vtkSMVRMovePointStyleProxy Class Reference
an interaction style to control the position of a point with a stylus More...
#include <vtkSMVRMovePointStyleProxy.h>
Inheritance diagram for vtkSMVRMovePointStyleProxy:
Collaboration diagram for vtkSMVRMovePointStyleProxy:
typedef vtkSMVRTrackStyleProxy Superclass
- Public Types inherited from vtkSMVRTrackStyleProxy
enum  { INTERACTOR_STYLE_REQUEST_CONFIGURE = vtkCommand::UserEvent + 7370 }
typedef vtkSMProxy Superclass
int GetControlledPropertySize () override
- Public Member Functions inherited from vtkSMVRTrackStyleProxy
virtual vtkSMProxy * GetControlledProxy ()
virtual bool Update ()
int GetNumberOfButtonRoles ()
std::string GetValuatorRole (const std::string &name)
void ClearAllRoles ()
virtual vtkPVXMLElement * SaveConfiguration ()
 Save state to xml. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMVRMovePointStyleProxy * New ()
static vtkSMVRMovePointStyleProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMVRTrackStyleProxy
static vtkSMVRTrackStyleProxy * New ()
static vtkSMVRTrackStyleProxy * SafeDownCast (vtkObject *o)
static vtkSMVRInteractorStyleProxy * New ()
static vtkSMVRInteractorStyleProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMVRMovePointStyleProxy ()
 ~vtkSMVRMovePointStyleProxy () override=default
void HandleButton (const vtkVREvent &data) override
void HandleTracker (const vtkVREvent &data) override
- Protected Member Functions inherited from vtkSMVRTrackStyleProxy
 vtkSMVRTrackStyleProxy ()
 ~vtkSMVRTrackStyleProxy () override
void HandleTracker (const vtkVREvent &event) override
virtual void HandleValuator (const vtkVREvent &event)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
bool EnableMovePoint
vtkSMProxy * ControlledProxy
char * ControlledPropertyName
StringMap Valuators
StringMap Buttons
StringMap Trackers
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
- Protected Types inherited from vtkSMVRInteractorStyleProxy
typedef std::map< std::string, std::string > StringMap
static std::vector< std::string > Tokenize (std::string input)
vtkSMVRMovePointStyleProxy is an interaction style that uses the position of the tracker in screen space to modify the position of a 3D point.
Definition at line 19 of file vtkSMVRMovePointStyleProxy.h.
Definition at line 24 of file vtkSMVRMovePointStyleProxy.h.
◆ vtkSMVRMovePointStyleProxy()
vtkSMVRMovePointStyleProxy::vtkSMVRMovePointStyleProxy ( )
◆ ~vtkSMVRMovePointStyleProxy()
vtkSMVRMovePointStyleProxy::~vtkSMVRMovePointStyleProxy ( )
overrideprotecteddefault
static vtkSMVRMovePointStyleProxy* vtkSMVRMovePointStyleProxy::New ( )
virtual const char* vtkSMVRMovePointStyleProxy::GetClassName ( )
Reimplemented from vtkSMVRTrackStyleProxy.
static int vtkSMVRMovePointStyleProxy::IsTypeOf ( const char *  type)
virtual int vtkSMVRMovePointStyleProxy::IsA ( const char *  type)
static vtkSMVRMovePointStyleProxy* vtkSMVRMovePointStyleProxy::SafeDownCast ( vtkObject *  o)
void vtkSMVRMovePointStyleProxy::PrintSelf ( ostream &  os,
◆ GetControlledPropertySize()
int vtkSMVRMovePointStyleProxy::GetControlledPropertySize ( )
inlineoverridevirtual
Definition at line 27 of file vtkSMVRMovePointStyleProxy.h.
◆ HandleButton()
void vtkSMVRMovePointStyleProxy::HandleButton ( const vtkVREvent &  data)
overrideprotectedvirtual
◆ HandleTracker()
void vtkSMVRMovePointStyleProxy::HandleTracker ( const vtkVREvent &  data)
◆ EnableMovePoint
bool vtkSMVRMovePointStyleProxy::EnableMovePoint
Definition at line 36 of file vtkSMVRMovePointStyleProxy.h.
