vtkSMMaterialDomain Class Reference
Manages the list of OSPRay materials choosable to draw with. More...
#include <vtkSMMaterialDomain.h>
Inheritance diagram for vtkSMMaterialDomain:
Collaboration diagram for vtkSMMaterialDomain:
typedef vtkSMStringListDomain Superclass
- Public Types inherited from vtkSMStringListDomain
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
void Update (vtkSMProperty *) override
 Overridden to get list of materials from materiallibrary singleton. More...
- Public Member Functions inherited from vtkSMStringListDomain
int IsInDomain (vtkSMProperty *property) override
 Returns true if the value of the property is in the domain. More...
int IsInDomain (const char *string, unsigned int &idx)
 Returns true if the string is in the domain. More...
const char * GetString (unsigned int idx)
 Returns a string in the domain. More...
unsigned int GetNumberOfStrings ()
 Returns the number of strings in the domain. More...
void SetAnimationValue (vtkSMProperty *, int, double) override
 Set the value of an element of a property from the animation editor. More...
virtual char * GetNoneString ()
 Return the string that is used as "none_string" in XML configuration. More...
virtual void SetNoneString (const char *)
int SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override
 A vtkSMProperty is often defined with a default value in the XML itself. More...
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMMaterialDomain * New ()
static vtkSMMaterialDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMStringListDomain
static vtkSMStringListDomain * New ()
static vtkSMStringListDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMMaterialDomain ()
 ~vtkSMMaterialDomain () override
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
void CallMeSometime ()
- Protected Member Functions inherited from vtkSMStringListDomain
void ChildSaveState (vtkPVXMLElement *domainElement) override
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void SetStrings (const std::vector< std::string > &strings)
 Call to set the strings. More...
const std::vector< std::string > & GetStrings ()
 vtkSMStringListDomain ()
 ~vtkSMStringListDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
vtkSMMaterialObserver * Observer
- Protected Attributes inherited from vtkSMStringListDomain
char * NoneString
 Default string always present in this string list. More...
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
Friends
class vtkSMMaterialObserver
This class is a link between the global MaterialLibrary and the choices available on the display section of the Property Panel. When ParaView has no materials loaded, the list is simply "None" and not useable. When materials are loaded, the list lets the user pick None, any one for whole actor colors, or 'Value Indexed' which says that each block and cell gets to make its own choice via the indexed lookup table annotation names.
Definition at line 24 of file vtkSMMaterialDomain.h.
Definition at line 28 of file vtkSMMaterialDomain.h.
◆ vtkSMMaterialDomain()
vtkSMMaterialDomain::vtkSMMaterialDomain ( )
◆ ~vtkSMMaterialDomain()
vtkSMMaterialDomain::~vtkSMMaterialDomain ( )
static vtkSMMaterialDomain* vtkSMMaterialDomain::New ( )
virtual const char* vtkSMMaterialDomain::GetClassName ( )
Reimplemented from vtkSMStringListDomain.
static int vtkSMMaterialDomain::IsTypeOf ( const char *  type)
virtual int vtkSMMaterialDomain::IsA ( const char *  type)
static vtkSMMaterialDomain* vtkSMMaterialDomain::SafeDownCast ( vtkObject *  o)
void vtkSMMaterialDomain::PrintSelf ( ostream &  os,
◆ Update()
void vtkSMMaterialDomain::Update ( vtkSMProperty *  )
◆ ReadXMLAttributes()
int vtkSMMaterialDomain::ReadXMLAttributes ( vtkSMProperty *  prop,
vtkPVXMLElement *  element
overrideprotectedvirtual
◆ CallMeSometime()
void vtkSMMaterialDomain::CallMeSometime ( )
◆ vtkSMMaterialObserver
friend class vtkSMMaterialObserver
friend
Definition at line 43 of file vtkSMMaterialDomain.h.
◆ Observer
vtkSMMaterialObserver* vtkSMMaterialDomain::Observer
Definition at line 44 of file vtkSMMaterialDomain.h.
