type specific extension to vtkSMRangeDomainTemplate for ints. More...
#include <vtkSMIntRangeDomain.h>
| typedef vtkSMDomain | Superclass |
Public Types inherited from vtkSMDomain | |
| enum | IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 } |
| int | GetMinimum (unsigned int idx, int &exists) |
| Return a min. More... | |
| int | GetMaximum (unsigned int idx, int &exists) |
| Return a max. More... | |
| int | GetMinimumExists (unsigned int idx) |
| Returns if minimum/maximum bound is set for the domain. More... | |
| int | GetMaximumExists (unsigned int idx) |
| int | GetMinimum (unsigned int idx) |
| Returns the minimum/maximum value, is exists, otherwise 0 is returned. More... | |
| int | GetMaximum (unsigned int idx) |
Public Member Functions inherited from vtkSMDomain | |
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More... | |
| virtual void | Update (vtkSMProperty *requestingProperty) |
| Update self based on the "unchecked" values of all required properties. More... | |
| Set the value of an element of a property from the animation editor. More... | |
| A vtkSMProperty is often defined with a default value in the XML itself. More... | |
| Provides access to the vtkSMProperty on which this domain is hooked up. More... | |
| Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More... | |
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More... | |
| When the IsOptional flag is set, IsInDomain() always returns true. More... | |
| static vtkSMIntRangeDomain * | New () |
| static vtkSMIntRangeDomain * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSMDomain | |
| static vtkSMDomain * | New () |
| static vtkSMDomain * | SafeDownCast (vtkObject *o) |
| vtkSMIntRangeDomain () | |
| ~vtkSMIntRangeDomain () override | |
Protected Member Functions inherited from vtkSMDomain | |
| vtkSMDomain () | |
| ~vtkSMDomain () override | |
| Load the state of the domain from the XML. More... | |
| virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
| Returns a given required property of the given function. More... | |
| Remove the given property from the required properties list. More... | |
| Add a new required property to this domain. More... | |
| void | DomainModified () |
| Invokes DomainModifiedEvent. More... | |
| void | InvokeModified () |
| Gets the number of required properties added. More... | |
| Set the domain's property. More... | |
| Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More... | |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| vtkSMSessionObject () | |
| vtkSMObject () | |
Protected Attributes inherited from vtkSMDomain | |
| char * | XMLName |
| bool | IsOptional |
| vtkSMDomainInternals * | Internals |
vtkSMIntRangeDomain is a type specific extension to vtkSMRangeDomainTemplate for ints.
Definition at line 39 of file vtkSMIntRangeDomain.h.
Definition at line 46 of file vtkSMIntRangeDomain.h.
Reimplemented in vtkSMDimensionsDomain, vtkSMAMRLevelsDomain, vtkSMExtentDomain, vtkSMTimeStepIndexDomain, vtkSMAnimationFrameWindowDomain, and vtkSMViewResolutionDomain.
Reimplemented in vtkSMTimeStepIndexDomain, and vtkSMViewResolutionDomain.
Return a min.
value if it exists. If the min. exists exists is set to 1. Otherwise, it is set to 0. An unspecified min. is equivalent to -inf
Definition at line 54 of file vtkSMIntRangeDomain.h.
Return a max.
value if it exists. If the max. exists exists is set to 1. Otherwise, it is set to 0. An unspecified max. is equivalent to +inf
Definition at line 64 of file vtkSMIntRangeDomain.h.
Definition at line 72 of file vtkSMIntRangeDomain.h.
Definition at line 76 of file vtkSMIntRangeDomain.h.
Use GetMaximumExists() GetMaximumExists() to make sure that the bound is set.
Definition at line 86 of file vtkSMIntRangeDomain.h.
Definition at line 87 of file vtkSMIntRangeDomain.h.
