Render View for ParaView. More...
#include <vtkPVRenderView.h>
| enum | InteractionModes { INTERACTION_MODE_UNINTIALIZED = -1, INTERACTION_MODE_3D = 0, INTERACTION_MODE_2D, INTERACTION_MODE_SELECTION, INTERACTION_MODE_ZOOM, INTERACTION_MODE_POLYGON } |
| enum | { DEFAULT_RENDERER = 0, NON_COMPOSITED_RENDERER = 1 } |
| Defines various renderer types. More... | |
| enum | GenericFilmicPresets { Custom = 0, Default = 1, Uncharted2 = 2 } |
| Defines tone mapping generic filmic presets. More... | |
| typedef vtkPVView | Superclass |
Public Types inherited from vtkPVView | |
| typedef vtkView | Superclass |
Public Types inherited from vtkView | |
| virtual vtkRenderer * | GetRenderer (int rendererType=DEFAULT_RENDERER) |
| Returns the renderer given an int identifying its type. More... | |
| vtkRenderWindowInteractor * | GetInteractor () |
| Returns the interactor. More... | |
| virtual void | SetupInteractor (vtkRenderWindowInteractor *) |
| Set the interactor. More... | |
| void | StillRender () override |
| Triggers a high-resolution render. More... | |
| void | InteractiveRender () override |
| Triggers a interactive render. More... | |
| void | ConfigureCompressor (const char *configuration) |
| Passes the compressor configuration to the client-server synchronizer, if any. More... | |
| virtual void | ResetCameraClippingRange () |
| Resets the clipping range. More... | |
| void | InvalidateCachedSelection () |
| Invalidates cached selection. More... | |
| void | SetMaxClipBounds (double bds[6]) |
| Used by Cinema to enforce a consistent depth scaling. More... | |
| virtual void | SetGridAxes3DActor (vtkPVGridAxes3DActor *) |
| Set the vtkPVGridAxes3DActor to use for the view. More... | |
| virtual void | SetOrientationAxesInteractivity (bool) |
| virtual void | SetOrientationAxesVisibility (bool) |
| void | SetOrientationAxesLabelColor (double r, double g, double b) |
| void | SetOrientationAxesOutlineColor (double r, double g, double b) |
| virtual void | SetCenterAxesVisibility (bool) |
| virtual void | SetCenterOfRotation (double x, double y, double z) |
| virtual void | SetRotationFactor (double factor) |
| void | SetKeyLightWarmth (double val) |
| void | SetKeyLightIntensity (double val) |
| void | SetKeyLightElevation (double val) |
| void | SetKeyLightAzimuth (double val) |
| void | SetFillLightWarmth (double val) |
| void | SetKeyToFillRatio (double val) |
| void | SetFillLightElevation (double val) |
| void | SetFillLightAzimuth (double val) |
| void | SetBackLightWarmth (double val) |
| void | SetKeyToBackRatio (double val) |
| void | SetBackLightElevation (double val) |
| void | SetBackLightAzimuth (double val) |
| void | SetHeadLightWarmth (double val) |
| void | SetKeyToHeadRatio (double val) |
| void | SetMaintainLuminance (int val) |
| virtual void | SetUseHiddenLineRemoval (bool) |
| virtual void | SetUseDepthPeeling (int val) |
| virtual void | SetUseDepthPeelingForVolumes (bool val) |
| virtual void | SetMaximumNumberOfPeels (int val) |
| virtual void | SetBackground (double r, double g, double b) |
| virtual void | SetBackground2 (double r, double g, double b) |
| virtual void | SetBackgroundTexture (vtkTexture *val) |
| virtual void | SetGradientBackground (int val) |
| virtual void | SetTexturedBackground (int val) |
| virtual void | SetSkyboxBackground (int val) |
| virtual void | SetUseEnvironmentLighting (bool val) |
| virtual void | SetEnvironmentalBG (double r, double g, double b) |
| virtual void | SetEnvironmentalBG2 (double r, double g, double b) |
| virtual void | SetEnvironmentalBGTexture (vtkTexture *val) |
| virtual void | SetGradientEnvironmentalBG (int val) |
| virtual void | SetTexturedEnvironmentalBG (int val) |
| virtual void | SetBackgroundMode (int val) |
| void | AddLight (vtkLight *) |
| void | RemoveLight (vtkLight *) |
| void | SetStereoCapableWindow (int val) |
| void | SetStereoRender (int val) |
| virtual void | SetStereoType (int) |
| virtual void | SetServerStereoType (int) |
| void | SetMultiSamples (int val) |
| void | SetAlphaBitPlanes (int val) |
| void | SetStencilCapable (int val) |
| void | SetParallelProjection (int mode) |
| virtual void | SetCamera2DManipulators (const int manipulators[9]) |
| virtual void | SetCamera3DManipulators (const int manipulators[9]) |
| void | SetCameraManipulators (vtkPVInteractorStyle *style, const int manipulators[9]) |
| virtual void | SetCamera2DMouseWheelMotionFactor (double factor) |
| virtual void | SetCamera3DMouseWheelMotionFactor (double factor) |
| void | Update () override |
| Overridden to synchronize information among processes whenever data changes. More... | |
| virtual void | UpdateLOD () |
| Asks representations to update their LOD geometries. More... | |
| int | GetDataDistributionMode (bool low_res) |
| Returns the data distribution mode to use. More... | |
| void | Deliver (int use_lod, unsigned int size, unsigned int *representation_ids) override |
| Called on all processes to request data-delivery for the list of representations. More... | |
| bool | GetUseOrderedCompositing () |
| Returns true when ordered compositing is needed on the current group of processes. More... | |
| bool | GetRenderEmptyImages () |
| Returns true when the compositor should not use the empty images optimization. More... | |
| void | CopyViewUpdateOptions (vtkPVRenderView *otherView) |
| Copy internal fields that are used for rendering decision such as remote/local rendering, composite and so on. More... | |
| bool | GetOSPRayContinueStreaming () |
| Has OSPRay reached the max frames? More... | |
| void | SetOSPRayRendererType (std::string) |
| Set the OSPRay renderer to use. More... | |
| virtual void | SetMaterialLibrary (vtkPVMaterialLibrary *) |
| For OSPRay, set the library of materials. More... | |
| void | SetViewTime (double value) override |
| Get/Set the time this view is showing. More... | |
| virtual vtkRenderViewBase * | GetRenderView () |
| void | ScaleRendererViewports (const double viewport[4]) override |
| Overridden to scale the OrientationWidget appropriately. More... | |
| void | SynchronizeMaximumIds (vtkIdType *maxPointId, vtkIdType *maxCellId) |
| This is used by vtkPVHardwareSelector to synchronize element ids between all ranks involved in selection. More... | |
| virtual void | SetInteractionMode (int mode) |
| Get/Set the interaction mode. More... | |
| virtual int | GetInteractionMode () |
| void | SetSize (int, int) override |
| Overridden to call InvalidateCachedSelection() whenever the render window parameters change. More... | |
| void | SetPosition (int, int) override |
| virtual vtkRenderer * | GetNonCompositedRenderer () |
| Gets the non-composited renderer for this view. More... | |
| vtkCamera * | GetActiveCamera () |
| Get/Set the active camera. More... | |
| virtual void | SetActiveCamera (vtkCamera *) |
| virtual vtkPVInteractorStyle * | GetInteractorStyle () |
| Returns the interactor style. More... | |
| void | ResetCamera () |
| Resets the active camera using collective prop-bounds. More... | |
| void | ResetCamera (double bounds[6]) |
| virtual void | SetSuppressRendering (bool) |
| SuppressRendering can be used to suppress the render within a StillRender or InteractiveRender. More... | |
| virtual bool | GetSuppressRendering () |
| virtual void | SuppressRenderingOn () |
| virtual void | SuppressRenderingOff () |
| virtual void | SetStillRenderImageReductionFactor (int) |
| Get/Set the reduction-factor to use when for StillRender(). More... | |
| virtual int | GetStillRenderImageReductionFactor () |
| virtual void | SetInteractiveRenderImageReductionFactor (int) |
| Get/Set the reduction-factor to use when for InteractiveRender(). More... | |
| virtual int | GetInteractiveRenderImageReductionFactor () |
| virtual void | SetRemoteRenderingThreshold (double) |
| Get/Set the data-size in megabytes above which remote-rendering should be used, if possible. More... | |
| virtual double | GetRemoteRenderingThreshold () |
| virtual void | SetLODRenderingThreshold (double) |
| Get/Set the data-size in megabytes above which LOD rendering should be used, if possible. More... | |
| virtual double | GetLODRenderingThreshold () |
| virtual void | SetLODResolution (double) |
| Get/Set the LOD resolution. More... | |
| virtual double | GetLODResolution () |
| virtual void | SetUseOutlineForLODRendering (bool) |
| When set to true, instead of using simplified geometry for LOD rendering, uses outline, if possible. More... | |
| virtual bool | GetUseOutlineForLODRendering () |
| void | SetUseLightKit (bool enable) |
| Enable/Disable light kit. More... | |
| virtual bool | GetUseLightKit () |
| virtual void | UseLightKitOn () |
| virtual void | UseLightKitOff () |
| void | StreamingUpdate (const double view_planes[24]) |
| void | DeliverStreamedPieces (unsigned int size, unsigned int *representation_ids) |
| void | SelectCells (int region[4], const char *array=nullptr) |
| Make a selection. More... | |
| void | SelectCells (int region0, int region1, int region2, int region3, const char *array=nullptr) |
| void | SelectPoints (int region[4], const char *array=nullptr) |
| void | SelectPoints (int region0, int region1, int region2, int region3, const char *array=nullptr) |
| void | Select (int field_association, int region[4], const char *array=nullptr) |
| void | SelectPolygonPoints (int *polygon2DArray, vtkIdType arrayLen) |
| Make a selection with a polygon. More... | |
| void | SelectPolygonCells (int *polygon2DArray, vtkIdType arrayLen) |
| void | SelectPolygon (int field_association, int *polygon2DArray, vtkIdType arrayLen) |
| virtual vtkSelection * | GetLastSelection () |
| Provides access to the last selection. More... | |
| virtual void | SetUseInteractiveRenderingForScreenshots (bool) |
| Set or get whether capture should be done as StillRender or InteractiveRender when capturing screenshots. More... | |
| virtual void | UseInteractiveRenderingForScreenshotsOn () |
| virtual void | UseInteractiveRenderingForScreenshotsOff () |
| virtual bool | GetUseInteractiveRenderingForScreenshots () |
| virtual bool | GetRemoteRenderingAvailable () |
| Returns if remote-rendering is possible on the current group of processes. More... | |
| void | RemoteRenderingAvailableOff () |
| void | NVPipeAvailableOn () |
| Determine if NVPipe is an available compressor option. More... | |
| void | NVPipeAvailableOff () |
| virtual bool | GetUsedLODForLastRender () |
| Returns true if the most recent render used LOD. More... | |
| void | SetLockBounds (bool nv) |
| Used by Cinema to enforce a consistent viewpoint and depth scaling. More... | |
| virtual bool | GetLockBounds () |
| int | RegisterPropForHardwareSelection (vtkPVDataRepresentation *repr, vtkProp *prop) |
| Representations that support hardware (render-buffer based) selection, should register the prop that they use for selection rendering. More... | |
| void | UnRegisterPropForHardwareSelection (vtkPVDataRepresentation *repr, vtkProp *prop) |
| void | SetShowAnnotation (bool val) |
| Enable/disable showing of annotation for developers. More... | |
| virtual void | SetUpdateAnnotation (bool) |
| void | SetAnnotationColor (double r, double g, double b) |
| Set color of annotation text for developers. More... | |
| virtual bool | GetUseLODForInteractiveRender () |
| Returns whether the view will use LOD rendering for the next InteractiveRender() call based on the geometry sizes determined by the most recent call to Update(). More... | |
| virtual bool | GetUseDistributedRenderingForRender () |
| Returns whether the view will use distributed rendering for the next full-resolution render. More... | |
| virtual bool | GetUseDistributedRenderingForLODRender () |
| Returns whether the view will use distributed rendering for the next low-resolution render. More... | |
| virtual vtkTypeUInt32 | GetStillRenderProcesses () |
| Returns the processes (vtkPVSession::ServerFlags) that are to be involved in the next StillRender() call based on the decisions made during the most recent Update(). More... | |
| virtual vtkTypeUInt32 | GetInteractiveRenderProcesses () |
| Returns the processes (vtkPVSession::ServerFlags) that are to be involved in the next InteractiveRender() call based on the decisions made during the most recent Update() and UpdateLOD(). More... | |
| virtual void | SetUseFXAA (bool) |
| Enable/disable FXAA antialiasing. More... | |
| virtual bool | GetUseFXAA () |
| void | SetFXAARelativeContrastThreshold (double val) |
| FXAA tunable parameters. More... | |
| void | SetFXAAHardContrastThreshold (double val) |
| void | SetFXAASubpixelBlendLimit (double val) |
| void | SetFXAASubpixelContrastThreshold (double val) |
| void | SetFXAAUseHighQualityEndpoints (bool val) |
| void | SetFXAAEndpointSearchIterations (int val) |
| void | SetUseToneMapping (bool v) |
| Tone Mapping options. More... | |
| virtual bool | GetUseToneMapping () |
| void | SetToneMappingType (int) |
| void | SetExposure (double) |
| void | SetContrast (double) |
| void | SetShoulder (double) |
| void | SetMidIn (double) |
| void | SetMidOut (double) |
| void | SetHdrMax (double) |
| void | SetUseACES (bool) |
| void | SetGenericFilmicPresets (int t) |
| virtual void | SetUseSSAO (bool) |
| SSAO options. More... | |
| virtual bool | GetUseSSAO () |
| virtual void | SetUseSSAODefaultPresets (bool) |
| virtual void | SetRadius (double) |
| virtual void | SetKernelSize (int) |
| virtual void | SetBias (double) |
| virtual void | SetBlur (bool) |
| void | AddPropToRenderer (vtkProp *prop) |
| Add props directly to the view. More... | |
| void | RemovePropFromRenderer (vtkProp *prop) |
| void | SetDrawCells (bool choice) |
| Tells view that it should draw a particular array component to the screen such that the pixels can be read back and decoded to obtain the values. More... | |
| void | SetArrayNameToDraw (const char *name) |
| void | SetArrayNumberToDraw (int fieldAttributeType) |
| void | SetArrayComponentToDraw (int comp) |
| void | SetScalarRange (double min, double max) |
| void | BeginValueCapture () |
| void | EndValueCapture () |
| void | SetValueRenderingModeCommand (int mode) |
| Current rendering mode of vtkValuePass (float or invertible RGB). More... | |
| int | GetValueRenderingModeCommand () |
| void | CaptureValuesFloat () |
| Access to vtkValuePass::FLOATING_POINT mode rendered image. More... | |
| vtkFloatArray * | GetCapturedValuesFloat () |
| void | StartCaptureLuminance () |
| Tells views that it should draw the lighting contributions to the framebuffer. More... | |
| void | StopCaptureLuminance () |
| void | CaptureZBuffer () |
| Access to the Z buffer. More... | |
| vtkFloatArray * | GetCapturedZBuffer () |
| void | SetEnableOSPRay (bool) |
| Switches between rasterization and ray tracing. More... | |
| bool | GetEnableOSPRay () |
| void | SetShadows (bool) |
| Controls whether OSPRay sends casts shadow rays or not. More... | |
| bool | GetShadows () |
| void | SetAmbientOcclusionSamples (int) |
| Sets the number of occlusion query rays that OSPRay sends at each intersection. More... | |
| int | GetAmbientOcclusionSamples () |
| void | SetRouletteDepth (int) |
| Sets the depth of monte carlo samples on the path tracer. More... | |
| int | GetRouletteDepth () |
| void | SetVolumeAnisotropy (double) |
| Set the path tracers volume anisotropy. More... | |
| double | GetVolumeAnisotropy () |
| void | SetSamplesPerPixel (int) |
| Set the number of primary rays that OSPRay shoots per pixel. More... | |
| int | GetSamplesPerPixel () |
| void | SetMaxFrames (int) |
| Set the number of render passes OSPRay takes to accumulate subsampled color results. More... | |
| int | GetMaxFrames () |
| void | SetDenoise (bool) |
| Controls whether to use image denoising to improve appearance. More... | |
| bool | GetDenoise () |
| void | SetLightScale (double) |
| Dimish or Amplify all lights in the scene. More... | |
| double | GetLightScale () |
| void | SetBackgroundNorth (double x, double y, double z) |
| Control of background orientation for OSPRay. More... | |
| void | SetBackgroundEast (double x, double y, double z) |
| void | SetTimeCacheSize (int) |
| Set the size of OSPRay's temporal cache. More... | |
| int | GetTimeCacheSize () |
Public Member Functions inherited from vtkPVView | |
| virtual void | SetPPI (int) |
| Description: Set the screen PPI. More... | |
| virtual int | GetPPI () |
| Overridden to not call Update() directly on the input representations, instead use ProcessViewRequest() for all vtkPVDataRepresentations. More... | |
| bool | InTileDisplayMode () |
| Returns true if the application is currently in tile display mode. More... | |
| bool | InCaveDisplayMode () |
| Returns true if the application is currently in cave/immersive display mode. More... | |
| bool | GetLocalProcessSupportsInteraction () |
| Returns true if the local process can support interaction. More... | |
| vtkRenderWindow * | GetRenderWindow () |
| If this view needs a render window (not all views may use one), this method can be used to get the render window associated with this view on the current process. More... | |
| vtkMTimeType | GetUpdateTimeStamp () |
| Provides access to the time when Update() was last called. More... | |
| virtual bool | IsCached (vtkPVDataRepresentation *) |
Called in vtkPVDataRepresentation::ProcessViewRequest to check if the representation already has cached data. More... | |
| virtual void | ClearCache (vtkPVDataRepresentation *) |
Called by vtkPVDataRepresentation whenever vtkPVDataRepresentation::MarkModified is called. More... | |
| virtual int * | GetPosition () |
| Set the position on this view in the multiview configuration. More... | |
| virtual void | GetPosition (int &, int &) |
| virtual void | GetPosition (int [2]) |
| virtual int * | GetSize () |
| Set the size of this view in the multiview configuration. More... | |
| virtual void | GetSize (int &, int &) |
| virtual void | GetSize (int [2]) |
| virtual double | GetViewTime () |
| virtual void | SetCacheKey (double) |
| Get/Set the cache key. More... | |
| virtual double | GetCacheKey () |
| virtual void | SetUseCache (bool) |
| Get/Set whether caching is enabled. More... | |
| virtual bool | GetUseCache () |
| virtual void | PrepareForScreenshot () |
| These methods are used to setup the view for capturing screen shots. More... | |
| virtual void | CleanupAfterScreenshot () |
| void | SetTileScale (int x, int y) |
| When saving screenshots with tiling, these methods get called. More... | |
| void | SetTileViewport (double x0, double y0, double x1, double y1) |
| This is solely intended to simplify debugging and use for any other purpose is vehemently discouraged. More... | |
| void | SetDeliveryManager (vtkPVDataDeliveryManager *) |
| Provides access to data delivery & cache manager for this view. More... | |
| virtual vtkPVDataDeliveryManager * | GetDeliveryManager () |
Public Member Functions inherited from vtkView | |
| vtkView * | NewInstance () const |
| void | AddRepresentation (vtkDataRepresentation *rep) |
| void | SetRepresentation (vtkDataRepresentation *rep) |
| vtkDataRepresentation * | AddRepresentationFromInputConnection (vtkAlgorithmOutput *conn) |
| vtkDataRepresentation * | SetRepresentationFromInputConnection (vtkAlgorithmOutput *conn) |
| vtkDataRepresentation * | AddRepresentationFromInput (vtkDataObject *input) |
| vtkDataRepresentation * | SetRepresentationFromInput (vtkDataObject *input) |
| void | RemoveRepresentation (vtkDataRepresentation *rep) |
| void | RemoveRepresentation (vtkAlgorithmOutput *rep) |
| void | RemoveAllRepresentations () |
| int | GetNumberOfRepresentations () |
| vtkDataRepresentation * | GetRepresentation (int index=0) |
| bool | IsRepresentationPresent (vtkDataRepresentation *rep) |
| vtkCommand * | GetObserver () |
| void | RegisterProgress (vtkObject *algorithm, const char *message=NULL) |
| void | UnRegisterProgress (vtkObject *algorithm) |
| static vtkPVRenderView * | New () |
| static vtkPVRenderView * | SafeDownCast (vtkObject *o) |
| static vtkInformationIntegerKey * | USE_LOD () |
| USE_LOD indicates if LOD is being used for the current render/update. More... | |
| static vtkInformationDoubleKey * | LOD_RESOLUTION () |
| Indicates the LOD resolution in REQUEST_UPDATE_LOD() pass. More... | |
| static vtkInformationIntegerKey * | USE_OUTLINE_FOR_LOD () |
| Indicates the LOD must use outline if possible in REQUEST_UPDATE_LOD() pass. More... | |
| static vtkInformationIntegerKey * | RENDER_EMPTY_IMAGES () |
| Representation can publish this key in their REQUEST_INFORMATION() pass to indicate that the representation needs to disable IceT's empty image optimization. More... | |
| static vtkInformationIntegerKey * | NEED_ORDERED_COMPOSITING () |
| Representation can publish this key in their REQUEST_INFORMATION() pass to indicate that the representation needs ordered compositing. More... | |
| static vtkInformationDoubleVectorKey * | VIEW_PLANES () |
| Key used to pass meta-data about the view frustum in REQUEST_STREAMING_UPDATE() pass. More... | |
| static vtkInformationRequestKey * | REQUEST_STREAMING_UPDATE () |
| Streaming pass request. More... | |
| static vtkInformationRequestKey * | REQUEST_PROCESS_STREAMED_PIECE () |
| Pass to relay the streamed "piece" to the representations. More... | |
| static void | SetDeliverToAllProcesses (vtkInformation *info, vtkPVDataRepresentation *repr, bool clone) |
Requests the view to deliver the pieces produced by the repr to all processes after a gather to the root node to merge the datasets generated by each process. More... | |
| static void | SetDeliverToClientAndRenderingProcesses (vtkInformation *info, vtkPVDataRepresentation *repr, bool deliver_to_client, bool gather_before_delivery, int port=0) |
| Requests the view to deliver the data to the client always. More... | |
| static vtkAlgorithmOutput * | GetPieceProducer (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| Convenience methods used by representations to pass represented data. More... | |
| static vtkAlgorithmOutput * | GetPieceProducerLOD (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static void | SetRedistributionMode (vtkInformation *info, vtkPVDataRepresentation *repr, int mode, int port=0) |
| static void | SetRedistributionModeToSplitBoundaryCells (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static void | SetRedistributionModeToDuplicateBoundaryCells (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static void | SetRedistributionModeToUniquelyAssignBoundaryCells (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static void | SetGeometryBounds (vtkInformation *info, vtkPVDataRepresentation *repr, const double bounds[6], vtkMatrix4x4 *transform=nullptr, int port=0) |
| static void | SetStreamable (vtkInformation *info, vtkPVDataRepresentation *repr, bool streamable) |
| static void | SetNextStreamedPiece (vtkInformation *info, vtkPVDataRepresentation *repr, vtkDataObject *piece) |
| static vtkDataObject * | GetCurrentStreamedPiece (vtkInformation *info, vtkPVDataRepresentation *repr) |
| static void | MarkAsRedistributable (vtkInformation *info, vtkPVDataRepresentation *repr, bool value=true, int port=0) |
As of ParaView 5.9, these methods are replaced by SetOrderedCompositingConfiguration which provides a new mechanisms for indicating to the view how this representation participates in data-redistribution needed when ordered-compositing is being used. More... | |
| static void | SetOrderedCompositingInformation (vtkInformation *info, vtkPVDataRepresentation *repr, vtkExtentTranslator *translator, const int whole_extents[6], const double origin[3], const double spacing[3]) |
| static void | SetOrderedCompositingInformation (vtkInformation *info, const double bounds[6]) |
| static void | SetRequiresDistributedRendering (vtkInformation *info, vtkPVDataRepresentation *repr, bool value, bool for_lod=false) |
| Some representation only work when remote rendering or local rendering. More... | |
| static void | SetRequiresDistributedRenderingLOD (vtkInformation *info, vtkPVDataRepresentation *repr, bool value) |
| static vtkPVCameraCollection * | GetDiscreteCameras (vtkInformation *info, vtkPVDataRepresentation *repr) |
| DiscreteCameras are a collection of cameras when specified, forces the view to only interact to a camera in the collection. More... | |
| static void | SetDiscreteCameras (vtkInformation *info, vtkPVDataRepresentation *repr, vtkPVCameraCollection *style) |
Static Public Member Functions inherited from vtkPVView | |
| static vtkPVView * | SafeDownCast (vtkObject *o) |
| static void | SetEnableStreaming (bool) |
| static bool | GetEnableStreaming () |
| static vtkInformationObjectBaseKey * | VIEW () |
| Key used to pass the vtkPVView pointer to the representation during any of the view passes such as REQUEST_UPDATE(), REQUEST_UPDATE_LOD(), REQUEST_RENDER(), etc. More... | |
| static vtkInformationRequestKey * | REQUEST_UPDATE () |
| This is a Update-Data pass. More... | |
| static vtkInformationRequestKey * | REQUEST_UPDATE_LOD () |
| This is a Update-LOD-Data pass. More... | |
| static vtkInformationRequestKey * | REQUEST_RENDER () |
| This is a render pass. More... | |
| static void | SetPiece (vtkInformation *info, vtkPVDataRepresentation *repr, vtkDataObject *data, unsigned long trueSize=0, int port=0) |
| static vtkDataObject * | GetPiece (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static vtkDataObject * | GetDeliveredPiece (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static void | SetPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, vtkDataObject *data, unsigned long trueSize=0, int port=0) |
| static vtkDataObject * | GetPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static vtkDataObject * | GetDeliveredPieceLOD (vtkInformation *info, vtkPVDataRepresentation *repr, int port=0) |
| static void | SetUseGenericOpenGLRenderWindow (bool val) |
| Use this to indicate that the process should use vtkGenericOpenGLRenderWindow rather than vtkRenderWindow when creating an new render window. More... | |
| static bool | GetUseGenericOpenGLRenderWindow () |
Static Public Member Functions inherited from vtkView | |
| static vtkView * | New () |
| static vtkView * | SafeDownCast (vtkObjectBase *o) |
| vtkPVRenderView () | |
| ~vtkPVRenderView () override | |
| virtual void | Render (bool interactive, bool skip_rendering) |
| Actual render method. More... | |
| virtual void | AboutToRenderOnLocalProcess (bool interactive) |
| Called just before the local process renders. More... | |
| bool | ShouldUseDistributedRendering (double geometry_size, bool using_lod) |
| Returns true if distributed rendering should be used based on the geometry size. More... | |
| bool | ShouldUseLODRendering (double geometry) |
| Returns true if LOD rendering should be used based on the geometry size. More... | |
| bool | IsProcessRenderingGeometriesForCompositing (bool using_distributed_rendering) |
| Returns true if the local process is invovled in rendering composited geometry i.e. More... | |
| void | SynchronizeGeometryBounds () |
| Synchronizes bounds information on all nodes. More... | |
| void | SetLastSelection (vtkSelection *) |
| Set the last selection object. More... | |
| virtual void | UpdateCenterAxes () |
| UpdateCenterAxes(). More... | |
| bool | GetLocalProcessDoesRendering (bool using_distributed_rendering) |
| Returns true if the local process is doing to do actual render or displaying an image in a viewport. More... | |
| bool | TestCollaborationCounter () |
| In multi-clients mode, ensures that all processes are in the same "state" as far as the view is concerned. More... | |
| void | SynchronizeForCollaboration () |
| Synchronizes remote-rendering related parameters for collaborative rendering in multi-clients mode. More... | |
| virtual void | BuildAnnotationText (ostream &str) |
| Method to build annotation text to annotate the view with runtime information. More... | |
| bool | PrepareSelect (int fieldAssociation, const char *array=nullptr) |
| Prepare for selection. More... | |
| void | PostSelect (vtkSelection *sel, const char *array=nullptr) |
| Post process after selection. More... | |
| void | UpdateSkybox () |
| Update skybox actor. More... | |
| void | ConfigureTexture (vtkTexture *texture) |
| Configure texture based on scalar type. More... | |
| virtual unsigned int | GetSynchronizationCounter () |
| SynchronizationCounter is used in multi-clients mode to ensure that the views on two different clients are in the same state as the server side. More... | |
| virtual bool | GetMakingSelection () |
| Returns true is currently generating a selection. More... | |
Protected Member Functions inherited from vtkPVView | |
| vtkPVView (bool create_render_window=true) | |
| ~vtkPVView () override | |
| vtkRenderWindow * | NewRenderWindow () |
| Subclasses should use this method to create new render windows instead of directly creating a new one. More... | |
| void | SetRenderWindow (vtkRenderWindow *) |
| Subclasses can use this method to set the render window created for this view. More... | |
| void | AllReduce (const vtkBoundingBox &source, vtkBoundingBox &dest) |
| Reduce bounding box between all participating processes. More... | |
| void | AllReduce (const vtkTypeUInt64 source, vtkTypeUInt64 &dest, int operation, bool skip_data_server=false) |
| Reduce between all participating processes using the operation (vtkCommunicator::StandardOperations) specified. More... | |
| vtkPVSession * | GetSession () |
| virtual bool | GetInCaptureScreenshot () |
Flag set to true between calls to PrepareForScreenshot and CleanupAfterScreenshot. More... | |
| void | AddRepresentationInternal (vtkDataRepresentation *rep) override |
| Overridden to assign IDs to each representation. More... | |
| void | RemoveRepresentationInternal (vtkDataRepresentation *rep) override |
| int | CallProcessViewRequest (vtkInformationRequestKey *passType, vtkInformation *request, vtkInformationVector *reply) |
| Subclasses can use this method to trigger a pass on all representations. More... | |
Protected Member Functions inherited from vtkView | |
| vtkView () | |
| ~vtkView () | |
| virtual vtkDataRepresentation * | CreateDefaultRepresentation (vtkAlgorithmOutput *conn) |
| virtual void | AddRepresentationInternal (vtkDataRepresentation *vtkNotUsed(rep)) |
| virtual void | RemoveRepresentationInternal (vtkDataRepresentation *vtkNotUsed(rep)) |
| virtual void | SetReuseSingleRepresentation (bool) |
| virtual bool | GetReuseSingleRepresentation () |
| virtual void | ReuseSingleRepresentationOn () |
| virtual void | ReuseSingleRepresentationOff () |
Static Protected Member Functions inherited from vtkPVView | |
| static vtkPVDataDeliveryManager * | GetDeliveryManager (vtkInformation *info) |
vtkRenderView equivalent that is specialized for ParaView. vtkRenderView handles polygonal rendering for ParaView in all the different modes of operation. vtkPVRenderView instance must be created on all involved processes. vtkPVRenderView uses the information about what process it has been created on to decide what part of the "rendering" happens on the process.
Definition at line 73 of file vtkPVRenderView.h.
| typedef vtkPVView vtkPVRenderView::Superclass |
Definition at line 78 of file vtkPVRenderView.h.
| Enumerator | |
| INTERACTION_MODE_UNINTIALIZED | |
| INTERACTION_MODE_3D | |
| INTERACTION_MODE_2D | |
| INTERACTION_MODE_SELECTION | |
| INTERACTION_MODE_ZOOM | |
| INTERACTION_MODE_POLYGON | |
Definition at line 81 of file vtkPVRenderView.h.
| anonymous enum |
| Enumerator | |
| DEFAULT_RENDERER | |
| NON_COMPOSITED_RENDERER | |
Definition at line 128 of file vtkPVRenderView.h.
| anonymous enum |
OrderedCompositingConfiguration lets representations indicate to the view how the representation participates in data-redistribution necessary when ordered-compositing is being used.
These flags are meant to be combined together using bit-wise-OR.
If not specified, default is 0 i.e. the representation data will be left untouched. Except for trivial representations or representations that have their full rendering geometry available on all rendering ranks, this is not recommended.
DATA_IS_REDISTRIBUTABLE indicates that the view may redistribute the rendering data from this representation as needed. This is typical for representation rendering poly-data or unstructured grids.
USE_DATA_FOR_LOAD_BALANCING indicates that when building a sortable distribution for the data, it should use this representation data. If not set, the representation will not contribute to the algorithm that builds the kd-tree used to split data across rendering ranks.
USE_BOUNDS_FOR_REDISTRIBUTION may be used when the data is too heavy to move (i.e DATA_IS_REDISTRIBUTABLE is not true) and is already split across ranks in a sortable fashion. In that case, this indicates the view must use the spatial partitioning of this representation's data and move other data accordingly. This flag cannot be combined with DATA_IS_REDISTRIBUTABLE or USE_BOUNDS_FOR_REDISTRIBUTION.
| Enumerator | |
| USE_BOUNDS_FOR_REDISTRIBUTION | |
| DATA_IS_REDISTRIBUTABLE | |
| USE_DATA_FOR_LOAD_BALANCING | |
Definition at line 510 of file vtkPVRenderView.h.
| Enumerator | |
| Custom | |
| Default | |
| Uncharted2 | |
Definition at line 815 of file vtkPVRenderView.h.
Reimplemented from vtkPVView.
Reimplemented in vtkPVRenderViewWithEDL, vtkPVOrthographicSliceView, and vtkPVMultiSliceView.
Reimplemented from vtkView.
Reimplemented in vtkPVRenderViewWithEDL.
Default is INTERACTION_MODE_3D. If INTERACTION_MODE_SELECTION is selected, then whenever the user drags and creates a selection region, this class will fire a vtkCommand::SelectionChangedEvent event with the selection region as the argument.
Reimplemented in vtkPVOrthographicSliceView.
This is typically used for labels, 2D annotations etc.
| vtkCamera* vtkPVRenderView::GetActiveCamera | ( | ) |
The active camera is set on both the composited and non-composited renderer.
| vtkRenderWindowInteractor* vtkPVRenderView::GetInteractor | ( | ) |
Set the interactor.
Client applications must set the interactor to enable interactivity. Note this method will also change the interactor styles set on the interactor.
| void vtkPVRenderView::ResetCamera | ( | ) |
| void vtkPVRenderView::ResetCamera | ( | double | bounds[6] | ) |
this->GetStillRenderProcesses(). Implements vtkPVView.
Based on the settings on the view, this may result in a low-resolution rendering or a simplified geometry rendering.
this->GetInteractiveRenderProcesses(). Implements vtkPVView.
This is useful in cases where you want the representations mappers to be setup for rendering and have their data ready but not actually do the render. For example if you want to export the scene but not render it you must turn on SuppressRendering and then call StillRender
This is typically set to 1, but in some cases with terrible connectivity or really large displays, one may want to use a sub-sampled image even for StillRender(). This is set it number of pixels to be sub-sampled by. Note that image reduction factors have no effect when in built-in mode.
This affects the size of the grid used for quadric clustering, for example. 1.0 implies maximum resolution while 0 implies minimum resolution.
Note that not all representations support this mode and hence one may still see non-outline data being rendering when this flag is ON and LOD is being used.
| void vtkPVRenderView::ConfigureCompressor | ( | const char * | configuration | ) |
This affects the image compression used to relay images back to the client. See vtkPVClientServerSynchronizedRenderers::ConfigureCompressor() for details.
One does not need to call this directly ever. It is called periodically by the vtkRenderer to reset the camera range.
| void vtkPVRenderView::SetUseLightKit | ( | bool | enable | ) |
| void vtkPVRenderView::DeliverStreamedPieces | ( | unsigned int | size, |
| unsigned int * | representation_ids | ||
This is typically only needed if a painter will make use of MPI global collective communications.
The value is a double vector with exactly 24 values.
Make a selection.
This will result in setting up of this->LastSelection which can be accessed using GetLastSelection().
Make a selection.
Definition at line 359 of file vtkPVRenderView.h.
Make a selection.
Make a selection.
Definition at line 365 of file vtkPVRenderView.h.
Make a selection.
The polygon2DArray should contain the polygon points in display units of (x, y) tuples, and arrayLen is the total length of polygon2DArray. This will result in setting up of this->LastSelection which can be accessed using GetLastSelection().
| void vtkPVRenderView::SelectPolygon | ( | int | field_association, |
| int * | polygon2DArray, | ||
| vtkIdType | arrayLen | ||
This is valid only on the client or driver node displaying the composited result.
Definition at line 412 of file vtkPVRenderView.h.
| void vtkPVRenderView::NVPipeAvailableOn | ( | ) |
| void vtkPVRenderView::NVPipeAvailableOff | ( | ) |
| void vtkPVRenderView::InvalidateCachedSelection | ( | ) |
Called explicitly when view proxy thinks the cache may have become obsolete.
If trueSize is non-zero, then that's the size used in making decisions about LOD/remote rendering etc and not the actual size of the dataset.
| void vtkPVRenderView::SetMaxClipBounds | ( | double | bds[6] | ) |
Called with the global (visible and invisible) bounds at start of export.
| void vtkPVRenderView::SetLockBounds | ( | bool | nv | ) |
Prevents ParaView from changing depth scaling over course of an export.
This is essential for representation that render in the non-composited views e.g. the text-source representation. If SetDeliverToAllProcesses() is true, this is redundant. gather_before_delivery can be used to indicate if the data on the server-nodes must be gathered to the root node before shipping to the client. If gather_before_delivery is false, only the data from the root node will be sent to the client without any parallel communication.
Use this method in REQUEST_UPDATE() pass to tell the view if the representation requires a particular mode. Note, only use this to "require" a remote or local render. value == true indicates that the representation requires distributed rendering, value == false indicates the representation can only render property on the client or root node.
inlinestatic |
Definition at line 567 of file vtkPVRenderView.h.
This is an temporary/experimental option and may be removed without notice.
This is intended to be used within some experimental representations that require that all data being moved around uses a specific mode rather than the one automatically determined based on the process type. Set flag to -1 to clear. The flag is cleared in every vtkPVRenderView::Update() call, hence a representation must set it in vtkPVView::REQUEST_UPDATE() pass if needed each time. Also note, if the value it set to non-negative and is not equal to vtkMPIMoveData::PASS_THROUGH, ordered compositing will also be disabled.
Definition at line 588 of file vtkPVRenderView.h.
Definition at line 589 of file vtkPVRenderView.h.
| int vtkPVRenderView::RegisterPropForHardwareSelection | ( | vtkPVDataRepresentation * | repr, |
| vtkProp * | prop | ||
They can do that in the vtkPVDataRepresentation::AddToView() implementation.
| void vtkPVRenderView::UnRegisterPropForHardwareSelection | ( | vtkPVDataRepresentation * | repr, |
| void vtkPVRenderView::SetShowAnnotation | ( | bool | val | ) |
| void vtkPVRenderView::SetKeyLightWarmth | ( | double | val | ) |
| void vtkPVRenderView::SetKeyLightIntensity | ( | double | val | ) |
| void vtkPVRenderView::SetKeyLightElevation | ( | double | val | ) |
| void vtkPVRenderView::SetKeyLightAzimuth | ( | double | val | ) |
| void vtkPVRenderView::SetFillLightWarmth | ( | double | val | ) |
| void vtkPVRenderView::SetKeyToFillRatio | ( | double | val | ) |
| void vtkPVRenderView::SetFillLightElevation | ( | double | val | ) |
| void vtkPVRenderView::SetFillLightAzimuth | ( | double | val | ) |
| void vtkPVRenderView::SetBackLightWarmth | ( | double | val | ) |
| void vtkPVRenderView::SetKeyToBackRatio | ( | double | val | ) |
| void vtkPVRenderView::SetBackLightElevation | ( | double | val | ) |
| void vtkPVRenderView::SetBackLightAzimuth | ( | double | val | ) |
| void vtkPVRenderView::SetHeadLightWarmth | ( | double | val | ) |
| void vtkPVRenderView::SetKeyToHeadRatio | ( | double | val | ) |
| void vtkPVRenderView::SetMaintainLuminance | ( | int | val | ) |
| void vtkPVRenderView::AddLight | ( | vtkLight * | ) |
| void vtkPVRenderView::RemoveLight | ( | vtkLight * | ) |
| void vtkPVRenderView::SetStereoCapableWindow | ( | int | val | ) |
| void vtkPVRenderView::SetStereoRender | ( | int | val | ) |
| void vtkPVRenderView::SetMultiSamples | ( | int | val | ) |
| void vtkPVRenderView::SetAlphaBitPlanes | ( | int | val | ) |
| void vtkPVRenderView::SetStencilCapable | ( | int | val | ) |
| void vtkPVRenderView::SetParallelProjection | ( | int | mode | ) |
| void vtkPVRenderView::SetCameraManipulators | ( | vtkPVInteractorStyle * | style, |
| const int | manipulators[9] | ||
The vtkSMViewProxy ensures that this method is called only when something has changed on the view-proxy or one of its representations or their inputs. Hence it's okay to do some extra inter-process communication here.
This uses the full resolution geometry sizes as determined by the most recent call to Update.
This uses the low-resolution (or LOD) geometry sizes as determined by the most recent call to UpdateLOD.
| int vtkPVRenderView::GetDataDistributionMode | ( | bool | low_res | ) |
Note this method has to be called on all processes or it may lead to deadlock.
| bool vtkPVRenderView::GetUseOrderedCompositing | ( | ) |
Note that unlike most other functions, this may return different values on different processes e.g.
| bool vtkPVRenderView::GetRenderEmptyImages | ( | ) |
| void vtkPVRenderView::SetFXAARelativeContrastThreshold | ( | double | val | ) |
See vtkFXAAOptions for details.
| void vtkPVRenderView::SetFXAAHardContrastThreshold | ( | double | val | ) |
| void vtkPVRenderView::SetFXAASubpixelBlendLimit | ( | double | val | ) |
| void vtkPVRenderView::SetFXAASubpixelContrastThreshold | ( | double | val | ) |
| void vtkPVRenderView::SetFXAAUseHighQualityEndpoints | ( | bool | val | ) |
| void vtkPVRenderView::SetFXAAEndpointSearchIterations | ( | int | val | ) |
| void vtkPVRenderView::SetUseToneMapping | ( | bool | v | ) |
| void vtkPVRenderView::SetToneMappingType | ( | int | ) |
| void vtkPVRenderView::SetExposure | ( | double | ) |
| void vtkPVRenderView::SetContrast | ( | double | ) |
| void vtkPVRenderView::SetShoulder | ( | double | ) |
| void vtkPVRenderView::SetMidIn | ( | double | ) |
| void vtkPVRenderView::SetMidOut | ( | double | ) |
| void vtkPVRenderView::SetHdrMax | ( | double | ) |
| void vtkPVRenderView::SetUseACES | ( | bool | ) |
| void vtkPVRenderView::SetGenericFilmicPresets | ( | int | t | ) |
SSAO options.
SSAO options.
SSAO options.
SSAO options.
SSAO options.
SSAO options.
SSAO options.
| void vtkPVRenderView::CopyViewUpdateOptions | ( | vtkPVRenderView * | otherView | ) |
This method was introduced for the quad view so internal views could use the decision that were made in the main view.
| void vtkPVRenderView::AddPropToRenderer | ( | vtkProp * | prop | ) |
| void vtkPVRenderView::RemovePropFromRenderer | ( | vtkProp * | prop | ) |
| void vtkPVRenderView::SetDrawCells | ( | bool | choice | ) |
| void vtkPVRenderView::SetArrayNameToDraw | ( | const char * | name | ) |
| void vtkPVRenderView::SetArrayNumberToDraw | ( | int | fieldAttributeType | ) |
| void vtkPVRenderView::SetArrayComponentToDraw | ( | int | comp | ) |
| void vtkPVRenderView::BeginValueCapture | ( | ) |
| void vtkPVRenderView::EndValueCapture | ( | ) |
| void vtkPVRenderView::SetValueRenderingModeCommand | ( | int | mode | ) |
Invertible is deprecated, so this currently does nothing and will be removed.
| int vtkPVRenderView::GetValueRenderingModeCommand | ( | ) |
| void vtkPVRenderView::CaptureValuesFloat | ( | ) |
vtkValuePass's internal FBO is accessed directly when rendering locally. When rendering in parallel, IceT composites the intermediate results from vtkValuePass and the final result is accessed through vtkIceTCompositePass. Float value rendering is only supported in BATCH mode and in CLIENT mode (local rendering). These methods do nothing if INVERTIBLE_LUT mode is active.
| vtkFloatArray* vtkPVRenderView::GetCapturedValuesFloat | ( | ) |
| void vtkPVRenderView::StartCaptureLuminance | ( | ) |
| void vtkPVRenderView::StopCaptureLuminance | ( | ) |
| void vtkPVRenderView::CaptureZBuffer | ( | ) |
| vtkFloatArray* vtkPVRenderView::GetCapturedZBuffer | ( | ) |
| void vtkPVRenderView::SetEnableOSPRay | ( | bool | ) |
| bool vtkPVRenderView::GetEnableOSPRay | ( | ) |
| void vtkPVRenderView::SetShadows | ( | bool | ) |
| bool vtkPVRenderView::GetShadows | ( | ) |
| void vtkPVRenderView::SetAmbientOcclusionSamples | ( | int | ) |
| int vtkPVRenderView::GetAmbientOcclusionSamples | ( | ) |
| void vtkPVRenderView::SetRouletteDepth | ( | int | ) |
| int vtkPVRenderView::GetRouletteDepth | ( | ) |
| void vtkPVRenderView::SetVolumeAnisotropy | ( | double | ) |
| double vtkPVRenderView::GetVolumeAnisotropy | ( | ) |
| void vtkPVRenderView::SetSamplesPerPixel | ( | int | ) |
| int vtkPVRenderView::GetSamplesPerPixel | ( | ) |
| void vtkPVRenderView::SetMaxFrames | ( | int | ) |
| int vtkPVRenderView::GetMaxFrames | ( | ) |
| bool vtkPVRenderView::GetOSPRayContinueStreaming | ( | ) |
| void vtkPVRenderView::SetDenoise | ( | bool | ) |
| bool vtkPVRenderView::GetDenoise | ( | ) |
| void vtkPVRenderView::SetLightScale | ( | double | ) |
| double vtkPVRenderView::GetLightScale | ( | ) |
| void vtkPVRenderView::SetOSPRayRendererType | ( | std::string | ) |
May be either scivis (default) or pathtracer.
| void vtkPVRenderView::SetTimeCacheSize | ( | int | ) |
| int vtkPVRenderView::GetTimeCacheSize | ( | ) |
In vtkPVView::REQUEST_UPDATE() pass, representations may request the view to use discrete cameras by providing a vtkPVCameraCollection to the view. Since multiple representations may be visible in the view, it's up to the representations how to handle multiple representations providing different styles.
When set, on each render, vtkPVRenderView will try to update the current camera to match a camera in the collection. During interacting, however, the snapping to a camera in the collection is only done when the snapped to camera is different from the previous. This avoids side effects on camera manipulators that simply update existing camera positions during interaction.
protectedvirtual |
inlineprotectedvirtual |
This is only called on the nodes where the rendering is going to happen.
Reimplemented in vtkPVOrthographicSliceView, and vtkPVMultiSliceView.
Definition at line 1073 of file vtkPVRenderView.h.
using_lod will be true if this method is called to determine distributed rendering status for renders using lower LOD i.e when called in UpdateLOD().
geometry rendered in view that is composited together.
protectedvirtual |
Updates CenterAxes's scale and position.
Returns false if that's not the case.
protectedvirtual |
protectedvirtual |
protectedvirtual |
Returns false if it is currently generating a selection.
Definition at line 1171 of file vtkPVRenderView.h.
Definition at line 1172 of file vtkPVRenderView.h.
Definition at line 1173 of file vtkPVRenderView.h.
Definition at line 1174 of file vtkPVRenderView.h.
Definition at line 1175 of file vtkPVRenderView.h.
Definition at line 1176 of file vtkPVRenderView.h.
Definition at line 1177 of file vtkPVRenderView.h.
Definition at line 1178 of file vtkPVRenderView.h.
Definition at line 1179 of file vtkPVRenderView.h.
Definition at line 1180 of file vtkPVRenderView.h.
Definition at line 1181 of file vtkPVRenderView.h.
Definition at line 1182 of file vtkPVRenderView.h.
Definition at line 1183 of file vtkPVRenderView.h.
Definition at line 1184 of file vtkPVRenderView.h.
Definition at line 1185 of file vtkPVRenderView.h.
Definition at line 1187 of file vtkPVRenderView.h.
Definition at line 1188 of file vtkPVRenderView.h.
Definition at line 1189 of file vtkPVRenderView.h.
Definition at line 1190 of file vtkPVRenderView.h.
Definition at line 1191 of file vtkPVRenderView.h.
Definition at line 1200 of file vtkPVRenderView.h.
Definition at line 1203 of file vtkPVRenderView.h.
Definition at line 1204 of file vtkPVRenderView.h.
Definition at line 1207 of file vtkPVRenderView.h.
Definition at line 1209 of file vtkPVRenderView.h.
Definition at line 1213 of file vtkPVRenderView.h.
Definition at line 1216 of file vtkPVRenderView.h.
Definition at line 1217 of file vtkPVRenderView.h.
Definition at line 1218 of file vtkPVRenderView.h.
Definition at line 1220 of file vtkPVRenderView.h.
Definition at line 1221 of file vtkPVRenderView.h.
Definition at line 1222 of file vtkPVRenderView.h.
Definition at line 1224 of file vtkPVRenderView.h.
Definition at line 1225 of file vtkPVRenderView.h.
Definition at line 1227 of file vtkPVRenderView.h.
Definition at line 1229 of file vtkPVRenderView.h.
Definition at line 1230 of file vtkPVRenderView.h.
Definition at line 1231 of file vtkPVRenderView.h.
Definition at line 1232 of file vtkPVRenderView.h.
Definition at line 1233 of file vtkPVRenderView.h.
Definition at line 1234 of file vtkPVRenderView.h.
Definition at line 1236 of file vtkPVRenderView.h.
Definition at line 1237 of file vtkPVRenderView.h.
Definition at line 1239 of file vtkPVRenderView.h.
Definition at line 1240 of file vtkPVRenderView.h.
Definition at line 1241 of file vtkPVRenderView.h.
Definition at line 1242 of file vtkPVRenderView.h.
Definition at line 1243 of file vtkPVRenderView.h.
Definition at line 1245 of file vtkPVRenderView.h.
Definition at line 1246 of file vtkPVRenderView.h.
Keeps track of the time when the priority-queue for streaming was generated.
Definition at line 1252 of file vtkPVRenderView.h.
Definition at line 1254 of file vtkPVRenderView.h.
