pqPropertyGroupWidget is a (custom) widget created for a PropertyGroup.
#include <pqPropertyGroupWidget.h>
| | pqPropertyGroupWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smGroup, QWidget *parent=0) |
| vtkSMPropertyGroup * | propertyGroup () const |
| void | addPropertyLink (QComboBox *cb, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QLineEdit *edit, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QCheckBox *button, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QToolButton *button, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QGroupBox *groupBox, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QDoubleSpinBox *spinBox, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (QSpinBox *spinBox, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (pqColorChooserButton *color, const char *propertyName, int smindex=-1) |
| void | addPropertyLink (pqDoubleSliderWidget *slider, const char *propertyName, int smindex=-1) |
| char * | panelVisibility () const override |
| | Overwrite pqPropertyWidget to forward calls to vtkSMPropertyGroup. More...
| void | setPanelVisibility (const char *vis) override |
| | pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=0) |
| | ~pqPropertyWidget () override |
| virtual void | apply () |
| virtual void | reset () |
| virtual void | select () |
| | These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive. More...
| pqView * | view () const |
| | Determines if the PropertyWidget must be constructed using a single row. More...
| bool | showLabel () const |
| | Provides access to the decorators for this widget. More...
| | called to set the active view. More...
| | This signal is emitted when the current view changes. More...
| void | changeAvailable () |
| | This signal is fired as soon as the user starts editing in the widget. More...
| void | changeFinished () |
| | This signal is fired as soon as the user is done with making an atomic change. More...
| void | restartRequired () |
| | Indicates that a restart of the program is required for the setting to take effect. More...
| template<class T > |
It provides functions for linking standard controls with Server Manager properties as well as storing the property group.
- See also
- vtkSMPropertyGroup
Definition at line 57 of file pqPropertyGroupWidget.h.
◆ pqPropertyGroupWidget()
◆ propertyGroup()
◆ addPropertyLink() [1/9]
| void pqPropertyGroupWidget::addPropertyLink |
QComboBox * |
cb, |
const char * |
propertyName, |
int |
smindex = -1 |
◆ addPropertyLink() [2/9]
QLineEdit * |
edit, |
const char * |
propertyName, |
int |
smindex = -1 |
◆ addPropertyLink() [3/9]
QCheckBox * |
button, |
const char * |
propertyName, |
int |
smindex = -1 |
◆ addPropertyLink() [4/9]
QToolButton * |
button, |
const char * |
propertyName, |
int |
smindex = -1 |
◆ addPropertyLink() [5/9]
QGroupBox * |
groupBox, |
const char * |
propertyName, |
int |
smindex = -1 |
◆ addPropertyLink() [6/9]
QDoubleSpinBox * |
spinBox, |
const char * |
propertyName, |
int |
smindex = -1 |
◆ addPropertyLink() [7/9]
QSpinBox * |
spinBox, |
const char * |
propertyName, |
int |
smindex = -1 |
◆ addPropertyLink() [8/9]
◆ addPropertyLink() [9/9]
◆ panelVisibility()
| char* pqPropertyGroupWidget::panelVisibility |
const |
◆ setPanelVisibility()
| void pqPropertyGroupWidget::setPanelVisibility |
const char * |
vis | ) |
