Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Friends | List of all members
vtkSMMultiplexerSourceProxy Class Reference
a multiplexer proxy More...
#include <vtkSMMultiplexerSourceProxy.h>
Inheritance diagram for vtkSMMultiplexerSourceProxy:
Collaboration diagram for vtkSMMultiplexerSourceProxy:
typedef vtkSMSourceProxy Superclass
- Public Types inherited from vtkSMSourceProxy
enum  ProcessSupportType { SINGLE_PROCESS, MULTIPLE_PROCESSES, BOTH }
typedef vtkSMProxy Superclass
vtkPVXMLElement * SaveXMLState (vtkPVXMLElement *root, vtkSMPropertyIterator *iter) override
int LoadXMLState (vtkPVXMLElement *element, vtkSMProxyLocator *locator) override
- Public Member Functions inherited from vtkSMSourceProxy
void UpdatePipelineInformation () override
 Calls UpdateInformation() on all sources. More...
virtual void UpdatePipeline ()
 Calls Update() on all sources. More...
virtual void UpdatePipeline (double time)
 Calls Update() on all sources with the given time request. More...
virtual unsigned int GetNumberOfOutputPorts ()
 Return the number of output ports. More...
virtual vtkSMOutputPort * GetOutputPort (unsigned int idx)
 Return an output port. More...
virtual vtkSMOutputPort * GetOutputPort (const char *portname)
 Return an output port, given the name for the port. More...
virtual unsigned int GetOutputPortIndex (const char *portname)
 Returns the port index, given the name of an output port. More...
virtual const char * GetOutputPortName (unsigned int index)
 Returns the output port name given its index. More...
virtual void CreateOutputPorts ()
 Creates the output port proxies for this filter. More...
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, unsigned int compositeIndex)
 A GetSubsetDataInformation overload that uses composite index. More...
virtual void CreateSelectionProxies ()
 Creates extract selection proxies for each output port if not already created. More...
void SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort)
 Set/Get the selection input. More...
void CleanSelectionInputs (unsigned int portIndex)
 Clean all selection inputs for the given port. More...
vtkSMSourceProxy * GetSelectionOutput (unsigned int portIndex)
 Returns the source proxy which provides the selected data from the given output port. More...
unsigned int GetNumberOfAlgorithmOutputPorts ()
 Returns the number of output ports provided by the algorithm. More...
virtual unsigned int GetNumberOfAlgorithmRequiredInputPorts ()
 Returns the number of non-optional input ports required by the algorithm. More...
vtkTypeUInt32 GetGlobalID () override
 Overridden to reserve additional IDs for use by "ExtractSelection" proxies. More...
void MarkDirty (vtkSMProxy *modifiedProxy) override
 Marks the selection proxies dirty as well as chain to superclass. More...
virtual int GetOutputPortsCreated ()
 Returns if the output port proxies have been created. More...
vtkSMDocumentation * GetOutputPortDocumentation (unsigned int index)
 It is possible to provide some documentation for each output port in the configuration xml. More...
vtkSMDocumentation * GetOutputPortDocumentation (const char *portname)
vtkPVDataInformation * GetDataInformation ()
 DataInformation is used by the source proxy to obtain information on the output(s) from the server. More...
vtkPVDataInformation * GetDataInformation (unsigned int outputIdx)
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, const char *selector, const char *assemblyName=nullptr)
 For composite datasets, GetDataInformation returns summary data information for all blocks combined. More...
vtkPVDataInformation * GetRankDataInformation (int rank)
 Get rank-specific data information. More...
vtkPVDataInformation * GetRankDataInformation (unsigned int outputIdx, int rank)
vtkSMSourceProxy * GetSelectionInput (unsigned int portIndex)
 API to query selection input set using SetSelectionInput. More...
unsigned int GetSelectionInputPort (unsigned int portIndex)
virtual int GetProcessSupport ()
 This returns information about whether the VTK algorithm supports multiple processes or not. More...
virtual bool GetMPIRequired ()
 This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMMultiplexerSourceProxy * New ()
static vtkSMMultiplexerSourceProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMSourceProxy
static vtkSMSourceProxy * New ()
static vtkSMSourceProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMMultiplexerSourceProxy ()
 ~vtkSMMultiplexerSourceProxy () override
int CreateSubProxiesAndProperties (vtkSMSessionProxyManager *pm, vtkPVXMLElement *element) override
int IsInDomain (vtkSMInputProperty *property)
void Select (vtkSMProxy *)
- Protected Member Functions inherited from vtkSMSourceProxy
 vtkSMSourceProxy ()
 ~vtkSMSourceProxy () override
virtual void InvalidateDataInformation ()
 Mark the data information as invalid. More...
 Call superclass' and then assigns a new executive (vtkCompositeDataPipeline) More...
virtual void SetExecutiveName (const char *)
void PostUpdateData (bool) override
 Overwritten from superclass to invoke. More...
void SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override
 Overridden to pass the logname to the internal ExtractSelection proxies. More...
void SetOutputPort (unsigned int index, const char *name, vtkSMOutputPort *port, vtkSMDocumentation *doc)
 Method to set an output port at the given index. More...
void RemoveAllOutputPorts ()
void SetExtractSelectionProxy (unsigned int index, vtkSMSourceProxy *proxy)
void RemoveAllExtractSelectionProxies ()
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
Friends
class vtkSMMultiplexerInputDomain
- Protected Attributes inherited from vtkSMSourceProxy
int OutputPortsCreated
int ProcessSupport
bool MPIRequired
char * ExecutiveName
bool DisableSelectionProxies
bool SelectionProxiesCreated
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
a multiplexer proxy
vtkSMMultiplexerSourceProxy is a multiplexer that can pick and act as one of the internal proxies (called multiplexed proxies). Once a choice is made, for all intents and purposes the multiplexer behaves like the chosen proxy.
For original motivation and design, refer to paraview/paraview#19936.
Defining a Multiplexer Proxy
A multiplexer proxy can be defined in the ServerManager XML configuration as follows:
<ProxyGroup name="filters">
<MultiplexerSourceProxy name="ExtractBlock" label="Extract Block">
<Documentation long_help="Extract blocks from composite datasets">
This filter extract blocks.
</Documentation>
<InputProperty name="Input">
<Documentation>
Specify the input to this filter.
</Documentation>
<MultiplexerInputDomain name="input" />
</InputProperty>
</MultiplexerSourceProxy>
It's similar to other proxy definitions, except a few key differences:
Defining proxies that should be included as the available multiplexed proxies is done by adding the <MultiplexerSourceProxy /> hint as follows:
<SourceProxy class="vtkExtractBlock"
name="ExtractBlockUsingIds">
<Documentation long_help="This filter extracts a range of blocks from a multiblock dataset."
short_help="Extract block.">This filter extracts a range
of groups from a multiblock dataset</Documentation>
<InputProperty name="Input" command="SetInputConnection">
<DataTypeDomain name="input_type">
<DataType value="vtkMultiBlockDataSet" />
</DataTypeDomain>
</InputProperty>
<Hints>
<MultiplexerSourceProxy proxygroup="filters" proxyname="ExtractBlock" >
<LinkProperties>
<Property name="Input" with_property="Input" />
</LinkProperties>
</Hints>
</SourceProxy>
The proxygroup and proxyname on the MultiplexerSourceProxy hint element refer to the group and name of the multiplexed proxy. If the proxy can be part of multiple multiplexers, then multiple MultiplexerSourceProxy elements can be added to the hints.
When a vtkSMMultiplexerSourceProxy is instantiated, it looks for all available proxy definitions that have a matching MultiplexerSourceProxy hint. The optional LinkProperties nested element defines how the properties on this proxy map to properties on the multiplexer proxy. If not specified, they are matched by name.
In vtkSMMultiplexerSourceProxy::CreateVTKObjects, based on the values set on the multiplexer's properties, one (or more) of the available multiplexed proxies are chosen and rest are discarded. Selecting a proxy implies that it will be added as subproxies, and its properties (those that are not linked with properties on the multiplexer) exposed from the multiplexer so that they are available for users to check and set.
The check to see if one of the available multiplexed proxy can be chosen is as follows: for each property on the multiplexed proxy that is linked with a property on the multiplexer, we copy the current value from the multiplexer property and then check if the value is in domain (vtkSMProperty::IsInDomains); if it succeeds for all linked properties, then that multiplexed property is chosen, else it's not and is discarded.
Current implementation is intended for at most 1 proxy to be chosen. If multiple proxies succeed at this test, current implementation only selects the first one.
Caveats
While the implementation has some initial plumbing to support multiple multiplexed proxies, currently we only support exactly one. In future, the plan is to add a user-settable property to choose between multiple proxies if multiple of them match.
When multiple proxies are chosen, we need to add a mechanism to share properties with same names between the chosen proxies since we cannot expose a property with same name multiple times.
Python Support
vtkSMMultiplexerSourceProxy currently suffers from lack of Python support. ParaView's Python infrastructure is not capable of supporting different instances of the same proxy with different set of properties. Consequently, do not use this unless you don't need Python support. See paraview/paraview#20187.
See also
vtkSIMultiplexerSourceProxy, vtkSMMultiplexerInputDomain.
Definition at line 132 of file vtkSMMultiplexerSourceProxy.h.
Definition at line 136 of file vtkSMMultiplexerSourceProxy.h.
◆ vtkSMMultiplexerSourceProxy()
vtkSMMultiplexerSourceProxy::vtkSMMultiplexerSourceProxy ( )
◆ ~vtkSMMultiplexerSourceProxy()
vtkSMMultiplexerSourceProxy::~vtkSMMultiplexerSourceProxy ( )
static vtkSMMultiplexerSourceProxy* vtkSMMultiplexerSourceProxy::New ( )
virtual const char* vtkSMMultiplexerSourceProxy::GetClassName ( )
Reimplemented from vtkSMSourceProxy.
static int vtkSMMultiplexerSourceProxy::IsTypeOf ( const char *  type)
virtual int vtkSMMultiplexerSourceProxy::IsA ( const char *  type)
static vtkSMMultiplexerSourceProxy* vtkSMMultiplexerSourceProxy::SafeDownCast ( vtkObject *  o)
void vtkSMMultiplexerSourceProxy::PrintSelf ( ostream &  os,
◆ SaveXMLState()
vtkPVXMLElement* vtkSMMultiplexerSourceProxy::SaveXMLState ( vtkPVXMLElement *  root,
vtkSMPropertyIterator *  iter
The iterator is use to filter the property available on the given proxy.
◆ LoadXMLState()
int vtkSMMultiplexerSourceProxy::LoadXMLState ( vtkPVXMLElement *  element,
vtkSMProxyLocator *  locator
Loads the proxy state from the XML element.
Returns 0 on failure. locator is used to locate other proxies that may be referred to in the state XML (which happens in case of properties of type vtkSMProxyProperty or subclasses). If locator is nullptr, then such properties are left unchanged.
◆ LoadState()
void vtkSMMultiplexerSourceProxy::LoadState ( const vtkSMMessage *  msg,
This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set.
This allow to split the load process in 2 step to prevent invalid state when property refere to a sub-proxy that does not exist yet.
Reimplemented from vtkSMRemoteObject.
◆ CreateVTKObjects()
void vtkSMMultiplexerSourceProxy::CreateVTKObjects ( )
overrideprotectedvirtual
Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s)
◆ CreateSubProxiesAndProperties()
int vtkSMMultiplexerSourceProxy::CreateSubProxiesAndProperties ( vtkSMSessionProxyManager *  pm,
◆ IsInDomain()
int vtkSMMultiplexerSourceProxy::IsInDomain ( vtkSMInputProperty *  property)
◆ Select()
void vtkSMMultiplexerSourceProxy::Select ( vtkSMProxy *  )
◆ vtkSMMultiplexerInputDomain
friend class vtkSMMultiplexerInputDomain
friend
Definition at line 159 of file vtkSMMultiplexerSourceProxy.h.
