| void | SetViewProxy (vtkSMViewProxy *proxy) |
| | Set the view proxy. More...
| vtkSMViewProxy * | GetViewProxy () |
| void | SetupInteractor (vtkRenderWindowInteractor *iren) |
| | Set the interactor to "help" the view with. More...
| vtkRenderWindowInteractor * | GetInteractor () |
| void | CleanupInteractor () |
helper class that make it easier to hook vtkRenderWindowInteractor and vtkSMViewProxy.
vtkSMViewProxyInteractorHelper is a helper class designed to make it easier to hook up vtkRenderWindowInteractor to call methods on a vtkSMViewProxy (or subclass). It's primarily designed to work with vtkSMRenderViewProxy (and subclasses), but it should work with other types of views too.
To use this helper, the view typically creates a instance for itself as register itself (using vtkSMViewProxyInteractorHelper::SetViewProxy) and then calls vtkSMViewProxyInteractorHelper::SetupInteractor(). This method will initialize the interactor (potentially changing some ivars on the interactor to avoid automatic rendering, using vtkRenderWindowInteractor::EnableRenderOff(), etc.) and setup event observer to monitor interaction.
vtkSMViewProxyInteractorHelper only using vtkSMViewProxy::StillRender() and vtkSMViewProxy::InteractiveRender() APIs directly. However several properties can be optionally present on the view proxy to dictate this class' behaviour. These are as follows:
NonInteractiveRenderDelay :- when present provides time in seconds to delay the StillRender() call after user interaction has ended i.e. vtkRenderWindowInteractor fires the vtkCommand::EndInteractionEvent. If missing, or less than 0.01, the view will immediately render.
EnableRenderOnInteraction :- when present provides a flag whether the interactor should trigger the render calls (either StillRender or InteractiveRender) as a consequence of interaction. If missing, we treat EnableRender as ON.
Definition at line 58 of file vtkSMViewProxyInteractorHelper.h.
