Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Friends | List of all members
vtkPVDataInformation Class Reference
provides meta data about a vtkDataObject subclass. More...
#include <vtkPVDataInformation.h>
Inheritance diagram for vtkPVDataInformation:
Collaboration diagram for vtkPVDataInformation:
typedef vtkPVInformation Superclass
- Public Types inherited from vtkPVInformation
void CopyFromObject (vtkObject *object) override
 Populate vtkPVDataInformation using object. More...
void Initialize ()
 Initializes and clears all values updated in CopyFromObject. More...
void DeepCopy (vtkPVDataInformation *info)
 Simply copies from another vtkPVDataInformation. More...
vtkPVArrayInformation * GetArrayInformation (const char *arrayname, int fieldAssociation) const
 Finds and returns array information associated with the chosen array. More...
virtual int GetDataSetType ()
 Returns the data set type. More...
virtual int GetCompositeDataSetType ()
 Returns the type flag for composite datasets. More...
bool IsCompositeDataSet () const
 Returns true if the data information corresponds to a composite dataset. More...
bool IsNull () const
 Returns true if the data information is empty or invalid. More...
vtkTypeInt64 GetNumberOfElements (int elementType) const
 Returns number of elements of the chosen type in the data. More...
virtual vtkTypeInt64 GetNumberOfAMRLevels ()
 For vtkUniformGridAMR and subclasses, this returns the number of levels. More...
vtkTypeInt64 GetNumberOfAMRDataSets (vtkTypeInt64 level) const
 For vtkUniformGridAMR and subclasses, this returns the number of datasets at each level. More...
virtual vtkTypeInt64 GetNumberOfDataSets ()
 This is count of non-null non-composite datasets. More...
virtual vtkTypeInt64 GetMemorySize ()
 Returns the memory size as reported by vtkDataObject::GetActualMemorySize. More...
virtual double * GetBounds ()
 Returns bounds for the dataset. More...
virtual void GetBounds (double &, double &, double &, double &, double &, double &)
virtual void GetBounds (double[6])
virtual vtkPVArrayInformation * GetPointArrayInformation ()
 For a vtkPointSet and subclasses, this provides information about the vtkPoints array. More...
bool IsDataStructured () const
 Returns true if the data is structured i.e. More...
bool HasStructuredData () const
 Returns true if the data has structured data. More...
bool HasUnstructuredData () const
 Returns true if the data has unstructured data. More...
bool IsAttributeValid (int fieldAssociation) const
 Returns true if provided fieldAssociation is valid for this dataset, false otherwise. More...
virtual vtkTypeUInt64 GetFirstLeafCompositeIndex ()
 Until multiblock dataset is deprecated, applications often want to locate the composite-index for the first leaf node. More...
std::string GetBlockName (vtkTypeUInt64 cid) const
 Given a composite index, return the blockname, if any. More...
std::vector< std::string > GetBlockNames (const std::vector< std::string > &selectors, const char *assemblyName) const
 Given a collection of selectors, returns all block names for chosen blocks. More...
unsigned int ComputeCompositeIndexForAMR (unsigned int level, unsigned int index) const
 A helper method to convert an AMR level-index to a flat index. More...
virtual void SetPortNumber (int)
 Indicates which output port of an algorithm this data should information should be / has been collected from. More...
virtual int GetPortNumber ()
virtual void SetRank (int)
 Indicates which rank to gather the information from. More...
virtual int GetRank ()
virtual char * GetSubsetSelector ()
 Path if non-null, used to limit blocks from a composite dataset. More...
virtual void SetSubsetSelector (const char *)
virtual void SetSubsetAssemblyName (const char *)
 Get/Set the assembly to use for subsetting. More...
virtual char * GetSubsetAssemblyName ()
void SetSubsetAssemblyNameToHierarchy ()
void AddInformation (vtkPVInformation *info) override
 vtkPVInformation API implementation. More...
void CopyToStream (vtkClientServerStream *) override
void CopyFromStream (const vtkClientServerStream *) override
void CopyParametersToStream (vtkMultiProcessStream &) override
void CopyParametersFromStream (vtkMultiProcessStream &) override
const std::vector< int > & GetUniqueBlockTypes () const
 For a composite dataset, returns a list of unique data set types for all non-null leaf nodes. More...
unsigned int GetNumberOfUniqueBlockTypes () const
int GetUniqueBlockType (unsigned int index) const
bool DataSetTypeIsA (const char *classname) const
 Returns true if the type is of the requested classname (or typeId). More...
bool DataSetTypeIsA (int typeId) const
bool HasDataSetType (const char *classname) const
 Similar to DataSetTypeIsA except, in case of composite datasets, returns true if any of the leaf nodes match the requested type. More...
bool HasDataSetType (int typeId) const
vtkTypeInt64 GetNumberOfPoints () const
 Convenience methods that simply call GetNumberOfElements with appropriate element type. More...
vtkTypeInt64 GetNumberOfCells () const
vtkTypeInt64 GetNumberOfVertices () const
vtkTypeInt64 GetNumberOfEdges () const
vtkTypeInt64 GetNumberOfRows () const
virtual vtkTypeInt64 GetNumberOfTrees ()
 vtkHyperTreeGrid / vtkUniformHyperTreeGrid specific properties. More...
virtual vtkTypeInt64 GetNumberOfLeaves ()
virtual int * GetExtent ()
 Returns structured extents for the data. More...
virtual void GetExtent (int &, int &, int &, int &, int &, int &)
virtual void GetExtent (int[6])
vtkPVDataSetAttributesInformation * GetAttributeInformation (int fieldAssociation) const
 Get vtkPVDataSetAttributesInformation information for the given association. More...
vtkPVDataSetAttributesInformation * GetPointDataInformation () const
 Convenience methods to get vtkPVDataSetAttributesInformation for specific field type. More...
vtkPVDataSetAttributesInformation * GetCellDataInformation () const
vtkPVDataSetAttributesInformation * GetVertexDataInformation () const
vtkPVDataSetAttributesInformation * GetEdgeDataInformation () const
vtkPVDataSetAttributesInformation * GetRowDataInformation () const
vtkPVDataSetAttributesInformation * GetFieldDataInformation () const
virtual bool GetHasTime ()
 Returns DATA_TIME_STEP, if any, provided by the information object associated with data. More...
virtual double GetTime ()
virtual double * GetTimeRange ()
 Strictly speaking, these are not data information since these cannot be obtained from the data but from the pipeline producing the data. More...
virtual void GetTimeRange (double &, double &)
virtual void GetTimeRange (double[2])
virtual std::string GetTimeLabel ()
const std::set< double > & GetTimeSteps () const
vtkTypeInt64 GetNumberOfTimeSteps () const
vtkDataAssembly * GetHierarchy () const
 For composite datasets, this provides access to the information about the dataset hierarchy and any data assembly associated with it. More...
vtkDataAssembly * GetDataAssembly () const
vtkDataAssembly * GetDataAssembly (const char *assemblyName) const
- Public Member Functions inherited from vtkPVInformation
virtual int GetRootOnly ()
 Set/get whether to gather information only from the root. More...
static vtkPVDataInformation * New ()
static vtkPVDataInformation * SafeDownCast (vtkObject *o)
static int GetExtentType (int dataType)
 Returns the extent type for a given data-object type. More...
- Static Public Member Functions inherited from vtkPVInformation
static vtkPVInformation * SafeDownCast (vtkObject *o)
 vtkPVDataInformation ()
 ~vtkPVDataInformation () override
void CopyFromPipelineInformation (vtkInformation *pipelineInfo)
 Populate information object with contents from producer pipeline's output port information. More...
void CopyFromDataObject (vtkDataObject *dobj)
vtkSmartPointer< vtkDataObject > GetSubset (vtkDataObject *dobj) const
 Extracts selected blocks. More...
- Protected Member Functions inherited from vtkPVInformation
 vtkPVInformation ()
 ~vtkPVInformation () override
virtual void SetRootOnly (int)
 vtkPVInformation (const vtkPVInformation &)=delete
void operator= (const vtkPVInformation &)=delete
Friends
class vtkPVDataInformationHelper
class vtkPVDataInformationAccumulator
static const char * GetDataSetTypeAsString (int type)
 Returns a string for the given type. More...
const char * GetDataSetTypeAsString () const
const char * GetDataClassName () const
const char * GetCompositeDataClassName () const
static const char * GetPrettyDataTypeString (int dtype)
 Returns a user-friendly string describing the datatype. More...
const char * GetPrettyDataTypeString () const
- Protected Attributes inherited from vtkPVInformation
int RootOnly
vtkPVDataInformation is a vtkPVInformation subclass intended to collect information from vtkDataObject and subclasses. It designed to be used by application in lieu of actual data to glean insight into the data e.g. data type, number of points, number of cells, arrays, ranges etc.
Definition at line 42 of file vtkPVDataInformation.h.
Definition at line 46 of file vtkPVDataInformation.h.
◆ vtkPVDataInformation()
vtkPVDataInformation::vtkPVDataInformation ( )
◆ ~vtkPVDataInformation()
vtkPVDataInformation::~vtkPVDataInformation ( )
static vtkPVDataInformation* vtkPVDataInformation::New ( )
virtual const char* vtkPVDataInformation::GetClassName ( )
static int vtkPVDataInformation::IsTypeOf ( const char *  type)
virtual int vtkPVDataInformation::IsA ( const char *  type)
static vtkPVDataInformation* vtkPVDataInformation::SafeDownCast ( vtkObject *  o)
void vtkPVDataInformation::PrintSelf ( ostream &  os,
Reimplemented in vtkPVTemporalDataInformation, and vtkPVRepresentedDataInformation.
◆ SetPortNumber()
virtual void vtkPVDataInformation::SetPortNumber ( int  )
Default is 0.
◆ GetPortNumber()
virtual int vtkPVDataInformation::GetPortNumber ( )
Default is 0.
◆ SetRank()
virtual void vtkPVDataInformation::SetRank ( int  )
Default is -1 which means all ranks.
◆ GetRank()
virtual int vtkPVDataInformation::GetRank ( )
◆ GetSubsetSelector()
virtual char* vtkPVDataInformation::GetSubsetSelector ( )
For details on support form of selector expressions see vtkDataAssembly::SelectNodes.
◆ SetSubsetSelector()
virtual void vtkPVDataInformation::SetSubsetSelector ( const char *  )
◆ SetSubsetAssemblyName()
virtual void vtkPVDataInformation::SetSubsetAssemblyName ( const char *  )
To use hierarchy, set this to vtkDataAssembly::HierarchyName() or simply use SetSubsetAssemblyNameToHierarchy().
◆ GetSubsetAssemblyName()
virtual char* vtkPVDataInformation::GetSubsetAssemblyName ( )
◆ SetSubsetAssemblyNameToHierarchy()
void vtkPVDataInformation::SetSubsetAssemblyNameToHierarchy ( )
◆ CopyFromObject()
void vtkPVDataInformation::CopyFromObject ( vtkObject *  object)
The object can be a vtkDataObject, vtkAlgorithm or vtkAlgorithmOutput.
Reimplemented from vtkPVInformation.
◆ AddInformation()
void vtkPVDataInformation::AddInformation ( vtkPVInformation *  info)
◆ CopyToStream()
void vtkPVDataInformation::CopyToStream ( vtkClientServerStream *  )
Implements vtkPVInformation.
◆ CopyFromStream()
void vtkPVDataInformation::CopyFromStream ( const vtkClientServerStream *  )
◆ CopyParametersToStream()
void vtkPVDataInformation::CopyParametersToStream ( vtkMultiProcessStream &  )
◆ CopyParametersFromStream()
void vtkPVDataInformation::CopyParametersFromStream ( vtkMultiProcessStream &  )
◆ Initialize()
void vtkPVDataInformation::Initialize ( )
◆ DeepCopy()
void vtkPVDataInformation::DeepCopy ( vtkPVDataInformation *  info)
◆ GetArrayInformation()
vtkPVArrayInformation* vtkPVDataInformation::GetArrayInformation ( const char *  arrayname,
) const
fieldAssociation must be one of vtkDataObject::FieldAssociations or vtkDataObject::AttributeTypes.
◆ GetDataSetType()
virtual int vtkPVDataInformation::GetDataSetType ( )
Returned values are defined in vtkType.h. For composite datasets, this returns the common superclass for all non-null leaf nodes in the composite dataset.
-1 indicates that the information has not be collected yet, was collected from nullptr data object, or from a composite dataset with no non-null leaf nodes.
See also
◆ GetCompositeDataSetType()
virtual int vtkPVDataInformation::GetCompositeDataSetType ( )
For non-composite datasets, this is set to -1.
◆ IsCompositeDataSet()
bool vtkPVDataInformation::IsCompositeDataSet ( ) const
inline
Definition at line 146 of file vtkPVDataInformation.h.
◆ IsNull()
bool vtkPVDataInformation::IsNull ( ) const
inline
Definition at line 151 of file vtkPVDataInformation.h.
◆ GetUniqueBlockTypes()
const std::vector<int>& vtkPVDataInformation::GetUniqueBlockTypes ( ) const
inline
May be empty if there are non-null leaf nodes are the dataset is not a composite dataset.
Note
There is no significance to the order of the types.
Definition at line 161 of file vtkPVDataInformation.h.
◆ GetNumberOfUniqueBlockTypes()
unsigned int vtkPVDataInformation::GetNumberOfUniqueBlockTypes ( ) const
inline
Note
Definition at line 162 of file vtkPVDataInformation.h.
◆ GetUniqueBlockType()
int vtkPVDataInformation::GetUniqueBlockType ( unsigned int  index) const
Note
◆ GetDataSetTypeAsString() [1/2]
static const char* vtkPVDataInformation::GetDataSetTypeAsString ( int  type)
This directly returns the classname and hence may not be user-friendly.
See also
◆ GetDataSetTypeAsString() [2/2]
const char* vtkPVDataInformation::GetDataSetTypeAsString ( ) const
inline
See also
Definition at line 177 of file vtkPVDataInformation.h.
◆ GetDataClassName()
const char* vtkPVDataInformation::GetDataClassName ( ) const
inline
See also
Definition at line 181 of file vtkPVDataInformation.h.
◆ GetCompositeDataClassName()
const char* vtkPVDataInformation::GetCompositeDataClassName ( ) const
inline
See also
Definition at line 185 of file vtkPVDataInformation.h.
◆ GetPrettyDataTypeString() [1/2]
const char* vtkPVDataInformation::GetPrettyDataTypeString ( ) const
◆ GetPrettyDataTypeString() [2/2]
static const char* vtkPVDataInformation::GetPrettyDataTypeString ( int  dtype)
◆ DataSetTypeIsA() [1/2]
bool vtkPVDataInformation::DataSetTypeIsA ( const char *  classname) const
If this->CompositeDataSetType is valid i.e. the information represents a composite dataset, the composite dataset type is first checked. If not, this->DataSetType is checked. Since this->DataSetType is set to the most common data type among all the leaf nodes in the composite dataset, true implies all datasets in the composite dataset match the type.
See also
HasDataSetType
◆ DataSetTypeIsA() [2/2]
bool vtkPVDataInformation::DataSetTypeIsA ( int  typeId) const
See also
HasDataSetType
◆ HasDataSetType() [1/2]
bool vtkPVDataInformation::HasDataSetType ( const char *  classname) const
For non-composite datasets, this is same as DataSetTypeIsA.
◆ HasDataSetType() [2/2]
bool vtkPVDataInformation::HasDataSetType ( int  typeId) const
◆ GetNumberOfElements()
vtkTypeInt64 vtkPVDataInformation::GetNumberOfElements ( int  elementType) const
For a composite dataset, this is a sum of the element count across all leaf nodes.
elementType must be vtkDataObject::AttributeTypes. For vtkDataObject::FIELD, and vtkDataObject::POINT_THEN_CELL returns 0.
◆ GetNumberOfPoints()
vtkTypeInt64 vtkPVDataInformation::GetNumberOfPoints ( ) const
inline
Definition at line 241 of file vtkPVDataInformation.h.
◆ GetNumberOfCells()
vtkTypeInt64 vtkPVDataInformation::GetNumberOfCells ( ) const
inline
Definition at line 242 of file vtkPVDataInformation.h.
◆ GetNumberOfVertices()
vtkTypeInt64 vtkPVDataInformation::GetNumberOfVertices ( ) const
inline
Definition at line 243 of file vtkPVDataInformation.h.
◆ GetNumberOfEdges()
vtkTypeInt64 vtkPVDataInformation::GetNumberOfEdges ( ) const
inline
Definition at line 247 of file vtkPVDataInformation.h.
◆ GetNumberOfRows()
vtkTypeInt64 vtkPVDataInformation::GetNumberOfRows ( ) const
inline
Definition at line 248 of file vtkPVDataInformation.h.
◆ GetNumberOfTrees()
virtual vtkTypeInt64 vtkPVDataInformation::GetNumberOfTrees ( )
Will return 0 for all other data types.
◆ GetNumberOfLeaves()
virtual vtkTypeInt64 vtkPVDataInformation::GetNumberOfLeaves ( )
◆ GetNumberOfAMRLevels()
virtual vtkTypeInt64 vtkPVDataInformation::GetNumberOfAMRLevels ( )
◆ GetNumberOfAMRDataSets()
vtkTypeInt64 vtkPVDataInformation::GetNumberOfAMRDataSets ( vtkTypeInt64  level) const
◆ GetNumberOfDataSets()
virtual vtkTypeInt64 vtkPVDataInformation::GetNumberOfDataSets ( )
A count of 0 may mean:
  • the data is nullptr
  • the data is a composite dataset with no non-null leaf nodes A count of 1 may mean:
  • the data is non-composite dataset
  • the data is a composite dataset with exactly 1 non-null leaf node. A count of > 1 may mean:
  • the data is non-composite, but distributed across ranks.
  • the data is composite with multiple non-null leaf nodes.
◆ GetMemorySize()
virtual vtkTypeInt64 vtkPVDataInformation::GetMemorySize ( )
For composite datasets, this is simply a sum of the values returned by vtkDataObject::GetActualMemorySize per non-null leaf node. For datasets that share internal arrays, this will overestimate the size.
◆ GetBounds() [1/3]
virtual double* vtkPVDataInformation::GetBounds ( )
May return an invalid bounding box for data types where bounds don't make sense. For composite datasets, this is a bounding box of all valid bounding boxes.
◆ GetBounds() [2/3]
virtual void vtkPVDataInformation::GetBounds ( double &  ,
double &  ,
double &  ,
double &  ,
double &  ,
double &
◆ GetBounds() [3/3]
virtual void vtkPVDataInformation::GetBounds ( double  [6])
◆ GetExtent() [1/3]
virtual int* vtkPVDataInformation::GetExtent ( )
These are only valid for structured data types like vtkStructuredGrid, vtkImageData etc. For composite dataset, these represent the combined extents for structured datasets in the collection.
◆ GetExtent() [2/3]
virtual void vtkPVDataInformation::GetExtent ( int &  ,
int &  ,
int &  ,
int &  ,
int &  ,
int &
◆ GetExtent() [3/3]
virtual void vtkPVDataInformation::GetExtent ( int  [6])
◆ GetAttributeInformation()
vtkPVDataSetAttributesInformation* vtkPVDataInformation::GetAttributeInformation ( int  fieldAssociation) const
vtkPVDataSetAttributesInformation can be used to determine available arrays and get meta-data about each of the available arrays.
fieldAssociation must be vtkDataObject::FieldAssociations (or vtkDataObject::AttributeTypes). vtkDataObject::FIELD_ASSOCIATION_POINTS_THEN_CELLS (or vtkDataObject::POINT_THEN_CELL) is not supported.
◆ GetPointDataInformation()
vtkPVDataSetAttributesInformation* vtkPVDataInformation::GetPointDataInformation ( ) const
inline
Same as calling GetAttributeInformation with appropriate type.
Definition at line 328 of file vtkPVDataInformation.h.
◆ GetCellDataInformation()
vtkPVDataSetAttributesInformation* vtkPVDataInformation::GetCellDataInformation ( ) const
inline
Definition at line 332 of file vtkPVDataInformation.h.
◆ GetVertexDataInformation()
vtkPVDataSetAttributesInformation* vtkPVDataInformation::GetVertexDataInformation ( ) const
inline
Definition at line 336 of file vtkPVDataInformation.h.
◆ GetEdgeDataInformation()
vtkPVDataSetAttributesInformation* vtkPVDataInformation::GetEdgeDataInformation ( ) const
inline
Definition at line 340 of file vtkPVDataInformation.h.
◆ GetRowDataInformation()
vtkPVDataSetAttributesInformation* vtkPVDataInformation::GetRowDataInformation ( ) const
inline
Definition at line 344 of file vtkPVDataInformation.h.
◆ GetFieldDataInformation()
vtkPVDataSetAttributesInformation* vtkPVDataInformation::GetFieldDataInformation ( ) const
inline
Definition at line 348 of file vtkPVDataInformation.h.
◆ GetPointArrayInformation()
virtual vtkPVArrayInformation* vtkPVDataInformation::GetPointArrayInformation ( )
For composite datasets, this is the obtained by accumulating information from all point-sets in the collection.
◆ GetHasTime()
virtual bool vtkPVDataInformation::GetHasTime ( )
◆ GetTime()
virtual double vtkPVDataInformation::GetTime ( )
◆ GetTimeRange() [1/3]
virtual double* vtkPVDataInformation::GetTimeRange ( )
However, they are provided as part data information for simplicity.
◆ GetTimeRange() [2/3]
virtual void vtkPVDataInformation::GetTimeRange ( double &  ,
double &
◆ GetTimeRange() [3/3]
virtual void vtkPVDataInformation::GetTimeRange ( double  [2])
◆ GetTimeLabel()
virtual std::string vtkPVDataInformation::GetTimeLabel ( )
◆ GetTimeSteps()
const std::set<double>& vtkPVDataInformation::GetTimeSteps ( ) const
inline
Definition at line 378 of file vtkPVDataInformation.h.
◆ GetNumberOfTimeSteps()
vtkTypeInt64 vtkPVDataInformation::GetNumberOfTimeSteps ( ) const
inline
Definition at line 379 of file vtkPVDataInformation.h.
◆ IsDataStructured()
bool vtkPVDataInformation::IsDataStructured ( ) const
supports i-j-k indexing. For composite datasets, this returns true if all leaf nodes are structured.
◆ HasStructuredData()
bool vtkPVDataInformation::HasStructuredData ( ) const
For composite datasets, this returns true if any of the datasets are structured.
◆ HasUnstructuredData()
bool vtkPVDataInformation::HasUnstructuredData ( ) const
For composite datasets, this returns true if any of the datasets are unstructured.
◆ IsAttributeValid()
bool vtkPVDataInformation::IsAttributeValid ( int  fieldAssociation) const
For composite datasets, this returns true if the attribute type if valid for any of the datasets in the collection.
◆ GetExtentType()
static int vtkPVDataInformation::GetExtentType ( int  dataType)
◆ GetHierarchy()
vtkDataAssembly* vtkPVDataInformation::GetHierarchy ( ) const
Hierarchy represents the hierarchy of the datatype while assembly provides access to logical grouping and organization, if any.
◆ GetDataAssembly() [1/2]
vtkDataAssembly* vtkPVDataInformation::GetDataAssembly ( ) const
◆ GetDataAssembly() [2/2]
vtkDataAssembly* vtkPVDataInformation::GetDataAssembly ( const char *  assemblyName) const
◆ GetFirstLeafCompositeIndex()
virtual vtkTypeUInt64 vtkPVDataInformation::GetFirstLeafCompositeIndex ( )
Returns 0 if not applicable.
◆ GetBlockName()
std::string vtkPVDataInformation::GetBlockName ( vtkTypeUInt64  cid) const
Note, this is not reliable if executed on partitioned-dataset collection since partitioned-dataset collection may have different composite indices across ranks. Thus, this must only be used in code that is currently only slated for migration from using composite-ids to selectors and hence does not encounter partitioned-dataset collections.
This uses Hierarchy and hence it only supported when hierarchy is defined/available.
Returns empty string if no name available or cannot be determined.
◆ GetBlockNames()
std::vector<std::string> vtkPVDataInformation::GetBlockNames ( const std::vector< std::string > &  selectors,
) const
◆ ComputeCompositeIndexForAMR()
unsigned int vtkPVDataInformation::ComputeCompositeIndexForAMR ( unsigned int  level,
unsigned int  index
) const
This uses the hierarchy to compute the flat index.
Calling this on a non-AMR dataset will simply return 0.
◆ CopyFromPipelineInformation()
void vtkPVDataInformation::CopyFromPipelineInformation ( vtkInformation *  pipelineInfo)
◆ CopyFromDataObject()
void vtkPVDataInformation::CopyFromDataObject ( vtkDataObject *  dobj)
◆ GetSubset()
vtkSmartPointer<vtkDataObject> vtkPVDataInformation::GetSubset ( vtkDataObject *  dobj) const
Use SubsetSelector and SubsetAssemblyName to extract chosen part of the composite dataset and returns that.
◆ vtkPVDataInformationHelper
friend class vtkPVDataInformationHelper
friend
Definition at line 475 of file vtkPVDataInformation.h.
◆ vtkPVDataInformationAccumulator
friend class vtkPVDataInformationAccumulator
friend
Definition at line 520 of file vtkPVDataInformation.h.
