vtkSMWriterProxy Class Reference
proxy for a VTK writer on a server More...
#include <vtkSMWriterProxy.h>
Inheritance diagram for vtkSMWriterProxy:
Collaboration diagram for vtkSMWriterProxy:
typedef vtkSMSourceProxy Superclass
- Public Types inherited from vtkSMSourceProxy
enum  ProcessSupportType { SINGLE_PROCESS, MULTIPLE_PROCESSES, BOTH }
typedef vtkSMProxy Superclass
void UpdatePipeline () override
 Updates the pipeline and writes the file(s). More...
void UpdatePipeline (double time) override
virtual void SetSupportsParallel (int)
 Flag indicating if the writer supports writing in parallel. More...
int GetSupportsParallel ()
virtual int GetParallelOnly ()
 Flag indicating if the writer works only in parallel. More...
virtual void SetParallelOnly (int)
- Public Member Functions inherited from vtkSMSourceProxy
void UpdatePipelineInformation () override
 Calls UpdateInformation() on all sources. More...
virtual unsigned int GetNumberOfOutputPorts ()
 Return the number of output ports. More...
virtual vtkSMOutputPort * GetOutputPort (unsigned int idx)
 Return an output port. More...
virtual vtkSMOutputPort * GetOutputPort (const char *portname)
 Return an output port, given the name for the port. More...
virtual unsigned int GetOutputPortIndex (const char *portname)
 Returns the port index, given the name of an output port. More...
virtual const char * GetOutputPortName (unsigned int index)
 Returns the output port name given its index. More...
virtual void CreateOutputPorts ()
 Creates the output port proxies for this filter. More...
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, unsigned int compositeIndex)
 A GetSubsetDataInformation overload that uses composite index. More...
virtual void CreateSelectionProxies ()
 Creates extract selection proxies for each output port if not already created. More...
void SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort)
 Set/Get the selection input. More...
void CleanSelectionInputs (unsigned int portIndex)
 Clean all selection inputs for the given port. More...
vtkSMSourceProxy * GetSelectionOutput (unsigned int portIndex)
 Returns the source proxy which provides the selected data from the given output port. More...
unsigned int GetNumberOfAlgorithmOutputPorts ()
 Returns the number of output ports provided by the algorithm. More...
virtual unsigned int GetNumberOfAlgorithmRequiredInputPorts ()
 Returns the number of non-optional input ports required by the algorithm. More...
vtkTypeUInt32 GetGlobalID () override
 Overridden to reserve additional IDs for use by "ExtractSelection" proxies. More...
void MarkDirty (vtkSMProxy *modifiedProxy) override
 Marks the selection proxies dirty as well as chain to superclass. More...
virtual int GetOutputPortsCreated ()
 Returns if the output port proxies have been created. More...
vtkSMDocumentation * GetOutputPortDocumentation (unsigned int index)
 It is possible to provide some documentation for each output port in the configuration xml. More...
vtkSMDocumentation * GetOutputPortDocumentation (const char *portname)
vtkPVDataInformation * GetDataInformation ()
 DataInformation is used by the source proxy to obtain information on the output(s) from the server. More...
vtkPVDataInformation * GetDataInformation (unsigned int outputIdx)
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, const char *selector, const char *assemblyName=nullptr)
 For composite datasets, GetDataInformation returns summary data information for all blocks combined. More...
vtkPVDataInformation * GetRankDataInformation (int rank)
 Get rank-specific data information. More...
vtkPVDataInformation * GetRankDataInformation (unsigned int outputIdx, int rank)
vtkSMSourceProxy * GetSelectionInput (unsigned int portIndex)
 API to query selection input set using SetSelectionInput. More...
unsigned int GetSelectionInputPort (unsigned int portIndex)
virtual int GetProcessSupport ()
 This returns information about whether the VTK algorithm supports multiple processes or not. More...
virtual bool GetMPIRequired ()
 This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMWriterProxy * New ()
static vtkSMWriterProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMSourceProxy
static vtkSMSourceProxy * New ()
static vtkSMSourceProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMWriterProxy ()
 ~vtkSMWriterProxy () override
virtual void SetFileNameMethod (const char *)
virtual char * GetFileNameMethod ()
- Protected Member Functions inherited from vtkSMSourceProxy
 vtkSMSourceProxy ()
 ~vtkSMSourceProxy () override
virtual void InvalidateDataInformation ()
 Mark the data information as invalid. More...
 Call superclass' and then assigns a new executive (vtkCompositeDataPipeline) More...
virtual void SetExecutiveName (const char *)
void PostUpdateData (bool) override
 Overwritten from superclass to invoke. More...
void SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override
 Overridden to pass the logname to the internal ExtractSelection proxies. More...
void SetOutputPort (unsigned int index, const char *name, vtkSMOutputPort *port, vtkSMDocumentation *doc)
 Method to set an output port at the given index. More...
void RemoveAllOutputPorts ()
void SetExtractSelectionProxy (unsigned int index, vtkSMSourceProxy *proxy)
void RemoveAllExtractSelectionProxies ()
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
int SupportsParallel
int ParallelOnly
char * FileNameMethod
- Protected Attributes inherited from vtkSMSourceProxy
int OutputPortsCreated
int ProcessSupport
bool MPIRequired
char * ExecutiveName
bool DisableSelectionProxies
bool SelectionProxiesCreated
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMWriterProxy manages VTK writers that are created on a server using the proxy pattern. vtkSMWriterProxy also provides support for meta-writers. i.e. if the proxy has a subproxy name "Writer" that this proxy represents a meta-writer which uses the given writer as the writer to write each component.
Definition at line 20 of file vtkSMWriterProxy.h.
Definition at line 24 of file vtkSMWriterProxy.h.
◆ vtkSMWriterProxy()
vtkSMWriterProxy::vtkSMWriterProxy ( )
◆ ~vtkSMWriterProxy()
vtkSMWriterProxy::~vtkSMWriterProxy ( )
static vtkSMWriterProxy* vtkSMWriterProxy::New ( )
virtual const char* vtkSMWriterProxy::GetClassName ( )
Reimplemented from vtkSMSourceProxy.
Reimplemented in vtkSMPWriterProxy, and vtkSMPSWriterProxy.
static int vtkSMWriterProxy::IsTypeOf ( const char *  type)
virtual int vtkSMWriterProxy::IsA ( const char *  type)
static vtkSMWriterProxy* vtkSMWriterProxy::SafeDownCast ( vtkObject *  o)
void vtkSMWriterProxy::PrintSelf ( ostream &  os,
◆ UpdatePipeline() [1/2]
void vtkSMWriterProxy::UpdatePipeline ( )
Must call UpdateVTKObjects() before calling UpdatePipeline() to ensure that the filename etc. are set correctly.
◆ UpdatePipeline() [2/2]
void vtkSMWriterProxy::UpdatePipeline ( double  time)
◆ SetSupportsParallel()
virtual void vtkSMWriterProxy::SetSupportsParallel ( int  )
Not set by default.
◆ GetSupportsParallel()
int vtkSMWriterProxy::GetSupportsParallel ( )
inline
Not set by default.
Definition at line 47 of file vtkSMWriterProxy.h.
◆ GetParallelOnly()
virtual int vtkSMWriterProxy::GetParallelOnly ( )
If this is set, SupportsParallel is always true.
◆ SetParallelOnly()
virtual void vtkSMWriterProxy::SetParallelOnly ( int  )
◆ ReadXMLAttributes()
int vtkSMWriterProxy::ReadXMLAttributes ( vtkSMSessionProxyManager *  pm,
vtkPVXMLElement *  element
overrideprotectedvirtual
Read attributes from an XML element.
◆ SetFileNameMethod()
virtual void vtkSMWriterProxy::SetFileNameMethod ( const char *  )
protectedvirtual
◆ GetFileNameMethod()
virtual char* vtkSMWriterProxy::GetFileNameMethod ( )
protectedvirtual
◆ SupportsParallel
int vtkSMWriterProxy::SupportsParallel
Definition at line 68 of file vtkSMWriterProxy.h.
◆ ParallelOnly
int vtkSMWriterProxy::ParallelOnly
Definition at line 69 of file vtkSMWriterProxy.h.
◆ FileNameMethod
char* vtkSMWriterProxy::FileNameMethod
Definition at line 74 of file vtkSMWriterProxy.h.
