pqPropertyWidget that can be used for any proxy with a vtkSMProxyListDomain.
#include <pqProxySelectionWidget.h>
| template<class T > |
pqProxyPropertyWidget automatically creates this widget when it encounters a property with vtkSMProxyListDomain.
Definition at line 49 of file pqProxySelectionWidget.h.
◆ pqProxySelectionWidget()
| pqProxySelectionWidget::pqProxySelectionWidget |
vtkSMProperty * |
property, |
vtkSMProxy * |
proxy, |
QWidget * |
parent = 0 |
constructor requires the proxy, property.
Note that this will abort if the property does not have a ProxyListDomain.
◆ ~pqProxySelectionWidget()
| pqProxySelectionWidget::~pqProxySelectionWidget |
◆ chosenProxy()
| vtkSMProxy* pqProxySelectionWidget::chosenProxy |
const |
◆ setChosenProxy()
| void pqProxySelectionWidget::setChosenProxy |
vtkSMProxy * |
proxy | ) |
◆ apply()
| void pqProxySelectionWidget::apply |
◆ reset()
| void pqProxySelectionWidget::reset |
◆ select()
| void pqProxySelectionWidget::select |
These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive.
Only widgets that have 3D widgets need to override these methods to select/deselect the 3D widgets. Default implementation does nothing.
Reimplemented from pqPropertyWidget.
◆ deselect()
| void pqProxySelectionWidget::deselect |
◆ updateWidget()
| void pqProxySelectionWidget::updateWidget |
bool |
showing_advanced_properties | ) |
◆ setPanelVisibility()
| void pqProxySelectionWidget::setPanelVisibility |
const char * |
vis | ) |
◆ setView()
| void pqProxySelectionWidget::setView |
pqView * |
◆ chosenProxyChanged
| void pqProxySelectionWidget::chosenProxyChanged |
signal |
◆ chosenProxy
| pqSMProxy pqProxySelectionWidget::chosenProxy |
readwrite |
