vtkPVProminentValuesInformation Class Reference
Prominent values a data array takes on. More...
#include <vtkPVProminentValuesInformation.h>
Inheritance diagram for vtkPVProminentValuesInformation:
Collaboration diagram for vtkPVProminentValuesInformation:
typedef vtkPVInformation Superclass
- Public Types inherited from vtkPVInformation
void InitializeParameters ()
 Remove all parameter information. More...
void Initialize ()
 Remove all gathered information (but not parameters). More...
void AddDistinctValues (vtkPVProminentValuesInformation *)
 Merge another list of prominent values. More...
vtkAbstractArray * GetProminentComponentValues (int component)
 Returns either nullptr (array component appears to be continuous) or a pointer to a vtkAbstractArray (array component appears to be discrete) containing a sorted list of all distinct prominent values encountered in the array component. More...
virtual void SetPortNumber (int)
 Set/get the output port whose dataset should be queried. More...
virtual int GetPortNumber ()
virtual void SetFieldAssociation (const char *)
 Set/get array's association. More...
virtual char * GetFieldAssociation ()
virtual void SetFieldName (const char *)
 Set/get array's name. More...
virtual char * GetFieldName ()
void SetNumberOfComponents (int numComps)
 Changing the number of components clears the ranges back to the default. More...
virtual int GetNumberOfComponents ()
virtual void SetFraction (double)
 Set/get the minimum fraction of the array that should be composed of a value (between 0 and 1) in order for it to be considered prominent. More...
virtual double GetFraction ()
virtual void SetUncertainty (double)
 Set/get the maximum uncertainty allowed in the detection of prominent values. More...
virtual double GetUncertainty ()
virtual void SetForce (bool)
 Set/get the force flag that will be used when recovering the prominents values. More...
virtual bool GetForce ()
virtual bool GetValid ()
 Get the validity of the information. More...
int Compare (vtkPVProminentValuesInformation *info)
 Returns 1 if the array can be combined. More...
void DeepCopy (vtkPVProminentValuesInformation *other)
 Copy information from an other object. More...
void CopyFromObject (vtkObject *) override
 Transfer information about a single object into this object. More...
virtual void CopyDistinctValuesFromObject (vtkAbstractArray *)
 Transfer information about a single vtkAbstractArray's prominent values into this object. More...
void AddInformation (vtkPVInformation *other) override
 Merge another information object. More...
void CopyToStream (vtkClientServerStream *) override
 Manage a serialized version of the information. More...
void CopyFromStream (const vtkClientServerStream *) override
void CopyParametersToStream (vtkMultiProcessStream &) override
 Push/pop parameters controlling which array to sample onto/off of the stream. More...
void CopyParametersFromStream (vtkMultiProcessStream &) override
- Public Member Functions inherited from vtkPVInformation
virtual int GetRootOnly ()
 Set/get whether to gather information only from the root. More...
static vtkPVProminentValuesInformation * New ()
static vtkPVProminentValuesInformation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPVInformation
static vtkPVInformation * SafeDownCast (vtkObject *o)
 vtkPVProminentValuesInformation ()
 ~vtkPVProminentValuesInformation () override
void DeepCopyParameters (vtkPVProminentValuesInformation *other)
void CopyFromCompositeDataSet (vtkCompositeDataSet *)
void CopyFromLeafDataObject (vtkDataObject *)
 vtkPVProminentValuesInformation (const vtkPVProminentValuesInformation &)=delete
void operator= (const vtkPVProminentValuesInformation &)=delete
- Protected Member Functions inherited from vtkPVInformation
 vtkPVInformation ()
 ~vtkPVInformation () override
virtual void SetRootOnly (int)
 vtkPVInformation (const vtkPVInformation &)=delete
void operator= (const vtkPVInformation &)=delete
int PortNumber
 Information parameters. More...
int NumberOfComponents
char * FieldName
char * FieldAssociation
double Fraction
double Uncertainty
bool Force
bool Valid
vtkInternalDistinctValues * DistinctValues
- Protected Attributes inherited from vtkPVInformation
int RootOnly
This vtkPVInformation subclass provides a way for clients to discover whether a specific remote vtkAbstractArray instance behaves like a discrete set or a continuum (for each component of its tuples as well as for its tuples as a whole).
If the array behaves discretely (which we define to be: takes on fewer than 33 distinct values over more than 99.9% of its entries to within a given confidence that dictates the number of samples required), then the prominent values are also made available.
This class uses vtkAbstractArray::GetProminentComponentValues().
Definition at line 32 of file vtkPVProminentValuesInformation.h.
Definition at line 36 of file vtkPVProminentValuesInformation.h.
◆ vtkPVProminentValuesInformation() [1/2]
vtkPVProminentValuesInformation::vtkPVProminentValuesInformation ( )
◆ ~vtkPVProminentValuesInformation()
vtkPVProminentValuesInformation::~vtkPVProminentValuesInformation ( )
◆ vtkPVProminentValuesInformation() [2/2]
vtkPVProminentValuesInformation::vtkPVProminentValuesInformation ( const vtkPVProminentValuesInformation &  )
protecteddelete
static vtkPVProminentValuesInformation* vtkPVProminentValuesInformation::New ( )
virtual const char* vtkPVProminentValuesInformation::GetClassName ( )
Reimplemented from vtkPVInformation.
static int vtkPVProminentValuesInformation::IsTypeOf ( const char *  type)
virtual int vtkPVProminentValuesInformation::IsA ( const char *  type)
static vtkPVProminentValuesInformation* vtkPVProminentValuesInformation::SafeDownCast ( vtkObject *  o)
void vtkPVProminentValuesInformation::PrintSelf ( ostream &  os,
◆ SetPortNumber()
virtual void vtkPVProminentValuesInformation::SetPortNumber ( int  )
◆ GetPortNumber()
virtual int vtkPVProminentValuesInformation::GetPortNumber ( )
◆ SetFieldAssociation()
virtual void vtkPVProminentValuesInformation::SetFieldAssociation ( const char *  )
◆ GetFieldAssociation()
virtual char* vtkPVProminentValuesInformation::GetFieldAssociation ( )
◆ SetFieldName()
virtual void vtkPVProminentValuesInformation::SetFieldName ( const char *  )
◆ GetFieldName()
virtual char* vtkPVProminentValuesInformation::GetFieldName ( )
◆ SetNumberOfComponents()
void vtkPVProminentValuesInformation::SetNumberOfComponents ( int  numComps)
◆ GetNumberOfComponents()
virtual int vtkPVProminentValuesInformation::GetNumberOfComponents ( )
◆ SetFraction()
virtual void vtkPVProminentValuesInformation::SetFraction ( double  )
Setting this to one indicates that an array must have every value be identical in order to have any considered prominent.
◆ GetFraction()
virtual double vtkPVProminentValuesInformation::GetFraction ( )
◆ SetUncertainty()
virtual void vtkPVProminentValuesInformation::SetUncertainty ( double  )
The uncertainty is the probability of prominent values going undetected. Setting this to zero forces the entire array to be inspected.
◆ GetUncertainty()
virtual double vtkPVProminentValuesInformation::GetUncertainty ( )
◆ SetForce()
virtual void vtkPVProminentValuesInformation::SetForce ( bool  )
If not set, a maximum of vtkAbstractArray::MAX_DISCRETE_VALUES (32) values will be recovered, if there is more, none will be recovered and the information will be considered invalid. If the force flag is set, there is no maximum number of prominent values recovered and the information should be valid even with a high number of prominent values.
◆ GetForce()
virtual bool vtkPVProminentValuesInformation::GetForce ( )
◆ GetValid()
virtual bool vtkPVProminentValuesInformation::GetValid ( )
The flag has a meaning after trying to recover prominent values, if true, the data can be used, if false, this information should be considered invalid.
◆ Compare()
int vtkPVProminentValuesInformation::Compare ( vtkPVProminentValuesInformation *  info)
It must have the same name and number of components.
◆ DeepCopy()
void vtkPVProminentValuesInformation::DeepCopy ( vtkPVProminentValuesInformation *  other)
◆ CopyFromObject()
void vtkPVProminentValuesInformation::CopyFromObject ( vtkObject *  )
◆ CopyDistinctValuesFromObject()
virtual void vtkPVProminentValuesInformation::CopyDistinctValuesFromObject ( vtkAbstractArray *  )
This is called after CopyFromObject has determined the number of components available; this method relies on this->NumberOfComponents being valid.
◆ AddInformation()
void vtkPVProminentValuesInformation::AddInformation ( vtkPVInformation *  other)
◆ CopyToStream()
void vtkPVProminentValuesInformation::CopyToStream ( vtkClientServerStream *  )
Implements vtkPVInformation.
◆ CopyFromStream()
void vtkPVProminentValuesInformation::CopyFromStream ( const vtkClientServerStream *  )
◆ CopyParametersToStream()
void vtkPVProminentValuesInformation::CopyParametersToStream ( vtkMultiProcessStream &  )
◆ CopyParametersFromStream()
void vtkPVProminentValuesInformation::CopyParametersFromStream ( vtkMultiProcessStream &  )
◆ InitializeParameters()
void vtkPVProminentValuesInformation::InitializeParameters ( )
You must copy/set parameter values before adding data or copying data from an object.
◆ Initialize()
void vtkPVProminentValuesInformation::Initialize ( )
Next add will behave like a copy.
◆ AddDistinctValues()
void vtkPVProminentValuesInformation::AddDistinctValues ( vtkPVProminentValuesInformation *  )
◆ GetProminentComponentValues()
vtkAbstractArray* vtkPVProminentValuesInformation::GetProminentComponentValues ( int  component)
Passing -1 as the component will return information about distinct tuple values as opposed to distinct component values.
◆ DeepCopyParameters()
void vtkPVProminentValuesInformation::DeepCopyParameters ( vtkPVProminentValuesInformation *  other)
◆ CopyFromCompositeDataSet()
void vtkPVProminentValuesInformation::CopyFromCompositeDataSet ( vtkCompositeDataSet *  )
◆ CopyFromLeafDataObject()
void vtkPVProminentValuesInformation::CopyFromLeafDataObject ( vtkDataObject *  )
◆ operator=()
void vtkPVProminentValuesInformation::operator= ( const vtkPVProminentValuesInformation &  )
protecteddelete
◆ PortNumber
int vtkPVProminentValuesInformation::PortNumber
Definition at line 196 of file vtkPVProminentValuesInformation.h.
◆ NumberOfComponents
int vtkPVProminentValuesInformation::NumberOfComponents
Definition at line 197 of file vtkPVProminentValuesInformation.h.
◆ FieldName
char* vtkPVProminentValuesInformation::FieldName
Definition at line 198 of file vtkPVProminentValuesInformation.h.
◆ FieldAssociation
char* vtkPVProminentValuesInformation::FieldAssociation
Definition at line 199 of file vtkPVProminentValuesInformation.h.
◆ Fraction
double vtkPVProminentValuesInformation::Fraction
Definition at line 200 of file vtkPVProminentValuesInformation.h.
◆ Uncertainty
double vtkPVProminentValuesInformation::Uncertainty
Definition at line 201 of file vtkPVProminentValuesInformation.h.
◆ Force
bool vtkPVProminentValuesInformation::Force
Definition at line 202 of file vtkPVProminentValuesInformation.h.
◆ Valid
bool vtkPVProminentValuesInformation::Valid
Definition at line 203 of file vtkPVProminentValuesInformation.h.
◆ DistinctValues
vtkInternalDistinctValues* vtkPVProminentValuesInformation::DistinctValues
Definition at line 209 of file vtkPVProminentValuesInformation.h.
