pqPropertyWidgetDecorator provides a mechanism to decorate pqPropertyWidget instances to add logic to the widget to add additional control logic.
#include <pqPropertyWidgetDecorator.h>
| void | visibilityChanged () |
| | This signal is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More...
| void | enableStateChanged () |
Subclasses can be used to logic to control when the widget is enabled/disabled, hidden/visible, etc. based on values of other properties of UI elements.
Definition at line 47 of file pqPropertyWidgetDecorator.h.
◆ pqPropertyWidgetDecorator()
Constructor.
- Parameters
| xml | The XML element from the <Hints/> section for the proxy/property that resulted in the creation of the decorator. Decorators can be provided configuration parameters from the XML. |
| parent | Parent widget |
◆ ~pqPropertyWidgetDecorator()
| pqPropertyWidgetDecorator::~pqPropertyWidgetDecorator |
◆ parentWidget()
◆ canShowWidget()
| virtual bool pqPropertyWidgetDecorator::canShowWidget |
bool |
show_advanced | ) |
const |
inlinevirtual |
◆ enableWidget()
| virtual bool pqPropertyWidgetDecorator::enableWidget |
const |
inlinevirtual |
◆ create()
Creates a new decorator, given the xml config and the parent pqPropertyWidget for the decorator.
◆ visibilityChanged
| void pqPropertyWidgetDecorator::visibilityChanged |
signal |
◆ enableStateChanged
| void pqPropertyWidgetDecorator::enableStateChanged |
signal |
◆ xml()
