Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Friends | List of all members
vtkSMPropertyLink Class Reference
#include <vtkSMPropertyLink.h>
Inheritance diagram for vtkSMPropertyLink:
Collaboration diagram for vtkSMPropertyLink:
typedef vtkSMLink Superclass
vtkSMProxy * GetLinkedProxy (int index) override
 Get a proxy involved in this link. More...
const char * GetLinkedPropertyName (int index)
 Get a property involved in this link. More...
void RemoveAllLinks () override
 Remove all links. More...
 This method is used to initialize the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalIDs set. More...
void AddLinkedProperty (vtkSMProxy *proxy, const char *propertyname, int updateDir)
 Add a property to the link. More...
void RemoveLinkedProperty (vtkSMProxy *proxy, const char *propertyname)
unsigned int GetNumberOfLinkedObjects () override
 Get the number of properties that are involved in this link. More...
unsigned int GetNumberOfLinkedProperties ()
int GetLinkedObjectDirection (int index) override
 Get the direction of a property involved in this link (see vtkSMLink::UpdateDirections) More...
int GetLinkedPropertyDirection (int index)
bool HasGlobalID ()
virtual void EnableLocalPushOnly ()
virtual void DisableLocalPushOnly ()
virtual void SetLocation (vtkTypeUInt32)
virtual void PrototypeOn ()
virtual void PrototypeOff ()
bool IsPrototype ()
virtual void SetPrototype (bool)
static vtkSMPropertyLink * New ()
static vtkSMPropertyLink * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMPropertyLink ()
 ~vtkSMPropertyLink () override
void Synchronize ()
 Synchronize the value of all output properties with the input property. More...
int LoadXMLState (vtkPVXMLElement *linkElement, vtkSMProxyLocator *locator) override
 Load the link state. More...
void SaveXMLState (const char *linkname, vtkPVXMLElement *parent) override
 Save the state of the link. More...
void UpdateVTKObjects (vtkSMProxy *caller) override
 Called when an input proxy is updated (UpdateVTKObjects). More...
void PropertyModified (vtkSMProxy *caller, const char *pname) override
 Called when a property of an input proxy is modified. More...
void UpdateProperty (vtkSMProxy *caller, const char *pname) override
 Called when a property is pushed. More...
void UpdateState () override
 Update the internal protobuf state. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
Friends
class vtkSMPropertyLinkInternals
class vtkSMPropertyLinkObserver
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Creates a link between two properties. Can create M->N links. At the time when the link is created every output property is synchornized with the first input property.
Definition at line 21 of file vtkSMPropertyLink.h.
Definition at line 25 of file vtkSMPropertyLink.h.
◆ vtkSMPropertyLink()
vtkSMPropertyLink::vtkSMPropertyLink ( )
◆ ~vtkSMPropertyLink()
vtkSMPropertyLink::~vtkSMPropertyLink ( )
static vtkSMPropertyLink* vtkSMPropertyLink::New ( )
virtual const char* vtkSMPropertyLink::GetClassName ( )
Reimplemented from vtkSMLink.
static int vtkSMPropertyLink::IsTypeOf ( const char *  type)
virtual int vtkSMPropertyLink::IsA ( const char *  type)
static vtkSMPropertyLink* vtkSMPropertyLink::SafeDownCast ( vtkObject *  o)
void vtkSMPropertyLink::PrintSelf ( ostream &  os,
◆ AddLinkedProperty()
void vtkSMPropertyLink::AddLinkedProperty ( vtkSMProxy *  proxy,
const char *  propertyname,
int  updateDir
updateDir determines whether a property of the proxy is read or written. When a property of an input proxy changes, it's value is pushed to all other output proxies in the link. A property can be set to be both input and output by adding 2 links, one to INPUT and the other to OUTPUT When a link is added, all output property values are synchronized with that of the input.
◆ RemoveLinkedProperty()
void vtkSMPropertyLink::RemoveLinkedProperty ( vtkSMProxy *  proxy,
◆ GetNumberOfLinkedObjects()
unsigned int vtkSMPropertyLink::GetNumberOfLinkedObjects ( )
Implements vtkSMLink.
◆ GetNumberOfLinkedProperties()
unsigned int vtkSMPropertyLink::GetNumberOfLinkedProperties ( )
◆ GetLinkedProxy()
vtkSMProxy* vtkSMPropertyLink::GetLinkedProxy ( int  index)
◆ GetLinkedPropertyName()
const char* vtkSMPropertyLink::GetLinkedPropertyName ( int  index)
◆ GetLinkedObjectDirection()
int vtkSMPropertyLink::GetLinkedObjectDirection ( int  index)
◆ GetLinkedPropertyDirection()
int vtkSMPropertyLink::GetLinkedPropertyDirection ( int  index)
◆ RemoveAllLinks()
void vtkSMPropertyLink::RemoveAllLinks ( )
Remove all links.
◆ LoadState()
void vtkSMPropertyLink::LoadState ( const vtkSMMessage *  msg,
vtkSMProxyLocator *  locator
This enables splitting the load process in 2 step to prevent invalid state when a property refers to a sub-proxy that does not exist yet.
◆ Synchronize()
void vtkSMPropertyLink::Synchronize ( )
◆ LoadXMLState()
int vtkSMPropertyLink::LoadXMLState ( vtkPVXMLElement *  linkElement,
overrideprotectedvirtual
◆ SaveXMLState()
void vtkSMPropertyLink::SaveXMLState ( const char *  linkname,
vtkPVXMLElement *  parent
◆ UpdateVTKObjects()
void vtkSMPropertyLink::UpdateVTKObjects ( vtkSMProxy *  proxy)
Argument is the input proxy.
◆ PropertyModified()
void vtkSMPropertyLink::PropertyModified ( vtkSMProxy *  proxy,
const char *  pname
caller:- the input proxy. pname:- name of the property being modified.
◆ UpdateProperty()
void vtkSMPropertyLink::UpdateProperty ( vtkSMProxy *  caller,
const char *  pname
caller :- the input proxy. pname :- name of property that was pushed.
◆ UpdateState()
void vtkSMPropertyLink::UpdateState ( )
◆ vtkSMPropertyLinkInternals
friend class vtkSMPropertyLinkInternals
friend
Definition at line 92 of file vtkSMPropertyLink.h.
◆ vtkSMPropertyLinkObserver
friend class vtkSMPropertyLinkObserver
friend
Definition at line 93 of file vtkSMPropertyLink.h.
