vtkSMStringVectorProperty Class Reference
property representing a vector of strings More...
#include <vtkSMStringVectorProperty.h>
Inheritance diagram for vtkSMStringVectorProperty:
Collaboration diagram for vtkSMStringVectorProperty:
enum  ElementTypes { INT, DOUBLE, STRING }
typedef vtkSMVectorProperty Superclass
- Public Types inherited from vtkSMVectorProperty
typedef vtkSMProperty Superclass
- Public Types inherited from vtkSMProperty
unsigned int GetNumberOfElements () override
 Returns the size of the vector. More...
void SetNumberOfElements (unsigned int num) override
 Sets the size of the vector. More...
int SetElement (unsigned int idx, const char *value)
 Set the value of 1 element. More...
int SetElements (const char *values[], unsigned int count)
 Sets multiple elements. More...
int AppendElements (const std::vector< std::string > &newvalue)
 Append the values. More...
int AppendUncheckedElements (const std::vector< std::string > &newvalue)
 Append the values to the unchecked elements. More...
void GetElements (vtkStringList *list)
 Fills up the vtkStringList instance with the current value. More...
const char * GetElement (unsigned int idx)
 Returns the value of 1 element. More...
unsigned int GetElementIndex (const char *value, int &exists)
 Returns the index of an element with a particular value. More...
const char * GetUncheckedElement (unsigned int idx)
 Returns the value of 1 unchecked element. More...
void SetUncheckedElement (unsigned int idx, const char *value)
 Set the value of 1 unchecked element. More...
unsigned int GetNumberOfUncheckedElements () override
 Returns the size of unchecked elements. More...
void Copy (vtkSMProperty *src) override
 Copy all property values. More...
const char * GetDefaultValue (int idx)
 Returns the default value, if any, specified in the XML. More...
void ClearUncheckedElements () override
 API for setting unchecked element values. More...
bool IsValueDefault () override
 Returns true if the property's value is different from the default value. More...
void ResetToXMLDefaults () override
 For properties that support specifying defaults in XML configuration, this method will reset the property value to the default values specified in the XML. More...
int SetElements (vtkStringList *newvalue)
int SetElements (const std::vector< std::string > &newvalue)
int SetUncheckedElements (const char *values[], unsigned int count)
 Sets the values of all the unchecked elements. More...
int SetUncheckedElements (const std::vector< std::string > &newvalue)
const std::vector< std::string > & GetElements () const
 Another API to access all elements. More...
const std::vector< std::string > & GetUncheckedElements () const
void SetElementType (unsigned int idx, int type)
 Set the cast type used when passing a value to the stream. More...
int GetElementType (unsigned int idx)
void GetUncheckedElements (vtkStringList *list)
 Get/Set unchecked elements. More...
int SetUncheckedElements (vtkStringList *list)
- Public Member Functions inherited from vtkSMVectorProperty
virtual void SetInitialString (const char *)
virtual char * GetInitialString ()
bool ResetToDomainDefaults (bool use_unchecked_values=false) override
 Overridden to add support to load defaults from this->GetInformationProperty(), if one exists. More...
virtual int GetRepeatCommand ()
 If RepeatCommand is true, the command is invoked multiple times, each time with NumberOfElementsPerCommand values. More...
virtual void SetRepeatCommand (int)
virtual void RepeatCommandOn ()
virtual void RepeatCommandOff ()
virtual int GetNumberOfElementsPerCommand ()
virtual void SetNumberOfElementsPerCommand (int)
virtual int GetUseIndex ()
 If UseIndex and RepeatCommand are true, the property will add an index integer before each command. More...
virtual void SetUseIndex (int)
virtual void UseIndexOn ()
virtual void UseIndexOff ()
virtual void SetCleanCommand (const char *)
 Command that can be used to remove all values. More...
virtual char * GetCleanCommand ()
virtual void SetSetNumberCommand (const char *)
 If SetNumberCommand is set, it is called before Command with the number of arguments as the parameter. More...
virtual char * GetSetNumberCommand ()
- Public Member Functions inherited from vtkSMProperty
int IsInDomains ()
 Returns true if all values are in all domains, false otherwise. More...
int IsInDomains (vtkSMDomain **domain)
 Overload of IsInDomains() that provides a mechanism to return the first domain that fails the check. More...
void UnRegister (vtkObjectBase *obj) override
 Overloaded to break the reference loop caused by the internal domain iterator. More...
vtkSMDomainIterator * NewDomainIterator ()
 Creates, initializes and returns a new domain iterator. More...
vtkSMDomain * GetDomain (const char *name)
 Returns a domain give a name. More...
vtkSMDomain * FindDomain (const char *classname)
 Returns the first domain which is of the specified type. More...
template<class DomainType >
DomainType * FindDomain ()
 Same as FindDomain(classname), except the classname is deduced from the type. More...
unsigned int GetNumberOfDomains ()
 Returns the number of domains this property has. More...
void AddDomain (const char *name, vtkSMDomain *dom)
 Properties can have one or more domains. More...
virtual void AddLinkedProperty (vtkSMProperty *targetProperty)
 Add a link to a property whose value should be synchronized with this property value. More...
virtual void RemoveLinkedProperty (vtkSMProperty *targetProperty)
 Remove a link to a property added with AddLinkedProperty() More...
virtual void RemoveFromSourceLink ()
 Remove a link from the source property. More...
void ResetToDefault ()
 Simply calls this->ResetToDomainDefaults() and if that returns false, calls this->ResetToXMLDefaults(). More...
vtkSMProxy * GetParent ()
 Get the proxy to which this property belongs. More...
virtual bool IsStateIgnored ()
bool HasDomainsWithRequiredProperties ()
 Returns true if the property has a domain with required properties. More...
 PARAVIEW_DEPRECATED_IN_5_12_0 ("Use vtkSMObject::CreatePrettyLabel(const std::string& name) instead.") static const char *CreateNewPrettyLabel(const char *name)
 Given the string, this method will create and set a well-formated string as XMLLabel and returns it. More...
virtual void SetCommand (const char *)
 The command name used to set the value on the server object. More...
virtual char * GetCommand ()
virtual void SetImmediateUpdate (int)
 If ImmediateUpdate is true, the value of the property will be pushed to the server as soon as it is modified. More...
virtual int GetImmediateUpdate ()
virtual int GetInformationOnly ()
 Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
virtual int GetIgnoreSynchronization ()
 If IgnoreSynchronization is set to true, this property is used to prevent that property from being updated when changed remotely by another collaborative client. More...
virtual vtkSMProperty * GetInformationProperty ()
 Get the associated information property. More...
virtual void SetAnimateable (int)
 Get/Set if the property is animateable. More...
virtual int GetAnimateable ()
virtual void SetIsInternal (int)
 Get/Set if the property is internal to server manager. More...
virtual int GetIsInternal ()
virtual void SetNoCustomDefault (int)
 Sets whether the property should ignore custom default settings. More...
virtual int GetNoCustomDefault ()
 Gets whether the property should ignore custom default settings. More...
virtual void SetPanelVisibility (const char *)
 Sets the panel visibility for the property. More...
virtual char * GetPanelVisibility ()
 Returns the panel visibility for the property. More...
virtual void SetPanelVisibilityDefaultForRepresentation (const char *)
 Sets the panel visibility to default if the current representation type matches representation. More...
virtual char * GetPanelVisibilityDefaultForRepresentation ()
 Returns which representation type the property will be shown by default for. More...
virtual void SetPanelWidget (const char *)
 Sets the name of the custom panel widget to use for the property. More...
virtual char * GetPanelWidget ()
 Returns name of the panel widget for the property. More...
virtual void SetDisableSubTrace (const char *)
 Sets the tracing of sub property of this property. More...
virtual char * GetDisableSubTrace ()
 Returns the tracing state of the properties of this property. More...
virtual char * GetXMLLabel ()
 The label assigned by the xml parser. More...
virtual char * GetXMLName ()
 The name assigned by the xml parser. More...
virtual int GetRepeatable ()
 If repeatable, a property can have 1 or more values of the same kind. More...
 The server manager configuration XML may define <Hints/> element for a property. More...
void Modified () override
 Overridden to support blocking of modified events. More...
static vtkSMStringVectorProperty * New ()
static vtkSMStringVectorProperty * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMVectorProperty
static vtkSMVectorProperty * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMProperty
static vtkSMProperty * New ()
static vtkSMProperty * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMStringVectorProperty ()
 ~vtkSMStringVectorProperty () override
void SetNumberOfUncheckedElements (unsigned int num) override
 Sets the size of unchecked elements. More...
int ReadXMLAttributes (vtkSMProxy *parent, vtkPVXMLElement *element) override
 Manage additional attribute from the XML -default_values_delimiter: char used to split the "default_values" into a vector. More...
void WriteTo (vtkSMMessage *) override
 Let the property write its content into the stream. More...
void ReadFrom (const vtkSMMessage *, int msg_offset, vtkSMProxyLocator *) override
 Let the property read and set its content from the stream. More...
int LoadState (vtkPVXMLElement *element, vtkSMProxyLocator *loader) override
 Load the XML state. More...
void SaveStateValues (vtkPVXMLElement *propElement) override
 This method must be overridden by concrete class in order to save the real property data. More...
- Protected Member Functions inherited from vtkSMVectorProperty
 vtkSMVectorProperty ()
 ~vtkSMVectorProperty () override
- Protected Member Functions inherited from vtkSMProperty
 vtkSMProperty ()
 ~vtkSMProperty () override
virtual void ReadFrom (const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *)
virtual void UpdateAllInputs ()
 Update all proxies referred by this property (if any). More...
 Internal. More...
void AddDependent (vtkSMDomain *dom)
 Internal. More...
void RemoveAllDependents ()
 Removes all dependents. More...
void UpdateDomains ()
 Calls Update() on all domains contained by the property as well as all dependent domains. More...
virtual void SaveState (vtkPVXMLElement *parent, const char *property_name, const char *uid, int saveDomains=1)
 Save the property state in XML. More...
virtual void SaveDomainState (vtkPVXMLElement *propertyElement, const char *uid)
 Save property domain. More...
virtual void SetInformationOnly (int)
virtual void SetIgnoreSynchronization (int)
void SetInformationProperty (vtkSMProperty *ip)
void SetDocumentation (vtkSMDocumentation *)
void SetParent (vtkSMProxy *proxy)
virtual void SetStateIgnored (bool)
virtual void StateIgnoredOn ()
virtual void StateIgnoredOff ()
bool SetBlockModifiedEvents (bool block)
 Block/unblock modified events, returns the current state of the block flag. More...
virtual bool GetPendingModifiedEvents ()
 Returns if any modified evetns are pending. More...
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMVectorProperty
int RepeatCommand
int NumberOfElementsPerCommand
int UseIndex
char * CleanCommand
char * SetNumberCommand
char * InitialString
- Protected Attributes inherited from vtkSMProperty
vtkPVXMLElement * Hints
char * Command
vtkSMPropertyInternals * PInternals
int ImmediateUpdate
int Animateable
int IsInternal
int NoCustomDefault
char * XMLName
char * XMLLabel
char * PanelVisibility
char * PanelVisibilityDefaultForRepresentation
char * PanelWidget
char * DisableSubTrace
vtkSMDomainIterator * DomainIterator
int InformationOnly
int IgnoreSynchronization
vtkSMInformationHelper * InformationHelper
vtkSMProperty * InformationProperty
int Repeatable
vtkWeakPointer< vtkSMProxy > Proxy
bool StateIgnored
vtkSMPropertyLink * Links
vtkSMStringVectorProperty is a concrete sub-class of vtkSMVectorProperty representing a vector of strings. vtkSMStringVectorProperty can also be used to store double and int values as strings. The strings are converted to the appropriate type when they are being passed to the stream. This is generally used for calling methods that have mixed type arguments.
See also
vtkSMVectorProperty vtkSMDoubleVectorProperty vtkSMIntVectorProperty
Definition at line 29 of file vtkSMStringVectorProperty.h.
Definition at line 33 of file vtkSMStringVectorProperty.h.
◆ ElementTypes
Enumerator
INT
DOUBLE
STRING
Definition at line 152 of file vtkSMStringVectorProperty.h.
◆ vtkSMStringVectorProperty()
vtkSMStringVectorProperty::vtkSMStringVectorProperty ( )
◆ ~vtkSMStringVectorProperty()
vtkSMStringVectorProperty::~vtkSMStringVectorProperty ( )
static vtkSMStringVectorProperty* vtkSMStringVectorProperty::New ( )
virtual const char* vtkSMStringVectorProperty::GetClassName ( )
Reimplemented from vtkSMVectorProperty.
static int vtkSMStringVectorProperty::IsTypeOf ( const char *  type)
virtual int vtkSMStringVectorProperty::IsA ( const char *  type)
static vtkSMStringVectorProperty* vtkSMStringVectorProperty::SafeDownCast ( vtkObject *  o)
void vtkSMStringVectorProperty::PrintSelf ( ostream &  os,
Reimplemented from vtkSMProperty.
◆ GetNumberOfElements()
unsigned int vtkSMStringVectorProperty::GetNumberOfElements ( )
Implements vtkSMVectorProperty.
◆ SetNumberOfElements()
void vtkSMStringVectorProperty::SetNumberOfElements ( unsigned int  num)
If num is larger than the current number of elements, this may cause reallocation and copying.
◆ SetElement()
int vtkSMStringVectorProperty::SetElement ( unsigned int  idx,
const char *  value
The vector is resized as necessary. Returns 0 if Set fails either because the property is read only or the value is not in all domains. Returns 1 otherwise.
◆ SetElements() [1/3]
int vtkSMStringVectorProperty::SetElements ( const char *  values[],
unsigned int  count
The size of the property is changed to match count.
◆ SetElements() [2/3]
int vtkSMStringVectorProperty::SetElements ( vtkStringList *  newvalue)
◆ SetElements() [3/3]
int vtkSMStringVectorProperty::SetElements ( const std::vector< std::string > &  newvalue)
◆ SetUncheckedElements() [1/3]
int vtkSMStringVectorProperty::SetUncheckedElements ( const char *  values[],
unsigned int  count
◆ SetUncheckedElements() [2/3]
int vtkSMStringVectorProperty::SetUncheckedElements ( const std::vector< std::string > &  newvalue)
◆ AppendElements()
int vtkSMStringVectorProperty::AppendElements ( const std::vector< std::string > &  newvalue)
Append the values.
◆ AppendUncheckedElements()
int vtkSMStringVectorProperty::AppendUncheckedElements ( const std::vector< std::string > &  newvalue)
◆ GetElements() [1/2]
void vtkSMStringVectorProperty::GetElements ( vtkStringList *  list)
◆ GetElements() [2/2]
const std::vector<std::string>& vtkSMStringVectorProperty::GetElements ( ) const
◆ GetUncheckedElements() [1/2]
const std::vector<std::string>& vtkSMStringVectorProperty::GetUncheckedElements ( ) const
◆ GetElement()
const char* vtkSMStringVectorProperty::GetElement ( unsigned int  idx)
◆ GetElementIndex()
unsigned int vtkSMStringVectorProperty::GetElementIndex ( const char *  value,
int &  exists
exists is set to false if element does not exist.
◆ SetElementType()
void vtkSMStringVectorProperty::SetElementType ( unsigned int  idx,
int  type
For example, if the type is INT, the string is converted to an int (with atoi()) before being passed to stream. Note that representing scalar values as strings can result in loss of accuracy. Possible values are: INT, DOUBLE, STRING.
◆ GetElementType()
int vtkSMStringVectorProperty::GetElementType ( unsigned int  idx)
◆ GetUncheckedElement()
const char* vtkSMStringVectorProperty::GetUncheckedElement ( unsigned int  idx)
These are used by domains. SetElement() first sets the value of 1 unchecked element and then calls IsInDomain and updates the value of the corresponding element only if IsInDomain passes.
◆ SetUncheckedElement()
void vtkSMStringVectorProperty::SetUncheckedElement ( unsigned int  idx,
const char *  value
This can be used to check if a value is in all domains of the property. Call this and call IsInDomains().
◆ GetUncheckedElements() [2/2]
void vtkSMStringVectorProperty::GetUncheckedElements ( vtkStringList *  list)
◆ SetUncheckedElements() [3/3]
int vtkSMStringVectorProperty::SetUncheckedElements ( vtkStringList *  list)
◆ GetNumberOfUncheckedElements()
unsigned int vtkSMStringVectorProperty::GetNumberOfUncheckedElements ( )
Usually this is the same as the number of elements but can be different before a domain check is performed.
◆ Copy()
void vtkSMStringVectorProperty::Copy ( vtkSMProperty *  src)
◆ GetDefaultValue()
const char* vtkSMStringVectorProperty::GetDefaultValue ( int  idx)
◆ ClearUncheckedElements()
void vtkSMStringVectorProperty::ClearUncheckedElements ( )
◆ IsValueDefault()
bool vtkSMStringVectorProperty::IsValueDefault ( )
◆ ResetToXMLDefaults()
void vtkSMStringVectorProperty::ResetToXMLDefaults ( )
◆ SetNumberOfUncheckedElements()
void vtkSMStringVectorProperty::SetNumberOfUncheckedElements ( unsigned int  num)
overrideprotectedvirtual
◆ ReadXMLAttributes()
int vtkSMStringVectorProperty::ReadXMLAttributes ( vtkSMProxy *  parent,
vtkPVXMLElement *  element
-element_types: StringVectorProperty may be used to store non homogeneous vector, therefore we store for each element its type. [INT, DOUBLE, STRING]
◆ WriteTo()
void vtkSMStringVectorProperty::WriteTo ( vtkSMMessage *  )
◆ ReadFrom()
void vtkSMStringVectorProperty::ReadFrom ( const vtkSMMessage *  ,
int  msg_offset,
vtkSMProxyLocator *
◆ LoadState()
int vtkSMStringVectorProperty::LoadState ( vtkPVXMLElement *  element,
vtkSMProxyLocator *  loader
Load the XML state.
◆ SaveStateValues()
void vtkSMStringVectorProperty::SaveStateValues ( vtkPVXMLElement *  propertyElement)
