vtkSMStringListDomain Class Reference
list of strings More...
#include <vtkSMStringListDomain.h>
Inheritance diagram for vtkSMStringListDomain:
Collaboration diagram for vtkSMStringListDomain:
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
int IsInDomain (vtkSMProperty *property) override
 Returns true if the value of the property is in the domain. More...
int IsInDomain (const char *string, unsigned int &idx)
 Returns true if the string is in the domain. More...
const char * GetString (unsigned int idx)
 Returns a string in the domain. More...
unsigned int GetNumberOfStrings ()
 Returns the number of strings in the domain. More...
void Update (vtkSMProperty *) override
 Update self checking the "unchecked" values of all required properties. More...
void SetAnimationValue (vtkSMProperty *, int, double) override
 Set the value of an element of a property from the animation editor. More...
virtual char * GetNoneString ()
 Return the string that is used as "none_string" in XML configuration. More...
virtual void SetNoneString (const char *)
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMStringListDomain * New ()
static vtkSMStringListDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
void ChildSaveState (vtkPVXMLElement *domainElement) override
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void SetStrings (const std::vector< std::string > &strings)
 Call to set the strings. More...
const std::vector< std::string > & GetStrings ()
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
char * NoneString
 Default string always present in this string list. More...
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
int SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override
 vtkSMStringListDomain ()
 ~vtkSMStringListDomain () override
list of strings
vtkSMStringListDomain represents a domain consisting of a list of strings. It only works with vtkSMStringVectorProperty.
Supported attributes:
Valid XML elements are:
* * <String value="">
See also
vtkSMDomain vtkSMStringVectorProperty
Definition at line 32 of file vtkSMStringListDomain.h.
Definition at line 36 of file vtkSMStringListDomain.h.
◆ vtkSMStringListDomain()
vtkSMStringListDomain::vtkSMStringListDomain ( )
However, many times, the default value must be determined at run time. To facilitate this, domains can override this method to compute and set the default value for the property. Note that unlike the compile-time default values, the application must explicitly call this method to initialize the property. Returns 1 if the domain updated the property.
◆ ~vtkSMStringListDomain()
vtkSMStringListDomain::~vtkSMStringListDomain ( )
static vtkSMStringListDomain* vtkSMStringListDomain::New ( )
virtual const char* vtkSMStringListDomain::GetClassName ( )
static int vtkSMStringListDomain::IsTypeOf ( const char *  type)
virtual int vtkSMStringListDomain::IsA ( const char *  type)
static vtkSMStringListDomain* vtkSMStringListDomain::SafeDownCast ( vtkObject *  o)
void vtkSMStringListDomain::PrintSelf ( ostream &  os,
◆ IsInDomain() [1/2]
int vtkSMStringListDomain::IsInDomain ( vtkSMProperty *  property)
override
The property has to be a vtkSMStringVectorProperty. If all vector values are in the domain, it returns 1. It returns 0 otherwise.
◆ IsInDomain() [2/2]
int vtkSMStringListDomain::IsInDomain ( const char *  string,
unsigned int &  idx
◆ GetString()
const char* vtkSMStringListDomain::GetString ( unsigned int  idx)
The pointer may become invalid once the domain has been modified.
◆ GetNumberOfStrings()
unsigned int vtkSMStringListDomain::GetNumberOfStrings ( )
◆ Update()
void vtkSMStringListDomain::Update ( vtkSMProperty *  )
Reimplemented in vtkSMChartSeriesSelectionDomain, vtkSMChartSeriesListDomain, vtkSMRepresentedArrayListDomain, vtkSMMaterialDomain, and vtkSMRendererDomain.
◆ SetAnimationValue()
void vtkSMStringListDomain::SetAnimationValue ( vtkSMProperty *  ,
int  ,
double
override
◆ GetNoneString()
virtual char* vtkSMStringListDomain::GetNoneString ( )
◆ SetNoneString()
virtual void vtkSMStringListDomain::SetNoneString ( const char *  )
◆ SetDefaultValues()
int vtkSMStringListDomain::SetDefaultValues ( vtkSMProperty *  ,
override
◆ ReadXMLAttributes()
int vtkSMStringListDomain::ReadXMLAttributes ( vtkSMProperty *  prop,
vtkPVXMLElement *  element
overrideprotectedvirtual
Reimplemented in vtkSMChartSeriesSelectionDomain, vtkSMChartSeriesListDomain, vtkSMMaterialDomain, vtkSMRendererDomain, and vtkSMRepresentedArrayListDomain.
◆ ChildSaveState()
void vtkSMStringListDomain::ChildSaveState ( vtkPVXMLElement *  domainElement)
The newly created element will also be added to the parent element as a child node. Subclasses can override ChildSaveState() method to fill it up with subclass specific values.
◆ SetStrings()
virtual void vtkSMStringListDomain::SetStrings ( const std::vector< std::string > &  strings)
protectedvirtual
Will fire DomainModifiedEvent if the domain values have indeed changed.
◆ GetStrings()
const std::vector<std::string>& vtkSMStringListDomain::GetStrings ( )
◆ NoneString
char* vtkSMStringListDomain::NoneString
When selected, it is equivalent with not selecting any string.
Definition at line 112 of file vtkSMStringListDomain.h.
