Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Friends | List of all members
vtkSMRepresentationProxy Class Reference
Proxy for a representations. More...
#include <vtkSMRepresentationProxy.h>
Inheritance diagram for vtkSMRepresentationProxy:
Collaboration diagram for vtkSMRepresentationProxy:
typedef vtkSMSourceProxy Superclass
- Public Types inherited from vtkSMSourceProxy
enum  ProcessSupportType { SINGLE_PROCESS, MULTIPLE_PROCESSES, BOTH }
typedef vtkSMProxy Superclass
virtual vtkPVDataInformation * GetRepresentedDataInformation ()
 Returns information about the data that is finally rendered by this representation. More...
virtual vtkPVProminentValuesInformation * GetProminentValuesInformation (std::string name, int fieldAssoc, int numComponents, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false)
 Returns information about a specific array component's prominent values (or nullptr). More...
void UpdatePipeline () override
 Calls Update() on all sources. More...
void UpdatePipeline (double time) override
 Calls Update() on all sources with the given time request. More...
void PostUpdateData (bool) override
 Overridden to reset this->MarkedModified flag. More...
virtual void ViewUpdated (vtkSMProxy *view)
 Called after the view updates. More...
vtkTypeUInt32 GetGlobalID () override
 Overridden to reserve additional IDs for use by internal composite representation. More...
void MarkDirty (vtkSMProxy *modifiedProxy) override
 Marks the selection proxies dirty as well as chain to superclass. More...
- Public Member Functions inherited from vtkSMSourceProxy
void UpdatePipelineInformation () override
 Calls UpdateInformation() on all sources. More...
virtual unsigned int GetNumberOfOutputPorts ()
 Return the number of output ports. More...
virtual vtkSMOutputPort * GetOutputPort (unsigned int idx)
 Return an output port. More...
virtual vtkSMOutputPort * GetOutputPort (const char *portname)
 Return an output port, given the name for the port. More...
virtual unsigned int GetOutputPortIndex (const char *portname)
 Returns the port index, given the name of an output port. More...
virtual const char * GetOutputPortName (unsigned int index)
 Returns the output port name given its index. More...
virtual void CreateOutputPorts ()
 Creates the output port proxies for this filter. More...
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, unsigned int compositeIndex)
 A GetSubsetDataInformation overload that uses composite index. More...
virtual void CreateSelectionProxies ()
 Creates extract selection proxies for each output port if not already created. More...
void SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort)
 Set/Get the selection input. More...
void CleanSelectionInputs (unsigned int portIndex)
 Clean all selection inputs for the given port. More...
vtkSMSourceProxy * GetSelectionOutput (unsigned int portIndex)
 Returns the source proxy which provides the selected data from the given output port. More...
unsigned int GetNumberOfAlgorithmOutputPorts ()
 Returns the number of output ports provided by the algorithm. More...
virtual unsigned int GetNumberOfAlgorithmRequiredInputPorts ()
 Returns the number of non-optional input ports required by the algorithm. More...
virtual int GetOutputPortsCreated ()
 Returns if the output port proxies have been created. More...
vtkSMDocumentation * GetOutputPortDocumentation (unsigned int index)
 It is possible to provide some documentation for each output port in the configuration xml. More...
vtkSMDocumentation * GetOutputPortDocumentation (const char *portname)
vtkPVDataInformation * GetDataInformation ()
 DataInformation is used by the source proxy to obtain information on the output(s) from the server. More...
vtkPVDataInformation * GetDataInformation (unsigned int outputIdx)
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, const char *selector, const char *assemblyName=nullptr)
 For composite datasets, GetDataInformation returns summary data information for all blocks combined. More...
vtkPVDataInformation * GetRankDataInformation (int rank)
 Get rank-specific data information. More...
vtkPVDataInformation * GetRankDataInformation (unsigned int outputIdx, int rank)
vtkSMSourceProxy * GetSelectionInput (unsigned int portIndex)
 API to query selection input set using SetSelectionInput. More...
unsigned int GetSelectionInputPort (unsigned int portIndex)
virtual int GetProcessSupport ()
 This returns information about whether the VTK algorithm supports multiple processes or not. More...
virtual bool GetMPIRequired ()
 This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMRepresentationProxy * New ()
static vtkSMRepresentationProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMSourceProxy
static vtkSMSourceProxy * New ()
static vtkSMSourceProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMRepresentationProxy ()
 ~vtkSMRepresentationProxy () override
void MarkDirtyFromProducer (vtkSMProxy *modifiedProxy, vtkSMProxy *producer, vtkSMProperty *property) override
 When the representation is being marked dirty due to a producer i.e. More...
void AddConsumer (vtkSMProperty *property, vtkSMProxy *proxy) override
void RemoveConsumer (vtkSMProperty *property, vtkSMProxy *proxy) override
void RemoveAllConsumers () override
 Remove all consumers. More...
 Call superclass' and then assigns a new executive (vtkCompositeDataPipeline) More...
void OnVTKRepresentationUpdated ()
void OnVTKRepresentationUpdateSkipped ()
void OnVTKRepresentationUpdateTimeChanged ()
virtual void UpdatePipelineInternal (double time, bool doTime)
void InvalidateDataInformation () override
 Mark the data information as invalid. More...
int LoadXMLState (vtkPVXMLElement *element, vtkSMProxyLocator *locator) override
 Overridden to restore this->Servers flag state. More...
- Protected Member Functions inherited from vtkSMSourceProxy
 vtkSMSourceProxy ()
 ~vtkSMSourceProxy () override
virtual void SetExecutiveName (const char *)
void SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override
 Overridden to pass the logname to the internal ExtractSelection proxies. More...
void SetOutputPort (unsigned int index, const char *name, vtkSMOutputPort *port, vtkSMDocumentation *doc)
 Method to set an output port at the given index. More...
void RemoveAllOutputPorts ()
void SetExtractSelectionProxy (unsigned int index, vtkSMSourceProxy *proxy)
void RemoveAllExtractSelectionProxies ()
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
Friends
class vtkPVComparativeViewNS::vtkCloningVectorOfRepresentations
static bool SetRepresentationType (vtkSMProxy *repr, const char *type)
 Set the representation type. More...
static const char * GetRepresentationType (vtkSMProxy *repr)
virtual bool SetRepresentationType (const char *type)
const char * GetRepresentationType ()
static bool IsVolumeRendering (vtkSMProxy *repr)
 Convenient method to check if this representation is currently rendering volumes, using 2D Transfer function. More...
static bool GetUsing2DTransferFunction (vtkSMProxy *repr)
bool IsVolumeRendering ()
bool GetUsing2DTransferFunction ()
- Protected Attributes inherited from vtkSMSourceProxy
int OutputPortsCreated
int ProcessSupport
bool MPIRequired
char * ExecutiveName
bool DisableSelectionProxies
bool SelectionProxiesCreated
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMRepresentationProxy is a vtkSMSourceProxy subclass that is designed to be used either directly or as a superclass for "data" representations i.e. representation that have an input (as against proxies for annotations such as 3D widgets).
Special handling of <tt>MarkDirty</tt>
vtkSMProxy::MarkDirty is a mechanism that ParaView uses to know on the client side (i.e. in the server-manager layer) when a pipeline on the server side is "dirty" or has potential to execute on an update causing things like data information to be invalidated. Simply speaking, when a property on a vtkSMProxy is modified and pushed (using vtkSMProxy::UpdateVTKObjects or vtkSMProxy::UpdateProperty), it calls this->MarkDirty(this). vtkSMProxy::MarkDirty invokes vtkSMProxy::MarkConsumersAsDirty which results in any consumers of this dirtied proxy also getting the notification. Consumers (and conversely producers) are setup via ProxyProperty and InputProperty connections. For standard data processing pipelines, this mechanism works quite well. Consider a filter proxy, say Clip, which has an input set via a InputProperty and a implicit function set via a ProxyProperty. If either the input or the implicit function is modified, it is reasonable to expect the Clip filter to re-execute on an UpdatePipeline call. Whether the call will truly cause the VTK pipeline (server side) to execute is not that important. The pipeline may not re-execute and that's not a big deal.
Things get a little complicated for representations, however. Data representations don't necessary have valid input connections on all processes where their VTK objects are present (note, representations create VTK objects on all process while data input is only available on the data server nodes). As a result representations have to be explicitly told to re-execute following upstream changes since they cannot rely on their VTK-level upstream. Re-executing a representation means regenerating the geometry or data artifacts for rendering, redelivering them to the rendering nodes, etc. It can also mean cleaning up any caches the representation built for flip-book animation support. In other words, re-executing a representation is non-trivial task. Thus, we want do it only when absolutely needed.
The explicit pipeline update is often referred to as "update suppression" and handled by vtkPVDataRepresentation and vtkPVDataRepresentationPipeline. In short, calling Update on vtkPVDataRepresentation has no effect unless vtkPVDataRepresentation::MarkModified was explicitly called at some point since the last Update.
To explicitly call vtkPVDataRepresentation::MarkModified for only those cases where the representation must be re-executed, we follow the following strategy.
Definition at line 76 of file vtkSMRepresentationProxy.h.
Definition at line 80 of file vtkSMRepresentationProxy.h.
◆ vtkSMRepresentationProxy()
vtkSMRepresentationProxy::vtkSMRepresentationProxy ( )
◆ ~vtkSMRepresentationProxy()
vtkSMRepresentationProxy::~vtkSMRepresentationProxy ( )
static vtkSMRepresentationProxy* vtkSMRepresentationProxy::New ( )
virtual const char* vtkSMRepresentationProxy::GetClassName ( )
static int vtkSMRepresentationProxy::IsTypeOf ( const char *  type)
virtual int vtkSMRepresentationProxy::IsA ( const char *  type)
static vtkSMRepresentationProxy* vtkSMRepresentationProxy::SafeDownCast ( vtkObject *  o)
void vtkSMRepresentationProxy::PrintSelf ( ostream &  os,
Reimplemented from vtkSMSourceProxy.
Reimplemented in vtkSMSpreadSheetRepresentationProxy.
◆ GetRepresentedDataInformation()
virtual vtkPVDataInformation* vtkSMRepresentationProxy::GetRepresentedDataInformation ( )
◆ GetProminentValuesInformation()
virtual vtkPVProminentValuesInformation* vtkSMRepresentationProxy::GetProminentValuesInformation ( std::string  name,
int  fieldAssoc,
int  numComponents,
double  uncertaintyAllowed = 1e-6,
double  fraction = 1e-3,
bool  force = false
The name, fieldAssoc, and numComponents arguments specify which arrays on the input dataset to examine. Because multiblock datasets may have multiple arrays of the same name on different blocks, and these arrays may not have the same storage type or number of components, this method requires you to specify the number of components per tuple the array(s) of interest must have. You may call GetRepresentedDataInformation() to obtain the number of components for any array.
See vtkAbstractArray::GetProminentComponentValues for more information about the uncertaintyAllowed and fraction arguments.
◆ UpdatePipeline() [1/2]
void vtkSMRepresentationProxy::UpdatePipeline ( )
It also creates output ports if they are not already created.
◆ UpdatePipeline() [2/2]
void vtkSMRepresentationProxy::UpdatePipeline ( double  time)
◆ PostUpdateData()
void vtkSMRepresentationProxy::PostUpdateData ( bool  )
◆ ViewUpdated()
virtual void vtkSMRepresentationProxy::ViewUpdated ( vtkSMProxy *  view)
Reimplemented in vtkSMPVRepresentationProxy.
◆ GetGlobalID()
vtkTypeUInt32 vtkSMRepresentationProxy::GetGlobalID ( )
◆ SetRepresentationType() [1/2]
virtual bool vtkSMRepresentationProxy::SetRepresentationType ( const char *  type)
Default implementation simply updates the "Representation" property, if present with the value provided. Subclasses can override this method to add custom logic to manage the representation state to support the change e.g. pick a scalar color array when switching to Volume or Slice representation, for example. Returns true, if the change was successful, otherwise returns false.
◆ SetRepresentationType() [2/2]
static bool vtkSMRepresentationProxy::SetRepresentationType ( vtkSMProxy *  repr,
const char *  type
inlinestatic
Definition at line 145 of file vtkSMRepresentationProxy.h.
◆ GetRepresentationType() [1/2]
const char* vtkSMRepresentationProxy::GetRepresentationType ( )
◆ GetRepresentationType() [2/2]
static const char* vtkSMRepresentationProxy::GetRepresentationType ( vtkSMProxy *  repr)
inlinestatic
Definition at line 151 of file vtkSMRepresentationProxy.h.
◆ IsVolumeRendering() [1/2]
static bool vtkSMRepresentationProxy::IsVolumeRendering ( vtkSMProxy *  repr)
inlinestatic
Definition at line 163 of file vtkSMRepresentationProxy.h.
◆ IsVolumeRendering() [2/2]
bool vtkSMRepresentationProxy::IsVolumeRendering ( )
◆ GetUsing2DTransferFunction() [1/2]
static bool vtkSMRepresentationProxy::GetUsing2DTransferFunction ( vtkSMProxy *  repr)
inlinestatic
Definition at line 169 of file vtkSMRepresentationProxy.h.
◆ GetUsing2DTransferFunction() [2/2]
bool vtkSMRepresentationProxy::GetUsing2DTransferFunction ( )
◆ MarkDirty()
void vtkSMRepresentationProxy::MarkDirty ( vtkSMProxy *  modifiedProxy)
◆ MarkDirtyFromProducer()
void vtkSMRepresentationProxy::MarkDirtyFromProducer ( vtkSMProxy *  modifiedProxy,
vtkSMProxy *  producer,
vtkSMProperty *  property
overrideprotectedvirtual
a proxy-property input-property connection, we need to decide if the representation's data pipeline is indeed invalidated or is this simply a "rendering" change. We override this method to make that distinction.
◆ AddConsumer()
void vtkSMRepresentationProxy::AddConsumer ( vtkSMProperty *  property,
vtkSMProxy *  proxy
Called by a proxy property, this adds the property,proxy pair to the list of consumers.
◆ RemoveConsumer()
void vtkSMRepresentationProxy::RemoveConsumer ( vtkSMProperty *  property,
vtkSMProxy *  proxy
Remove the property,proxy pair from the list of consumers.
◆ RemoveAllConsumers()
void vtkSMRepresentationProxy::RemoveAllConsumers ( )
◆ CreateVTKObjects()
void vtkSMRepresentationProxy::CreateVTKObjects ( )
◆ OnVTKRepresentationUpdated()
void vtkSMRepresentationProxy::OnVTKRepresentationUpdated ( )
◆ OnVTKRepresentationUpdateSkipped()
void vtkSMRepresentationProxy::OnVTKRepresentationUpdateSkipped ( )
◆ OnVTKRepresentationUpdateTimeChanged()
void vtkSMRepresentationProxy::OnVTKRepresentationUpdateTimeChanged ( )
◆ UpdatePipelineInternal()
virtual void vtkSMRepresentationProxy::UpdatePipelineInternal ( double  time,
bool  doTime
protectedvirtual
◆ InvalidateDataInformation()
void vtkSMRepresentationProxy::InvalidateDataInformation ( )
◆ LoadXMLState()
int vtkSMRepresentationProxy::LoadXMLState ( vtkPVXMLElement *  element,
vtkSMProxyLocator *  locator
◆ vtkPVComparativeViewNS::vtkCloningVectorOfRepresentations
friend class vtkPVComparativeViewNS::vtkCloningVectorOfRepresentations
friend
Definition at line 230 of file vtkSMRepresentationProxy.h.
