vtkSMRenderViewProxy.h
3  Program: ParaView
4  Module: vtkSMRenderViewProxy.h
5
6  Copyright (c) Kitware, Inc.
7  All rights reserved.
8  See Copyright.txt or http://www.paraview.org/HTML/Copyright.html for details.
9
10  This software is distributed WITHOUT ANY WARRANTY; without even
11  the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR
12  PURPOSE. See the above copyright notice for more information.
13
14 =========================================================================*/
24 #ifndef vtkSMRenderViewProxy_h
25 #define vtkSMRenderViewProxy_h
26
27 #include "vtkNew.h" // needed for vtkInteractorObserver.
28 #include "vtkRemotingViewsModule.h" //needed for exports
29 #include "vtkSMViewProxy.h"
30 class vtkCamera;
31 class vtkCollection;
32 class vtkFloatArray;
33 class vtkIntArray;
34 class vtkRenderer;
35 class vtkRenderWindow;
36 class vtkRenderWinwInteractor;
38
39 class VTKREMOTINGVIEWS_EXPORT vtkSMRenderViewProxy : public vtkSMViewProxy
40 {
41 public:
42  static vtkSMRenderViewProxy* New();
44  void PrintSelf(ostream& os, vtkIndent indent) override;
45
47
50  bool SelectSurfaceCells(const int region[4], vtkCollection* selectedRepresentations,
51  vtkCollection* selectionSources, bool multiple_selections = false,
52  int modifier = /* replace */ 0, bool select_blocks = false, const char* arrayName = nullptr);
53  bool SelectSurfacePoints(const int region[4], vtkCollection* selectedRepresentations,
54  vtkCollection* selectionSources, bool multiple_selections = false,
55  int modifier = /* replace */ 0, bool select_blocks = false, const char* arrayName = nullptr);
56  bool SelectFrustumCells(const int region[4], vtkCollection* selectedRepresentations,
57  vtkCollection* selectionSources, bool multiple_selections = false);
58  bool SelectFrustumPoints(const int region[4], vtkCollection* selectedRepresentations,
59  vtkCollection* selectionSources, bool multiple_selections = false);
60  bool SelectPolygonPoints(vtkIntArray* polygon, vtkCollection* selectedRepresentations,
61  vtkCollection* selectionSources, bool multiple_selections = false, int modifier = 0,
62  bool selectBlocks = false);
63  bool SelectPolygonCells(vtkIntArray* polygon, vtkCollection* selectedRepresentations,
64  vtkCollection* selectionSources, bool multiple_selections = false, int modifier = 0,
65  bool selectBlocks = false);
67
69
72  bool ComputeVisibleScalarRange(const int region[4], int fieldAssociation, const char* scalarName,
73  int component, double range[]);
74  bool ComputeVisibleScalarRange(
75  int fieldAssociation, const char* scalarName, int component, double range[]);
77
82  vtkSMRepresentationProxy* Pick(int x, int y);
83
89  vtkSMRepresentationProxy* PickBlock(int x, int y, unsigned int& flatIndex);
90
97  bool ConvertDisplayToPointOnSurface(
98  const int display_position[2], double world_position[3], bool snapOnMeshPoint = false);
99
105  virtual bool IsSelectionAvailable();
106
108
111  void ResetCamera();
112  void ResetCamera(double bounds[6]);
113  void ResetCamera(double xmin, double xmax, double ymin, double ymax, double zmin, double zmax);
115
119  virtual void ZoomTo(vtkSMProxy* representation);
120
122
126  virtual const char* IsSelectVisibleCellsAvailable();
127  virtual const char* IsSelectVisiblePointsAvailable();
129
136  void SetupInteractor(vtkRenderWindowInteractor* iren) override;
137
142
146  vtkRenderer* GetRenderer();
147
151  vtkCamera* GetActiveCamera();
152
161  void SynchronizeCameraProperties();
162
166  virtual bool LastRenderWasInteractive();
167
172  void Update() override;
173
177  bool GetNeedsUpdate() override;
178
183  bool StreamingUpdate(bool render_if_needed);
184
189  const char* GetRepresentationType(vtkSMSourceProxy* producer, int outputPort) override;
190
194  vtkRenderWindow* GetRenderWindow() override;
195
201  vtkSMViewProxyInteractorHelper* GetInteractorHelper();
202
206  vtkFloatArray* CaptureDepthBuffer();
207
212  vtkFloatArray* GetValuesFloat();
213
215
219  void StartCaptureValues();
220  void StopCaptureValues();
221
225  int GetValueRenderingMode();
226  void SetValueRenderingMode(int mode);
228
229 protected:
231  ~vtkSMRenderViewProxy() override;
232
237  void RenderForImageCapture() override;
238
242  void UpdateLOD();
243
248  void MarkDirty(vtkSMProxy* modifiedProxy) override;
249
250  bool SelectFrustumInternal(const int region[4], vtkCollection* selectedRepresentations,
251  vtkCollection* selectionSources, bool multiple_selections, int fieldAssociation);
252  bool SelectPolygonInternal(vtkIntArray* polygon, vtkCollection* selectedRepresentations,
253  vtkCollection* selectionSources, bool multiple_selections, int fieldAssociation, int modifier,
254  bool selectBlocks);
255
256  vtkTypeUInt32 PreRender(bool interactive) override;
257  void PostRender(bool interactive) override;
258
263  bool FetchLastSelection(bool multiple_selections, vtkCollection* selectedRepresentations,
264  vtkCollection* selectionSources, int modifier, bool selectBlocks);
265
269  void CreateVTKObjects() override;
270
276  bool IsInSelectionMode();
277
279  void ClearSelectionCache(bool force = false);
280
281  // Internal fields for the observer mechanism that is used to invalidate
282  // the cache of selection when the current user became master
283  unsigned long NewMasterObserverId;
284  void NewMasterCallback(vtkObject* src, unsigned long event, void* data);
285
287
288 private:
290  void operator=(const vtkSMRenderViewProxy&) = delete;
291
296  bool SelectInternal(const vtkClientServerStream& cmd, vtkCollection* selectedRepresentations,
297  vtkCollection* selectionSources, bool multiple_selections, int modifier = /* replace */ 0,
298  bool selectBlocks = false);
299
301 };
302
303 #endif
Proxy for a representations.
virtual const char * GetRepresentationType(vtkSMSourceProxy *producer, int outputPort)
Returns the xml name of the representation proxy to create to show the data produced in this view...
Called at the end of CreateVTKObjects().
virtual bool GetNeedsUpdate()
Returns true if the subsequent call to Update() will result in an actual update.
virtual void PostRender(bool vtkNotUsed(interactive))
Superclass for all view proxies.
static vtkSMViewProxy * New()
virtual vtkRenderWindow * GetRenderWindow()
Return the vtkRenderWindow used by this view, if any.
Store messages for the interpreter.
virtual vtkRenderWindowInteractor * GetInteractor()
Returns the interactor.
virtual void MarkDirty(vtkSMProxy *modifiedProxy)
Dirty means this algorithm will execute during next update.
virtual vtkTypeUInt32 PreRender(bool vtkNotUsed(interactive))
This method is called before executing code that could cause a render on the underlying vtkPVView...
virtual void RenderForImageCapture()
This method is called whenever the view wants to render to during image capture.
implementation for View that includes render window and renderers.
proxy for a VTK source on a server
Definition: vtkSMProxy.h:152
virtual void SetupInteractor(vtkRenderWindowInteractor *iren)
A client process need to set the interactor to enable interactivity.
virtual void Update()
Called vtkPVView::Update on the server-side.
helper class that make it easier to hook vtkRenderWindowInteractor and vtkSMViewProxy.
