vtkSMDoubleMapProperty Class Reference
a map property storing double values More...
#include <vtkSMDoubleMapProperty.h>
Inheritance diagram for vtkSMDoubleMapProperty:
Collaboration diagram for vtkSMDoubleMapProperty:
typedef vtkSMMapProperty Superclass
- Public Types inherited from vtkSMMapProperty
typedef vtkSMProperty Superclass
- Public Types inherited from vtkSMProperty
void SetNumberOfComponents (unsigned int components)
 Sets the number of components. More...
unsigned int GetNumberOfComponents ()
 Returns the number of components. More...
void SetElement (vtkIdType index, double value)
 Sets the element at index to value. More...
void SetElements (vtkIdType index, const double *values)
 Sets the elements at index to values. More...
void SetElements (vtkIdType index, const double *values, unsigned int numValues)
void SetElementComponent (vtkIdType index, unsigned int component, double value)
 Sets the component at index to value. More...
double GetElement (vtkIdType index)
 Returns the element at index. More...
double * GetElements (vtkIdType index)
 Returns the elements at index. More...
double GetElementComponent (vtkIdType index, vtkIdType component)
 Returns the element component at index. More...
void RemoveElement (vtkIdType index)
 Removes the element at index. More...
vtkIdType GetNumberOfElements () override
 Returns the number of elements. More...
bool HasElement (vtkIdType index)
 Returns true if the property has an element with the given index. More...
void ClearElements ()
 Clears all of the elements from the property. More...
VTK_NEWINSTANCE vtkSMDoubleMapPropertyIterator * NewIterator ()
 Returns a new iterator for the map. More...
void * GetMapPointer ()
void Copy (vtkSMProperty *src) override
 Copy all property values. More...
void ResetToXMLDefaults () override
 For properties that support specifying defaults in XML configuration, this method will reset the property value to the default values specified in the XML. More...
- Public Member Functions inherited from vtkSMMapProperty
bool IsValueDefault () override
 Returns true if the current value is the same as the default value. More...
- Public Member Functions inherited from vtkSMProperty
int IsInDomains ()
 Returns true if all values are in all domains, false otherwise. More...
int IsInDomains (vtkSMDomain **domain)
 Overload of IsInDomains() that provides a mechanism to return the first domain that fails the check. More...
void UnRegister (vtkObjectBase *obj) override
 Overloaded to break the reference loop caused by the internal domain iterator. More...
vtkSMDomainIterator * NewDomainIterator ()
 Creates, initializes and returns a new domain iterator. More...
vtkSMDomain * GetDomain (const char *name)
 Returns a domain give a name. More...
vtkSMDomain * FindDomain (const char *classname)
 Returns the first domain which is of the specified type. More...
template<class DomainType >
DomainType * FindDomain ()
 Same as FindDomain(classname), except the classname is deduced from the type. More...
unsigned int GetNumberOfDomains ()
 Returns the number of domains this property has. More...
void AddDomain (const char *name, vtkSMDomain *dom)
 Properties can have one or more domains. More...
virtual void AddLinkedProperty (vtkSMProperty *targetProperty)
 Add a link to a property whose value should be synchronized with this property value. More...
virtual void RemoveLinkedProperty (vtkSMProperty *targetProperty)
 Remove a link to a property added with AddLinkedProperty() More...
virtual void RemoveFromSourceLink ()
 Remove a link from the source property. More...
void ResetToDefault ()
 Simply calls this->ResetToDomainDefaults() and if that returns false, calls this->ResetToXMLDefaults(). More...
virtual bool ResetToDomainDefaults (bool use_unchecked_values=false)
 Iterates over all domains and call SetDefaultValues() on each domain until the first one returns true i.e. More...
vtkSMProxy * GetParent ()
 Get the proxy to which this property belongs. More...
virtual bool IsStateIgnored ()
bool HasDomainsWithRequiredProperties ()
 Returns true if the property has a domain with required properties. More...
virtual void ClearUncheckedElements ()
 Use this method to clear unchecked values set of this property. More...
 PARAVIEW_DEPRECATED_IN_5_12_0 ("Use vtkSMObject::CreatePrettyLabel(const std::string& name) instead.") static const char *CreateNewPrettyLabel(const char *name)
 Given the string, this method will create and set a well-formated string as XMLLabel and returns it. More...
virtual void SetCommand (const char *)
 The command name used to set the value on the server object. More...
virtual char * GetCommand ()
virtual void SetImmediateUpdate (int)
 If ImmediateUpdate is true, the value of the property will be pushed to the server as soon as it is modified. More...
virtual int GetImmediateUpdate ()
virtual int GetInformationOnly ()
 Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
virtual int GetIgnoreSynchronization ()
 If IgnoreSynchronization is set to true, this property is used to prevent that property from being updated when changed remotely by another collaborative client. More...
virtual vtkSMProperty * GetInformationProperty ()
 Get the associated information property. More...
virtual void SetAnimateable (int)
 Get/Set if the property is animateable. More...
virtual int GetAnimateable ()
virtual void SetIsInternal (int)
 Get/Set if the property is internal to server manager. More...
virtual int GetIsInternal ()
virtual void SetNoCustomDefault (int)
 Sets whether the property should ignore custom default settings. More...
virtual int GetNoCustomDefault ()
 Gets whether the property should ignore custom default settings. More...
virtual void SetPanelVisibility (const char *)
 Sets the panel visibility for the property. More...
virtual char * GetPanelVisibility ()
 Returns the panel visibility for the property. More...
virtual void SetPanelVisibilityDefaultForRepresentation (const char *)
 Sets the panel visibility to default if the current representation type matches representation. More...
virtual char * GetPanelVisibilityDefaultForRepresentation ()
 Returns which representation type the property will be shown by default for. More...
virtual void SetPanelWidget (const char *)
 Sets the name of the custom panel widget to use for the property. More...
virtual char * GetPanelWidget ()
 Returns name of the panel widget for the property. More...
virtual void SetDisableSubTrace (const char *)
 Sets the tracing of sub property of this property. More...
virtual char * GetDisableSubTrace ()
 Returns the tracing state of the properties of this property. More...
virtual char * GetXMLLabel ()
 The label assigned by the xml parser. More...
virtual char * GetXMLName ()
 The name assigned by the xml parser. More...
virtual int GetRepeatable ()
 If repeatable, a property can have 1 or more values of the same kind. More...
 The server manager configuration XML may define <Hints/> element for a property. More...
void Modified () override
 Overridden to support blocking of modified events. More...
static vtkSMDoubleMapProperty * New ()
static vtkSMDoubleMapProperty * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMMapProperty
static vtkSMMapProperty * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMProperty
static vtkSMProperty * New ()
static vtkSMProperty * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMDoubleMapProperty ()
 ~vtkSMDoubleMapProperty () override
void WriteTo (vtkSMMessage *msg) override
 Let the property write its content into the stream. More...
void ReadFrom (const vtkSMMessage *message, int message_offset, vtkSMProxyLocator *locator) override
int ReadXMLAttributes (vtkSMProxy *parent, vtkPVXMLElement *element) override
void SaveStateValues (vtkPVXMLElement *propertyElement) override
 This method must be overridden by concrete class in order to save the real property data. More...
int LoadState (vtkPVXMLElement *element, vtkSMProxyLocator *loader) override
 Updates state from an XML element. More...
- Protected Member Functions inherited from vtkSMMapProperty
 vtkSMMapProperty ()
 ~vtkSMMapProperty () override
- Protected Member Functions inherited from vtkSMProperty
 vtkSMProperty ()
 ~vtkSMProperty () override
virtual void ReadFrom (const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *)
 Let the property read and set its content from the stream. More...
virtual void UpdateAllInputs ()
 Update all proxies referred by this property (if any). More...
 Internal. More...
void AddDependent (vtkSMDomain *dom)
 Internal. More...
void RemoveAllDependents ()
 Removes all dependents. More...
void UpdateDomains ()
 Calls Update() on all domains contained by the property as well as all dependent domains. More...
virtual void SaveState (vtkPVXMLElement *parent, const char *property_name, const char *uid, int saveDomains=1)
 Save the property state in XML. More...
virtual void SaveDomainState (vtkPVXMLElement *propertyElement, const char *uid)
 Save property domain. More...
virtual void SetInformationOnly (int)
virtual void SetIgnoreSynchronization (int)
void SetInformationProperty (vtkSMProperty *ip)
void SetDocumentation (vtkSMDocumentation *)
void SetParent (vtkSMProxy *proxy)
virtual void SetStateIgnored (bool)
virtual void StateIgnoredOn ()
virtual void StateIgnoredOff ()
bool SetBlockModifiedEvents (bool block)
 Block/unblock modified events, returns the current state of the block flag. More...
virtual bool GetPendingModifiedEvents ()
 Returns if any modified evetns are pending. More...
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMProperty
vtkPVXMLElement * Hints
char * Command
vtkSMPropertyInternals * PInternals
int ImmediateUpdate
int Animateable
int IsInternal
int NoCustomDefault
char * XMLName
char * XMLLabel
char * PanelVisibility
char * PanelVisibilityDefaultForRepresentation
char * PanelWidget
char * DisableSubTrace
vtkSMDomainIterator * DomainIterator
int InformationOnly
int IgnoreSynchronization
vtkSMInformationHelper * InformationHelper
vtkSMProperty * InformationProperty
int Repeatable
vtkWeakPointer< vtkSMProxy > Proxy
bool StateIgnored
vtkSMPropertyLink * Links
vtkSMDoubleMapProperty stores a map of vtkIdType keys to double values.
Definition at line 19 of file vtkSMDoubleMapProperty.h.
Definition at line 23 of file vtkSMDoubleMapProperty.h.
◆ vtkSMDoubleMapProperty()
vtkSMDoubleMapProperty::vtkSMDoubleMapProperty ( )
◆ ~vtkSMDoubleMapProperty()
vtkSMDoubleMapProperty::~vtkSMDoubleMapProperty ( )
static vtkSMDoubleMapProperty* vtkSMDoubleMapProperty::New ( )
virtual const char* vtkSMDoubleMapProperty::GetClassName ( )
Reimplemented from vtkSMMapProperty.
static int vtkSMDoubleMapProperty::IsTypeOf ( const char *  type)
virtual int vtkSMDoubleMapProperty::IsA ( const char *  type)
static vtkSMDoubleMapProperty* vtkSMDoubleMapProperty::SafeDownCast ( vtkObject *  o)
void vtkSMDoubleMapProperty::PrintSelf ( ostream &  os,
◆ SetNumberOfComponents()
void vtkSMDoubleMapProperty::SetNumberOfComponents ( unsigned int  components)
◆ GetNumberOfComponents()
unsigned int vtkSMDoubleMapProperty::GetNumberOfComponents ( )
◆ SetElement()
void vtkSMDoubleMapProperty::SetElement ( vtkIdType  index,
double  value
◆ SetElements() [1/2]
void vtkSMDoubleMapProperty::SetElements ( vtkIdType  index,
const double *  values
◆ SetElements() [2/2]
const double *  values,
◆ SetElementComponent()
void vtkSMDoubleMapProperty::SetElementComponent ( vtkIdType  index,
double  value
◆ GetElement()
double vtkSMDoubleMapProperty::GetElement ( vtkIdType  index)
◆ GetElements()
double* vtkSMDoubleMapProperty::GetElements ( vtkIdType  index)
◆ GetElementComponent()
double vtkSMDoubleMapProperty::GetElementComponent ( vtkIdType  index,
vtkIdType  component
◆ RemoveElement()
void vtkSMDoubleMapProperty::RemoveElement ( vtkIdType  index)
◆ GetNumberOfElements()
vtkIdType vtkSMDoubleMapProperty::GetNumberOfElements ( )
◆ HasElement()
bool vtkSMDoubleMapProperty::HasElement ( vtkIdType  index)
◆ ClearElements()
void vtkSMDoubleMapProperty::ClearElements ( )
◆ NewIterator()
VTK_NEWINSTANCE vtkSMDoubleMapPropertyIterator* vtkSMDoubleMapProperty::NewIterator ( )
◆ GetMapPointer()
void* vtkSMDoubleMapProperty::GetMapPointer ( )
◆ Copy()
void vtkSMDoubleMapProperty::Copy ( vtkSMProperty *  src)
Reimplemented from vtkSMProperty.
◆ ResetToXMLDefaults()
void vtkSMDoubleMapProperty::ResetToXMLDefaults ( )
◆ WriteTo()
void vtkSMDoubleMapProperty::WriteTo ( vtkSMMessage *  msg)
overrideprotectedvirtual
◆ ReadFrom()
void vtkSMDoubleMapProperty::ReadFrom ( const vtkSMMessage *  message,
int  message_offset,
vtkSMProxyLocator *  locator
◆ ReadXMLAttributes()
int vtkSMDoubleMapProperty::ReadXMLAttributes ( vtkSMProxy *  parent,
vtkPVXMLElement *  element
◆ SaveStateValues()
void vtkSMDoubleMapProperty::SaveStateValues ( vtkPVXMLElement *  propertyElement)
◆ LoadState()
int vtkSMDoubleMapProperty::LoadState ( vtkPVXMLElement *  element,
vtkSMProxyLocator *  loader
Returns 0 on failure.
