| | called to set the active view. More...
| | This signal is emitted when the current view changes. More...
| void | changeAvailable () |
| | This signal is fired as soon as the user starts editing in the widget. More...
| void | changeFinished () |
| | This signal is fired as soon as the user is done with making an atomic change. More...
| void | restartRequired () |
| | Indicates that a restart of the program is required for the setting to take effect. More...
| template<class T > |
pqDoubleRangeSliderPropertyWidget is a widget used for properties such as the "ThresholdRange" property on the Threshold filter's panel.
It provides two double sliders, one for min and one for max and has logic to ensure that the min <= max.
The appearance of this widget can be modified by hints in the property XML definition. If a hint element named "HideResetButton" is present, the range reset button will be hidden. If a hint element named "MinimumLabel" is present with a "text" attribute, that text attribute will be used as the label text instead of "Minimum". Similarly, the default "Maximum" label can be replaced with a "MaximumLabel" element with a "text" attribute.
Definition at line 51 of file pqDoubleRangeSliderPropertyWidget.h.
