vtkSMArrayListDomain Class Reference
list of arrays obtained from input More...
#include <vtkSMArrayListDomain.h>
Inheritance diagram for vtkSMArrayListDomain:
Collaboration diagram for vtkSMArrayListDomain:
enum  InformationKeyStrategy { NEED_KEY, REJECT_KEY }
typedef vtkSMStringListDomain Superclass
- Public Types inherited from vtkSMStringListDomain
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
void Update (vtkSMProperty *prop) override
 Updates the string list based on the available arrays. More...
int IsArrayPartial (unsigned int idx)
 Returns true if the array with the given idx is partial false otherwise. More...
int GetFieldAssociation (unsigned int idx)
 Get field association for the array. More...
int GetDomainAssociation (unsigned int idx)
 Get the true field association for the array. More...
int SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override
 A vtkSMProperty is often defined with a default value in the XML itself. More...
unsigned int RemoveInformationKey (const char *location, const char *name)
 Removes an InformationKey from this domain. More...
unsigned int GetNumberOfInformationKeys ()
 Returns the number of InformationKeys in this domain. More...
void RemoveAllInformationKeys ()
 Removes all InformationKeys from this domain. More...
virtual int GetAttributeType ()
 Return the attribute type. More...
virtual unsigned int AddInformationKey (const char *location, const char *name, int strategy)
 Adds a new InformationKey to the domain. More...
virtual unsigned int AddInformationKey (const char *location, const char *name)
const char * GetInformationKeyLocation (unsigned int)
 Returns the location/name/strategy of a given InformationKey. More...
const char * GetInformationKeyName (unsigned int)
int GetInformationKeyStrategy (unsigned int)
- Public Member Functions inherited from vtkSMStringListDomain
int IsInDomain (vtkSMProperty *property) override
 Returns true if the value of the property is in the domain. More...
int IsInDomain (const char *string, unsigned int &idx)
 Returns true if the string is in the domain. More...
const char * GetString (unsigned int idx)
 Returns a string in the domain. More...
unsigned int GetNumberOfStrings ()
 Returns the number of strings in the domain. More...
void Update (vtkSMProperty *) override
 Update self checking the "unchecked" values of all required properties. More...
void SetAnimationValue (vtkSMProperty *, int, double) override
 Set the value of an element of a property from the animation editor. More...
virtual char * GetNoneString ()
 Return the string that is used as "none_string" in XML configuration. More...
virtual void SetNoneString (const char *)
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMArrayListDomain * New ()
static vtkSMArrayListDomain * SafeDownCast (vtkObject *o)
static std::string CreateMangledName (vtkPVArrayInformation *arrayInfo, int component)
 returns the mangled name for the component index that is passed in. More...
static std::string ArrayNameFromMangledName (const char *name)
static int ComponentIndexFromMangledName (vtkPVArrayInformation *info, const char *name)
- Static Public Member Functions inherited from vtkSMStringListDomain
static vtkSMStringListDomain * New ()
static vtkSMStringListDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMArrayListDomain ()
 ~vtkSMArrayListDomain () override
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
virtual vtkPVDataInformation * GetExtraDataInformation ()
 HACK: Provides a temporary mechanism for subclasses to provide an "additional" vtkPVDataInformation instance to get available arrays list from. More...
virtual bool IsFilteredArray (vtkPVDataInformation *info, int association, const char *arrayName)
 Returns true if an array should be filtered out. More...
virtual char * GetInputDomainName ()
 InputDomainName refers to a input property domain that describes the type of array is needed by this property. More...
virtual void SetInputDomainName (const char *)
- Protected Member Functions inherited from vtkSMStringListDomain
void ChildSaveState (vtkPVXMLElement *domainElement) override
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void SetStrings (const std::vector< std::string > &strings)
 Call to set the strings. More...
const std::vector< std::string > & GetStrings ()
 vtkSMStringListDomain ()
 ~vtkSMStringListDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
char * InputDomainName
bool PickFirstAvailableArrayByDefault
- Protected Attributes inherited from vtkSMStringListDomain
char * NoneString
 Default string always present in this string list. More...
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
Friends
class vtkSMArrayListDomainInternals
int AttributeType
 Set to an attribute type defined in vtkDataSetAttributes. More...
virtual void SetAttributeType (int)
vtkSMArrayListDomain is used on vtkSMStringVectorProperty when the values on the property correspond to data arrays in the input.
Supported Required Property Functions:
Supported XML attributes:
Definition at line 79 of file vtkSMArrayListDomain.h.
Definition at line 83 of file vtkSMArrayListDomain.h.
◆ InformationKeyStrategy
Enumerator
NEED_KEY
REJECT_KEY
Definition at line 154 of file vtkSMArrayListDomain.h.
◆ vtkSMArrayListDomain()
vtkSMArrayListDomain::vtkSMArrayListDomain ( )
◆ ~vtkSMArrayListDomain()
vtkSMArrayListDomain::~vtkSMArrayListDomain ( )
static vtkSMArrayListDomain* vtkSMArrayListDomain::New ( )
virtual const char* vtkSMArrayListDomain::GetClassName ( )
Reimplemented from vtkSMStringListDomain.
Reimplemented in vtkSMRepresentedArrayListDomain.
static int vtkSMArrayListDomain::IsTypeOf ( const char *  type)
virtual int vtkSMArrayListDomain::IsA ( const char *  type)
static vtkSMArrayListDomain* vtkSMArrayListDomain::SafeDownCast ( vtkObject *  o)
void vtkSMArrayListDomain::PrintSelf ( ostream &  os,
◆ Update()
void vtkSMArrayListDomain::Update ( vtkSMProperty *  prop)
Requires a property of class vtkSMProxyProperty which points to a vtkSMSourceProxy and contains a vtkSMInputArrayDomain. Only the first proxy and domain are used.
◆ IsArrayPartial()
int vtkSMArrayListDomain::IsArrayPartial ( unsigned int  idx)
See vtkPVArrayInformation for more information.
◆ GetFieldAssociation()
int vtkSMArrayListDomain::GetFieldAssociation ( unsigned int  idx)
When vtkSMInputArrayDomain::AutomaticPropertyConversion is ON, this is not the true association for a particular array, but what the target filter is expecting. Thus use this to set the value on the property. To correctly show icons in UI, use GetDomainAssociation().
◆ GetDomainAssociation()
int vtkSMArrayListDomain::GetDomainAssociation ( unsigned int  idx)
This is same as GetFieldAssociation() except when vtkSMInputArrayDomain::AutomaticPropertyConversion is ON. In that case, this may be different. e.g. let's say Pressure is a point array on the input, however this filter only works with cell array. In that case, since AutomaticPropertyConversion is ON, vtkPVPostFilter is going to automatically convert the point array Pressure to a cell array for the filter. Now in this case, the SetInputArrayToProcess property on the filter must be set to ask a "cell" array named Pressure, despite the fact that there's no such cell array. And the UI needs to show the "Pressure" as a point array, since that's what the user is expecting. In this case, GetFieldAssociation() is going to return "CELL" for the "Pressure", while GetDomainAssociation() is going to return "POINT". Thus, use GetFieldAssociation() for setting the property value, but use GetDomainAssociation() for the icon.
◆ GetAttributeType()
virtual int vtkSMArrayListDomain::GetAttributeType ( )
The values are listed in vtkDataSetAttributes.h.
◆ SetDefaultValues()
int vtkSMArrayListDomain::SetDefaultValues ( vtkSMProperty *  ,
override
However, many times, the default value must be determined at run time. To facilitate this, domains can override this method to compute and set the default value for the property. Note that unlike the compile-time default values, the application must explicitly call this method to initialize the property. Returns 1 if the domain updated the property.
◆ AddInformationKey() [1/2]
virtual unsigned int vtkSMArrayListDomain::AddInformationKey ( const char *  location,
const char *  name,
int  strategy
The default strategy is NEED_KEY if none is specified. If no InformationKey is specified in the xml, the default behavior is to create a rejected key vtkAbstractArray::GUI_HIDE
◆ AddInformationKey() [2/2]
const char *  name
inlinevirtual
Definition at line 168 of file vtkSMArrayListDomain.h.
◆ RemoveInformationKey()
unsigned int vtkSMArrayListDomain::RemoveInformationKey ( const char *  location,
const char *  name
◆ GetNumberOfInformationKeys()
unsigned int vtkSMArrayListDomain::GetNumberOfInformationKeys ( )
◆ RemoveAllInformationKeys()
void vtkSMArrayListDomain::RemoveAllInformationKeys ( )
◆ GetInformationKeyLocation()
const char* vtkSMArrayListDomain::GetInformationKeyLocation ( unsigned int  )
◆ GetInformationKeyName()
const char* vtkSMArrayListDomain::GetInformationKeyName ( unsigned int  )
◆ GetInformationKeyStrategy()
int vtkSMArrayListDomain::GetInformationKeyStrategy ( unsigned int  )
◆ CreateMangledName()
static std::string vtkSMArrayListDomain::CreateMangledName ( vtkPVArrayInformation *  arrayInfo,
int  component
◆ ArrayNameFromMangledName()
static std::string vtkSMArrayListDomain::ArrayNameFromMangledName ( const char *  name)
◆ ComponentIndexFromMangledName()
static int vtkSMArrayListDomain::ComponentIndexFromMangledName ( vtkPVArrayInformation *  info,
const char *  name
◆ ReadXMLAttributes()
int vtkSMArrayListDomain::ReadXMLAttributes ( vtkSMProperty *  prop,
vtkPVXMLElement *  element
overrideprotectedvirtual
◆ GetExtraDataInformation()
virtual vtkPVDataInformation* vtkSMArrayListDomain::GetExtraDataInformation ( )
inlineprotectedvirtual
Definition at line 228 of file vtkSMArrayListDomain.h.
◆ IsFilteredArray()
virtual bool vtkSMArrayListDomain::IsFilteredArray ( vtkPVDataInformation *  info,
int  association,
const char *  arrayName
protectedvirtual
This is typically used to filter out arrays based on their names by subclasses. This implementation always returns false, but subclasses may override.
◆ SetAttributeType()
virtual void vtkSMArrayListDomain::SetAttributeType ( int  )
protectedvirtual
◆ GetInputDomainName()
virtual char* vtkSMArrayListDomain::GetInputDomainName ( )
protectedvirtual
◆ SetInputDomainName()
virtual void vtkSMArrayListDomain::SetInputDomainName ( const char *  )
protectedvirtual
◆ vtkSMArrayListDomainInternals
friend class vtkSMArrayListDomainInternals
friend
Definition at line 265 of file vtkSMArrayListDomain.h.
◆ AttributeType
int vtkSMArrayListDomain::AttributeType
Definition at line 241 of file vtkSMArrayListDomain.h.
◆ InputDomainName
char* vtkSMArrayListDomain::InputDomainName
Definition at line 251 of file vtkSMArrayListDomain.h.
◆ PickFirstAvailableArrayByDefault
bool vtkSMArrayListDomain::PickFirstAvailableArrayByDefault
Definition at line 259 of file vtkSMArrayListDomain.h.
