vtkSMChartRepresentationProxy Class Reference
#include <vtkSMChartRepresentationProxy.h>
Inheritance diagram for vtkSMChartRepresentationProxy:
Collaboration diagram for vtkSMChartRepresentationProxy:
typedef vtkSMRepresentationProxy Superclass
- Public Types inherited from vtkSMRepresentationProxy
typedef vtkSMSourceProxy Superclass
- Public Types inherited from vtkSMSourceProxy
enum  ProcessSupportType { SINGLE_PROCESS, MULTIPLE_PROCESSES, BOTH }
typedef vtkSMProxy Superclass
vtkChartRepresentation * GetRepresentation ()
 Returns client side representation object. More...
 Overridden to handle links with subproxy properties. More...
- Public Member Functions inherited from vtkSMRepresentationProxy
virtual vtkPVDataInformation * GetRepresentedDataInformation ()
 Returns information about the data that is finally rendered by this representation. More...
virtual vtkPVProminentValuesInformation * GetProminentValuesInformation (std::string name, int fieldAssoc, int numComponents, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false)
 Returns information about a specific array component's prominent values (or nullptr). More...
void UpdatePipeline () override
 Calls Update() on all sources. More...
void UpdatePipeline (double time) override
 Calls Update() on all sources with the given time request. More...
void PostUpdateData (bool) override
 Overridden to reset this->MarkedModified flag. More...
virtual void ViewUpdated (vtkSMProxy *view)
 Called after the view updates. More...
vtkTypeUInt32 GetGlobalID () override
 Overridden to reserve additional IDs for use by internal composite representation. More...
void MarkDirty (vtkSMProxy *modifiedProxy) override
 Marks the selection proxies dirty as well as chain to superclass. More...
virtual bool SetRepresentationType (const char *type)
 Set the representation type. More...
const char * GetRepresentationType ()
bool IsVolumeRendering ()
 Convenient method to check if this representation is currently rendering volumes, using 2D Transfer function. More...
bool GetUsing2DTransferFunction ()
- Public Member Functions inherited from vtkSMSourceProxy
void UpdatePipelineInformation () override
 Calls UpdateInformation() on all sources. More...
virtual unsigned int GetNumberOfOutputPorts ()
 Return the number of output ports. More...
virtual vtkSMOutputPort * GetOutputPort (unsigned int idx)
 Return an output port. More...
virtual vtkSMOutputPort * GetOutputPort (const char *portname)
 Return an output port, given the name for the port. More...
virtual unsigned int GetOutputPortIndex (const char *portname)
 Returns the port index, given the name of an output port. More...
virtual const char * GetOutputPortName (unsigned int index)
 Returns the output port name given its index. More...
virtual void CreateOutputPorts ()
 Creates the output port proxies for this filter. More...
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, unsigned int compositeIndex)
 A GetSubsetDataInformation overload that uses composite index. More...
virtual void CreateSelectionProxies ()
 Creates extract selection proxies for each output port if not already created. More...
void SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort)
 Set/Get the selection input. More...
void CleanSelectionInputs (unsigned int portIndex)
 Clean all selection inputs for the given port. More...
vtkSMSourceProxy * GetSelectionOutput (unsigned int portIndex)
 Returns the source proxy which provides the selected data from the given output port. More...
unsigned int GetNumberOfAlgorithmOutputPorts ()
 Returns the number of output ports provided by the algorithm. More...
virtual unsigned int GetNumberOfAlgorithmRequiredInputPorts ()
 Returns the number of non-optional input ports required by the algorithm. More...
virtual int GetOutputPortsCreated ()
 Returns if the output port proxies have been created. More...
vtkSMDocumentation * GetOutputPortDocumentation (unsigned int index)
 It is possible to provide some documentation for each output port in the configuration xml. More...
vtkSMDocumentation * GetOutputPortDocumentation (const char *portname)
vtkPVDataInformation * GetDataInformation ()
 DataInformation is used by the source proxy to obtain information on the output(s) from the server. More...
vtkPVDataInformation * GetDataInformation (unsigned int outputIdx)
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, const char *selector, const char *assemblyName=nullptr)
 For composite datasets, GetDataInformation returns summary data information for all blocks combined. More...
vtkPVDataInformation * GetRankDataInformation (int rank)
 Get rank-specific data information. More...
vtkPVDataInformation * GetRankDataInformation (unsigned int outputIdx, int rank)
vtkSMSourceProxy * GetSelectionInput (unsigned int portIndex)
 API to query selection input set using SetSelectionInput. More...
unsigned int GetSelectionInputPort (unsigned int portIndex)
virtual int GetProcessSupport ()
 This returns information about whether the VTK algorithm supports multiple processes or not. More...
virtual bool GetMPIRequired ()
 This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMChartRepresentationProxy * New ()
static vtkSMChartRepresentationProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMRepresentationProxy
static vtkSMRepresentationProxy * New ()
static vtkSMRepresentationProxy * SafeDownCast (vtkObject *o)
static bool SetRepresentationType (vtkSMProxy *repr, const char *type)
static const char * GetRepresentationType (vtkSMProxy *repr)
static bool IsVolumeRendering (vtkSMProxy *repr)
static bool GetUsing2DTransferFunction (vtkSMProxy *repr)
- Static Public Member Functions inherited from vtkSMSourceProxy
static vtkSMSourceProxy * New ()
static vtkSMSourceProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMChartRepresentationProxy ()
 ~vtkSMChartRepresentationProxy () override
void SetPropertyModifiedFlag (const char *name, int flag) override
 Overridden to ensure that whenever "Input" property changes, we update the "Input" properties for all internal representations (including setting up of the link to the extract-selection representation). More...
- Protected Member Functions inherited from vtkSMRepresentationProxy
 vtkSMRepresentationProxy ()
 ~vtkSMRepresentationProxy () override
void MarkDirtyFromProducer (vtkSMProxy *modifiedProxy, vtkSMProxy *producer, vtkSMProperty *property) override
 When the representation is being marked dirty due to a producer i.e. More...
void AddConsumer (vtkSMProperty *property, vtkSMProxy *proxy) override
void RemoveConsumer (vtkSMProperty *property, vtkSMProxy *proxy) override
void RemoveAllConsumers () override
 Remove all consumers. More...
 Call superclass' and then assigns a new executive (vtkCompositeDataPipeline) More...
void OnVTKRepresentationUpdated ()
void OnVTKRepresentationUpdateSkipped ()
void OnVTKRepresentationUpdateTimeChanged ()
virtual void UpdatePipelineInternal (double time, bool doTime)
void InvalidateDataInformation () override
 Mark the data information as invalid. More...
int LoadXMLState (vtkPVXMLElement *element, vtkSMProxyLocator *locator) override
 Overridden to restore this->Servers flag state. More...
- Protected Member Functions inherited from vtkSMSourceProxy
 vtkSMSourceProxy ()
 ~vtkSMSourceProxy () override
virtual void SetExecutiveName (const char *)
void SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override
 Overridden to pass the logname to the internal ExtractSelection proxies. More...
void SetOutputPort (unsigned int index, const char *name, vtkSMOutputPort *port, vtkSMDocumentation *doc)
 Method to set an output port at the given index. More...
void RemoveAllOutputPorts ()
void SetExtractSelectionProxy (unsigned int index, vtkSMSourceProxy *proxy)
void RemoveAllExtractSelectionProxies ()
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMSourceProxy
int OutputPortsCreated
int ProcessSupport
bool MPIRequired
char * ExecutiveName
bool DisableSelectionProxies
bool SelectionProxiesCreated
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Definition at line 17 of file vtkSMChartRepresentationProxy.h.
Definition at line 21 of file vtkSMChartRepresentationProxy.h.
◆ vtkSMChartRepresentationProxy()
vtkSMChartRepresentationProxy::vtkSMChartRepresentationProxy ( )
◆ ~vtkSMChartRepresentationProxy()
vtkSMChartRepresentationProxy::~vtkSMChartRepresentationProxy ( )
static vtkSMChartRepresentationProxy* vtkSMChartRepresentationProxy::New ( )
virtual const char* vtkSMChartRepresentationProxy::GetClassName ( )
Reimplemented from vtkSMRepresentationProxy.
static int vtkSMChartRepresentationProxy::IsTypeOf ( const char *  type)
virtual int vtkSMChartRepresentationProxy::IsA ( const char *  type)
static vtkSMChartRepresentationProxy* vtkSMChartRepresentationProxy::SafeDownCast ( vtkObject *  o)
void vtkSMChartRepresentationProxy::PrintSelf ( ostream &  os,
Reimplemented from vtkSMSourceProxy.
◆ GetRepresentation()
vtkChartRepresentation* vtkSMChartRepresentationProxy::GetRepresentation ( )
◆ ReadXMLAttributes()
int vtkSMChartRepresentationProxy::ReadXMLAttributes ( vtkSMSessionProxyManager *  pm,
vtkPVXMLElement *  element
◆ SetPropertyModifiedFlag()
void vtkSMChartRepresentationProxy::SetPropertyModifiedFlag ( const char *  name,
int  flag
overrideprotectedvirtual
Two selection input properties are available. The standard one, created by vtkPVExtractSelection, is named "SelectionInput". The other one, which is just the original input selection, is named "OriginalSelectionInput". see views_and_representations.xml::HistogramChartRepresentation::SelectionRepresentation for an example usage.
