Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Friends | List of all members
vtkPVArrayInformation Class Reference
provides meta data about arrays. More...
#include <vtkPVArrayInformation.h>
Inheritance diagram for vtkPVArrayInformation:
Collaboration diagram for vtkPVArrayInformation:
void Initialize ()
 Resets to default state. More...
virtual int GetDataType ()
 Get the type for values in the array e.g. More...
const char * GetDataTypeAsString () const
 Returns a printable string for the array value type. More...
std::string GetRangesAsString (int lowExponent=-6, int highExponent=20) const
 Returns range as a string. More...
const char * GetName () const
 Get array's name. More...
int GetNumberOfComponents () const
 Get number of components. More...
const char * GetComponentName (int component) const
 Returns the name for a component. More...
virtual vtkTypeInt64 GetNumberOfTuples ()
 Returns the number of tuples in this array. More...
void GetDataTypeRange (double range[2]) const
 This method return the Min and Max possible range of the native data type. More...
void CopyFromArray (vtkAbstractArray *array, vtkFieldData *fd=nullptr)
void CopyFromCellAttribute (vtkCellGrid *grid, vtkCellAttribute *attribute)
void CopyFromGenericAttribute (vtkGenericAttribute *array)
void CopyToStream (vtkClientServerStream *) const
bool CopyFromStream (const vtkClientServerStream *)
const double * GetComponentRange (int comp) const VTK_SIZEHINT(2)
 Returns component range. More...
void GetComponentRange (int comp, double range[2]) const
const double * GetComponentFiniteRange (int component) const VTK_SIZEHINT(2)
 Returns the finite range for each component. More...
void GetComponentFiniteRange (int comp, double range[2]) const
virtual bool GetIsPartial ()
 If IsPartial is true, this array is in only some of the parts of a multi-block dataset. More...
int GetNumberOfInformationKeys () const
 Get information on the InformationKeys of this array. More...
const char * GetInformationKeyLocation (int) const
const char * GetInformationKeyName (int) const
bool HasInformationKey (const char *location, const char *name) const
int GetNumberOfStringValues ()
 For string arrays, this returns first few non-empty values. More...
const char * GetStringValue (int)
static vtkPVArrayInformation * New ()
static vtkPVArrayInformation * SafeDownCast (vtkObject *o)
 vtkPVArrayInformation ()
 ~vtkPVArrayInformation () override
virtual void SetName (std::string)
void DeepCopy (vtkPVArrayInformation *info)
 API for vtkPVDataSetAttributesInformation. More...
void AddInformation (vtkPVArrayInformation *, int fieldAssociation)
virtual void SetIsPartial (bool)
Friends
class vtkPVDataSetAttributesInformation
class vtkPVDataInformation
vtkPVArrayInformation provides meta-data about individual arrays. It is accessed through vtkPVDataInformation and provides information like ranges, component names, etc. for array present in a dataset.
Definition at line 30 of file vtkPVArrayInformation.h.
Definition at line 34 of file vtkPVArrayInformation.h.
◆ vtkPVArrayInformation()
vtkPVArrayInformation::vtkPVArrayInformation ( )
◆ ~vtkPVArrayInformation()
vtkPVArrayInformation::~vtkPVArrayInformation ( )
static vtkPVArrayInformation* vtkPVArrayInformation::New ( )
virtual const char* vtkPVArrayInformation::GetClassName ( )
static int vtkPVArrayInformation::IsTypeOf ( const char *  type)
virtual int vtkPVArrayInformation::IsA ( const char *  type)
static vtkPVArrayInformation* vtkPVArrayInformation::SafeDownCast ( vtkObject *  o)
void vtkPVArrayInformation::PrintSelf ( ostream &  os,
◆ Initialize()
void vtkPVArrayInformation::Initialize ( )
◆ GetDataType()
virtual int vtkPVArrayInformation::GetDataType ( )
VTK_FLOAT, VTK_DOUBLE etc.
◆ GetDataTypeAsString()
const char* vtkPVArrayInformation::GetDataTypeAsString ( ) const
inline
Definition at line 50 of file vtkPVArrayInformation.h.
◆ GetRangesAsString()
std::string vtkPVArrayInformation::GetRangesAsString ( int  lowExponent = -6,
int  highExponent = 20
) const
For string arrays, this lists string values instead.
◆ GetName()
const char* vtkPVArrayInformation::GetName ( ) const
inline
Get array's name.
Definition at line 61 of file vtkPVArrayInformation.h.
◆ GetNumberOfComponents()
int vtkPVArrayInformation::GetNumberOfComponents ( ) const
◆ GetComponentName()
const char* vtkPVArrayInformation::GetComponentName ( int  component) const
If none present, a default component name may be returned.
◆ GetNumberOfTuples()
virtual vtkTypeInt64 vtkPVArrayInformation::GetNumberOfTuples ( )
◆ GetComponentRange() [1/2]
const double* vtkPVArrayInformation::GetComponentRange ( int  comp) const
If component is -1, then the range of the magnitude (L2 norm) over all components will be provided.
Returns invalid range for non-numeric arrays.
◆ GetComponentRange() [2/2]
void vtkPVArrayInformation::GetComponentRange ( int  comp,
double  range[2]
) const
◆ GetComponentFiniteRange() [1/2]
const double* vtkPVArrayInformation::GetComponentFiniteRange ( int  component) const
◆ GetComponentFiniteRange() [2/2]
void vtkPVArrayInformation::GetComponentFiniteRange ( int  comp,
double  range[2]
) const
◆ GetDataTypeRange()
void vtkPVArrayInformation::GetDataTypeRange ( double  range[2]) const
For example if a vtkScalars consists of unsigned char data these will return (0,255). Nothing particular for 12bits data is done
◆ GetIsPartial()
virtual bool vtkPVArrayInformation::GetIsPartial ( )
By default, IsPartial is set to 0.
◆ GetNumberOfInformationKeys()
int vtkPVArrayInformation::GetNumberOfInformationKeys ( ) const
◆ GetInformationKeyLocation()
const char* vtkPVArrayInformation::GetInformationKeyLocation ( int  ) const
◆ GetInformationKeyName()
const char* vtkPVArrayInformation::GetInformationKeyName ( int  ) const
◆ HasInformationKey()
bool vtkPVArrayInformation::HasInformationKey ( const char *  location,
const char *  name
) const
◆ GetNumberOfStringValues()
int vtkPVArrayInformation::GetNumberOfStringValues ( )
◆ GetStringValue()
const char* vtkPVArrayInformation::GetStringValue ( int  )
◆ CopyFromArray()
void vtkPVArrayInformation::CopyFromArray ( vtkAbstractArray *  array,
vtkFieldData *  fd = nullptr
◆ CopyFromCellAttribute()
void vtkPVArrayInformation::CopyFromCellAttribute ( vtkCellGrid *  grid,
vtkCellAttribute *  attribute
◆ CopyFromGenericAttribute()
void vtkPVArrayInformation::CopyFromGenericAttribute ( vtkGenericAttribute *  array)
◆ CopyToStream()
void vtkPVArrayInformation::CopyToStream ( vtkClientServerStream *  ) const
◆ CopyFromStream()
bool vtkPVArrayInformation::CopyFromStream ( const vtkClientServerStream *  )
◆ DeepCopy()
void vtkPVArrayInformation::DeepCopy ( vtkPVArrayInformation *  info)
◆ AddInformation()
void vtkPVArrayInformation::AddInformation ( vtkPVArrayInformation *  ,
◆ SetIsPartial()
virtual void vtkPVArrayInformation::SetIsPartial ( bool  )
protectedvirtual
◆ SetName()
virtual void vtkPVArrayInformation::SetName ( std::string  )
protectedvirtual
◆ vtkPVDataSetAttributesInformation
friend class vtkPVDataSetAttributesInformation
friend
Definition at line 147 of file vtkPVArrayInformation.h.
◆ vtkPVDataInformation
friend class vtkPVDataInformation
friend
Definition at line 148 of file vtkPVArrayInformation.h.
