vtkSMChartSeriesListDomain Class Reference
list of strings corresponding to the names of the arrays in the required input dataset that can be used as a series in a chart. More...
#include <vtkSMChartSeriesListDomain.h>
Inheritance diagram for vtkSMChartSeriesListDomain:
Collaboration diagram for vtkSMChartSeriesListDomain:
typedef vtkSMStringListDomain Superclass
- Public Types inherited from vtkSMStringListDomain
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
void Update (vtkSMProperty *) override
 Update self checking the "unchecked" values of all required properties. More...
int SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override
 Set the default values for the property. More...
 PARAVIEW_DEPRECATED_IN_5_12_0 ("See vtkPVRepresentedArrayListSettings::GetAllChartsDefaultXAxis instead") static const char **GetKnownSeriesNames()
 Returns the list of series that are know to this domain are are given a priority when setting default values. More...
- Public Member Functions inherited from vtkSMStringListDomain
int IsInDomain (vtkSMProperty *property) override
 Returns true if the value of the property is in the domain. More...
int IsInDomain (const char *string, unsigned int &idx)
 Returns true if the string is in the domain. More...
const char * GetString (unsigned int idx)
 Returns a string in the domain. More...
unsigned int GetNumberOfStrings ()
 Returns the number of strings in the domain. More...
void SetAnimationValue (vtkSMProperty *, int, double) override
 Set the value of an element of a property from the animation editor. More...
virtual char * GetNoneString ()
 Return the string that is used as "none_string" in XML configuration. More...
virtual void SetNoneString (const char *)
 A vtkSMProperty is often defined with a default value in the XML itself. More...
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMChartSeriesListDomain * New ()
static vtkSMChartSeriesListDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMStringListDomain
static vtkSMStringListDomain * New ()
static vtkSMStringListDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMChartSeriesListDomain ()
 ~vtkSMChartSeriesListDomain () override
vtkPVDataInformation * GetInputInformation ()
 Returns the datainformation from the current input, if possible. More...
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
virtual void PopulateArrayComponents (vtkPVArrayInformation *, std::vector< std::string > &)
- Protected Member Functions inherited from vtkSMStringListDomain
void ChildSaveState (vtkPVXMLElement *domainElement) override
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void SetStrings (const std::vector< std::string > &strings)
 Call to set the strings. More...
const std::vector< std::string > & GetStrings ()
 vtkSMStringListDomain ()
 ~vtkSMStringListDomain () override
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
bool HidePartialArrays
- Protected Attributes inherited from vtkSMStringListDomain
char * NoneString
 Default string always present in this string list. More...
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMChartSeriesListDomain is designed to be used for the X-axis array name property on chart representations. This is similar to vtkSMArrayListDomain, however, it simplifies the logic that is uses to determine the available arrays and at the same time, uses custom logic to pick the default array for based on priorities for arrays.
Supported Required-Property functions:
Supported XML attributes
Definition at line 35 of file vtkSMChartSeriesListDomain.h.
Definition at line 39 of file vtkSMChartSeriesListDomain.h.
◆ vtkSMChartSeriesListDomain()
vtkSMChartSeriesListDomain::vtkSMChartSeriesListDomain ( )
◆ ~vtkSMChartSeriesListDomain()
vtkSMChartSeriesListDomain::~vtkSMChartSeriesListDomain ( )
static vtkSMChartSeriesListDomain* vtkSMChartSeriesListDomain::New ( )
virtual const char* vtkSMChartSeriesListDomain::GetClassName ( )
Reimplemented from vtkSMStringListDomain.
static int vtkSMChartSeriesListDomain::IsTypeOf ( const char *  type)
virtual int vtkSMChartSeriesListDomain::IsA ( const char *  type)
static vtkSMChartSeriesListDomain* vtkSMChartSeriesListDomain::SafeDownCast ( vtkObject *  o)
void vtkSMChartSeriesListDomain::PrintSelf ( ostream &  os,
◆ Update()
void vtkSMChartSeriesListDomain::Update ( vtkSMProperty *  )
◆ SetDefaultValues()
int vtkSMChartSeriesListDomain::SetDefaultValues ( vtkSMProperty *  ,
override
◆ PARAVIEW_DEPRECATED_IN_5_12_0()
vtkSMChartSeriesListDomain::PARAVIEW_DEPRECATED_IN_5_12_0 ( "See vtkPVRepresentedArrayListSettings::GetAllChartsDefaultXAxis instead"  ) const
This array is nullptr terminated i.e. the last entry in this array will be nullptr.
Deprecated:
this should now be accessed via ParaView settings at vtkPVRepresentedArrayListSettings::GetAllChartsDefaultXAxis
◆ GetInputInformation()
vtkPVDataInformation* vtkSMChartSeriesListDomain::GetInputInformation ( )
◆ ReadXMLAttributes()
int vtkSMChartSeriesListDomain::ReadXMLAttributes ( vtkSMProperty *  prop,
vtkPVXMLElement *  element
overrideprotectedvirtual
◆ PopulateArrayComponents()
virtual void vtkSMChartSeriesListDomain::PopulateArrayComponents ( vtkPVArrayInformation *  ,
protectedvirtual
◆ HidePartialArrays
bool vtkSMChartSeriesListDomain::HidePartialArrays
Definition at line 78 of file vtkSMChartSeriesListDomain.h.
