pqPropertyWidget represents a widget created for each property of a proxy on the pqPropertiesPanel (for the proxy's properties or display properties).
#include <pqPropertyWidget.h>
Definition at line 54 of file pqPropertyWidget.h.
◆ pqPropertyWidget()
| pqPropertyWidget::pqPropertyWidget |
vtkSMProxy * |
proxy, |
QWidget * |
parent = 0 |
◆ ~pqPropertyWidget()
| pqPropertyWidget::~pqPropertyWidget |
◆ apply()
| virtual void pqPropertyWidget::apply |
◆ reset()
| virtual void pqPropertyWidget::reset |
◆ select()
| virtual void pqPropertyWidget::select |
inlinevirtual |
◆ deselect()
| virtual void pqPropertyWidget::deselect |
inlinevirtual |
◆ isSelected()
| bool pqPropertyWidget::isSelected |
const |
◆ updateWidget()
| virtual void pqPropertyWidget::updateWidget |
bool |
showing_advanced_properties | ) |
inlinevirtual |
◆ view()
| pqView* pqPropertyWidget::view |
const |
◆ proxy()
◆ property()
◆ panelVisibility()
| virtual char* pqPropertyWidget::panelVisibility |
const |
◆ setPanelVisibility()
| virtual void pqPropertyWidget::setPanelVisibility |
const char * |
vis | ) |
◆ isSingleRowItem()
| virtual bool pqPropertyWidget::isSingleRowItem |
const |
Determines if the PropertyWidget must be constructed using a single row.
Originally intended for PropertyWidgets which are a group of other Propertywidgets, such as pqCheckableProperty. This mandates that when the widget is rendered, its label to be placed in the same row as the widget group.
- See also
- pqProxyWidgetItem::newGroupItem
Reimplemented in pqCheckableProperty.
◆ showLabel()
| bool pqPropertyWidget::showLabel |
const |
◆ getXMLName()
template<class T >
| static QString pqPropertyWidget::getXMLName |
T * |
object | ) |
inlinestatic |
Description: This static utility method returns the XML name for an object as a QString.
This allows for code to get the XML name of an object without having to explicitly check for a possibly NULL char* pointer.
This is templated so that it will work with a variety of objects such as vtkSMProperty's and vtkSMDomain's. It can be called with anything that has a "char* GetXMLName()" method.
For example, to get the XML name of a vtkSMIntRangeDomain: QString name = pqPropertyWidget::getXMLName(domain);
Definition at line 127 of file pqPropertyWidget.h.
◆ decorators()
◆ getTooltip()
| static QString pqPropertyWidget::getTooltip |
vtkSMProperty * |
property | ) |
Returns the tooltip to use for the property.
May return an empty string.
◆ hintsWidgetHeightNumberOfRows()
| static int pqPropertyWidget::hintsWidgetHeightNumberOfRows |
vtkPVXMLElement * |
hints, |
int |
defaultValue = 10 |
Helper method to return value from WidgetHeight XML hint, if any.
<WidgetHeight number_of_rows="val">,
◆ viewChanged
| void pqPropertyWidget::viewChanged |
pqView * |
view | ) |
signal |
This signal is emitted when the current view changes.
◆ changeAvailable
| void pqPropertyWidget::changeAvailable |
signal |
This signal is fired as soon as the user starts editing in the widget.
The editing may not be complete.
◆ changeFinished
| void pqPropertyWidget::changeFinished |
signal |
◆ restartRequired
| void pqPropertyWidget::restartRequired |
signal |
Indicates that a restart of the program is required for the setting to take effect.
◆ setView
| virtual void pqPropertyWidget::setView |
pqView * |
virtualslot |
◆ addPropertyLink() [1/2]
| void pqPropertyWidget::addPropertyLink |
QObject * |
qobject, |
const char * |
qproperty, |
const char * |
qsignal, |
vtkSMProperty * |
smproperty, |
int |
smindex = -1 |
◆ addPropertyLink() [2/2]
◆ removePropertyLink() [1/2]
| void pqPropertyWidget::removePropertyLink |
QObject * |
qobject, |
const char * |
qproperty, |
const char * |
qsignal, |
vtkSMProperty * |
smproperty, |
int |
smindex = -1 |
◆ removePropertyLink() [2/2]
◆ setShowLabel()
| void pqPropertyWidget::setShowLabel |
bool |
show | ) |
◆ setChangeAvailableAsChangeFinished()
| void pqPropertyWidget::setChangeAvailableAsChangeFinished |
bool |
status | ) |
inlineprotected |
◆ addDecorator()
◆ removeDecorator()
◆ links()
◆ setProperty()
◆ pqCompositePropertyWidgetDecorator
◆ pqPropertyWidgetDecorator
◆ pqProxyWidget
