vtkSMDataAssemblyListDomain Class Reference
domain listing available assembly types in the input More...
#include <vtkSMDataAssemblyListDomain.h>
Inheritance diagram for vtkSMDataAssemblyListDomain:
Collaboration diagram for vtkSMDataAssemblyListDomain:
typedef vtkSMStringListDomain Superclass
- Public Types inherited from vtkSMStringListDomain
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
void Update (vtkSMProperty *requestingProperty) override
 Update self based on the "unchecked" values of all required properties. More...
int SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override
virtual void SetBackwardCompatibilityMode (bool)
 When set to true, the domain will use the old functionality setting the assembly default value. More...
virtual bool GetBackwardCompatibilityMode ()
virtual void BackwardCompatibilityModeOn ()
virtual void BackwardCompatibilityModeOff ()
- Public Member Functions inherited from vtkSMStringListDomain
int IsInDomain (vtkSMProperty *property) override
 Returns true if the value of the property is in the domain. More...
int IsInDomain (const char *string, unsigned int &idx)
 Returns true if the string is in the domain. More...
const char * GetString (unsigned int idx)
 Returns a string in the domain. More...
unsigned int GetNumberOfStrings ()
 Returns the number of strings in the domain. More...
void Update (vtkSMProperty *) override
 Update self checking the "unchecked" values of all required properties. More...
void SetAnimationValue (vtkSMProperty *, int, double) override
 Set the value of an element of a property from the animation editor. More...
virtual char * GetNoneString ()
 Return the string that is used as "none_string" in XML configuration. More...
virtual void SetNoneString (const char *)
 A vtkSMProperty is often defined with a default value in the XML itself. More...
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMDataAssemblyListDomain * New ()
static vtkSMDataAssemblyListDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMStringListDomain
static vtkSMStringListDomain * New ()
static vtkSMStringListDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMDataAssemblyListDomain ()
 ~vtkSMDataAssemblyListDomain () override
- Protected Member Functions inherited from vtkSMStringListDomain
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
void ChildSaveState (vtkPVXMLElement *domainElement) override
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void SetStrings (const std::vector< std::string > &strings)
 Call to set the strings. More...
const std::vector< std::string > & GetStrings ()
 vtkSMStringListDomain ()
 ~vtkSMStringListDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
bool BackwardCompatibilityMode = false
- Protected Attributes inherited from vtkSMStringListDomain
char * NoneString
 Default string always present in this string list. More...
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMDataAssemblyListDomain is a string-list domain subclass that populates the list with names of assemblies available in the input.
Example usage is as follows:
<SourceProxy ...>
<StringVectorProperty name="BlockAssembly"
command="SetSelectorAssembly"
number_of_elements="1">
<DataAssemblyListDomain name="data_assembly_list">
<RequiredProperties>
<Property function="Input" name="Input" />
</RequiredProperties>
</DataAssemblyListDomain>
</StringVectorProperty>
</SourceProxy>
Definition at line 33 of file vtkSMDataAssemblyListDomain.h.
Definition at line 37 of file vtkSMDataAssemblyListDomain.h.
◆ vtkSMDataAssemblyListDomain()
vtkSMDataAssemblyListDomain::vtkSMDataAssemblyListDomain ( )
◆ ~vtkSMDataAssemblyListDomain()
vtkSMDataAssemblyListDomain::~vtkSMDataAssemblyListDomain ( )
static vtkSMDataAssemblyListDomain* vtkSMDataAssemblyListDomain::New ( )
virtual const char* vtkSMDataAssemblyListDomain::GetClassName ( )
Reimplemented from vtkSMStringListDomain.
static int vtkSMDataAssemblyListDomain::IsTypeOf ( const char *  type)
virtual int vtkSMDataAssemblyListDomain::IsA ( const char *  type)
static vtkSMDataAssemblyListDomain* vtkSMDataAssemblyListDomain::SafeDownCast ( vtkObject *  o)
void vtkSMDataAssemblyListDomain::PrintSelf ( ostream &  os,
◆ Update()
void vtkSMDataAssemblyListDomain::Update ( vtkSMProperty *  requestingProperty)
Subclasses must override this method to update the domain based on the requestingProperty (and/or other required properties).
◆ SetDefaultValues()
int vtkSMDataAssemblyListDomain::SetDefaultValues ( vtkSMProperty *  ,
override
◆ SetBackwardCompatibilityMode()
virtual void vtkSMDataAssemblyListDomain::SetBackwardCompatibilityMode ( bool  )
This is useful for backwards compatibility.
◆ GetBackwardCompatibilityMode()
virtual bool vtkSMDataAssemblyListDomain::GetBackwardCompatibilityMode ( )
◆ BackwardCompatibilityModeOn()
virtual void vtkSMDataAssemblyListDomain::BackwardCompatibilityModeOn ( )
◆ BackwardCompatibilityModeOff()
virtual void vtkSMDataAssemblyListDomain::BackwardCompatibilityModeOff ( )
bool vtkSMDataAssemblyListDomain::BackwardCompatibilityMode = false
Definition at line 58 of file vtkSMDataAssemblyListDomain.h.
