| | This signal is emitted when the current view changes. More...
| void | changeAvailable () |
| | This signal is fired as soon as the user starts editing in the widget. More...
| void | changeFinished () |
| | This signal is fired as soon as the user is done with making an atomic change. More...
| void | restartRequired () |
| | Indicates that a restart of the program is required for the setting to take effect. More...
| template<class T > |
property widget for properties representing a checkable property.
pqCheckableProperty is designed for a specific use-case: a property that can be enabled or disabled by a checkbox. This is useful for optional properties since it restrains the user to use the property unless it is really needed.
Example proxy definition(s) that use this widget is as follows:
<ServerManagerConfiguration>
<ProxyGroup name="sources">
<SourceProxy name="CustomSource" class="vtkSphereSource">
<DoubleVectorProperty name="PropertyA"
number_of_elements="1"
default_values="0">
<DoubleRangeDomain name="range" min="0" max="10" />
</DoubleVectorProperty>
<IntVectorProperty name="EnablePropertyA"
default_values="0">
<BooleanDomain name="bool" />
</IntVectorProperty>
<PropertyGroup label="Property A" panel_widget="CheckableProperty">
<Property name="PropertyA" function="Property" />
<Property name="EnablePropertyA" function="PropertyCheckBox" />
</PropertyGroup>
</SourceProxy>
</ProxyGroup>
</ServerManagerConfiguration>
Definition at line 75 of file pqCheckableProperty.h.
