vtkSMInputFileNameDomain Class Reference
a string domain that can be set automatically with the source file name More...
#include <vtkSMInputFileNameDomain.h>
Inheritance diagram for vtkSMInputFileNameDomain:
Collaboration diagram for vtkSMInputFileNameDomain:
typedef vtkSMStringListDomain Superclass
- Public Types inherited from vtkSMStringListDomain
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
void Update (vtkSMProperty *) override
 Update self based on the "unchecked" values of all required properties. More...
virtual std::string GetFileName ()
int SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override
 This method is over-written to automatically update the default filename at run time. More...
- Public Member Functions inherited from vtkSMStringListDomain
int IsInDomain (vtkSMProperty *property) override
 Returns true if the value of the property is in the domain. More...
int IsInDomain (const char *string, unsigned int &idx)
 Returns true if the string is in the domain. More...
const char * GetString (unsigned int idx)
 Returns a string in the domain. More...
unsigned int GetNumberOfStrings ()
 Returns the number of strings in the domain. More...
 Update self checking the "unchecked" values of all required properties. More...
void SetAnimationValue (vtkSMProperty *, int, double) override
 Set the value of an element of a property from the animation editor. More...
virtual char * GetNoneString ()
 Return the string that is used as "none_string" in XML configuration. More...
virtual void SetNoneString (const char *)
 A vtkSMProperty is often defined with a default value in the XML itself. More...
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMInputFileNameDomain * New ()
static vtkSMInputFileNameDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMStringListDomain
static vtkSMStringListDomain * New ()
static vtkSMStringListDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMInputFileNameDomain ()
 ~vtkSMInputFileNameDomain () override
- Protected Member Functions inherited from vtkSMStringListDomain
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
void ChildSaveState (vtkPVXMLElement *domainElement) override
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void SetStrings (const std::vector< std::string > &strings)
 Call to set the strings. More...
const std::vector< std::string > & GetStrings ()
 vtkSMStringListDomain ()
 ~vtkSMStringListDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMStringListDomain
char * NoneString
 Default string always present in this string list. More...
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMInputFileNameDomain does not really restrict the values of the property that contains it. All string values are valid. Rather, it is used to annotate a pipeline with the source name. This domain works with only vtkSMStringVectorProperty.
See also
vtkSMDomain vtkSMStringVectorProperty
Definition at line 22 of file vtkSMInputFileNameDomain.h.
Definition at line 26 of file vtkSMInputFileNameDomain.h.
◆ vtkSMInputFileNameDomain()
vtkSMInputFileNameDomain::vtkSMInputFileNameDomain ( )
◆ ~vtkSMInputFileNameDomain()
vtkSMInputFileNameDomain::~vtkSMInputFileNameDomain ( )
static vtkSMInputFileNameDomain* vtkSMInputFileNameDomain::New ( )
virtual const char* vtkSMInputFileNameDomain::GetClassName ( )
Reimplemented from vtkSMStringListDomain.
static int vtkSMInputFileNameDomain::IsTypeOf ( const char *  type)
virtual int vtkSMInputFileNameDomain::IsA ( const char *  type)
static vtkSMInputFileNameDomain* vtkSMInputFileNameDomain::SafeDownCast ( vtkObject *  o)
void vtkSMInputFileNameDomain::PrintSelf ( ostream &  os,
◆ Update()
void vtkSMInputFileNameDomain::Update ( vtkSMProperty *  requestingProperty)
Subclasses must override this method to update the domain based on the requestingProperty (and/or other required properties).
◆ GetFileName()
virtual std::string vtkSMInputFileNameDomain::GetFileName ( )
◆ SetDefaultValues()
int vtkSMInputFileNameDomain::SetDefaultValues ( vtkSMProperty *  ,
override
The default filename depends on the filename of the source. Returns 1 if the domain updated the property.
