Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
vtkSMArraySelectionDomain Class Reference
used on properties that allow users to select arrays. More...
#include <vtkSMArraySelectionDomain.h>
Inheritance diagram for vtkSMArraySelectionDomain:
Collaboration diagram for vtkSMArraySelectionDomain:
typedef vtkSMStringListDomain Superclass
- Public Types inherited from vtkSMStringListDomain
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
int SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override
 Since this domain relies on an information only property to get the default status, we override this method to copy the values the info property as the default array selection. More...
- Public Member Functions inherited from vtkSMStringListDomain
int IsInDomain (vtkSMProperty *property) override
 Returns true if the value of the property is in the domain. More...
int IsInDomain (const char *string, unsigned int &idx)
 Returns true if the string is in the domain. More...
const char * GetString (unsigned int idx)
 Returns a string in the domain. More...
unsigned int GetNumberOfStrings ()
 Returns the number of strings in the domain. More...
void Update (vtkSMProperty *) override
 Update self checking the "unchecked" values of all required properties. More...
void SetAnimationValue (vtkSMProperty *, int, double) override
 Set the value of an element of a property from the animation editor. More...
virtual char * GetNoneString ()
 Return the string that is used as "none_string" in XML configuration. More...
virtual void SetNoneString (const char *)
 A vtkSMProperty is often defined with a default value in the XML itself. More...
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMArraySelectionDomain * New ()
static vtkSMArraySelectionDomain * SafeDownCast (vtkObject *o)
static void SetLoadAllVariables (bool choice)
 Global flag to toggle between (a) the default behavior of setting default values according to infoProperty and (b) setting all default values to on. More...
static bool GetLoadAllVariables ()
- Static Public Member Functions inherited from vtkSMStringListDomain
static vtkSMStringListDomain * New ()
static vtkSMStringListDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMArraySelectionDomain ()
 ~vtkSMArraySelectionDomain () override
- Protected Member Functions inherited from vtkSMStringListDomain
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
void ChildSaveState (vtkPVXMLElement *domainElement) override
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void SetStrings (const std::vector< std::string > &strings)
 Call to set the strings. More...
const std::vector< std::string > & GetStrings ()
 vtkSMStringListDomain ()
 ~vtkSMStringListDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
static bool LoadAllVariables
- Protected Attributes inherited from vtkSMStringListDomain
char * NoneString
 Default string always present in this string list. More...
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMArraySelectionDomain is a domain that can be for used for properties that allow users to set selection-statuses for multiple arrays (or similar items). This is similar to vtkSMArrayListDomain, the only different is that vtkSMArrayListDomain is designed to work with data-information obtained from the required Input property, while vtkSMArraySelectionDomain depends on a required information-only property ("ArrayList") that provides the arrays available.
Supported Required-Property functions:
Definition at line 27 of file vtkSMArraySelectionDomain.h.
Definition at line 31 of file vtkSMArraySelectionDomain.h.
◆ vtkSMArraySelectionDomain()
vtkSMArraySelectionDomain::vtkSMArraySelectionDomain ( )
◆ ~vtkSMArraySelectionDomain()
vtkSMArraySelectionDomain::~vtkSMArraySelectionDomain ( )
static vtkSMArraySelectionDomain* vtkSMArraySelectionDomain::New ( )
virtual const char* vtkSMArraySelectionDomain::GetClassName ( )
Reimplemented from vtkSMStringListDomain.
static int vtkSMArraySelectionDomain::IsTypeOf ( const char *  type)
virtual int vtkSMArraySelectionDomain::IsA ( const char *  type)
static vtkSMArraySelectionDomain* vtkSMArraySelectionDomain::SafeDownCast ( vtkObject *  o)
void vtkSMArraySelectionDomain::PrintSelf ( ostream &  os,
◆ SetDefaultValues()
int vtkSMArraySelectionDomain::SetDefaultValues ( vtkSMProperty *  ,
override
◆ SetLoadAllVariables()
static void vtkSMArraySelectionDomain::SetLoadAllVariables ( bool  choice)
inlinestatic
Definition at line 45 of file vtkSMArraySelectionDomain.h.
◆ GetLoadAllVariables()
static bool vtkSMArraySelectionDomain::GetLoadAllVariables ( )
inlinestatic
Definition at line 49 of file vtkSMArraySelectionDomain.h.
◆ LoadAllVariables
bool vtkSMArraySelectionDomain::LoadAllVariables
staticprotected
Definition at line 55 of file vtkSMArraySelectionDomain.h.
