vtkSMMapProperty Class Reference
abstract superclass for all map properties More...
#include <vtkSMMapProperty.h>
Inheritance diagram for vtkSMMapProperty:
Collaboration diagram for vtkSMMapProperty:
typedef vtkSMProperty Superclass
- Public Types inherited from vtkSMProperty
virtual vtkIdType GetNumberOfElements ()
 Returns the number of elements for the value type. More...
bool IsValueDefault () override
 Returns true if the current value is the same as the default value. More...
void Copy (vtkSMProperty *src) override
 Copy all property values. More...
- Public Member Functions inherited from vtkSMProperty
int IsInDomains ()
 Returns true if all values are in all domains, false otherwise. More...
int IsInDomains (vtkSMDomain **domain)
 Overload of IsInDomains() that provides a mechanism to return the first domain that fails the check. More...
void UnRegister (vtkObjectBase *obj) override
 Overloaded to break the reference loop caused by the internal domain iterator. More...
vtkSMDomainIterator * NewDomainIterator ()
 Creates, initializes and returns a new domain iterator. More...
vtkSMDomain * GetDomain (const char *name)
 Returns a domain give a name. More...
vtkSMDomain * FindDomain (const char *classname)
 Returns the first domain which is of the specified type. More...
template<class DomainType >
DomainType * FindDomain ()
 Same as FindDomain(classname), except the classname is deduced from the type. More...
unsigned int GetNumberOfDomains ()
 Returns the number of domains this property has. More...
void AddDomain (const char *name, vtkSMDomain *dom)
 Properties can have one or more domains. More...
virtual void AddLinkedProperty (vtkSMProperty *targetProperty)
 Add a link to a property whose value should be synchronized with this property value. More...
virtual void RemoveLinkedProperty (vtkSMProperty *targetProperty)
 Remove a link to a property added with AddLinkedProperty() More...
virtual void RemoveFromSourceLink ()
 Remove a link from the source property. More...
void ResetToDefault ()
 Simply calls this->ResetToDomainDefaults() and if that returns false, calls this->ResetToXMLDefaults(). More...
virtual void ResetToXMLDefaults ()
 For properties that support specifying defaults in XML configuration, this method will reset the property value to the default values specified in the XML. More...
virtual bool ResetToDomainDefaults (bool use_unchecked_values=false)
 Iterates over all domains and call SetDefaultValues() on each domain until the first one returns true i.e. More...
vtkSMProxy * GetParent ()
 Get the proxy to which this property belongs. More...
virtual bool IsStateIgnored ()
bool HasDomainsWithRequiredProperties ()
 Returns true if the property has a domain with required properties. More...
virtual void ClearUncheckedElements ()
 Use this method to clear unchecked values set of this property. More...
 PARAVIEW_DEPRECATED_IN_5_12_0 ("Use vtkSMObject::CreatePrettyLabel(const std::string& name) instead.") static const char *CreateNewPrettyLabel(const char *name)
 Given the string, this method will create and set a well-formated string as XMLLabel and returns it. More...
virtual void SetCommand (const char *)
 The command name used to set the value on the server object. More...
virtual char * GetCommand ()
virtual void SetImmediateUpdate (int)
 If ImmediateUpdate is true, the value of the property will be pushed to the server as soon as it is modified. More...
virtual int GetImmediateUpdate ()
virtual int GetInformationOnly ()
 Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
virtual int GetIgnoreSynchronization ()
 If IgnoreSynchronization is set to true, this property is used to prevent that property from being updated when changed remotely by another collaborative client. More...
virtual vtkSMProperty * GetInformationProperty ()
 Get the associated information property. More...
virtual void SetAnimateable (int)
 Get/Set if the property is animateable. More...
virtual int GetAnimateable ()
virtual void SetIsInternal (int)
 Get/Set if the property is internal to server manager. More...
virtual int GetIsInternal ()
virtual void SetNoCustomDefault (int)
 Sets whether the property should ignore custom default settings. More...
virtual int GetNoCustomDefault ()
 Gets whether the property should ignore custom default settings. More...
virtual void SetPanelVisibility (const char *)
 Sets the panel visibility for the property. More...
virtual char * GetPanelVisibility ()
 Returns the panel visibility for the property. More...
virtual void SetPanelVisibilityDefaultForRepresentation (const char *)
 Sets the panel visibility to default if the current representation type matches representation. More...
virtual char * GetPanelVisibilityDefaultForRepresentation ()
 Returns which representation type the property will be shown by default for. More...
virtual void SetPanelWidget (const char *)
 Sets the name of the custom panel widget to use for the property. More...
virtual char * GetPanelWidget ()
 Returns name of the panel widget for the property. More...
virtual void SetDisableSubTrace (const char *)
 Sets the tracing of sub property of this property. More...
virtual char * GetDisableSubTrace ()
 Returns the tracing state of the properties of this property. More...
virtual char * GetXMLLabel ()
 The label assigned by the xml parser. More...
virtual char * GetXMLName ()
 The name assigned by the xml parser. More...
virtual int GetRepeatable ()
 If repeatable, a property can have 1 or more values of the same kind. More...
 The server manager configuration XML may define <Hints/> element for a property. More...
void Modified () override
 Overridden to support blocking of modified events. More...
static vtkSMMapProperty * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMProperty
static vtkSMProperty * New ()
static vtkSMProperty * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMMapProperty ()
 ~vtkSMMapProperty () override
int LoadState (vtkPVXMLElement *element, vtkSMProxyLocator *loader) override
 Updates state from an XML element. More...
int ReadXMLAttributes (vtkSMProxy *parent, vtkPVXMLElement *element) override
- Protected Member Functions inherited from vtkSMProperty
 vtkSMProperty ()
 ~vtkSMProperty () override
virtual void WriteTo (vtkSMMessage *msg)
 Let the property write its content into the stream. More...
virtual void ReadFrom (const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *)
 Let the property read and set its content from the stream. More...
virtual void UpdateAllInputs ()
 Update all proxies referred by this property (if any). More...
 Internal. More...
void AddDependent (vtkSMDomain *dom)
 Internal. More...
void RemoveAllDependents ()
 Removes all dependents. More...
void UpdateDomains ()
 Calls Update() on all domains contained by the property as well as all dependent domains. More...
virtual void SaveState (vtkPVXMLElement *parent, const char *property_name, const char *uid, int saveDomains=1)
 Save the property state in XML. More...
virtual void SaveStateValues (vtkPVXMLElement *propertyElement)
 This method must be overridden by concrete class in order to save the real property data. More...
virtual void SaveDomainState (vtkPVXMLElement *propertyElement, const char *uid)
 Save property domain. More...
virtual void SetInformationOnly (int)
virtual void SetIgnoreSynchronization (int)
void SetInformationProperty (vtkSMProperty *ip)
void SetDocumentation (vtkSMDocumentation *)
void SetParent (vtkSMProxy *proxy)
virtual void SetStateIgnored (bool)
virtual void StateIgnoredOn ()
virtual void StateIgnoredOff ()
bool SetBlockModifiedEvents (bool block)
 Block/unblock modified events, returns the current state of the block flag. More...
virtual bool GetPendingModifiedEvents ()
 Returns if any modified evetns are pending. More...
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMProperty
vtkPVXMLElement * Hints
char * Command
vtkSMPropertyInternals * PInternals
int ImmediateUpdate
int Animateable
int IsInternal
int NoCustomDefault
char * XMLName
char * XMLLabel
char * PanelVisibility
char * PanelVisibilityDefaultForRepresentation
char * PanelWidget
char * DisableSubTrace
vtkSMDomainIterator * DomainIterator
int InformationOnly
int IgnoreSynchronization
vtkSMInformationHelper * InformationHelper
vtkSMProperty * InformationProperty
int Repeatable
vtkWeakPointer< vtkSMProxy > Proxy
bool StateIgnored
vtkSMPropertyLink * Links
vtkSMMapProperty defines an interface common for all map properties. A map property stores a set of keys and values.
Definition at line 17 of file vtkSMMapProperty.h.
Definition at line 20 of file vtkSMMapProperty.h.
◆ vtkSMMapProperty()
vtkSMMapProperty::vtkSMMapProperty ( )
◆ ~vtkSMMapProperty()
vtkSMMapProperty::~vtkSMMapProperty ( )
virtual const char* vtkSMMapProperty::GetClassName ( )
Reimplemented from vtkSMProperty.
Reimplemented in vtkSMDoubleMapProperty.
static int vtkSMMapProperty::IsTypeOf ( const char *  type)
virtual int vtkSMMapProperty::IsA ( const char *  type)
static vtkSMMapProperty* vtkSMMapProperty::SafeDownCast ( vtkObject *  o)
void vtkSMMapProperty::PrintSelf ( ostream &  os,
◆ GetNumberOfElements()
virtual vtkIdType vtkSMMapProperty::GetNumberOfElements ( )
◆ IsValueDefault()
bool vtkSMMapProperty::IsValueDefault ( )
◆ Copy()
void vtkSMMapProperty::Copy ( vtkSMProperty *  src)
◆ LoadState()
int vtkSMMapProperty::LoadState ( vtkPVXMLElement *  element,
vtkSMProxyLocator *  loader
overrideprotectedvirtual
Returns 0 on failure.
◆ ReadXMLAttributes()
int vtkSMMapProperty::ReadXMLAttributes ( vtkSMProxy *  parent,
