vtkSMPropertyModificationUndoElement Class Reference
#include <vtkSMPropertyModificationUndoElement.h>
Inheritance diagram for vtkSMPropertyModificationUndoElement:
Collaboration diagram for vtkSMPropertyModificationUndoElement:
typedef vtkSMUndoElement Superclass
- Public Types inherited from vtkSMUndoElement
typedef vtkUndoElement Superclass
- Public Types inherited from vtkUndoElement
int Undo () override
 Undo the operation encapsulated by this element. More...
int Redo () override
 Redo the operation encaspsulated by this element. More...
void ModifiedProperty (vtkSMProxy *proxy, const char *propertyname)
 Set the property/proxy that was modified. More...
bool Merge (vtkUndoElement *vtkNotUsed(new_element)) override
 Called on the older element in the UndoSet to merge with the element being added if both the elements are mergeable. More...
- Public Member Functions inherited from vtkSMUndoElement
virtual void SetSession (vtkSMSession *)
- Public Member Functions inherited from vtkUndoElement
virtual void SetUndoSetWorkingContext (vtkCollection *workCTX)
virtual bool GetMergeable ()
 Returns if this undo element can be merged with other undo elements. More...
static vtkSMPropertyModificationUndoElement * New ()
static vtkSMPropertyModificationUndoElement * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMUndoElement
static vtkSMUndoElement * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkUndoElement
static vtkUndoElement * SafeDownCast (vtkObject *o)
 vtkSMPropertyModificationUndoElement ()
 ~vtkSMPropertyModificationUndoElement () override
int RevertToState ()
virtual void SetPropertyName (const char *)
- Protected Member Functions inherited from vtkSMUndoElement
 vtkSMUndoElement ()
 ~vtkSMUndoElement () override
- Protected Member Functions inherited from vtkUndoElement
 vtkUndoElement ()
 ~vtkUndoElement () override
virtual void SetMergeable (bool)
 Subclasses must set this flag to enable merging of consecutive elements in an UndoSet. More...
vtkTypeUInt32 ProxyGlobalID
char * PropertyName
vtkSMMessage * PropertyState
- Protected Attributes inherited from vtkSMUndoElement
- Protected Attributes inherited from vtkUndoElement
bool Mergeable
vtkCollection * UndoSetWorkingContext
This is the concrete implementation for the Undo element for a property modification event. The undo action sets the property to the value that was pushed on to the server previous to the modification. The redo action sets the property to the modified value.
Definition at line 21 of file vtkSMPropertyModificationUndoElement.h.
Definition at line 25 of file vtkSMPropertyModificationUndoElement.h.
◆ vtkSMPropertyModificationUndoElement()
vtkSMPropertyModificationUndoElement::vtkSMPropertyModificationUndoElement ( )
◆ ~vtkSMPropertyModificationUndoElement()
vtkSMPropertyModificationUndoElement::~vtkSMPropertyModificationUndoElement ( )
static vtkSMPropertyModificationUndoElement* vtkSMPropertyModificationUndoElement::New ( )
virtual const char* vtkSMPropertyModificationUndoElement::GetClassName ( )
Reimplemented from vtkSMUndoElement.
static int vtkSMPropertyModificationUndoElement::IsTypeOf ( const char *  type)
virtual int vtkSMPropertyModificationUndoElement::IsA ( const char *  type)
static vtkSMPropertyModificationUndoElement* vtkSMPropertyModificationUndoElement::SafeDownCast ( vtkObject *  o)
void vtkSMPropertyModificationUndoElement::PrintSelf ( ostream &  os,
◆ Undo()
int vtkSMPropertyModificationUndoElement::Undo ( )
Implements vtkUndoElement.
◆ Redo()
int vtkSMPropertyModificationUndoElement::Redo ( )
◆ ModifiedProperty()
void vtkSMPropertyModificationUndoElement::ModifiedProperty ( vtkSMProxy *  proxy,
const char *  propertyname
◆ Merge()
bool vtkSMPropertyModificationUndoElement::Merge ( vtkUndoElement *  vtkNotUsednew_element)
vtkSMPropertyModificationUndoElement is mergeable with vtkSMPropertyModificationUndoElement alone if both represent change to the same property. Returns if the merge was successful.
Reimplemented from vtkUndoElement.
◆ RevertToState()
int vtkSMPropertyModificationUndoElement::RevertToState ( )
◆ SetPropertyName()
virtual void vtkSMPropertyModificationUndoElement::SetPropertyName ( const char *  )
protectedvirtual
◆ ProxyGlobalID
vtkTypeUInt32 vtkSMPropertyModificationUndoElement::ProxyGlobalID
Definition at line 59 of file vtkSMPropertyModificationUndoElement.h.
◆ PropertyName
char* vtkSMPropertyModificationUndoElement::PropertyName
Definition at line 62 of file vtkSMPropertyModificationUndoElement.h.
◆ PropertyState
vtkSMMessage* vtkSMPropertyModificationUndoElement::PropertyState
Definition at line 63 of file vtkSMPropertyModificationUndoElement.h.
