vtkSMInputArrayDomain Class Reference
domain to ensure that input has required types of arrays. More...
#include <vtkSMInputArrayDomain.h>
Inheritance diagram for vtkSMInputArrayDomain:
Collaboration diagram for vtkSMInputArrayDomain:
enum  AttributeTypes {
  POINT = vtkDataObject::POINT, CELL = vtkDataObject::CELL, FIELD = vtkDataObject::FIELD, ANY_EXCEPT_FIELD = vtkDataObject::POINT_THEN_CELL,
  VERTEX = vtkDataObject::VERTEX, EDGE = vtkDataObject::EDGE, ROW = vtkDataObject::ROW, ANY = vtkDataObject::NUMBER_OF_ATTRIBUTE_TYPES,
  NUMBER_OF_ATTRIBUTE_TYPES = ANY + 1
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
int IsInDomain (vtkSMProperty *property) override
 Returns true if the value of the property is in the domain. More...
int IsInDomain (vtkSMSourceProxy *proxy, unsigned int outputport=0)
 Returns true if input has one or more arrays that match the requirements on the given output port. More...
std::vector< int > GetAcceptableNumbersOfComponents () const
 Get the AcceptableNumberOfComponents vector Empty or containing a zero means no check. More...
int IsArrayAcceptable (vtkPVArrayInformation *arrayInfo)
 This method will check if the arrayInfo contain info about an acceptable array, by checking its number of components against this domain acceptable numbers of components. More...
virtual int GetAttributeType ()
 Get the attribute type. More...
const char * GetAttributeTypeAsString ()
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void Update (vtkSMProperty *requestingProperty)
 Update self based on the "unchecked" values of all required properties. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMInputArrayDomain * New ()
static vtkSMInputArrayDomain * SafeDownCast (vtkObject *o)
static void SetAutomaticPropertyConversion (bool)
 Get/Set the application wide setting for automatic conversion of properties. More...
static bool GetAutomaticPropertyConversion ()
static bool IsAttributeTypeAcceptable (int required_type, int attribute_type, int *acceptable_as_type=nullptr)
 Method to check if a particular attribute-type (attribute_type) will be accepted by this domain with a required attribute type (required_type). More...
static vtkSMInputArrayDomain * FindApplicableDomain (vtkSMProperty *property)
 Helper method find the first vtkSMInputArrayDomain on the property that is acceptable based on the value of the property. More...
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMInputArrayDomain ()
 ~vtkSMInputArrayDomain () override
virtual void SetAttributeType (int)
void SetAttributeType (const char *type)
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
bool IsAttributeTypeAcceptable (int attributeType)
 Returns true if based on this->AttributeType, the specified attributeType is acceptable to this domain. More...
bool HasAcceptableArray (vtkPVDataSetAttributesInformation *attrInfo)
 Returns true if based on this->AutomaticPropertyConversion and this->NumberOfComponents, an acceptable array can be found in the attrInfo. More...
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void ChildSaveState (vtkPVXMLElement *domainElement)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
int AttributeType
std::vector< int > AcceptableNumbersOfComponents
std::string DataType
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMInputArrayDomain is a domain that can be used on a vtkSMInputProperty to check if the pipeline input provides attribute arrays of the required types e.g. if a filter can only work if the input data set has cell data arrays, then one can use this domain.
vtkSMInputArrayDomain also provides a mechanism to check if the attribute arrays have a certain number of components.
When enabled, ParaView supports automatic array conversion i.e. extracting components or converting cell data to point data and vice-versa is done implicitly. In that case, vtkSMInputArrayDomain's behavior also changes as appropriate.
Supported XML attributes:
This domain doesn't support any required properties (to help clean old code, we print a warning if any required properties are specified).
Attention
Prior to ParaView 5.0, attribute_type="any" meant all attributes excepting field data. For being consistent with general understanding of "any", this has been changed to include field data arrays since 5.0. Use "any-except-field" for cases where the intention is to match any attribute arrays except field data arrays.
Definition at line 67 of file vtkSMInputArrayDomain.h.
Definition at line 71 of file vtkSMInputArrayDomain.h.
◆ AttributeTypes
Enumerator
POINT
CELL
FIELD
ANY_EXCEPT_FIELD
VERTEX
EDGE
ROW
ANY
Definition at line 109 of file vtkSMInputArrayDomain.h.
◆ vtkSMInputArrayDomain()
vtkSMInputArrayDomain::vtkSMInputArrayDomain ( )
◆ ~vtkSMInputArrayDomain()
vtkSMInputArrayDomain::~vtkSMInputArrayDomain ( )
static vtkSMInputArrayDomain* vtkSMInputArrayDomain::New ( )
virtual const char* vtkSMInputArrayDomain::GetClassName ( )
static int vtkSMInputArrayDomain::IsTypeOf ( const char *  type)
virtual int vtkSMInputArrayDomain::IsA ( const char *  type)
static vtkSMInputArrayDomain* vtkSMInputArrayDomain::SafeDownCast ( vtkObject *  o)
void vtkSMInputArrayDomain::PrintSelf ( ostream &  os,
◆ IsInDomain() [1/2]
int vtkSMInputArrayDomain::IsInDomain ( vtkSMProperty *  property)
override
The property has to be a vtkSMProxyProperty which points to a vtkSMSourceProxy. The input has to have one or more arrays that match the requirements.
◆ IsInDomain() [2/2]
int vtkSMInputArrayDomain::IsInDomain ( vtkSMSourceProxy *  proxy,
unsigned int  outputport = 0
◆ GetAttributeType()
virtual int vtkSMInputArrayDomain::GetAttributeType ( )
Valid values are defined in AttributeTypes which map to vtkDataObject::AttributeTypes.
◆ GetAttributeTypeAsString()
const char* vtkSMInputArrayDomain::GetAttributeTypeAsString ( )
◆ GetAcceptableNumbersOfComponents()
std::vector<int> vtkSMInputArrayDomain::GetAcceptableNumbersOfComponents ( ) const
◆ SetAutomaticPropertyConversion()
static void vtkSMInputArrayDomain::SetAutomaticPropertyConversion ( bool  )
Automatic conversion of properties allows conversion between cell and point based properties, and the extraction of vector components as scalar properties
◆ GetAutomaticPropertyConversion()
static bool vtkSMInputArrayDomain::GetAutomaticPropertyConversion ( )
◆ IsAttributeTypeAcceptable() [1/2]
static bool vtkSMInputArrayDomain::IsAttributeTypeAcceptable ( int  required_type,
int  attribute_type,
int *  acceptable_as_type = nullptr
This takes into consideration the state of AutomaticePropertyConversion flag. If a particular attribute_type is acceptable only because AutomaticPropertyConversion is true, acceptable_as_type value will be set to the attribute type that the particular attribute was automatically converted to. e.g. is required_type = POINT and attribute_type is CELL and AutomaticPropertyConversion is true, this method will return true and acceptable_as_type will be set to POINT. In other cases, acceptable_as_type is simply set to attribute_type.
◆ IsArrayAcceptable()
int vtkSMInputArrayDomain::IsArrayAcceptable ( vtkPVArrayInformation *  arrayInfo)
Note that it takes into account property conversion This method return the accepted number of components to use.
◆ FindApplicableDomain()
static vtkSMInputArrayDomain* vtkSMInputArrayDomain::FindApplicableDomain ( vtkSMProperty *  property)
The property is typically vtkSMInputProperty. If none of the domains applicable, this will simply return the first vtkSMInputArrayDomain that is found.
◆ SetAttributeType() [1/2]
virtual void vtkSMInputArrayDomain::SetAttributeType ( int  )
protectedvirtual
◆ SetAttributeType() [2/2]
void vtkSMInputArrayDomain::SetAttributeType ( const char *  type)
◆ ReadXMLAttributes()
int vtkSMInputArrayDomain::ReadXMLAttributes ( vtkSMProperty *  prop,
vtkPVXMLElement *  element
overrideprotectedvirtual
◆ IsAttributeTypeAcceptable() [2/2]
bool vtkSMInputArrayDomain::IsAttributeTypeAcceptable ( int  attributeType)
◆ HasAcceptableArray()
bool vtkSMInputArrayDomain::HasAcceptableArray ( vtkPVDataSetAttributesInformation *  attrInfo)
◆ AttributeType
int vtkSMInputArrayDomain::AttributeType
Definition at line 178 of file vtkSMInputArrayDomain.h.
◆ AcceptableNumbersOfComponents
std::vector<int> vtkSMInputArrayDomain::AcceptableNumbersOfComponents
Definition at line 179 of file vtkSMInputArrayDomain.h.
◆ DataType
std::string vtkSMInputArrayDomain::DataType
Definition at line 180 of file vtkSMInputArrayDomain.h.
