vtkSMMultiServerSourceProxy Class Reference
#include <vtkSMMultiServerSourceProxy.h>
Inheritance diagram for vtkSMMultiServerSourceProxy:
Collaboration diagram for vtkSMMultiServerSourceProxy:
typedef vtkSMSourceProxy Superclass
- Public Types inherited from vtkSMSourceProxy
enum  ProcessSupportType { SINGLE_PROCESS, MULTIPLE_PROCESSES, BOTH }
typedef vtkSMProxy Superclass
virtual void SetExternalProxy (vtkSMSourceProxy *proxyFromAnotherServer, int port=0)
 Bind proxy with a given external proxy. More...
virtual vtkSMSourceProxy * GetExternalProxy ()
 Return the proxy that is currently binded if any otherwise return nullptr;. More...
void MarkDirty (vtkSMProxy *modifiedProxy) override
 Marks the selection proxies dirty as well as chain to superclass. More...
void LoadState (const vtkSMMessage *message, vtkSMProxyLocator *locator) override
- Public Member Functions inherited from vtkSMSourceProxy
void UpdatePipelineInformation () override
 Calls UpdateInformation() on all sources. More...
virtual void UpdatePipeline ()
 Calls Update() on all sources. More...
virtual void UpdatePipeline (double time)
 Calls Update() on all sources with the given time request. More...
virtual unsigned int GetNumberOfOutputPorts ()
 Return the number of output ports. More...
virtual vtkSMOutputPort * GetOutputPort (unsigned int idx)
 Return an output port. More...
virtual vtkSMOutputPort * GetOutputPort (const char *portname)
 Return an output port, given the name for the port. More...
virtual unsigned int GetOutputPortIndex (const char *portname)
 Returns the port index, given the name of an output port. More...
virtual const char * GetOutputPortName (unsigned int index)
 Returns the output port name given its index. More...
virtual void CreateOutputPorts ()
 Creates the output port proxies for this filter. More...
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, unsigned int compositeIndex)
 A GetSubsetDataInformation overload that uses composite index. More...
virtual void CreateSelectionProxies ()
 Creates extract selection proxies for each output port if not already created. More...
void SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort)
 Set/Get the selection input. More...
void CleanSelectionInputs (unsigned int portIndex)
 Clean all selection inputs for the given port. More...
vtkSMSourceProxy * GetSelectionOutput (unsigned int portIndex)
 Returns the source proxy which provides the selected data from the given output port. More...
unsigned int GetNumberOfAlgorithmOutputPorts ()
 Returns the number of output ports provided by the algorithm. More...
virtual unsigned int GetNumberOfAlgorithmRequiredInputPorts ()
 Returns the number of non-optional input ports required by the algorithm. More...
vtkTypeUInt32 GetGlobalID () override
 Overridden to reserve additional IDs for use by "ExtractSelection" proxies. More...
virtual int GetOutputPortsCreated ()
 Returns if the output port proxies have been created. More...
vtkSMDocumentation * GetOutputPortDocumentation (unsigned int index)
 It is possible to provide some documentation for each output port in the configuration xml. More...
vtkSMDocumentation * GetOutputPortDocumentation (const char *portname)
vtkPVDataInformation * GetDataInformation ()
 DataInformation is used by the source proxy to obtain information on the output(s) from the server. More...
vtkPVDataInformation * GetDataInformation (unsigned int outputIdx)
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, const char *selector, const char *assemblyName=nullptr)
 For composite datasets, GetDataInformation returns summary data information for all blocks combined. More...
vtkPVDataInformation * GetRankDataInformation (int rank)
 Get rank-specific data information. More...
vtkPVDataInformation * GetRankDataInformation (unsigned int outputIdx, int rank)
vtkSMSourceProxy * GetSelectionInput (unsigned int portIndex)
 API to query selection input set using SetSelectionInput. More...
unsigned int GetSelectionInputPort (unsigned int portIndex)
virtual int GetProcessSupport ()
 This returns information about whether the VTK algorithm supports multiple processes or not. More...
virtual bool GetMPIRequired ()
 This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMMultiServerSourceProxy * New ()
static vtkSMMultiServerSourceProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMSourceProxy
static vtkSMSourceProxy * New ()
static vtkSMSourceProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMMultiServerSourceProxy ()
 ~vtkSMMultiServerSourceProxy () override
virtual void UpdateState ()
- Protected Member Functions inherited from vtkSMSourceProxy
 vtkSMSourceProxy ()
 ~vtkSMSourceProxy () override
virtual void InvalidateDataInformation ()
 Mark the data information as invalid. More...
 Call superclass' and then assigns a new executive (vtkCompositeDataPipeline) More...
virtual void SetExecutiveName (const char *)
void PostUpdateData (bool) override
 Overwritten from superclass to invoke. More...
void SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override
 Overridden to pass the logname to the internal ExtractSelection proxies. More...
void SetOutputPort (unsigned int index, const char *name, vtkSMOutputPort *port, vtkSMDocumentation *doc)
 Method to set an output port at the given index. More...
void RemoveAllOutputPorts ()
void SetExtractSelectionProxy (unsigned int index, vtkSMSourceProxy *proxy)
void RemoveAllExtractSelectionProxies ()
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkIdType RemoteProxySessionID
vtkIdType RemoteProxyID
int PortToExport
- Protected Attributes inherited from vtkSMSourceProxy
int OutputPortsCreated
int ProcessSupport
bool MPIRequired
char * ExecutiveName
bool DisableSelectionProxies
bool SelectionProxiesCreated
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMMultiServerSourceProxy can be useful in case of multi-server setup when the user want to display a data object that belong to another server into its local built-in view.
Definition at line 20 of file vtkSMMultiServerSourceProxy.h.
Definition at line 24 of file vtkSMMultiServerSourceProxy.h.
◆ vtkSMMultiServerSourceProxy()
vtkSMMultiServerSourceProxy::vtkSMMultiServerSourceProxy ( )
◆ ~vtkSMMultiServerSourceProxy()
vtkSMMultiServerSourceProxy::~vtkSMMultiServerSourceProxy ( )
static vtkSMMultiServerSourceProxy* vtkSMMultiServerSourceProxy::New ( )
virtual const char* vtkSMMultiServerSourceProxy::GetClassName ( )
Reimplemented from vtkSMSourceProxy.
static int vtkSMMultiServerSourceProxy::IsTypeOf ( const char *  type)
virtual int vtkSMMultiServerSourceProxy::IsA ( const char *  type)
static vtkSMMultiServerSourceProxy* vtkSMMultiServerSourceProxy::SafeDownCast ( vtkObject *  o)
void vtkSMMultiServerSourceProxy::PrintSelf ( ostream &  os,
◆ SetExternalProxy()
virtual void vtkSMMultiServerSourceProxy::SetExternalProxy ( vtkSMSourceProxy *  proxyFromAnotherServer,
int  port = 0
◆ GetExternalProxy()
virtual vtkSMSourceProxy* vtkSMMultiServerSourceProxy::GetExternalProxy ( )
◆ MarkDirty()
void vtkSMMultiServerSourceProxy::MarkDirty ( vtkSMProxy *  modifiedProxy)
◆ LoadState()
void vtkSMMultiServerSourceProxy::LoadState ( const vtkSMMessage *  message,
vtkSMProxyLocator *  locator
This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set.
This allow to split the load process in 2 step to prevent invalid state when property refere to a sub-proxy that does not exist yet.
Reimplemented from vtkSMRemoteObject.
◆ UpdateState()
virtual void vtkSMMultiServerSourceProxy::UpdateState ( )
protectedvirtual
◆ RemoteProxySessionID
vtkIdType vtkSMMultiServerSourceProxy::RemoteProxySessionID
Definition at line 57 of file vtkSMMultiServerSourceProxy.h.
◆ RemoteProxyID
vtkIdType vtkSMMultiServerSourceProxy::RemoteProxyID
Definition at line 58 of file vtkSMMultiServerSourceProxy.h.
◆ PortToExport
int vtkSMMultiServerSourceProxy::PortToExport
Definition at line 59 of file vtkSMMultiServerSourceProxy.h.
