Static Public Member Functions | Static Protected Member Functions | List of all members
vtkSMColorMapEditorHelper Class Reference
helper for color map editor handling More...
#include <vtkSMColorMapEditorHelper.h>
static vtkSMProxy * GetLUTProxy (vtkSMProxy *proxy, vtkSMProxy *view)
 Returns the lut proxy of this representation in the given view. More...
static bool GetUsingScalarColoring (vtkSMProxy *proxy)
 Returns true if scalar coloring is enabled. More...
static void SetupLookupTable (vtkSMProxy *proxy)
 Given the input registered representation proxy, sets up a lookup table associated with the representation if a scalar bar is being used for proxy. More...
static bool UpdateScalarBarRange (vtkSMProxy *proxy, vtkSMProxy *view, bool deleteRange)
 Updates the ranges shown in the scalar bar. More...
static bool SetScalarColoring (vtkSMProxy *proxy, const char *arrayname, int attribute_type)
 Enable/disable scalar coloring using the specified array. More...
static bool SetScalarColoring (vtkSMProxy *proxy, const char *arrayname, int attribute_type, int component)
static bool RescaleTransferFunctionToDataRange (vtkSMProxy *proxy, bool extend=false, bool force=true)
 Rescales the color transfer function and opacity transfer function using the current data range. More...
static bool RescaleTransferFunctionToDataRange (vtkSMProxy *proxy, const char *arrayname, int attribute_type, bool extend=false, bool force=true)
 Rescales the color transfer function and opacity transfer function using the current data range for the chosen data-array. More...
static bool RescaleTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy)
 Rescales the color transfer function and opacity transfer function using the current data range over time. More...
static bool RescaleTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy, const char *arrayname, int attribute_type)
 Rescales the color transfer function and opacity transfer function using the current data range over time for the chosen data-array. More...
static bool SetScalarBarVisibility (vtkSMProxy *proxy, vtkSMProxy *view, bool visible)
 Set the scalar bar visibility. More...
static bool HideScalarBarIfNotNeeded (vtkSMProxy *repr, vtkSMProxy *view)
 While SetScalarBarVisibility can be used to hide a scalar bar, it will always simply hide the scalar bar even if its being used by some other representation. More...
static bool IsScalarBarVisible (vtkSMProxy *repr, vtkSMProxy *view)
 Check scalar bar visibility. More...
static vtkPVArrayInformation * GetArrayInformationForColorArray (vtkSMProxy *proxy, bool checkRepresentedData=true)
 Returns the array information for the data array used for scalar coloring, from input data. More...
static std::string GetDecoratedArrayName (vtkSMProxy *proxy, const std::string &arrayname)
 In case of UseSeparateColorMap enabled, this function prefix the given arrayname with unique identifier, otherwise it acts as a passthrough. More...
static vtkPVProminentValuesInformation * GetProminentValuesInformationForColorArray (vtkSMProxy *proxy, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false)
 Call vtkSMRepresentationProxy::GetProminentValuesInformation() for the array used for scalar color, if any. More...
static int GetEstimatedNumberOfAnnotationsOnScalarBar (vtkSMProxy *proxy, vtkSMProxy *view)
 Get an estimated number of annotation shown on this representation scalar bar. More...
static int IsScalarBarStickyVisible (vtkSMProxy *proxy, vtkSMProxy *view)
 Checks if the scalar bar of this representation in view is sticky visible, i.e. More...
static bool RescaleTransferFunctionToVisibleRange (vtkSMProxy *proxy, vtkSMProxy *view)
 Rescales the color transfer function and the opacity transfer function using the current data range, limited to the currernt visible elements. More...
static bool RescaleTransferFunctionToVisibleRange (vtkSMProxy *proxy, vtkSMProxy *view, const char *arrayname, int attribute_type)
static bool RescaleTransferFunctionToDataRange (vtkSMProxy *proxy, vtkPVArrayInformation *info, bool extend=false, bool force=true)
 Rescales transfer function ranges using the array information provided. More...
static bool SetScalarColoringInternal (vtkSMProxy *proxy, const char *arrayname, int attribute_type, bool useComponent, int component)
 Internal method to set scalar coloring, do not use directly. More...
static vtkSMProxy * GetLastLUTProxy (vtkSMProxy *proxy)
 Used as a memory of what was the last LUT proxy linked to this representation. More...
static void SetLastLUTProxy (vtkSMProxy *proxy, vtkSMProxy *lutProxy)
It provides helper functions for controlling transfer functions, scalar coloring, etc. Scalar bar controlling is still working for RenderView only for now, as it's controlling the widget.
Definition at line 22 of file vtkSMColorMapEditorHelper.h.
◆ GetLUTProxy()
static vtkSMProxy* vtkSMColorMapEditorHelper::GetLUTProxy ( vtkSMProxy *  proxy,
vtkSMProxy *  view
This method will return nullptr if no lut proxy exists in this view.
◆ GetUsingScalarColoring()
static bool vtkSMColorMapEditorHelper::GetUsingScalarColoring ( vtkSMProxy *  proxy)
This checks whether a property named "ColorArrayName" exists and has a non-empty string. This does not check for the validity of the array.
◆ SetupLookupTable()
static void vtkSMColorMapEditorHelper::SetupLookupTable ( vtkSMProxy *  proxy)
◆ UpdateScalarBarRange()
static bool vtkSMColorMapEditorHelper::UpdateScalarBarRange ( vtkSMProxy *  proxy,
vtkSMProxy *  view,
bool  deleteRange
If deleteRange is true, then the range stored for current representation proxy is deleted. This should be done when the scalar bar gets separated or becomes not visible. If deleteRange is false, then the range stored for current representation proxy is updated with the new range value.
◆ SetScalarColoring() [1/2]
static bool vtkSMColorMapEditorHelper::SetScalarColoring ( vtkSMProxy *  proxy,
const char *  arrayname,
int  attribute_type
This will set up a color and opacity transfer functions using vtkSMTransferFunctionProxy instance. If arrayname is nullptr, then scalar coloring is turned off. attribute_type must be one of vtkDataObject::AttributeTypes.
◆ SetScalarColoring() [2/2]
int  attribute_type,
int  component
This will set up a color and opacity transfer functions using vtkSMTransferFunctionProxy instance. If arrayname is nullptr, then scalar coloring is turned off. attribute_type must be one of vtkDataObject::AttributeTypes. component enables choosing a component to color with, -1 will change to Magnitude, >=0 will change to corresponding component.
◆ RescaleTransferFunctionToDataRange() [1/3]
static bool vtkSMColorMapEditorHelper::RescaleTransferFunctionToDataRange ( vtkSMProxy *  proxy,
bool  extend = false,
bool  force = true
Returns true if rescale was successful. If extend is true (false by default), the transfer function range will only be extended as needed to fit the data range. If force is false (true by default), then the transfer function range is not changed if locked.
◆ RescaleTransferFunctionToDataRange() [2/3]
int  attribute_type,
bool  force = true
Returns true if rescale was successful. attribute_type must be one of vtkDataObject::AttributeTypes. If extend is true (false by default), the transfer function range will only be extended as needed to fit the data range. If force is false (true by default), then the transfer function range is not changed if locked.
◆ RescaleTransferFunctionToDataRangeOverTime() [1/2]
static bool vtkSMColorMapEditorHelper::RescaleTransferFunctionToDataRangeOverTime ( vtkSMProxy *  proxy)
◆ RescaleTransferFunctionToDataRangeOverTime() [2/2]
static bool vtkSMColorMapEditorHelper::RescaleTransferFunctionToDataRangeOverTime ( vtkSMProxy *  proxy,
int  attribute_type
Returns true if rescale was successful. attribute_type must be one of vtkDataObject::AttributeTypes,
◆ RescaleTransferFunctionToVisibleRange() [1/2]
static bool vtkSMColorMapEditorHelper::RescaleTransferFunctionToVisibleRange ( vtkSMProxy *  proxy,
vtkSMProxy *  view
◆ RescaleTransferFunctionToVisibleRange() [2/2]
vtkSMProxy *  view,
int  attribute_type
◆ SetScalarBarVisibility()
static bool vtkSMColorMapEditorHelper::SetScalarBarVisibility ( vtkSMProxy *  proxy,
vtkSMProxy *  view,
bool  visible
This will create a new scalar bar as needed. Scalar bar is only shown if scalar coloring is indeed being used.
◆ HideScalarBarIfNotNeeded()
static bool vtkSMColorMapEditorHelper::HideScalarBarIfNotNeeded ( vtkSMProxy *  repr,
vtkSMProxy *  view
Use this method instead to only hide the scalar/color bar if no other visible representation in the view is mapping data using the scalar bar.
◆ IsScalarBarVisible()
static bool vtkSMColorMapEditorHelper::IsScalarBarVisible ( vtkSMProxy *  repr,
vtkSMProxy *  view
Return true if the scalar bar for this representation and view is visible, return false otherwise.
◆ GetArrayInformationForColorArray()
static vtkPVArrayInformation* vtkSMColorMapEditorHelper::GetArrayInformationForColorArray ( vtkSMProxy *  proxy,
bool  checkRepresentedData = true
If checkRepresentedData is true, it will also check in the represented data. Default is true. If none is found, returns nullptr.
◆ GetDecoratedArrayName()
static std::string vtkSMColorMapEditorHelper::GetDecoratedArrayName ( vtkSMProxy *  proxy,
const std::string &  arrayname
◆ GetProminentValuesInformationForColorArray()
static vtkPVProminentValuesInformation* vtkSMColorMapEditorHelper::GetProminentValuesInformationForColorArray ( vtkSMProxy *  proxy,
double  uncertaintyAllowed = 1e-6,
double  fraction = 1e-3,
bool  force = false
Otherwise returns nullptr.
◆ GetEstimatedNumberOfAnnotationsOnScalarBar()
static int vtkSMColorMapEditorHelper::GetEstimatedNumberOfAnnotationsOnScalarBar ( vtkSMProxy *  proxy,
vtkSMProxy *  view
◆ IsScalarBarStickyVisible()
static int vtkSMColorMapEditorHelper::IsScalarBarStickyVisible ( vtkSMProxy *  proxy,
vtkSMProxy *  view
should be visible whenever this representation is also visible. It returns 1 if the scalar bar is sticky visible, 0 other wise. If any problem is encountered, for example if view == nullptr, or if the scalar bar representation is not instanciated / found, it returns -1.
◆ RescaleTransferFunctionToDataRange() [3/3]
vtkPVArrayInformation *  info,
bool  force = true
staticprotected
◆ SetScalarColoringInternal()
static bool vtkSMColorMapEditorHelper::SetScalarColoringInternal ( vtkSMProxy *  proxy,
int  attribute_type,
bool  useComponent,
int  component
staticprotected
◆ GetLastLUTProxy()
static vtkSMProxy* vtkSMColorMapEditorHelper::GetLastLUTProxy ( vtkSMProxy *  proxy)
staticprotected
This is used in UpdateScalarBarRange to update the scalar bar range when turning off the coloring for this representation.
◆ SetLastLUTProxy()
static void vtkSMColorMapEditorHelper::SetLastLUTProxy ( vtkSMProxy *  proxy,
vtkSMProxy *  lutProxy
staticprotected
