vtkSMDoubleVectorProperty Class Reference
property representing a vector of doubles More...
#include <vtkSMDoubleVectorProperty.h>
Inheritance diagram for vtkSMDoubleVectorProperty:
Collaboration diagram for vtkSMDoubleVectorProperty:
typedef vtkSMVectorProperty Superclass
- Public Types inherited from vtkSMVectorProperty
typedef vtkSMProperty Superclass
- Public Types inherited from vtkSMProperty
unsigned int GetNumberOfElements () override
 Returns the size of the vector. More...
void SetNumberOfElements (unsigned int num) override
 Sets the size of the vector. More...
int SetElement (unsigned int idx, double value)
 Set the value of 1 element. More...
int SetElements1 (double value0)
 Set the value of 1st element. More...
int SetElements2 (double value0, double value1)
 Set the values of the first 2 elements. More...
int SetElements3 (double value0, double value1, double value2)
 Set the values of the first 3 elements. More...
int SetElements4 (double value0, double value1, double value2, double value3)
 Set the values of the first 4 elements. More...
int AppendElements (const double *values, unsigned int numValues)
 Append the values. More...
int AppendUncheckedElements (const double *values, unsigned int numValues)
 Append the values to the unchecked elements. More...
double GetElement (unsigned int idx)
 Returns the value of 1 element. More...
unsigned int GetNumberOfUncheckedElements () override
 Returns the size of unchecked elements. More...
double GetUncheckedElement (unsigned int idx)
 Returns the value of 1 unchecked element. More...
void SetUncheckedElement (unsigned int idx, double value)
 Set the value of 1 unchecked element. More...
void Copy (vtkSMProperty *src) override
 Copy all property values. More...
void ClearUncheckedElements () override
 API for setting unchecked element values. More...
bool IsValueDefault () override
 Returns true if the property's value is different from the default value. More...
void ResetToXMLDefaults () override
 For properties that support specifying defaults in XML configuration, this method will reset the property value to the default values specified in the XML. More...
int SetElements (const double *values)
 Set the values of all elements. More...
int SetElements (const double *values, unsigned int numValues)
double * GetElements ()
int SetUncheckedElements (const double *values)
 Sets the values of all the unchecked elements. More...
int SetUncheckedElements (const double *values, unsigned int numValues)
virtual int GetArgumentIsArray ()
 If ArgumentIsArray is true, multiple elements are passed in as array arguments. More...
virtual void SetArgumentIsArray (int)
- Public Member Functions inherited from vtkSMVectorProperty
virtual void SetInitialString (const char *)
virtual char * GetInitialString ()
bool ResetToDomainDefaults (bool use_unchecked_values=false) override
 Overridden to add support to load defaults from this->GetInformationProperty(), if one exists. More...
virtual int GetRepeatCommand ()
 If RepeatCommand is true, the command is invoked multiple times, each time with NumberOfElementsPerCommand values. More...
virtual void SetRepeatCommand (int)
virtual void RepeatCommandOn ()
virtual void RepeatCommandOff ()
virtual int GetNumberOfElementsPerCommand ()
virtual void SetNumberOfElementsPerCommand (int)
virtual int GetUseIndex ()
 If UseIndex and RepeatCommand are true, the property will add an index integer before each command. More...
virtual void SetUseIndex (int)
virtual void UseIndexOn ()
virtual void UseIndexOff ()
virtual void SetCleanCommand (const char *)
 Command that can be used to remove all values. More...
virtual char * GetCleanCommand ()
virtual void SetSetNumberCommand (const char *)
 If SetNumberCommand is set, it is called before Command with the number of arguments as the parameter. More...
virtual char * GetSetNumberCommand ()
- Public Member Functions inherited from vtkSMProperty
int IsInDomains ()
 Returns true if all values are in all domains, false otherwise. More...
int IsInDomains (vtkSMDomain **domain)
 Overload of IsInDomains() that provides a mechanism to return the first domain that fails the check. More...
void UnRegister (vtkObjectBase *obj) override
 Overloaded to break the reference loop caused by the internal domain iterator. More...
vtkSMDomainIterator * NewDomainIterator ()
 Creates, initializes and returns a new domain iterator. More...
vtkSMDomain * GetDomain (const char *name)
 Returns a domain give a name. More...
vtkSMDomain * FindDomain (const char *classname)
 Returns the first domain which is of the specified type. More...
template<class DomainType >
DomainType * FindDomain ()
 Same as FindDomain(classname), except the classname is deduced from the type. More...
unsigned int GetNumberOfDomains ()
 Returns the number of domains this property has. More...
void AddDomain (const char *name, vtkSMDomain *dom)
 Properties can have one or more domains. More...
virtual void AddLinkedProperty (vtkSMProperty *targetProperty)
 Add a link to a property whose value should be synchronized with this property value. More...
virtual void RemoveLinkedProperty (vtkSMProperty *targetProperty)
 Remove a link to a property added with AddLinkedProperty() More...
virtual void RemoveFromSourceLink ()
 Remove a link from the source property. More...
void ResetToDefault ()
 Simply calls this->ResetToDomainDefaults() and if that returns false, calls this->ResetToXMLDefaults(). More...
vtkSMProxy * GetParent ()
 Get the proxy to which this property belongs. More...
virtual bool IsStateIgnored ()
bool HasDomainsWithRequiredProperties ()
 Returns true if the property has a domain with required properties. More...
 PARAVIEW_DEPRECATED_IN_5_12_0 ("Use vtkSMObject::CreatePrettyLabel(const std::string& name) instead.") static const char *CreateNewPrettyLabel(const char *name)
 Given the string, this method will create and set a well-formated string as XMLLabel and returns it. More...
virtual void SetCommand (const char *)
 The command name used to set the value on the server object. More...
virtual char * GetCommand ()
virtual void SetImmediateUpdate (int)
 If ImmediateUpdate is true, the value of the property will be pushed to the server as soon as it is modified. More...
virtual int GetImmediateUpdate ()
virtual int GetInformationOnly ()
 Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
virtual int GetIgnoreSynchronization ()
 If IgnoreSynchronization is set to true, this property is used to prevent that property from being updated when changed remotely by another collaborative client. More...
virtual vtkSMProperty * GetInformationProperty ()
 Get the associated information property. More...
virtual void SetAnimateable (int)
 Get/Set if the property is animateable. More...
virtual int GetAnimateable ()
virtual void SetIsInternal (int)
 Get/Set if the property is internal to server manager. More...
virtual int GetIsInternal ()
virtual void SetNoCustomDefault (int)
 Sets whether the property should ignore custom default settings. More...
virtual int GetNoCustomDefault ()
 Gets whether the property should ignore custom default settings. More...
virtual void SetPanelVisibility (const char *)
 Sets the panel visibility for the property. More...
virtual char * GetPanelVisibility ()
 Returns the panel visibility for the property. More...
virtual void SetPanelVisibilityDefaultForRepresentation (const char *)
 Sets the panel visibility to default if the current representation type matches representation. More...
virtual char * GetPanelVisibilityDefaultForRepresentation ()
 Returns which representation type the property will be shown by default for. More...
virtual void SetPanelWidget (const char *)
 Sets the name of the custom panel widget to use for the property. More...
virtual char * GetPanelWidget ()
 Returns name of the panel widget for the property. More...
virtual void SetDisableSubTrace (const char *)
 Sets the tracing of sub property of this property. More...
virtual char * GetDisableSubTrace ()
 Returns the tracing state of the properties of this property. More...
virtual char * GetXMLLabel ()
 The label assigned by the xml parser. More...
virtual char * GetXMLName ()
 The name assigned by the xml parser. More...
virtual int GetRepeatable ()
 If repeatable, a property can have 1 or more values of the same kind. More...
 The server manager configuration XML may define <Hints/> element for a property. More...
void Modified () override
 Overridden to support blocking of modified events. More...
static vtkSMDoubleVectorProperty * New ()
static vtkSMDoubleVectorProperty * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMVectorProperty
static vtkSMVectorProperty * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMProperty
static vtkSMProperty * New ()
static vtkSMProperty * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMDoubleVectorProperty ()
 ~vtkSMDoubleVectorProperty () override
void WriteTo (vtkSMMessage *) override
 Let the property write its content into the stream. More...
void ReadFrom (const vtkSMMessage *, int msg_offset, vtkSMProxyLocator *) override
 Let the property read and set its content from the stream. More...
int ReadXMLAttributes (vtkSMProxy *parent, vtkPVXMLElement *element) override
void SetNumberOfUncheckedElements (unsigned int num) override
 Sets the size of unchecked elements. More...
int LoadState (vtkPVXMLElement *element, vtkSMProxyLocator *loader) override
 Load the XML state. More...
void SaveStateValues (vtkPVXMLElement *propElement) override
 This method must be overridden by concrete class in order to save the real property data. More...
- Protected Member Functions inherited from vtkSMVectorProperty
 vtkSMVectorProperty ()
 ~vtkSMVectorProperty () override
- Protected Member Functions inherited from vtkSMProperty
 vtkSMProperty ()
 ~vtkSMProperty () override
virtual void ReadFrom (const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *)
virtual void UpdateAllInputs ()
 Update all proxies referred by this property (if any). More...
 Internal. More...
void AddDependent (vtkSMDomain *dom)
 Internal. More...
void RemoveAllDependents ()
 Removes all dependents. More...
void UpdateDomains ()
 Calls Update() on all domains contained by the property as well as all dependent domains. More...
virtual void SaveState (vtkPVXMLElement *parent, const char *property_name, const char *uid, int saveDomains=1)
 Save the property state in XML. More...
virtual void SaveDomainState (vtkPVXMLElement *propertyElement, const char *uid)
 Save property domain. More...
virtual void SetInformationOnly (int)
virtual void SetIgnoreSynchronization (int)
void SetInformationProperty (vtkSMProperty *ip)
void SetDocumentation (vtkSMDocumentation *)
void SetParent (vtkSMProxy *proxy)
virtual void SetStateIgnored (bool)
virtual void StateIgnoredOn ()
virtual void StateIgnoredOff ()
bool SetBlockModifiedEvents (bool block)
 Block/unblock modified events, returns the current state of the block flag. More...
virtual bool GetPendingModifiedEvents ()
 Returns if any modified evetns are pending. More...
 vtkSMObject ()
 ~vtkSMObject () override
int ArgumentIsArray
- Protected Attributes inherited from vtkSMVectorProperty
int RepeatCommand
int NumberOfElementsPerCommand
int UseIndex
char * CleanCommand
char * SetNumberCommand
char * InitialString
- Protected Attributes inherited from vtkSMProperty
vtkPVXMLElement * Hints
char * Command
vtkSMPropertyInternals * PInternals
int ImmediateUpdate
int Animateable
int IsInternal
int NoCustomDefault
char * XMLName
char * XMLLabel
char * PanelVisibility
char * PanelVisibilityDefaultForRepresentation
char * PanelWidget
char * DisableSubTrace
vtkSMDomainIterator * DomainIterator
int InformationOnly
int IgnoreSynchronization
vtkSMInformationHelper * InformationHelper
vtkSMProperty * InformationProperty
int Repeatable
vtkWeakPointer< vtkSMProxy > Proxy
bool StateIgnored
vtkSMPropertyLink * Links
Friends
class vtkSMRenderViewProxy
vtkSMDoubleVectorProperty is a concrete sub-class of vtkSMVectorProperty representing a vector of doubles.
See also
vtkSMVectorProperty vtkSMIntVectorProperty vtkSMStringVectorProperty
Definition at line 21 of file vtkSMDoubleVectorProperty.h.
Definition at line 25 of file vtkSMDoubleVectorProperty.h.
◆ vtkSMDoubleVectorProperty()
vtkSMDoubleVectorProperty::vtkSMDoubleVectorProperty ( )
◆ ~vtkSMDoubleVectorProperty()
vtkSMDoubleVectorProperty::~vtkSMDoubleVectorProperty ( )
static vtkSMDoubleVectorProperty* vtkSMDoubleVectorProperty::New ( )
virtual const char* vtkSMDoubleVectorProperty::GetClassName ( )
Reimplemented from vtkSMVectorProperty.
static int vtkSMDoubleVectorProperty::IsTypeOf ( const char *  type)
virtual int vtkSMDoubleVectorProperty::IsA ( const char *  type)
static vtkSMDoubleVectorProperty* vtkSMDoubleVectorProperty::SafeDownCast ( vtkObject *  o)
void vtkSMDoubleVectorProperty::PrintSelf ( ostream &  os,
◆ GetNumberOfElements()
unsigned int vtkSMDoubleVectorProperty::GetNumberOfElements ( )
Implements vtkSMVectorProperty.
◆ SetNumberOfElements()
void vtkSMDoubleVectorProperty::SetNumberOfElements ( unsigned int  num)
If num is larger than the current number of elements, this may cause reallocation and copying.
◆ SetElement()
int vtkSMDoubleVectorProperty::SetElement ( unsigned int  idx,
double  value
The vector is resized as necessary. Returns 0 if Set fails either because the property is read only or the value is not in all domains. Returns 1 otherwise.
◆ SetElements() [1/2]
int vtkSMDoubleVectorProperty::SetElements ( const double *  values)
The size of the values array has to be equal or larger to the size of the vector. Returns 0 if Set fails either because the property is read only or one or more of the values is not in all domains. Returns 1 otherwise.
◆ SetElements() [2/2]
int vtkSMDoubleVectorProperty::SetElements ( const double *  values,
◆ GetElements()
double* vtkSMDoubleVectorProperty::GetElements ( )
◆ SetUncheckedElements() [1/2]
int vtkSMDoubleVectorProperty::SetUncheckedElements ( const double *  values)
◆ SetUncheckedElements() [2/2]
int vtkSMDoubleVectorProperty::SetUncheckedElements ( const double *  values,
◆ SetElements1()
int vtkSMDoubleVectorProperty::SetElements1 ( double  value0)
The vector is resized as necessary. Returns 0 if Set fails either because the property is read only or one or more of the values is not in all domains. Returns 1 otherwise.
◆ SetElements2()
int vtkSMDoubleVectorProperty::SetElements2 ( double  value0,
double  value1
◆ SetElements3()
int vtkSMDoubleVectorProperty::SetElements3 ( double  value0,
double  value1,
double  value2
◆ SetElements4()
int vtkSMDoubleVectorProperty::SetElements4 ( double  value0,
double  value1,
double  value2,
double  value3
◆ AppendElements()
int vtkSMDoubleVectorProperty::AppendElements ( const double *  values,
Append the values.
◆ AppendUncheckedElements()
int vtkSMDoubleVectorProperty::AppendUncheckedElements ( const double *  values,
◆ GetElement()
double vtkSMDoubleVectorProperty::GetElement ( unsigned int  idx)
◆ GetNumberOfUncheckedElements()
unsigned int vtkSMDoubleVectorProperty::GetNumberOfUncheckedElements ( )
Usually this is the same as the number of elements but can be different before a domain check is performed.
◆ GetUncheckedElement()
double vtkSMDoubleVectorProperty::GetUncheckedElement ( unsigned int  idx)
These are used by domains. SetElement() first sets the value of 1 unchecked element and then calls IsInDomain and updates the value of the corresponding element only if IsInDomain passes.
◆ SetUncheckedElement()
void vtkSMDoubleVectorProperty::SetUncheckedElement ( unsigned int  idx,
double  value
This can be used to check if a value is in all domains of the property. Call this and call IsInDomains().
◆ GetArgumentIsArray()
virtual int vtkSMDoubleVectorProperty::GetArgumentIsArray ( )
For example, For example, if RepeatCommand is true, NumberOfElementsPerCommand is 2, the command is SetFoo and the values are 1 2 3 4 5 6, the resulting stream will have:
* * Invoke obj SetFoo array(1, 2)
* * Invoke obj SetFoo array(3, 4)
* * Invoke obj SetFoo array(5, 6)
◆ SetArgumentIsArray()
virtual void vtkSMDoubleVectorProperty::SetArgumentIsArray ( int  )
◆ Copy()
void vtkSMDoubleVectorProperty::Copy ( vtkSMProperty *  src)
Reimplemented from vtkSMProperty.
◆ ClearUncheckedElements()
void vtkSMDoubleVectorProperty::ClearUncheckedElements ( )
◆ IsValueDefault()
bool vtkSMDoubleVectorProperty::IsValueDefault ( )
◆ ResetToXMLDefaults()
void vtkSMDoubleVectorProperty::ResetToXMLDefaults ( )
◆ WriteTo()
void vtkSMDoubleVectorProperty::WriteTo ( vtkSMMessage *  )
overrideprotectedvirtual
◆ ReadFrom()
void vtkSMDoubleVectorProperty::ReadFrom ( const vtkSMMessage *  ,
int  msg_offset,
vtkSMProxyLocator *
◆ ReadXMLAttributes()
int vtkSMDoubleVectorProperty::ReadXMLAttributes ( vtkSMProxy *  parent,
vtkPVXMLElement *  element
◆ SetNumberOfUncheckedElements()
void vtkSMDoubleVectorProperty::SetNumberOfUncheckedElements ( unsigned int  num)
◆ LoadState()
int vtkSMDoubleVectorProperty::LoadState ( vtkPVXMLElement *  element,
vtkSMProxyLocator *  loader
Load the XML state.
◆ SaveStateValues()
void vtkSMDoubleVectorProperty::SaveStateValues ( vtkPVXMLElement *  propertyElement)
◆ vtkSMRenderViewProxy
friend class vtkSMRenderViewProxy
friend
Definition at line 173 of file vtkSMDoubleVectorProperty.h.
◆ ArgumentIsArray
int vtkSMDoubleVectorProperty::ArgumentIsArray
Definition at line 187 of file vtkSMDoubleVectorProperty.h.
