vtkSMEnsembleDataReaderProxy Class Reference
#include <vtkSMEnsembleDataReaderProxy.h>
Inheritance diagram for vtkSMEnsembleDataReaderProxy:
Collaboration diagram for vtkSMEnsembleDataReaderProxy:
typedef vtkSMSourceProxy Superclass
- Public Types inherited from vtkSMSourceProxy
enum  ProcessSupportType { SINGLE_PROCESS, MULTIPLE_PROCESSES, BOTH }
typedef vtkSMProxy Superclass
void UpdateVTKObjects () override
- Public Member Functions inherited from vtkSMSourceProxy
void UpdatePipelineInformation () override
 Calls UpdateInformation() on all sources. More...
virtual void UpdatePipeline ()
 Calls Update() on all sources. More...
virtual void UpdatePipeline (double time)
 Calls Update() on all sources with the given time request. More...
virtual unsigned int GetNumberOfOutputPorts ()
 Return the number of output ports. More...
virtual vtkSMOutputPort * GetOutputPort (unsigned int idx)
 Return an output port. More...
virtual vtkSMOutputPort * GetOutputPort (const char *portname)
 Return an output port, given the name for the port. More...
virtual unsigned int GetOutputPortIndex (const char *portname)
 Returns the port index, given the name of an output port. More...
virtual const char * GetOutputPortName (unsigned int index)
 Returns the output port name given its index. More...
virtual void CreateOutputPorts ()
 Creates the output port proxies for this filter. More...
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, unsigned int compositeIndex)
 A GetSubsetDataInformation overload that uses composite index. More...
virtual void CreateSelectionProxies ()
 Creates extract selection proxies for each output port if not already created. More...
void SetSelectionInput (unsigned int portIndex, vtkSMSourceProxy *input, unsigned int outputPort)
 Set/Get the selection input. More...
void CleanSelectionInputs (unsigned int portIndex)
 Clean all selection inputs for the given port. More...
vtkSMSourceProxy * GetSelectionOutput (unsigned int portIndex)
 Returns the source proxy which provides the selected data from the given output port. More...
unsigned int GetNumberOfAlgorithmOutputPorts ()
 Returns the number of output ports provided by the algorithm. More...
virtual unsigned int GetNumberOfAlgorithmRequiredInputPorts ()
 Returns the number of non-optional input ports required by the algorithm. More...
vtkTypeUInt32 GetGlobalID () override
 Overridden to reserve additional IDs for use by "ExtractSelection" proxies. More...
void MarkDirty (vtkSMProxy *modifiedProxy) override
 Marks the selection proxies dirty as well as chain to superclass. More...
virtual int GetOutputPortsCreated ()
 Returns if the output port proxies have been created. More...
vtkSMDocumentation * GetOutputPortDocumentation (unsigned int index)
 It is possible to provide some documentation for each output port in the configuration xml. More...
vtkSMDocumentation * GetOutputPortDocumentation (const char *portname)
vtkPVDataInformation * GetDataInformation ()
 DataInformation is used by the source proxy to obtain information on the output(s) from the server. More...
vtkPVDataInformation * GetDataInformation (unsigned int outputIdx)
vtkPVDataInformation * GetSubsetDataInformation (unsigned int outputIdx, const char *selector, const char *assemblyName=nullptr)
 For composite datasets, GetDataInformation returns summary data information for all blocks combined. More...
vtkPVDataInformation * GetRankDataInformation (int rank)
 Get rank-specific data information. More...
vtkPVDataInformation * GetRankDataInformation (unsigned int outputIdx, int rank)
vtkSMSourceProxy * GetSelectionInput (unsigned int portIndex)
 API to query selection input set using SetSelectionInput. More...
unsigned int GetSelectionInputPort (unsigned int portIndex)
virtual int GetProcessSupport ()
 This returns information about whether the VTK algorithm supports multiple processes or not. More...
virtual bool GetMPIRequired ()
 This returns information about whether the VTK algorithm explicitly needs MPI to be initialized. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMEnsembleDataReaderProxy * SafeDownCast (vtkObject *o)
static vtkSMEnsembleDataReaderProxy * New ()
- Static Public Member Functions inherited from vtkSMSourceProxy
static vtkSMSourceProxy * New ()
static vtkSMSourceProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMEnsembleDataReaderProxy ()
 ~vtkSMEnsembleDataReaderProxy () override
void SetPropertyModifiedFlag (const char *name, int flag) override
- Protected Member Functions inherited from vtkSMSourceProxy
 vtkSMSourceProxy ()
 ~vtkSMSourceProxy () override
virtual void InvalidateDataInformation ()
 Mark the data information as invalid. More...
 Call superclass' and then assigns a new executive (vtkCompositeDataPipeline) More...
virtual void SetExecutiveName (const char *)
void PostUpdateData (bool) override
 Overwritten from superclass to invoke. More...
void SetLogNameInternal (const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override
 Overridden to pass the logname to the internal ExtractSelection proxies. More...
void SetOutputPort (unsigned int index, const char *name, vtkSMOutputPort *port, vtkSMDocumentation *doc)
 Method to set an output port at the given index. More...
void RemoveAllOutputPorts ()
void SetExtractSelectionProxy (unsigned int index, vtkSMSourceProxy *proxy)
void RemoveAllExtractSelectionProxies ()
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
bool FileNamePotentiallyModified
- Protected Attributes inherited from vtkSMSourceProxy
int OutputPortsCreated
int ProcessSupport
bool MPIRequired
char * ExecutiveName
bool DisableSelectionProxies
bool SelectionProxiesCreated
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Examines file paths found in ensemble data files (.pve) and creates readers that can read those files. Sets the correct reader for each file on the corresponding VTK object.
Definition at line 18 of file vtkSMEnsembleDataReaderProxy.h.
Definition at line 21 of file vtkSMEnsembleDataReaderProxy.h.
◆ vtkSMEnsembleDataReaderProxy()
vtkSMEnsembleDataReaderProxy::vtkSMEnsembleDataReaderProxy ( )
◆ ~vtkSMEnsembleDataReaderProxy()
vtkSMEnsembleDataReaderProxy::~vtkSMEnsembleDataReaderProxy ( )
virtual const char* vtkSMEnsembleDataReaderProxy::GetClassName ( )
Reimplemented from vtkSMSourceProxy.
static int vtkSMEnsembleDataReaderProxy::IsTypeOf ( const char *  type)
virtual int vtkSMEnsembleDataReaderProxy::IsA ( const char *  type)
static vtkSMEnsembleDataReaderProxy* vtkSMEnsembleDataReaderProxy::SafeDownCast ( vtkObject *  o)
void vtkSMEnsembleDataReaderProxy::PrintSelf ( ostream &  os,
static vtkSMEnsembleDataReaderProxy* vtkSMEnsembleDataReaderProxy::New ( )
◆ UpdateVTKObjects()
void vtkSMEnsembleDataReaderProxy::UpdateVTKObjects ( )
Update the VTK object on the server by pushing the values of all modified properties (un-modified properties are ignored).
If the object has not been created, it will be created first.
◆ SetPropertyModifiedFlag()
void vtkSMEnsembleDataReaderProxy::SetPropertyModifiedFlag ( const char *  name,
int  flag
overrideprotectedvirtual
Note on property modified flags: The modified flag of each property associated with a proxy is stored in the proxy object instead of in the property itself.
Here is a brief explanation of how modified flags are used:
  • 1. When a property is modified, the modified flag is set
  • 2. In UpdateVTKObjects(), the proxy visits all properties and calls AppendCommandToStream() on each modified property. It also resets the modified flag.
The reason why the modified flag is stored in the proxy instead of property is in item 2 above. If multiple proxies were sharing the same property, the first one would reset the modified flag in UpdateVTKObjects() and then others would not call AppendCommandToStream() in their turn. Therefore, each proxy has to keep track of all properties it updated. This is done by adding observers to the properties. When a property is modified, it invokes all observers and the observers set the appropriate flags in the proxies. Changes the modified flag of a property. Used by the observers
◆ FileNamePotentiallyModified
bool vtkSMEnsembleDataReaderProxy::FileNamePotentiallyModified
Definition at line 33 of file vtkSMEnsembleDataReaderProxy.h.
