is used to locate proxies referred to in state xmls while loading state files. More...
#include <vtkSMProxyLocator.h>
| virtual vtkSMProxy * | LocateProxy (vtkTypeUInt32 globalID) |
| Locate a proxy with the given "name". More... | |
| virtual void | Clear () |
| Clear the locator. More... | |
| virtual void | GetLocatedProxies (vtkCollection *collectionToFill) |
| Copy all the Located proxy into the collection. More... | |
| virtual void | UseSessionToLocateProxy (bool useSessionToo) |
| virtual void | AssignProxy (vtkTypeUInt32 id, vtkSMProxy *proxy) |
| For custom applications managing custom state loading, one can use this method to register proxies with locator to use when LocateProxy() before attempting the standard route i.e. More... | |
| void | SetDeserializer (vtkSMDeserializer *) |
| Get/Set the de-serializer to used to locate XMLs/Protobuf for unknown proxies requested to be located using LocateProxy(). More... | |
| virtual vtkSMDeserializer * | GetDeserializer () |
| Get/Set the session. More... | |
| virtual void | SetSession (vtkSMSession *s) |
| static vtkSMProxyLocator * | New () |
| static vtkSMProxyLocator * | SafeDownCast (vtkObject *o) |
| vtkSMProxyLocator () | |
| ~vtkSMProxyLocator () override | |
| virtual vtkSMProxy * | NewProxy (vtkTypeUInt32 globalID) |
| Create new proxy with the given id. More... | |
| vtkSMObject () | |
Protected Attributes | |
| vtkSMDeserializer * | Deserializer |
| bool | LocateProxyWithSessionToo |
vtkSMProxyLocator is used to locate proxies referred to in state xmls (and otherwise) when loading state files.
Definition at line 24 of file vtkSMProxyLocator.h.
Definition at line 28 of file vtkSMProxyLocator.h.
If none can be found returns nullptr. If a proxy with the name was not previously located, it will ask the Deserializer (if any) to create a new proxy is possible.
| void vtkSMProxyLocator::SetDeserializer | ( | vtkSMDeserializer * | ) |
Clear the locator.
This allow to keep a reference to them outside of the current locator. This is needed if we don't want to delete those proxy and if we want to Clear() the current ProxyLocator.
inlinevirtual |
Definition at line 68 of file vtkSMProxyLocator.h.
using the deserializer or session.
protectedvirtual |
Default implementation asks the Deserializer, if any, to create a new proxy.
Definition at line 91 of file vtkSMProxyLocator.h.
Definition at line 92 of file vtkSMProxyLocator.h.
Definition at line 93 of file vtkSMProxyLocator.h.
