Classes | Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | Friends | List of all members
vtkSMProxyListDomain Class Reference
union of proxies. More...
#include <vtkSMProxyListDomain.h>
Inheritance diagram for vtkSMProxyListDomain:
Collaboration diagram for vtkSMProxyListDomain:
struct  ProxyType
 Used to identify a proxy type. More...
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
const std::vector< ProxyType > & GetProxyTypes () const
 Returns a vector of proxy types for the proxies in the domain. More...
unsigned int GetNumberOfProxyTypes ()
 Returns the number of proxies in the domain. More...
const char * GetProxyGroup (unsigned int index)
 Returns the xml group name for the proxy at a given index. More...
const char * GetProxyName (unsigned int index)
 Returns the xml type name for the proxy at a given index. More...
const char * GetProxyName (vtkSMProxy *proxy)
 If the proxy is part of the domain, then this returns the name used for the proxy in the domain. More...
vtkSMProxy * GetProxyWithName (const char *pname)
 Inverse of GetProxyName, returns the first proxy with the given name. More...
int IsInDomain (vtkSMProperty *property) override
 This always returns true. More...
void AddProxy (vtkSMProxy *)
 Add a proxy to the domain. More...
bool HasProxy (vtkSMProxy *)
 Returns if the proxy is present in the domain. More...
unsigned int GetNumberOfProxies ()
 Get number of proxies in the domain. More...
vtkSMProxy * GetProxy (unsigned int index)
 Get proxy at a given index. More...
vtkSMProxy * FindProxy (const char *xmlgroup, const char *xmlname)
 Find a proxy in the domain of the given group and type. More...
int RemoveProxy (vtkSMProxy *proxy)
 Removes the first occurrence of the proxy in the domain. More...
int RemoveProxy (unsigned int index)
 Removes the proxy at the given index. More...
void CreateProxies (vtkSMSessionProxyManager *pxm)
 Creates and populates the domain with the proxy-types. More...
int SetDefaultValues (vtkSMProperty *prop, bool use_unchecked_values) override
 A vtkSMProperty is often defined with a default value in the XML itself. More...
void SetLogName (const char *prefix)
 Sets log name for each of the proxy in the domain using the prefix provided. More...
virtual void SetDefaultIndex (unsigned int)
 Set and Get the default proxy index. More...
virtual unsigned int GetDefaultIndex ()
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void Update (vtkSMProperty *requestingProperty)
 Update self based on the "unchecked" values of all required properties. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMProxyListDomain * New ()
static vtkSMProxyListDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMProxyListDomain ()
 ~vtkSMProxyListDomain () override
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
void AddProxy (const char *group, const char *name)
 Adds a proxy type, used by ReadXMLAttributes(). More...
void ChildSaveState (vtkPVXMLElement *propertyElement) override
 Save state for this domain. More...
int LoadState (vtkPVXMLElement *domainElement, vtkSMProxyLocator *loader) override
void SetProxies (vtkSMProxy **proxies, unsigned int count)
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
unsigned int DefaultIndex = 0
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
Friends
class vtkSMProxyProperty
union of proxies.
This domain is a collection of proxies that can be assigned as the value to a vtkSMProxyProperty. The Server Manager configuration defines the proxy types that form this list, while the value of this domain is the list of instances of proxies. Example usage :
<ProxyListDomain name="proxy_list">
<Proxy group="implicit_functions"
name="Plane" />
<Group name="implicit_functions"/>
</ProxyListDomain>
See also
vtkSMDomain vtkSMProxyProperty
Definition at line 40 of file vtkSMProxyListDomain.h.
Definition at line 44 of file vtkSMProxyListDomain.h.
◆ vtkSMProxyListDomain()
vtkSMProxyListDomain::vtkSMProxyListDomain ( )
◆ ~vtkSMProxyListDomain()
vtkSMProxyListDomain::~vtkSMProxyListDomain ( )
static vtkSMProxyListDomain* vtkSMProxyListDomain::New ( )
virtual const char* vtkSMProxyListDomain::GetClassName ( )
Reimplemented in vtkSMRangedTransferFunctionDomain.
static int vtkSMProxyListDomain::IsTypeOf ( const char *  type)
virtual int vtkSMProxyListDomain::IsA ( const char *  type)
static vtkSMProxyListDomain* vtkSMProxyListDomain::SafeDownCast ( vtkObject *  o)
void vtkSMProxyListDomain::PrintSelf ( ostream &  os,
◆ GetProxyTypes()
const std::vector<ProxyType>& vtkSMProxyListDomain::GetProxyTypes ( ) const
◆ GetNumberOfProxyTypes()
unsigned int vtkSMProxyListDomain::GetNumberOfProxyTypes ( )
◆ GetProxyGroup()
const char* vtkSMProxyListDomain::GetProxyGroup ( unsigned int  index)
◆ GetProxyName() [1/2]
const char* vtkSMProxyListDomain::GetProxyName ( unsigned int  index)
◆ GetProxyName() [2/2]
const char* vtkSMProxyListDomain::GetProxyName ( vtkSMProxy *  proxy)
Returns nullptr otherwise.
◆ GetProxyWithName()
vtkSMProxy* vtkSMProxyListDomain::GetProxyWithName ( const char *  pname)
◆ IsInDomain()
int vtkSMProxyListDomain::IsInDomain ( vtkSMProperty *  property)
override
◆ AddProxy() [1/2]
void vtkSMProxyListDomain::AddProxy ( vtkSMProxy *  )
◆ HasProxy()
bool vtkSMProxyListDomain::HasProxy ( vtkSMProxy *  )
◆ GetNumberOfProxies()
unsigned int vtkSMProxyListDomain::GetNumberOfProxies ( )
◆ GetProxy()
vtkSMProxy* vtkSMProxyListDomain::GetProxy ( unsigned int  index)
◆ FindProxy()
vtkSMProxy* vtkSMProxyListDomain::FindProxy ( const char *  xmlgroup,
const char *  xmlname
◆ RemoveProxy() [1/2]
int vtkSMProxyListDomain::RemoveProxy ( vtkSMProxy *  proxy)
Returns if the proxy was removed.
◆ RemoveProxy() [2/2]
int vtkSMProxyListDomain::RemoveProxy ( unsigned int  index)
◆ CreateProxies()
void vtkSMProxyListDomain::CreateProxies ( vtkSMSessionProxyManager *  pxm)
Note that the newly created proxies won't be registered with the proxy manager.
◆ SetDefaultValues()
int vtkSMProxyListDomain::SetDefaultValues ( vtkSMProperty *  prop,
override
However, many times, the default value must be determined at run time. To facilitate this, domains can override this method to compute and set the default value for the property. Note that unlike the compile-time default values, the application must explicitly call this method to initialize the property.
◆ SetDefaultIndex()
virtual void vtkSMProxyListDomain::SetDefaultIndex ( unsigned int  )
◆ GetDefaultIndex()
virtual unsigned int vtkSMProxyListDomain::GetDefaultIndex ( )
◆ SetLogName()
void vtkSMProxyListDomain::SetLogName ( const char *  prefix)
◆ ReadXMLAttributes()
int vtkSMProxyListDomain::ReadXMLAttributes ( vtkSMProperty *  prop,
vtkPVXMLElement *  element
overrideprotectedvirtual
◆ AddProxy() [2/2]
void vtkSMProxyListDomain::AddProxy ( const char *  group,
const char *  name
◆ ChildSaveState()
void vtkSMProxyListDomain::ChildSaveState ( vtkPVXMLElement *  propertyElement)
◆ LoadState()
int vtkSMProxyListDomain::LoadState ( vtkPVXMLElement *  domainElement,
vtkSMProxyLocator *  loader
◆ SetProxies()
void vtkSMProxyListDomain::SetProxies ( vtkSMProxy **  proxies,
unsigned int  count
◆ vtkSMProxyProperty
friend class vtkSMProxyProperty
friend
Definition at line 190 of file vtkSMProxyListDomain.h.
◆ DefaultIndex
unsigned int vtkSMProxyListDomain::DefaultIndex = 0
Definition at line 193 of file vtkSMProxyListDomain.h.
