vtkSMCompoundSourceProxy Class Reference
a proxy excapsulation a pipeline of proxies. More...
#include <vtkSMCompoundSourceProxy.h>
Inheritance diagram for vtkSMCompoundSourceProxy:
Collaboration diagram for vtkSMCompoundSourceProxy:
typedef vtkSMSourceProxy Superclass
- Public Types inherited from vtkSMSourceProxy
enum  ProcessSupportType { SINGLE_PROCESS, MULTIPLE_PROCESSES, BOTH }
typedef vtkSMProxy Superclass
void AddProxy (const char *name, vtkSMProxy *proxy)
 Add a proxy to be included in this compound proxy. More...
void ExposeProperty (const char *proxyName, const char *propertyName, const char *exposedName)
 Expose a property from the sub proxy (added using AddProxy). More...
void ExposeOutputPort (const char *proxyName, const char *portName, const char *exposedName)
 Expose an output port from a subproxy. More...
void ExposeOutputPort (const char *proxyName, unsigned int portIndex, const char *exposedName)
unsigned int GetNumberOfProxies ()
vtkSMProxy * GetProxy (unsigned int cc)
 Returns the sub proxy at a given index. More...
vtkSMProxy * GetProxy (const char *name)
 Returns the subproxy with the given name. More...
const char * GetProxyName (unsigned int index)
void CreateOutputPorts () override
 Creates the output port proxiess for this filter. More...
void CreateSelectionProxies () override
 Creates extract selection proxies for each output port if not already created. More...
void UpdateVTKObjects () override
vtkPVXMLElement * SaveDefinition (vtkPVXMLElement *root)
 This is the same as save state except it will remove all references to "outside" proxies. More...
- Public Member Functions inherited from vtkSMSourceProxy
void UpdatePipelineInformation () override
 Calls UpdateInformation() on all sources. More...
virtual void UpdatePipeline ()
 Calls Update() on all sources. More...
virtual void UpdatePipeline (double time)
 Calls Update() on all sources with the given time request. More...
virtual unsigned int GetNumberOfOutputPorts ()
 Return the number of output ports. More...
virtual vtkSMOutputPort * GetOutputPort (unsigned int idx)
 Return an output port. More...
virtual vtkSMOutputPort * GetOutputPort (const char *portname)
 Return an output port, given the name for the port. More...
virtual unsigned int GetOutputPortIndex (const char *portname)
 Returns the port index, given the name of an output port. More...
virtual const char * GetOutputPortName (unsigned int index)
 Returns the output port name given its index. More...
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, unsigned int compositeIndex)
 A GetSubsetDataInformation overload that uses composite index. More...
void SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort)
 Set/Get the selection input. More...
void CleanSelectionInputs (unsigned int portIndex)
 Clean all selection inputs for the given port. More...
vtkSMSourceProxy * GetSelectionOutput (unsigned int portIndex)
 Returns the source proxy which provides the selected data from the given output port. More...
unsigned int GetNumberOfAlgorithmOutputPorts ()
 Returns the number of output ports provided by the algorithm. More...
virtual unsigned int GetNumberOfAlgorithmRequiredInputPorts ()
 Returns the number of non-optional input ports required by the algorithm. More...
vtkTypeUInt32 GetGlobalID () override
 Overridden to reserve additional IDs for use by "ExtractSelection" proxies. More...
void MarkDirty (vtkSMProxy *modifiedProxy) override
 Marks the selection proxies dirty as well as chain to superclass. More...
virtual int GetOutputPortsCreated ()
 Returns if the output port proxies have been created. More...
vtkSMDocumentation * GetOutputPortDocumentation (unsigned int index)
 It is possible to provide some documentation for each output port in the configuration xml. More...
vtkSMDocumentation * GetOutputPortDocumentation (const char *portname)
vtkPVDataInformation * GetDataInformation ()
 DataInformation is used by the source proxy to obtain information on the output(s) from the server. More...
vtkPVDataInformation * GetDataInformation (unsigned int outputIdx)
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, const char *selector, const char *assemblyName=nullptr)
 For composite datasets, GetDataInformation returns summary data information for all blocks combined. More...
vtkPVDataInformation * GetRankDataInformation (int rank)
 Get rank-specific data information. More...
vtkPVDataInformation * GetRankDataInformation (unsigned int outputIdx, int rank)
vtkSMSourceProxy * GetSelectionInput (unsigned int portIndex)
 API to query selection input set using SetSelectionInput. More...
unsigned int GetSelectionInputPort (unsigned int portIndex)
virtual int GetProcessSupport ()
 This returns information about whether the VTK algorithm supports multiple processes or not. More...
virtual bool GetMPIRequired ()
 This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMCompoundSourceProxy * New ()
static vtkSMCompoundSourceProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMSourceProxy
static vtkSMSourceProxy * New ()
static vtkSMSourceProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMCompoundSourceProxy ()
 ~vtkSMCompoundSourceProxy () override
 Call superclass' and then assigns a new executive (vtkCompositeDataPipeline) More...
int ShouldWriteValue (vtkPVXMLElement *valueElem)
void TraverseForProperties (vtkPVXMLElement *root)
void StripValues (vtkPVXMLElement *propertyElem)
- Protected Member Functions inherited from vtkSMSourceProxy
 vtkSMSourceProxy ()
 ~vtkSMSourceProxy () override
virtual void InvalidateDataInformation ()
 Mark the data information as invalid. More...
virtual void SetExecutiveName (const char *)
void PostUpdateData (bool) override
 Overwritten from superclass to invoke. More...
void SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override
 Overridden to pass the logname to the internal ExtractSelection proxies. More...
void SetOutputPort (unsigned int index, const char *name, vtkSMOutputPort *port, vtkSMDocumentation *doc)
 Method to set an output port at the given index. More...
void RemoveAllOutputPorts ()
void SetExtractSelectionProxy (unsigned int index, vtkSMSourceProxy *proxy)
void RemoveAllExtractSelectionProxies ()
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMSourceProxy
int OutputPortsCreated
int ProcessSupport
bool MPIRequired
char * ExecutiveName
bool DisableSelectionProxies
bool SelectionProxiesCreated
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMCompoundSourceProxy is a proxy that allows grouping of multiple proxies. vtkSMProxy has also this capability since a proxy can have sub-proxies. However, vtkSMProxy does not allow public access to these proxies. The only access is through exposed properties. The main reason behind this is consistency. There are proxies that will not work if the program accesses the sub-proxies directly. The main purpose of vtkSMCompoundSourceProxy is to provide an interface to access the sub-proxies. The compound proxy also maintains the connections between subproxies. This makes it possible to encapsulate a pipeline into a single proxy. Since vtkSMCompoundSourceProxy is a vtkSMSourceProxy, it can be directly used to input to other filters, representations etc. vtkSMCompoundSourceProxy provides API to exposed properties from sub proxies as well as output ports of the subproxies.
Definition at line 32 of file vtkSMCompoundSourceProxy.h.
Definition at line 36 of file vtkSMCompoundSourceProxy.h.
◆ vtkSMCompoundSourceProxy()
vtkSMCompoundSourceProxy::vtkSMCompoundSourceProxy ( )
◆ ~vtkSMCompoundSourceProxy()
vtkSMCompoundSourceProxy::~vtkSMCompoundSourceProxy ( )
static vtkSMCompoundSourceProxy* vtkSMCompoundSourceProxy::New ( )
virtual const char* vtkSMCompoundSourceProxy::GetClassName ( )
Reimplemented from vtkSMSourceProxy.
static int vtkSMCompoundSourceProxy::IsTypeOf ( const char *  type)
virtual int vtkSMCompoundSourceProxy::IsA ( const char *  type)
static vtkSMCompoundSourceProxy* vtkSMCompoundSourceProxy::SafeDownCast ( vtkObject *  o)
void vtkSMCompoundSourceProxy::PrintSelf ( ostream &  os,
◆ AddProxy()
void vtkSMCompoundSourceProxy::AddProxy ( const char *  name,
vtkSMProxy *  proxy
The name must be unique to each proxy added, otherwise the previously added proxy will be replaced.
◆ ExposeProperty()
void vtkSMCompoundSourceProxy::ExposeProperty ( const char *  proxyName,
const char *  propertyName,
const char *  exposedName
Only exposed properties are accessible externally. Note that the sub proxy whose property is being exposed must have been already added using AddProxy().
◆ ExposeOutputPort() [1/2]
void vtkSMCompoundSourceProxy::ExposeOutputPort ( const char *  proxyName,
const char *  portName,
Exposed output ports are treated as output ports of the vtkSMCompoundSourceProxy itself. This method does not may the output port available. One must call CreateOutputPorts().
◆ ExposeOutputPort() [2/2]
◆ GetNumberOfProxies()
unsigned int vtkSMCompoundSourceProxy::GetNumberOfProxies ( )
inline
Returns the number of sub-proxies.
Definition at line 73 of file vtkSMCompoundSourceProxy.h.
◆ GetProxy() [1/2]
vtkSMProxy* vtkSMCompoundSourceProxy::GetProxy ( unsigned int  cc)
inline
Definition at line 78 of file vtkSMCompoundSourceProxy.h.
◆ GetProxy() [2/2]
vtkSMProxy* vtkSMCompoundSourceProxy::GetProxy ( const char *  name)
inline
Definition at line 83 of file vtkSMCompoundSourceProxy.h.
◆ GetProxyName()
const char* vtkSMCompoundSourceProxy::GetProxyName ( unsigned int  index)
inline
Returns the name used to store sub-proxy.
Returns 0 if sub-proxy does not exist.
Definition at line 89 of file vtkSMCompoundSourceProxy.h.
◆ CreateOutputPorts()
void vtkSMCompoundSourceProxy::CreateOutputPorts ( )
Each output port proxy corresponds to an actual output port on the algorithm.
◆ CreateSelectionProxies()
void vtkSMCompoundSourceProxy::CreateSelectionProxies ( )
Overridden to update the selection proxies.
◆ UpdateVTKObjects()
void vtkSMCompoundSourceProxy::UpdateVTKObjects ( )
Update the VTK object on the server by pushing the values of all modified properties (un-modified properties are ignored).
If the object has not been created, it will be created first.
◆ SaveDefinition()
vtkPVXMLElement* vtkSMCompoundSourceProxy::SaveDefinition ( vtkPVXMLElement *  root)
Outside proxies are proxies that are not contained in the compound proxy. As a result, the saved state will be self contained. Returns the top element created. It is the caller's responsibility to delete the returned element. If root is nullptr, the returned element will be a top level element.
◆ ReadXMLAttributes()
int vtkSMCompoundSourceProxy::ReadXMLAttributes ( vtkSMSessionProxyManager *  pm,
vtkPVXMLElement *  element
overrideprotectedvirtual
Read attributes from an XML element.
◆ CreateVTKObjects()
void vtkSMCompoundSourceProxy::CreateVTKObjects ( )
◆ ShouldWriteValue()
int vtkSMCompoundSourceProxy::ShouldWriteValue ( vtkPVXMLElement *  valueElem)
◆ TraverseForProperties()
void vtkSMCompoundSourceProxy::TraverseForProperties ( vtkPVXMLElement *  root)
◆ StripValues()
void vtkSMCompoundSourceProxy::StripValues ( vtkPVXMLElement *  propertyElem)
