This is a widget for a vtkSMProxyProperty. More...
#include <pqProxyPropertyWidget.h>
| pqProxyPropertyWidget (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parent=0) | |
| void | apply () override |
| Overridden to pass the calls to internal widgets. More... | |
| void | reset () override |
| void | select () override |
| These methods are called when the pqProxyPropertiesPanel containing the widget is activated/deactivated. More... | |
| void | deselect () override |
| void | updateWidget (bool showing_advanced_properties) override |
| Overridden to hide the properties for proxies in a vtkSMProxyListDomain if requested. More... | |
| pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=0) | |
| pqView * | view () const |
| bool | showLabel () const |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
| template<class T > | |
It handles a "SelectionInput" property and properties with ProxyListDomain.
Definition at line 46 of file pqProxyPropertyWidget.h.
| pqProxyPropertyWidget::pqProxyPropertyWidget | ( | vtkSMProperty * | property, |
| vtkSMProxy * | proxy, | ||
| QWidget * | parent = 0 |
Reimplemented from pqPropertyWidget.
Only widgets that have 3D widgets need to override these methods to select/deselect the 3D widgets.
