vtkSMVRGrabWorldStyleProxy Class Reference
#include <vtkSMVRGrabWorldStyleProxy.h>
Inheritance diagram for vtkSMVRGrabWorldStyleProxy:
Collaboration diagram for vtkSMVRGrabWorldStyleProxy:
typedef vtkSMVRTrackStyleProxy Superclass
- Public Types inherited from vtkSMVRTrackStyleProxy
enum  { INTERACTOR_STYLE_REQUEST_CONFIGURE = vtkCommand::UserEvent + 7370 }
typedef vtkSMProxy Superclass
- Public Member Functions inherited from vtkSMVRTrackStyleProxy
int GetControlledPropertySize () override
virtual vtkSMProxy * GetControlledProxy ()
virtual bool Update ()
int GetNumberOfButtonRoles ()
std::string GetValuatorRole (const std::string &name)
void ClearAllRoles ()
virtual vtkPVXMLElement * SaveConfiguration ()
 Save state to xml. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMVRGrabWorldStyleProxy * New ()
static vtkSMVRGrabWorldStyleProxy * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMVRTrackStyleProxy
static vtkSMVRTrackStyleProxy * New ()
static vtkSMVRTrackStyleProxy * SafeDownCast (vtkObject *o)
static vtkSMVRInteractorStyleProxy * New ()
static vtkSMVRInteractorStyleProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMVRGrabWorldStyleProxy ()
 ~vtkSMVRGrabWorldStyleProxy () override
void HandleButton (const vtkVREvent &event) override
void HandleTracker (const vtkVREvent &event) override
- Protected Member Functions inherited from vtkSMVRTrackStyleProxy
 vtkSMVRTrackStyleProxy ()
 ~vtkSMVRTrackStyleProxy () override
virtual void HandleValuator (const vtkVREvent &event)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
bool EnableTranslate
bool EnableRotate
bool IsInitialTransRecorded
bool IsInitialRotRecorded
vtkNew< vtkMatrix4x4 > InverseInitialTransMatrix
vtkNew< vtkMatrix4x4 > InverseInitialRotMatrix
vtkNew< vtkMatrix4x4 > CachedTransMatrix
vtkNew< vtkMatrix4x4 > CachedRotMatrix
vtkSMProxy * ControlledProxy
char * ControlledPropertyName
StringMap Valuators
StringMap Buttons
StringMap Trackers
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
- Protected Types inherited from vtkSMVRInteractorStyleProxy
typedef std::map< std::string, std::string > StringMap
static std::vector< std::string > Tokenize (std::string input)
Definition at line 18 of file vtkSMVRGrabWorldStyleProxy.h.
Definition at line 23 of file vtkSMVRGrabWorldStyleProxy.h.
◆ vtkSMVRGrabWorldStyleProxy()
vtkSMVRGrabWorldStyleProxy::vtkSMVRGrabWorldStyleProxy ( )
◆ ~vtkSMVRGrabWorldStyleProxy()
vtkSMVRGrabWorldStyleProxy::~vtkSMVRGrabWorldStyleProxy ( )
static vtkSMVRGrabWorldStyleProxy* vtkSMVRGrabWorldStyleProxy::New ( )
virtual const char* vtkSMVRGrabWorldStyleProxy::GetClassName ( )
Reimplemented from vtkSMVRTrackStyleProxy.
static int vtkSMVRGrabWorldStyleProxy::IsTypeOf ( const char *  type)
virtual int vtkSMVRGrabWorldStyleProxy::IsA ( const char *  type)
static vtkSMVRGrabWorldStyleProxy* vtkSMVRGrabWorldStyleProxy::SafeDownCast ( vtkObject *  o)
void vtkSMVRGrabWorldStyleProxy::PrintSelf ( ostream &  os,
◆ HandleButton()
void vtkSMVRGrabWorldStyleProxy::HandleButton ( const vtkVREvent &  event)
overrideprotectedvirtual
◆ HandleTracker()
void vtkSMVRGrabWorldStyleProxy::HandleTracker ( const vtkVREvent &  event)
◆ EnableTranslate
bool vtkSMVRGrabWorldStyleProxy::EnableTranslate
Definition at line 33 of file vtkSMVRGrabWorldStyleProxy.h.
◆ EnableRotate
bool vtkSMVRGrabWorldStyleProxy::EnableRotate
Definition at line 34 of file vtkSMVRGrabWorldStyleProxy.h.
◆ IsInitialTransRecorded
bool vtkSMVRGrabWorldStyleProxy::IsInitialTransRecorded
Definition at line 36 of file vtkSMVRGrabWorldStyleProxy.h.
◆ IsInitialRotRecorded
bool vtkSMVRGrabWorldStyleProxy::IsInitialRotRecorded
Definition at line 38 of file vtkSMVRGrabWorldStyleProxy.h.
◆ InverseInitialTransMatrix
vtkNew<vtkMatrix4x4> vtkSMVRGrabWorldStyleProxy::InverseInitialTransMatrix
Definition at line 41 of file vtkSMVRGrabWorldStyleProxy.h.
◆ InverseInitialRotMatrix
vtkNew<vtkMatrix4x4> vtkSMVRGrabWorldStyleProxy::InverseInitialRotMatrix
Definition at line 42 of file vtkSMVRGrabWorldStyleProxy.h.
◆ CachedTransMatrix
vtkNew<vtkMatrix4x4> vtkSMVRGrabWorldStyleProxy::CachedTransMatrix
Definition at line 44 of file vtkSMVRGrabWorldStyleProxy.h.
◆ CachedRotMatrix
vtkNew<vtkMatrix4x4> vtkSMVRGrabWorldStyleProxy::CachedRotMatrix
Definition at line 45 of file vtkSMVRGrabWorldStyleProxy.h.
