vtkSMRepresentedArrayListDomain Class Reference
extends vtkSMArrayListDomain to add support for arrays from represented data information. More...
#include <vtkSMRepresentedArrayListDomain.h>
Inheritance diagram for vtkSMRepresentedArrayListDomain:
Collaboration diagram for vtkSMRepresentedArrayListDomain:
typedef vtkSMArrayListDomain Superclass
- Public Types inherited from vtkSMArrayListDomain
enum  InformationKeyStrategy { NEED_KEY, REJECT_KEY }
typedef vtkSMStringListDomain Superclass
- Public Types inherited from vtkSMStringListDomain
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
void Update (vtkSMProperty *) override
 Update the domain. More...
virtual bool GetUseTrueParentForRepresentatedDataInformation ()
 Set this to true (default) to let this domain use the represented-data-information from the outer most representation proxy. More...
- Public Member Functions inherited from vtkSMArrayListDomain
int IsArrayPartial (unsigned int idx)
 Returns true if the array with the given idx is partial false otherwise. More...
int GetFieldAssociation (unsigned int idx)
 Get field association for the array. More...
int GetDomainAssociation (unsigned int idx)
 Get the true field association for the array. More...
int SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override
 A vtkSMProperty is often defined with a default value in the XML itself. More...
unsigned int RemoveInformationKey (const char *location, const char *name)
 Removes an InformationKey from this domain. More...
unsigned int GetNumberOfInformationKeys ()
 Returns the number of InformationKeys in this domain. More...
void RemoveAllInformationKeys ()
 Removes all InformationKeys from this domain. More...
virtual int GetAttributeType ()
 Return the attribute type. More...
virtual unsigned int AddInformationKey (const char *location, const char *name, int strategy)
 Adds a new InformationKey to the domain. More...
virtual unsigned int AddInformationKey (const char *location, const char *name)
const char * GetInformationKeyLocation (unsigned int)
 Returns the location/name/strategy of a given InformationKey. More...
const char * GetInformationKeyName (unsigned int)
int GetInformationKeyStrategy (unsigned int)
- Public Member Functions inherited from vtkSMStringListDomain
int IsInDomain (vtkSMProperty *property) override
 Returns true if the value of the property is in the domain. More...
int IsInDomain (const char *string, unsigned int &idx)
 Returns true if the string is in the domain. More...
const char * GetString (unsigned int idx)
 Returns a string in the domain. More...
unsigned int GetNumberOfStrings ()
 Returns the number of strings in the domain. More...
void SetAnimationValue (vtkSMProperty *, int, double) override
 Set the value of an element of a property from the animation editor. More...
virtual char * GetNoneString ()
 Return the string that is used as "none_string" in XML configuration. More...
virtual void SetNoneString (const char *)
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMRepresentedArrayListDomain * New ()
static vtkSMRepresentedArrayListDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMArrayListDomain
static vtkSMArrayListDomain * New ()
static vtkSMArrayListDomain * SafeDownCast (vtkObject *o)
static std::string CreateMangledName (vtkPVArrayInformation *arrayInfo, int component)
 returns the mangled name for the component index that is passed in. More...
static std::string ArrayNameFromMangledName (const char *name)
static int ComponentIndexFromMangledName (vtkPVArrayInformation *info, const char *name)
- Static Public Member Functions inherited from vtkSMStringListDomain
static vtkSMStringListDomain * New ()
static vtkSMStringListDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMRepresentedArrayListDomain ()
 ~vtkSMRepresentedArrayListDomain () override
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) override
 Overridden to process "use_true_parent". More...
bool IsFilteredArray (vtkPVDataInformation *info, int association, const char *arrayName) override
 Returns true if an array should be filtered out based on its name or number of tuples (for field data arrays). More...
vtkPVDataInformation * GetExtraDataInformation () override
 HACK: Provides a temporary mechanism for subclasses to provide an "additional" vtkPVDataInformation instance to get available arrays list from. More...
void SetRepresentationProxy (vtkSMRepresentationProxy *)
void OnRepresentationDataUpdated ()
virtual void SetUseTrueParentForRepresentatedDataInformation (bool)
- Protected Member Functions inherited from vtkSMArrayListDomain
 vtkSMArrayListDomain ()
 ~vtkSMArrayListDomain () override
virtual char * GetInputDomainName ()
 InputDomainName refers to a input property domain that describes the type of array is needed by this property. More...
virtual void SetInputDomainName (const char *)
virtual void SetAttributeType (int)
 Set to an attribute type defined in vtkDataSetAttributes. More...
- Protected Member Functions inherited from vtkSMStringListDomain
void ChildSaveState (vtkPVXMLElement *domainElement) override
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void SetStrings (const std::vector< std::string > &strings)
 Call to set the strings. More...
const std::vector< std::string > & GetStrings ()
 vtkSMStringListDomain ()
 ~vtkSMStringListDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkWeakPointer< vtkSMRepresentationProxy > RepresentationProxy
unsigned long ObserverId
bool UseTrueParentForRepresentatedDataInformation
- Protected Attributes inherited from vtkSMArrayListDomain
char * InputDomainName
bool PickFirstAvailableArrayByDefault
int AttributeType
- Protected Attributes inherited from vtkSMStringListDomain
char * NoneString
 Default string always present in this string list. More...
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
Representations often add new arrays on top of the ones provided by the inputs to the representations. In that case, the domains for properties that allow users to pick one of those newly added arrays need to show those arrays e.g. "ColorArrayName" property of geometry representations. This domain extends vtkSMArrayListDomain to add arrays from represented data for representations. If the chosen attribute type is not present on the data, no array (or none_string if available) will be chosen.
Definition at line 26 of file vtkSMRepresentedArrayListDomain.h.
Definition at line 30 of file vtkSMRepresentedArrayListDomain.h.
◆ vtkSMRepresentedArrayListDomain()
vtkSMRepresentedArrayListDomain::vtkSMRepresentedArrayListDomain ( )
◆ ~vtkSMRepresentedArrayListDomain()
vtkSMRepresentedArrayListDomain::~vtkSMRepresentedArrayListDomain ( )
static vtkSMRepresentedArrayListDomain* vtkSMRepresentedArrayListDomain::New ( )
virtual const char* vtkSMRepresentedArrayListDomain::GetClassName ( )
Reimplemented from vtkSMArrayListDomain.
static int vtkSMRepresentedArrayListDomain::IsTypeOf ( const char *  type)
virtual int vtkSMRepresentedArrayListDomain::IsA ( const char *  type)
static vtkSMRepresentedArrayListDomain* vtkSMRepresentedArrayListDomain::SafeDownCast ( vtkObject *  o)
void vtkSMRepresentedArrayListDomain::PrintSelf ( ostream &  os,
◆ Update()
void vtkSMRepresentedArrayListDomain::Update ( vtkSMProperty *  )
Update the domain.
◆ GetUseTrueParentForRepresentatedDataInformation()
virtual bool vtkSMRepresentedArrayListDomain::GetUseTrueParentForRepresentatedDataInformation ( )
This ensures that for composite representations where user is provided with a selection between multiple representations, the represented array list domain fills its values up based on the currently active representation type, rather than the representation subproxy from which the property was exposed. In XML, use 'use_true_parent' attribute on the domain element to set this value.
◆ ReadXMLAttributes()
int vtkSMRepresentedArrayListDomain::ReadXMLAttributes ( vtkSMProperty *  prop,
vtkPVXMLElement *  elem
overrideprotectedvirtual
◆ IsFilteredArray()
bool vtkSMRepresentedArrayListDomain::IsFilteredArray ( vtkPVDataInformation *  info,
int  association,
const char *  arrayName
This implementation returns true if the array name matches an expression in the vtkPVColorArrayListSettings singleton.
◆ GetExtraDataInformation()
vtkPVDataInformation* vtkSMRepresentedArrayListDomain::GetExtraDataInformation ( )
◆ SetRepresentationProxy()
void vtkSMRepresentedArrayListDomain::SetRepresentationProxy ( vtkSMRepresentationProxy *  )
◆ OnRepresentationDataUpdated()
void vtkSMRepresentedArrayListDomain::OnRepresentationDataUpdated ( )
◆ SetUseTrueParentForRepresentatedDataInformation()
virtual void vtkSMRepresentedArrayListDomain::SetUseTrueParentForRepresentatedDataInformation ( bool  )
protectedvirtual
◆ RepresentationProxy
vtkWeakPointer<vtkSMRepresentationProxy> vtkSMRepresentedArrayListDomain::RepresentationProxy
Definition at line 80 of file vtkSMRepresentedArrayListDomain.h.
◆ ObserverId
unsigned long vtkSMRepresentedArrayListDomain::ObserverId
Definition at line 81 of file vtkSMRepresentedArrayListDomain.h.
◆ UseTrueParentForRepresentatedDataInformation
bool vtkSMRepresentedArrayListDomain::UseTrueParentForRepresentatedDataInformation
Definition at line 83 of file vtkSMRepresentedArrayListDomain.h.
