimatedNumberOfAnnotationsOnScalarBar (vtkSMProxy *proxy, vtkSMProxy *view)
static bool GetUsingScalarColoring (vtkSMProxy *proxy)
 Safely call GetUsingScalarColoring() after casting the proxy to appropriate type. More...
static bool SetScalarColoring (vtkSMProxy *proxy, const char *arrayname, int attribute_type)
 Safely call SetScalarColoring() after casting the proxy to the appropriate type. More...
static bool SetScalarColoring (vtkSMProxy *proxy, const char *arrayname, int attribute_type, int component)
 Safely call SetScalarColoring() after casting the proxy to the appropriate type, component version. More...
static bool RescaleTransferFunctionToDataRange (vtkSMProxy *proxy, bool extend=false, bool force=true)
 Safely call RescaleTransferFunctionToDataRange() after casting the proxy to appropriate type. More...
static bool RescaleTransferFunctionToDataRange (vtkSMProxy *proxy, const char *arrayname, int attribute_type, bool extend=false, bool force=true)
static bool RescaleTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy)
 Safely call RescaleTransferFunctionToDataRangeOverTime() after casting the proxy to appropriate type. More...
static bool RescaleTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy, const char *arrayname, int attribute_type)
static bool RescaleTransferFunctionToVisibleRange (vtkSMProxy *proxy, vtkSMProxy *view)
 Safely call RescaleTransferFunctionToVisibleRange() after casting the proxy to the appropriate type. More...
static bool RescaleTransferFunctionToVisibleRange (vtkSMProxy *proxy, vtkSMProxy *view, const char *arrayname, int attribute_type)
static bool SetScalarBarVisibility (vtkSMProxy *proxy, vtkSMProxy *view, bool visible)
static bool HideScalarBarIfNotNeeded (vtkSMProxy *repr, vtkSMProxy *view)
static bool IsScalarBarVisible (vtkSMProxy *repr, vtkSMProxy *view)
static vtkPVArrayInformation * GetArrayInformationForColorArray (vtkSMProxy *proxy, bool checkRepresentedData=true)
static vtkPVProminentValuesInformation * GetProminentValuesInformationForColorArray (vtkSMProxy *proxy, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false)
- Static Public Member Functions inherited from vtkSMRepresentationProxy
static vtkSMRepresentationProxy * New ()
static vtkSMRepresentationProxy * SafeDownCast (vtkObject *o)
static bool SetRepresentationType (vtkSMProxy *repr, const char *type)
static const char * GetRepresentationType (vtkSMProxy *repr)
static bool IsVolumeRendering (vtkSMProxy *repr)
static bool GetUsing2DTransferFunction (vtkSMProxy *repr)
- Static Public Member Functions inherited from vtkSMSourceProxy
static vtkSMSourceProxy * New ()
static vtkSMSourceProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMPVMoleculeRepresentationProxy ()
 ~vtkSMPVMoleculeRepresentationProxy () override=default
- Protected Member Functions inherited from vtkSMPVRepresentationProxy
 vtkSMPVRepresentationProxy ()
 ~vtkSMPVRepresentationProxy () override
 PARAVIEW_DEPRECATED_IN_5_12_0 ("Internal logic should be in vtkSMColorMapEditorHelper, use " "exposed functions of the helper instead") virtual bool RescaleTransferFunctionToDataRange(vtkPVArrayInformation *info
 Rescales transfer function ranges using the array information provided. More...
 Overridden to ensure that the RepresentationTypesInfo and Representations's domain are up-to-date. More...
void OnPropertyUpdated (vtkObject *, unsigned long, void *calldata)
void SetPropertyModifiedFlag (const char *name, int flag) override
 Overridden to ensure that whenever "Input" property changes, we update the "Input" properties for all internal representations (including setting up of the link to the extract-selection representation). More...
 Overridden to process "RepresentationType" elements. More...
PARAVIEW_DEPRECATED_IN_5_12_0("Internal logic should be in vtkSMColorMapEditorHelper, use " "exposed functions of the helper instead") std PARAVIEW_DEPRECATED_IN_5_12_0 ("Internal logic should be in vtkSMColorMapEditorHelper, use " "exposed functions of the helper instead") virtual bool SetScalarColoringInternal(const char *arrayname
 In case of UseSeparateColorMap enabled, this function prefix the given arrayname with unique identifier, otherwise it acts as a passthrough. More...
- Protected Member Functions inherited from vtkSMRepresentationProxy
 vtkSMRepresentationProxy ()
 ~vtkSMRepresentationProxy () override
void MarkDirtyFromProducer (vtkSMProxy *modifiedProxy, vtkSMProxy *producer, vtkSMProperty *property) override
 When the representation is being marked dirty due to a producer i.e. More...
void AddConsumer (vtkSMProperty *property, vtkSMProxy *proxy) override
void RemoveConsumer (vtkSMProperty *property, vtkSMProxy *proxy) override
void RemoveAllConsumers () override
 Remove all consumers. More...
 Call superclass' and then assigns a new executive (vtkCompositeDataPipeline) More...
void OnVTKRepresentationUpdated ()
void OnVTKRepresentationUpdateSkipped ()
void OnVTKRepresentationUpdateTimeChanged ()
virtual void UpdatePipelineInternal (double time, bool doTime)
void InvalidateDataInformation () override
 Mark the data information as invalid. More...
int LoadXMLState (vtkPVXMLElement *element, vtkSMProxyLocator *locator) override
 Overridden to restore this->Servers flag state. More...
- Protected Member Functions inherited from vtkSMSourceProxy
 vtkSMSourceProxy ()
 ~vtkSMSourceProxy () override
virtual void SetExecutiveName (const char *)
void SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override
 Overridden to pass the logname to the internal ExtractSelection proxies. More...
void SetOutputPort (unsigned int index, const char *name, vtkSMOutputPort *port, vtkSMDocumentation *doc)
 Method to set an output port at the given index. More...
void RemoveAllOutputPorts ()
void SetExtractSelectionProxy (unsigned int index, vtkSMSourceProxy *proxy)
void RemoveAllExtractSelectionProxies ()
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMPVRepresentationProxy
bool extend = false
bool bool force = true)
PARAVIEW_DEPRECATED_IN_5_12_0("Internal logic should be in vtkSMColorMapEditorHelper, use " "exposed functions of the helper instead") std int attribute_type
PARAVIEW_DEPRECATED_IN_5_12_0("Internal logic should be in vtkSMColorMapEditorHelper, use " "exposed functions of the helper instead") std int bool useComponent
PARAVIEW_DEPRECATED_IN_5_12_0("Internal logic should be in vtkSMColorMapEditorHelper, use " "exposed functions of the helper instead") std int bool int component
vtkSmartPointer< vtkSMProxy > LastLUTProxy
 Used as a memory of what was the last LUT proxy linked to this representation. More...
- Protected Attributes inherited from vtkSMSourceProxy
int OutputPortsCreated
int ProcessSupport
bool MPIRequired
char * ExecutiveName
bool DisableSelectionProxies
bool SelectionProxiesCreated
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
This class exposes a method to apply a preset onto molecule properties.
Definition at line 33 of file vtkSMPVMoleculeRepresentationProxy.h.
Definition at line 37 of file vtkSMPVMoleculeRepresentationProxy.h.
◆ Preset
Enumerator
None
BallAndStick
Liquorice
VanDerWaals
Fast
NbOfPresets
Definition at line 40 of file vtkSMPVMoleculeRepresentationProxy.h.
◆ vtkSMPVMoleculeRepresentationProxy()
vtkSMPVMoleculeRepresentationProxy::vtkSMPVMoleculeRepresentationProxy ( )
◆ ~vtkSMPVMoleculeRepresentationProxy()
vtkSMPVMoleculeRepresentationProxy::~vtkSMPVMoleculeRepresentationProxy ( )
overrideprotecteddefault
static vtkSMPVMoleculeRepresentationProxy* vtkSMPVMoleculeRepresentationProxy::New ( )
virtual const char* vtkSMPVMoleculeRepresentationProxy::GetClassName ( )
Reimplemented from vtkSMPVRepresentationProxy.
static int vtkSMPVMoleculeRepresentationProxy::IsTypeOf ( const char *  type)
virtual int vtkSMPVMoleculeRepresentationProxy::IsA ( const char *  type)
static vtkSMPVMoleculeRepresentationProxy* vtkSMPVMoleculeRepresentationProxy::SafeDownCast ( vtkObject *  o)
void vtkSMPVMoleculeRepresentationProxy::PrintSelf ( ostream &  os,
Reimplemented from vtkSMSourceProxy.
◆ SetPreset() [1/2]
void vtkSMPVMoleculeRepresentationProxy::SetPreset ( int  preset)
If preset is None or 0, does nothing.
◆ SetPreset() [2/2]
void vtkSMPVMoleculeRepresentationProxy::SetPreset ( const char *  name)
◆ GetPresetName()
const char* vtkSMPVMoleculeRepresentationProxy::GetPresetName ( int  preset)
This name can be used with SetPreset() method.
◆ GetPresetDisplayName()
const char* vtkSMPVMoleculeRepresentationProxy::GetPresetDisplayName ( int  preset)
◆ GetCurrentPreset()
int vtkSMPVMoleculeRepresentationProxy::GetCurrentPreset ( )
