Public Types | Public Member Functions | Static Public Member Functions | Protected Types | Protected Member Functions | Static Protected Member Functions | Protected Attributes | List of all members
vtkSMVRInteractorStyleProxy Class Reference
#include <vtkSMVRInteractorStyleProxy.h>
Inheritance diagram for vtkSMVRInteractorStyleProxy:
Collaboration diagram for vtkSMVRInteractorStyleProxy:
enum  { INTERACTOR_STYLE_REQUEST_CONFIGURE = vtkCommand::UserEvent + 7370 }
typedef vtkSMProxy Superclass
virtual int GetControlledPropertySize ()
virtual vtkSMProxy * GetControlledProxy ()
virtual bool Update ()
int GetNumberOfButtonRoles ()
std::string GetValuatorRole (const std::string &name)
void ClearAllRoles ()
virtual vtkPVXMLElement * SaveConfiguration ()
 Save state to xml. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMVRInteractorStyleProxy * New ()
static vtkSMVRInteractorStyleProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
Protected Types
typedef std::map< std::string, std::string > StringMap
virtual void HandleButton (const vtkVREvent &event)
virtual void HandleValuator (const vtkVREvent &event)
virtual void HandleTracker (const vtkVREvent &event)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
static std::vector< std::string > Tokenize (std::string input)
vtkSMProxy * ControlledProxy
char * ControlledPropertyName
StringMap Valuators
StringMap Buttons
StringMap Trackers
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Definition at line 22 of file vtkSMVRInteractorStyleProxy.h.
Definition at line 26 of file vtkSMVRInteractorStyleProxy.h.
◆ StringMap
Definition at line 113 of file vtkSMVRInteractorStyleProxy.h.
◆ anonymous enum
anonymous enum
Enumerator
Definition at line 95 of file vtkSMVRInteractorStyleProxy.h.
◆ vtkSMVRInteractorStyleProxy()
vtkSMVRInteractorStyleProxy::vtkSMVRInteractorStyleProxy ( )
◆ ~vtkSMVRInteractorStyleProxy()
virtual vtkSMVRInteractorStyleProxy::~vtkSMVRInteractorStyleProxy ( )
protectedvirtual
static vtkSMVRInteractorStyleProxy* vtkSMVRInteractorStyleProxy::New ( )
virtual const char* vtkSMVRInteractorStyleProxy::GetClassName ( )
static int vtkSMVRInteractorStyleProxy::IsTypeOf ( const char *  type)
virtual int vtkSMVRInteractorStyleProxy::IsA ( const char *  type)
static vtkSMVRInteractorStyleProxy* vtkSMVRInteractorStyleProxy::SafeDownCast ( vtkObject *  o)
void vtkSMVRInteractorStyleProxy::PrintSelf ( ostream &  os,
◆ GetControlledPropertySize()
virtual int vtkSMVRInteractorStyleProxy::GetControlledPropertySize ( )
inlinevirtual
◆ SetControlledProxy()
virtual void vtkSMVRInteractorStyleProxy::SetControlledProxy ( vtkSMProxy *  )
◆ GetControlledProxy()
virtual vtkSMProxy* vtkSMVRInteractorStyleProxy::GetControlledProxy ( )
◆ SetControlledPropertyName()
virtual void vtkSMVRInteractorStyleProxy::SetControlledPropertyName ( const char *  )
◆ GetControlledPropertyName()
virtual char* vtkSMVRInteractorStyleProxy::GetControlledPropertyName ( )
◆ HandleEvent()
virtual bool vtkSMVRInteractorStyleProxy::HandleEvent ( const vtkVREvent &  event)
◆ Update()
virtual bool vtkSMVRInteractorStyleProxy::Update ( )
Typically processing intensive operations go here. The method should not be called from within the handler and is reserved to be called from an external interaction style manager.
Reimplemented in vtkSMVRGrabPointStyleProxy, vtkSMVRControlSlicePositionStyleProxy, and vtkSMVRControlSliceOrientationStyleProxy.
◆ GetValuatorRoles()
void vtkSMVRInteractorStyleProxy::GetValuatorRoles ( vtkStringList *  )
◆ GetButtonRoles()
void vtkSMVRInteractorStyleProxy::GetButtonRoles ( vtkStringList *  )
◆ GetTrackerRoles()
void vtkSMVRInteractorStyleProxy::GetTrackerRoles ( vtkStringList *  )
◆ GetNumberOfValuatorRoles()
int vtkSMVRInteractorStyleProxy::GetNumberOfValuatorRoles ( )
◆ GetNumberOfButtonRoles()
int vtkSMVRInteractorStyleProxy::GetNumberOfButtonRoles ( )
◆ GetNumberOfTrackerRoles()
int vtkSMVRInteractorStyleProxy::GetNumberOfTrackerRoles ( )
◆ GetValuatorRole()
std::string vtkSMVRInteractorStyleProxy::GetValuatorRole ( const std::string &  name)
◆ GetButtonRole()
std::string vtkSMVRInteractorStyleProxy::GetButtonRole ( const std::string &  name)
◆ GetTrackerRole()
std::string vtkSMVRInteractorStyleProxy::GetTrackerRole ( const std::string &  name)
◆ AddValuatorRole()
void vtkSMVRInteractorStyleProxy::AddValuatorRole ( const std::string &  role)
◆ AddButtonRole()
void vtkSMVRInteractorStyleProxy::AddButtonRole ( const std::string &  role)
◆ AddTrackerRole()
void vtkSMVRInteractorStyleProxy::AddTrackerRole ( const std::string &  role)
◆ ClearAllRoles()
void vtkSMVRInteractorStyleProxy::ClearAllRoles ( )
◆ SetValuatorName()
bool vtkSMVRInteractorStyleProxy::SetValuatorName ( const std::string &  role,
◆ GetValuatorName()
std::string vtkSMVRInteractorStyleProxy::GetValuatorName ( const std::string &  role)
◆ SetButtonName()
bool vtkSMVRInteractorStyleProxy::SetButtonName ( const std::string &  role,
◆ GetButtonName()
std::string vtkSMVRInteractorStyleProxy::GetButtonName ( const std::string &  role)
◆ SetTrackerName()
bool vtkSMVRInteractorStyleProxy::SetTrackerName ( const std::string &  role,
◆ GetTrackerName()
std::string vtkSMVRInteractorStyleProxy::GetTrackerName ( const std::string &  role)
◆ Configure()
virtual bool vtkSMVRInteractorStyleProxy::Configure ( vtkPVXMLElement *  child,
vtkSMProxyLocator *
Reimplemented in vtkSMVRPythonInteractorStyleProxy.
◆ SaveConfiguration()
virtual vtkPVXMLElement* vtkSMVRInteractorStyleProxy::SaveConfiguration ( )
Save state to xml.
◆ HandleButton()
virtual void vtkSMVRInteractorStyleProxy::HandleButton ( const vtkVREvent &  event)
protectedvirtual
◆ HandleValuator()
virtual void vtkSMVRInteractorStyleProxy::HandleValuator ( const vtkVREvent &  event)
protectedvirtual
◆ HandleTracker()
virtual void vtkSMVRInteractorStyleProxy::HandleTracker ( const vtkVREvent &  event)
protectedvirtual
◆ Tokenize()
static std::vector<std::string> vtkSMVRInteractorStyleProxy::Tokenize ( std::string  input)
staticprotected
◆ MapKeysToStringList()
void vtkSMVRInteractorStyleProxy::MapKeysToStringList ( const StringMap &  source,
vtkStringList *  target
◆ SetValueInMap()
bool vtkSMVRInteractorStyleProxy::SetValueInMap ( StringMap &  map_,
const std::string &  key,
const std::string &  value
◆ GetValueInMap()
std::string vtkSMVRInteractorStyleProxy::GetValueInMap ( const StringMap &  map_,
◆ GetKeyInMap()
std::string vtkSMVRInteractorStyleProxy::GetKeyInMap ( const StringMap &  map_,
◆ ControlledProxy
vtkSMProxy* vtkSMVRInteractorStyleProxy::ControlledProxy
Definition at line 110 of file vtkSMVRInteractorStyleProxy.h.
◆ ControlledPropertyName
char* vtkSMVRInteractorStyleProxy::ControlledPropertyName
Definition at line 111 of file vtkSMVRInteractorStyleProxy.h.
◆ Valuators
StringMap vtkSMVRInteractorStyleProxy::Valuators
Definition at line 114 of file vtkSMVRInteractorStyleProxy.h.
◆ Buttons
StringMap vtkSMVRInteractorStyleProxy::Buttons
Definition at line 115 of file vtkSMVRInteractorStyleProxy.h.
◆ Trackers
StringMap vtkSMVRInteractorStyleProxy::Trackers
Definition at line 116 of file vtkSMVRInteractorStyleProxy.h.
