vtkSMPVRepresentationProxy Class Reference
representation for "Render View" like views in ParaView. More...
#include <vtkSMPVRepresentationProxy.h>
Inheritance diagram for vtkSMPVRepresentationProxy:
Collaboration diagram for vtkSMPVRepresentationProxy:
typedef vtkSMRepresentationProxy Superclass
- Public Types inherited from vtkSMRepresentationProxy
typedef vtkSMSourceProxy Superclass
- Public Types inherited from vtkSMSourceProxy
enum  ProcessSupportType { SINGLE_PROCESS, MULTIPLE_PROCESSES, BOTH }
typedef vtkSMProxy Superclass
virtual bool GetUsingScalarColoring ()
 Returns true if scalar coloring is enabled. More...
vtkSMProxy * GetLUTProxy (vtkSMProxy *view)
 Returns the lut proxy of this representation in the given view. More...
bool UpdateScalarBarRange (vtkSMProxy *view, bool deleteRange)
 Updates the ranges shown in the scalar bar. More...
virtual bool SetScalarColoring (const char *arrayname, int attribute_type)
 Enable/disable scalar coloring using the specified array. More...
virtual bool SetScalarColoring (const char *arrayname, int attribute_type, int component)
virtual bool RescaleTransferFunctionToDataRange (bool extend=false, bool force=true)
 Rescales the color transfer function and opacity transfer function using the current data range. More...
virtual bool RescaleTransferFunctionToDataRange (const char *arrayname, int attribute_type, bool extend=false, bool force=true)
 Rescales the color transfer function and opacity transfer function using the current data range for the chosen data-array. More...
virtual bool RescaleTransferFunctionToDataRangeOverTime ()
 Rescales the color transfer function and opacity transfer function using the current data range over time. More...
virtual bool RescaleTransferFunctionToDataRangeOverTime (const char *arrayname, int attribute_type)
 Rescales the color transfer function and opacity transfer function using the current data range over time for the chosen data-array. More...
int GetEstimatedNumberOfAnnotationsOnScalarBar (vtkSMProxy *view)
 Get an estimated number of annotation shown on this representation scalar bar. More...
bool SetRepresentationType (const char *type) override
 Overridden to ensure when picking representation types that require scalar colors, scalar coloring it setup properly. More...
bool GetVolumeIndependentRanges ()
 True if ranges have to be computed independently on component 0 for the color and 1 for the opacity on the Volume representation. More...
void ViewUpdated (vtkSMProxy *view) override
 Called after the view updates. More...
void SetLastLUTProxy (vtkSMProxy *proxy)
 Set/get last LUT proxy. More...
vtkSMProxy * GetLastLUTProxy ()
virtual bool RescaleTransferFunctionToVisibleRange (vtkSMProxy *view)
 Rescales the color transfer function and the opacity transfer function using the current data range, limited to the currernt visible elements. More...
virtual bool RescaleTransferFunctionToVisibleRange (vtkSMProxy *view, const char *arrayname, int attribute_type)
int IsScalarBarStickyVisible (vtkSMProxy *view)
 Checks if the scalar bar of this representation in view is sticky visible, i.e. More...
- Public Member Functions inherited from vtkSMRepresentationProxy
virtual vtkPVDataInformation * GetRepresentedDataInformation ()
 Returns information about the data that is finally rendered by this representation. More...
virtual vtkPVProminentValuesInformation * GetProminentValuesInformation (std::string name, int fieldAssoc, int numComponents, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false)
 Returns information about a specific array component's prominent values (or nullptr). More...
void UpdatePipeline () override
 Calls Update() on all sources. More...
void UpdatePipeline (double time) override
 Calls Update() on all sources with the given time request. More...
void PostUpdateData (bool) override
 Overridden to reset this->MarkedModified flag. More...
vtkTypeUInt32 GetGlobalID () override
 Overridden to reserve additional IDs for use by internal composite representation. More...
void MarkDirty (vtkSMProxy *modifiedProxy) override
 Marks the selection proxies dirty as well as chain to superclass. More...
const char * GetRepresentationType ()
 Set the representation type. More...
bool IsVolumeRendering ()
 Convenient method to check if this representation is currently rendering volumes, using 2D Transfer function. More...
bool GetUsing2DTransferFunction ()
- Public Member Functions inherited from vtkSMSourceProxy
void UpdatePipelineInformation () override
 Calls UpdateInformation() on all sources. More...
virtual unsigned int GetNumberOfOutputPorts ()
 Return the number of output ports. More...
virtual vtkSMOutputPort * GetOutputPort (unsigned int idx)
 Return an output port. More...
virtual vtkSMOutputPort * GetOutputPort (const char *portname)
 Return an output port, given the name for the port. More...
virtual unsigned int GetOutputPortIndex (const char *portname)
 Returns the port index, given the name of an output port. More...
virtual const char * GetOutputPortName (unsigned int index)
 Returns the output port name given its index. More...
virtual void CreateOutputPorts ()
 Creates the output port proxies for this filter. More...
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, unsigned int compositeIndex)
 A GetSubsetDataInformation overload that uses composite index. More...
virtual void CreateSelectionProxies ()
 Creates extract selection proxies for each output port if not already created. More...
void SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort)
 Set/Get the selection input. More...
void CleanSelectionInputs (unsigned int portIndex)
 Clean all selection inputs for the given port. More...
vtkSMSourceProxy * GetSelectionOutput (unsigned int portIndex)
 Returns the source proxy which provides the selected data from the given output port. More...
unsigned int GetNumberOfAlgorithmOutputPorts ()
 Returns the number of output ports provided by the algorithm. More...
virtual unsigned int GetNumberOfAlgorithmRequiredInputPorts ()
 Returns the number of non-optional input ports required by the algorithm. More...
virtual int GetOutputPortsCreated ()
 Returns if the output port proxies have been created. More...
vtkSMDocumentation * GetOutputPortDocumentation (unsigned int index)
 It is possible to provide some documentation for each output port in the configuration xml. More...
vtkSMDocumentation * GetOutputPortDocumentation (const char *portname)
vtkPVDataInformation * GetDataInformation ()
 DataInformation is used by the source proxy to obtain information on the output(s) from the server. More...
vtkPVDataInformation * GetDataInformation (unsigned int outputIdx)
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, const char *selector, const char *assemblyName=nullptr)
 For composite datasets, GetDataInformation returns summary data information for all blocks combined. More...
vtkPVDataInformation * GetRankDataInformation (int rank)
 Get rank-specific data information. More...
vtkPVDataInformation * GetRankDataInformation (unsigned int outputIdx, int rank)
vtkSMSourceProxy * GetSelectionInput (unsigned int portIndex)
 API to query selection input set using SetSelectionInput. More...
unsigned int GetSelectionInputPort (unsigned int portIndex)
virtual int GetProcessSupport ()
 This returns information about whether the VTK algorithm supports multiple processes or not. More...
virtual bool GetMPIRequired ()
 This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMPVRepresentationProxy * New ()
static vtkSMPVRepresentationProxy * SafeDownCast (vtkObject *o)
static void SetupLookupTable (vtkSMProxy *proxy)
 Given the input registered representation proxy, sets up a lookup table associated with the representation if a scalar bar is being used for proxy. More...
static int GetEstimatedNumberOfAnnotationsOnScalarBar (vtkSMProxy *proxy, vtkSMProxy *view)
static bool GetUsingScalarColoring (vtkSMProxy *proxy)
 Safely call GetUsingScalarColoring() after casting the proxy to appropriate type. More...
static bool SetScalarColoring (vtkSMProxy *proxy, const char *arrayname, int attribute_type)
 Safely call SetScalarColoring() after casting the proxy to the appropriate type. More...
static bool SetScalarColoring (vtkSMProxy *proxy, const char *arrayname, int attribute_type, int component)
 Safely call SetScalarColoring() after casting the proxy to the appropriate type, component version. More...
static bool RescaleTransferFunctionToDataRange (vtkSMProxy *proxy, bool extend=false, bool force=true)
 Safely call RescaleTransferFunctionToDataRange() after casting the proxy to appropriate type. More...
static bool RescaleTransferFunctionToDataRange (vtkSMProxy *proxy, const char *arrayname, int attribute_type, bool extend=false, bool force=true)
static bool RescaleTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy)
 Safely call RescaleTransferFunctionToDataRangeOverTime() after casting the proxy to appropriate type. More...
static bool RescaleTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy, const char *arrayname, int attribute_type)
static bool RescaleTransferFunctionToVisibleRange (vtkSMProxy *proxy, vtkSMProxy *view)
 Safely call RescaleTransferFunctionToVisibleRange() after casting the proxy to the appropriate type. More...
static bool RescaleTransferFunctionToVisibleRange (vtkSMProxy *proxy, vtkSMProxy *view, const char *arrayname, int attribute_type)
- Static Public Member Functions inherited from vtkSMRepresentationProxy
static vtkSMRepresentationProxy * New ()
static vtkSMRepresentationProxy * SafeDownCast (vtkObject *o)
static bool SetRepresentationType (vtkSMProxy *repr, const char *type)
static const char * GetRepresentationType (vtkSMProxy *repr)
static bool IsVolumeRendering (vtkSMProxy *repr)
static bool GetUsing2DTransferFunction (vtkSMProxy *repr)
- Static Public Member Functions inherited from vtkSMSourceProxy
static vtkSMSourceProxy * New ()
static vtkSMSourceProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMPVRepresentationProxy ()
 ~vtkSMPVRepresentationProxy () override
 PARAVIEW_DEPRECATED_IN_5_12_0 ("Internal logic should be in vtkSMColorMapEditorHelper, use " "exposed functions of the helper instead") virtual bool RescaleTransferFunctionToDataRange(vtkPVArrayInformation *info
 Rescales transfer function ranges using the array information provided. More...
 Overridden to ensure that the RepresentationTypesInfo and Representations's domain are up-to-date. More...
void OnPropertyUpdated (vtkObject *, unsigned long, void *calldata)
void SetPropertyModifiedFlag (const char *name, int flag) override
 Overridden to ensure that whenever "Input" property changes, we update the "Input" properties for all internal representations (including setting up of the link to the extract-selection representation). More...
 Overridden to process "RepresentationType" elements. More...
PARAVIEW_DEPRECATED_IN_5_12_0("Internal logic should be in vtkSMColorMapEditorHelper, use " "exposed functions of the helper instead") std PARAVIEW_DEPRECATED_IN_5_12_0 ("Internal logic should be in vtkSMColorMapEditorHelper, use " "exposed functions of the helper instead") virtual bool SetScalarColoringInternal(const char *arrayname
 In case of UseSeparateColorMap enabled, this function prefix the given arrayname with unique identifier, otherwise it acts as a passthrough. More...
- Protected Member Functions inherited from vtkSMRepresentationProxy
 vtkSMRepresentationProxy ()
 ~vtkSMRepresentationProxy () override
void MarkDirtyFromProducer (vtkSMProxy *modifiedProxy, vtkSMProxy *producer, vtkSMProperty *property) override
 When the representation is being marked dirty due to a producer i.e. More...
void AddConsumer (vtkSMProperty *property, vtkSMProxy *proxy) override
void RemoveConsumer (vtkSMProperty *property, vtkSMProxy *proxy) override
void RemoveAllConsumers () override
 Remove all consumers. More...
 Call superclass' and then assigns a new executive (vtkCompositeDataPipeline) More...
void OnVTKRepresentationUpdated ()
void OnVTKRepresentationUpdateSkipped ()
void OnVTKRepresentationUpdateTimeChanged ()
virtual void UpdatePipelineInternal (double time, bool doTime)
void InvalidateDataInformation () override
 Mark the data information as invalid. More...
int LoadXMLState (vtkPVXMLElement *element, vtkSMProxyLocator *locator) override
 Overridden to restore this->Servers flag state. More...
- Protected Member Functions inherited from vtkSMSourceProxy
 vtkSMSourceProxy ()
 ~vtkSMSourceProxy () override
virtual void SetExecutiveName (const char *)
void SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override
 Overridden to pass the logname to the internal ExtractSelection proxies. More...
void SetOutputPort (unsigned int index, const char *name, vtkSMOutputPort *port, vtkSMDocumentation *doc)
 Method to set an output port at the given index. More...
void RemoveAllOutputPorts ()
void SetExtractSelectionProxy (unsigned int index, vtkSMSourceProxy *proxy)
void RemoveAllExtractSelectionProxies ()
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
bool extend = false
bool bool force = true)
PARAVIEW_DEPRECATED_IN_5_12_0("Internal logic should be in vtkSMColorMapEditorHelper, use " "exposed functions of the helper instead") std int attribute_type
PARAVIEW_DEPRECATED_IN_5_12_0("Internal logic should be in vtkSMColorMapEditorHelper, use " "exposed functions of the helper instead") std int bool useComponent
PARAVIEW_DEPRECATED_IN_5_12_0("Internal logic should be in vtkSMColorMapEditorHelper, use " "exposed functions of the helper instead") std int bool int component
vtkSmartPointer< vtkSMProxy > LastLUTProxy
 Used as a memory of what was the last LUT proxy linked to this representation. More...
- Protected Attributes inherited from vtkSMSourceProxy
int OutputPortsCreated
int ProcessSupport
bool MPIRequired
char * ExecutiveName
bool DisableSelectionProxies
bool SelectionProxiesCreated
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
static bool SetScalarBarVisibility (vtkSMProxy *proxy, vtkSMProxy *view, bool visible)
 Set the scalar bar visibility. More...
virtual bool SetScalarBarVisibility (vtkSMProxy *view, bool visible)
static bool HideScalarBarIfNotNeeded (vtkSMProxy *repr, vtkSMProxy *view)
 While SetScalarBarVisibility can be used to hide a scalar bar, it will always simply hide the scalar bar even if its being used by some other representation. More...
virtual bool HideScalarBarIfNotNeeded (vtkSMProxy *view)
static bool IsScalarBarVisible (vtkSMProxy *repr, vtkSMProxy *view)
 Check scalar bar visibility. More...
virtual bool IsScalarBarVisible (vtkSMProxy *view)
static vtkPVArrayInformation * GetArrayInformationForColorArray (vtkSMProxy *proxy, bool checkRepresentedData=true)
 Returns the array information for the data array used for scalar coloring, from input data. More...
virtual vtkPVArrayInformation * GetArrayInformationForColorArray (bool checkRepresentedData=true)
static vtkPVProminentValuesInformation * GetProminentValuesInformationForColorArray (vtkSMProxy *proxy, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false)
 Call vtkSMRepresentationProxy::GetProminentValuesInformation() for the array used for scalar color, if any. More...
virtual vtkPVProminentValuesInformation * GetProminentValuesInformationForColorArray (double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false)
vtkSMPVRepresentationProxy combines surface representation and volume representation proxies typically used for displaying data. This class also takes over the selection obligations for all the internal representations, i.e. is disables showing of selection in all the internal representations, and manages it. This avoids duplicate execution of extract selection filter for each of the internal representations.
vtkSMPVRepresentationProxy is used for pretty much all of the data-representations (i.e. representations showing input data) in the render views. It provides helper functions redirecting to vtkSMColorMapEditorHelper for controlling transfer functions, scalar coloring, etc.
See also
Definition at line 33 of file vtkSMPVRepresentationProxy.h.
Definition at line 37 of file vtkSMPVRepresentationProxy.h.
◆ vtkSMPVRepresentationProxy()
vtkSMPVRepresentationProxy::vtkSMPVRepresentationProxy ( )
◆ ~vtkSMPVRepresentationProxy()
vtkSMPVRepresentationProxy::~vtkSMPVRepresentationProxy ( )
static vtkSMPVRepresentationProxy* vtkSMPVRepresentationProxy::New ( )
virtual const char* vtkSMPVRepresentationProxy::GetClassName ( )
Reimplemented from vtkSMRepresentationProxy.
Reimplemented in vtkSMPVMoleculeRepresentationProxy.
static int vtkSMPVRepresentationProxy::IsTypeOf ( const char *  type)
virtual int vtkSMPVRepresentationProxy::IsA ( const char *  type)
static vtkSMPVRepresentationProxy* vtkSMPVRepresentationProxy::SafeDownCast ( vtkObject *  o)
void vtkSMPVRepresentationProxy::PrintSelf ( ostream &  os,
Reimplemented from vtkSMSourceProxy.
◆ SetLastLUTProxy()
void vtkSMPVRepresentationProxy::SetLastLUTProxy ( vtkSMProxy *  proxy)
◆ GetLastLUTProxy()
vtkSMProxy* vtkSMPVRepresentationProxy::GetLastLUTProxy ( )
◆ GetUsingScalarColoring() [1/2]
virtual bool vtkSMPVRepresentationProxy::GetUsingScalarColoring ( )
This checks whether a property named "ColorArrayName" exists and has a non-empty string. This does not check for the validity of the array.
◆ GetLUTProxy()
vtkSMProxy* vtkSMPVRepresentationProxy::GetLUTProxy ( vtkSMProxy *  view)
This method will return nullptr if no lut proxy exists in this view.
◆ GetUsingScalarColoring() [2/2]
static bool vtkSMPVRepresentationProxy::GetUsingScalarColoring ( vtkSMProxy *  proxy)
inlinestatic
Definition at line 68 of file vtkSMPVRepresentationProxy.h.
◆ SetupLookupTable()
static void vtkSMPVRepresentationProxy::SetupLookupTable ( vtkSMProxy *  proxy)
◆ UpdateScalarBarRange()
bool vtkSMPVRepresentationProxy::UpdateScalarBarRange ( vtkSMProxy *  view,
bool  deleteRange
If deleteRange is true, then the range stored for current representation proxy is deleted. This should be done when the scalar bar gets separated or becomes not visible. If deleteRange is false, then the range stored for current representation proxy is updated with the new range value.
◆ SetScalarColoring() [1/4]
virtual bool vtkSMPVRepresentationProxy::SetScalarColoring ( const char *  arrayname,
int  attribute_type
This will set up a color and opacity transfer functions using vtkSMTransferFunctionProxy instance. If arrayname is nullptr, then scalar coloring is turned off. attribute_type must be one of vtkDataObject::AttributeTypes.
◆ SetScalarColoring() [2/4]
int  attribute_type,
int  component
Parameters
arraynamethe name of the array.
attribute_typemust be one of vtkDataObject::AttributeTypes.
componentenables choosing a component to color with, -1 will change to Magnitude, >=0 will change to corresponding component.
◆ SetScalarColoring() [3/4]
static bool vtkSMPVRepresentationProxy::SetScalarColoring ( vtkSMProxy *  proxy,
int  attribute_type
inlinestatic
Definition at line 116 of file vtkSMPVRepresentationProxy.h.
◆ SetScalarColoring() [4/4]
int  attribute_type,
int  component
inlinestatic
Definition at line 129 of file vtkSMPVRepresentationProxy.h.
◆ RescaleTransferFunctionToDataRange() [1/4]
virtual bool vtkSMPVRepresentationProxy::RescaleTransferFunctionToDataRange ( bool  extend = false,
bool  force = true
Returns true if rescale was successful. If extend is true (false by default), the transfer function range will only be extended as needed to fit the data range. If force is false (true by default), then the transfer function range is not changed if locked.
Parameters
[in]extendExtend existing range instead of clamping to the new range (default: false).
[in]forceUpdate transfer function even if the range is locked (default: true).
◆ RescaleTransferFunctionToDataRange() [2/4]
virtual bool vtkSMPVRepresentationProxy::RescaleTransferFunctionToDataRange ( const char *  arrayname,
int  attribute_type,
bool  force = true
Parameters
◆ RescaleTransferFunctionToDataRange() [3/4]
static bool vtkSMPVRepresentationProxy::RescaleTransferFunctionToDataRange ( vtkSMProxy *  proxy,
bool  force = true
inlinestatic
Definition at line 175 of file vtkSMPVRepresentationProxy.h.
◆ RescaleTransferFunctionToDataRange() [4/4]
int  attribute_type,
bool  force = true
inlinestatic
Definition at line 189 of file vtkSMPVRepresentationProxy.h.
◆ RescaleTransferFunctionToDataRangeOverTime() [1/4]
virtual bool vtkSMPVRepresentationProxy::RescaleTransferFunctionToDataRangeOverTime ( )
◆ RescaleTransferFunctionToDataRangeOverTime() [2/4]
virtual bool vtkSMPVRepresentationProxy::RescaleTransferFunctionToDataRangeOverTime ( const char *  arrayname,
int  attribute_type
Returns true if rescale was successful. field_association must be one of vtkDataObject::AttributeTypes,
◆ RescaleTransferFunctionToDataRangeOverTime() [3/4]
static bool vtkSMPVRepresentationProxy::RescaleTransferFunctionToDataRangeOverTime ( vtkSMProxy *  proxy)
inlinestatic
Definition at line 219 of file vtkSMPVRepresentationProxy.h.
◆ RescaleTransferFunctionToDataRangeOverTime() [4/4]
static bool vtkSMPVRepresentationProxy::RescaleTransferFunctionToDataRangeOverTime ( vtkSMProxy *  proxy,
int  attribute_type
inlinestatic
Definition at line 232 of file vtkSMPVRepresentationProxy.h.
◆ RescaleTransferFunctionToVisibleRange() [1/4]
virtual bool vtkSMPVRepresentationProxy::RescaleTransferFunctionToVisibleRange ( vtkSMProxy *  view)
◆ RescaleTransferFunctionToVisibleRange() [2/4]
virtual bool vtkSMPVRepresentationProxy::RescaleTransferFunctionToVisibleRange ( vtkSMProxy *  view,
int  attribute_type
◆ RescaleTransferFunctionToVisibleRange() [3/4]
static bool vtkSMPVRepresentationProxy::RescaleTransferFunctionToVisibleRange ( vtkSMProxy *  proxy,
vtkSMProxy *  view
inlinestatic
Definition at line 257 of file vtkSMPVRepresentationProxy.h.
◆ RescaleTransferFunctionToVisibleRange() [4/4]
vtkSMProxy *  view,
int  attribute_type
inlinestatic
Definition at line 263 of file vtkSMPVRepresentationProxy.h.
◆ SetScalarBarVisibility() [1/2]
virtual bool vtkSMPVRepresentationProxy::SetScalarBarVisibility ( vtkSMProxy *  view,
bool  visible
This will create a new scalar bar as needed. Scalar bar is only shown if scalar coloring is indeed being used.
◆ SetScalarBarVisibility() [2/2]
static bool vtkSMPVRepresentationProxy::SetScalarBarVisibility ( vtkSMProxy *  proxy,
vtkSMProxy *  view,
bool  visible
inlinestatic
Definition at line 279 of file vtkSMPVRepresentationProxy.h.
◆ HideScalarBarIfNotNeeded() [1/2]
virtual bool vtkSMPVRepresentationProxy::HideScalarBarIfNotNeeded ( vtkSMProxy *  view)
Use this method instead to only hide the scalar/color bar if no other visible representation in the view is mapping data using the scalar bar.
◆ HideScalarBarIfNotNeeded() [2/2]
static bool vtkSMPVRepresentationProxy::HideScalarBarIfNotNeeded ( vtkSMProxy *  repr,
vtkSMProxy *  view
inlinestatic
Definition at line 296 of file vtkSMPVRepresentationProxy.h.
◆ IsScalarBarVisible() [1/2]
virtual bool vtkSMPVRepresentationProxy::IsScalarBarVisible ( vtkSMProxy *  view)
Return true if the scalar bar for this representation and view is visible, return false otherwise.
◆ IsScalarBarVisible() [2/2]
static bool vtkSMPVRepresentationProxy::IsScalarBarVisible ( vtkSMProxy *  repr,
vtkSMProxy *  view
inlinestatic
Definition at line 310 of file vtkSMPVRepresentationProxy.h.
◆ GetArrayInformationForColorArray() [1/2]
virtual vtkPVArrayInformation* vtkSMPVRepresentationProxy::GetArrayInformationForColorArray ( bool  checkRepresentedData = true)
If checkRepresentedData is true, it will also check in the represented data. Default is true. If none is found, returns nullptr.
◆ GetArrayInformationForColorArray() [2/2]
static vtkPVArrayInformation* vtkSMPVRepresentationProxy::GetArrayInformationForColorArray ( vtkSMProxy *  proxy,
inlinestatic
Definition at line 325 of file vtkSMPVRepresentationProxy.h.
◆ GetProminentValuesInformationForColorArray() [1/2]
virtual vtkPVProminentValuesInformation* vtkSMPVRepresentationProxy::GetProminentValuesInformationForColorArray ( double  uncertaintyAllowed = 1e-6,
double  fraction = 1e-3,
bool  force = false
Otherwise returns nullptr.
◆ GetProminentValuesInformationForColorArray() [2/2]
static vtkPVProminentValuesInformation* vtkSMPVRepresentationProxy::GetProminentValuesInformationForColorArray ( vtkSMProxy *  proxy,
bool  force = false
inlinestatic
Definition at line 341 of file vtkSMPVRepresentationProxy.h.
◆ GetEstimatedNumberOfAnnotationsOnScalarBar() [1/2]
int vtkSMPVRepresentationProxy::GetEstimatedNumberOfAnnotationsOnScalarBar ( vtkSMProxy *  view)
◆ GetEstimatedNumberOfAnnotationsOnScalarBar() [2/2]
static int vtkSMPVRepresentationProxy::GetEstimatedNumberOfAnnotationsOnScalarBar ( vtkSMProxy *  proxy,
vtkSMProxy *  view
inlinestatic
Definition at line 356 of file vtkSMPVRepresentationProxy.h.
◆ SetRepresentationType()
bool vtkSMPVRepresentationProxy::SetRepresentationType ( const char *  type)
Currently this is hard-coded for Volume and Slice representation types.
◆ GetVolumeIndependentRanges()
bool vtkSMPVRepresentationProxy::GetVolumeIndependentRanges ( )
◆ IsScalarBarStickyVisible()
int vtkSMPVRepresentationProxy::IsScalarBarStickyVisible ( vtkSMProxy *  view)
should be visible whenever this representation is also visible. It returns 1 if the scalar bar is sticky visible, 0 other wise. If any problem is encountered, for example if view == nullptr, or if the scalar bar representation is not instanciated / found, it returns -1.
◆ ViewUpdated()
void vtkSMPVRepresentationProxy::ViewUpdated ( vtkSMProxy *  view)
◆ PARAVIEW_DEPRECATED_IN_5_12_0() [1/2]
vtkSMPVRepresentationProxy::PARAVIEW_DEPRECATED_IN_5_12_0 ( "Internal logic should be in  vtkSMColorMapEditorHelper,
◆ CreateVTKObjects()
void vtkSMPVRepresentationProxy::CreateVTKObjects ( )
overrideprotectedvirtual
◆ OnPropertyUpdated()
void vtkSMPVRepresentationProxy::OnPropertyUpdated ( vtkObject *  ,
unsigned long  ,
void *  calldata
◆ SetPropertyModifiedFlag()
void vtkSMPVRepresentationProxy::SetPropertyModifiedFlag ( const char *  name,
int  flag
◆ ReadXMLAttributes()
int vtkSMPVRepresentationProxy::ReadXMLAttributes ( vtkSMSessionProxyManager *  pm,
vtkPVXMLElement *  element
◆ PARAVIEW_DEPRECATED_IN_5_12_0() [2/2]
PARAVIEW_DEPRECATED_IN_5_12_0 ("Internal logic should be in vtkSMColorMapEditorHelper, use " "exposed functions of the helper instead") std vtkSMPVRepresentationProxy::PARAVIEW_DEPRECATED_IN_5_12_0 ( "Internal logic should be in  vtkSMColorMapEditorHelper,
) const
Internal method to set scalar coloring, do not use directly.
◆ extend
bool vtkSMPVRepresentationProxy::extend = false
Definition at line 403 of file vtkSMPVRepresentationProxy.h.
◆ force
bool bool vtkSMPVRepresentationProxy::force = true)
◆ attribute_type
PARAVIEW_DEPRECATED_IN_5_12_0 ("Internal logic should be in vtkSMColorMapEditorHelper, use " "exposed functions of the helper instead") std int vtkSMPVRepresentationProxy::attribute_type
Definition at line 441 of file vtkSMPVRepresentationProxy.h.
◆ useComponent
PARAVIEW_DEPRECATED_IN_5_12_0 ("Internal logic should be in vtkSMColorMapEditorHelper, use " "exposed functions of the helper instead") std int bool vtkSMPVRepresentationProxy::useComponent
◆ component
PARAVIEW_DEPRECATED_IN_5_12_0 ("Internal logic should be in vtkSMColorMapEditorHelper, use " "exposed functions of the helper instead") std int bool int vtkSMPVRepresentationProxy::component
◆ LastLUTProxy
vtkSmartPointer<vtkSMProxy> vtkSMPVRepresentationProxy::LastLUTProxy
This is used in UpdateScalarBarRange to update the scalar bar range when turning off the coloring for this representation.
Definition at line 448 of file vtkSMPVRepresentationProxy.h.
