#include <pqDoubleVectorPropertyWidget.h>
| | called to set the active view. More...
| template<class T > |
◆ pqDoubleVectorPropertyWidget()
| pqDoubleVectorPropertyWidget::pqDoubleVectorPropertyWidget |
vtkSMProperty * |
property, |
vtkSMProxy * |
proxy, |
QWidget * |
parent = 0 |
◆ ~pqDoubleVectorPropertyWidget()
| pqDoubleVectorPropertyWidget::~pqDoubleVectorPropertyWidget |
◆ apply()
| void pqDoubleVectorPropertyWidget::apply |
◆ reset()
| void pqDoubleVectorPropertyWidget::reset |
◆ clearHighlight
| void pqDoubleVectorPropertyWidget::clearHighlight |
signal |
◆ highlightResetButton
| void pqDoubleVectorPropertyWidget::highlightResetButton |
signal |
◆ resetButtonClicked
| virtual void pqDoubleVectorPropertyWidget::resetButtonClicked |
protectedvirtualslot |
called when the user clicks the "reset" button for a specific property.
◆ scaleHalf
| void pqDoubleVectorPropertyWidget::scaleHalf |
protectedslot |
◆ scaleTwice
| void pqDoubleVectorPropertyWidget::scaleTwice |
protectedslot |
◆ scale
| void pqDoubleVectorPropertyWidget::scale |
double |
protectedslot |
◆ resetToActiveDataBounds
| void pqDoubleVectorPropertyWidget::resetToActiveDataBounds |
protectedslot |
sets the value using active source's data bounds.
◆ resetToBounds
| void pqDoubleVectorPropertyWidget::resetToBounds |
const double |
bds[6] | ) |
protectedslot |
sets the value to the specified bounds.
