vtkSMVRPythonInteractorStyleProxy Class Reference
#include <vtkSMVRPythonInteractorStyleProxy.h>
Inheritance diagram for vtkSMVRPythonInteractorStyleProxy:
Collaboration diagram for vtkSMVRPythonInteractorStyleProxy:
enum  { INTERACTOR_STYLE_REQUEST_CONFIGURE = vtkCommand::UserEvent + 7370 }
typedef vtkSMProxy Superclass
void SetPythonObject (void *obj)
 Specify the Python object that implements the handler methods this object will forward to. More...
 vtkSetFilePathMacro (FileName)
 Set/Get the filename of the python file containing the custom python interactor style class. More...
 vtkGetFilePathMacro (FileName)
void ReloadPythonFile ()
 Reload the python file. More...
void RecreateVTKObjects () override
 Overridden to support refreshing the python from the UI. More...
void UpdateVTKObjects () override
 Overridden to support retrieving the user-selected FileName and using it to read the python file. More...
virtual int GetControlledPropertySize ()
virtual vtkSMProxy * GetControlledProxy ()
virtual bool Update ()
int GetNumberOfButtonRoles ()
std::string GetValuatorRole (const std::string &name)
void ClearAllRoles ()
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMVRPythonInteractorStyleProxy * New ()
static vtkSMVRPythonInteractorStyleProxy * SafeDownCast (vtkObject *o)
static vtkSMVRInteractorStyleProxy * New ()
static vtkSMVRInteractorStyleProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMVRPythonInteractorStyleProxy ()
 ~vtkSMVRPythonInteractorStyleProxy () override
void HandleTracker (const vtkVREvent &event) override
void HandleValuator (const vtkVREvent &event) override
void HandleButton (const vtkVREvent &event) override
void InvokeHandler (const char *mname, const vtkVREvent &event)
vtkPVXMLElement * SaveConfiguration () override
 Save state to xml. More...
bool Configure (vtkPVXMLElement *child, vtkSMProxyLocator *locator) override
bool ReadPythonFile (const char *path, std::string &contents)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
char * FileName
vtkSMProxy * ControlledProxy
char * ControlledPropertyName
StringMap Valuators
StringMap Buttons
StringMap Trackers
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
- Protected Types inherited from vtkSMVRInteractorStyleProxy
typedef std::map< std::string, std::string > StringMap
static std::vector< std::string > Tokenize (std::string input)
Definition at line 20 of file vtkSMVRPythonInteractorStyleProxy.h.
Definition at line 25 of file vtkSMVRPythonInteractorStyleProxy.h.
◆ vtkSMVRPythonInteractorStyleProxy()
vtkSMVRPythonInteractorStyleProxy::vtkSMVRPythonInteractorStyleProxy ( )
◆ ~vtkSMVRPythonInteractorStyleProxy()
vtkSMVRPythonInteractorStyleProxy::~vtkSMVRPythonInteractorStyleProxy ( )
static vtkSMVRPythonInteractorStyleProxy* vtkSMVRPythonInteractorStyleProxy::New ( )
virtual const char* vtkSMVRPythonInteractorStyleProxy::GetClassName ( )
static int vtkSMVRPythonInteractorStyleProxy::IsTypeOf ( const char *  type)
virtual int vtkSMVRPythonInteractorStyleProxy::IsA ( const char *  type)
static vtkSMVRPythonInteractorStyleProxy* vtkSMVRPythonInteractorStyleProxy::SafeDownCast ( vtkObject *  o)
void vtkSMVRPythonInteractorStyleProxy::PrintSelf ( ostream &  os,
◆ vtkSetFilePathMacro()
vtkSMVRPythonInteractorStyleProxy::vtkSetFilePathMacro ( FileName  )
◆ vtkGetFilePathMacro()
vtkSMVRPythonInteractorStyleProxy::vtkGetFilePathMacro ( FileName  )
◆ ReloadPythonFile()
void vtkSMVRPythonInteractorStyleProxy::ReloadPythonFile ( )
◆ RecreateVTKObjects()
void vtkSMVRPythonInteractorStyleProxy::RecreateVTKObjects ( )
◆ SetPythonObject()
void vtkSMVRPythonInteractorStyleProxy::SetPythonObject ( void *  obj)
This will also invoke Initialize() on the Python object, providing an opportunity to perform tasks commonly done in the constructor of C++ vtkSMVRInteractorStyleProxy subclasses.
A reference will be taken on the object.
◆ UpdateVTKObjects()
void vtkSMVRPythonInteractorStyleProxy::UpdateVTKObjects ( )
◆ HandleTracker()
void vtkSMVRPythonInteractorStyleProxy::HandleTracker ( const vtkVREvent &  event)
overrideprotectedvirtual
◆ HandleValuator()
void vtkSMVRPythonInteractorStyleProxy::HandleValuator ( const vtkVREvent &  event)
◆ HandleButton()
void vtkSMVRPythonInteractorStyleProxy::HandleButton ( const vtkVREvent &  event)
◆ InvokeHandler()
void vtkSMVRPythonInteractorStyleProxy::InvokeHandler ( const char *  mname,
◆ SaveConfiguration()
vtkPVXMLElement* vtkSMVRPythonInteractorStyleProxy::SaveConfiguration ( )
Save state to xml.
◆ Configure()
bool vtkSMVRPythonInteractorStyleProxy::Configure ( vtkPVXMLElement *  child,
vtkSMProxyLocator *
◆ ReadPythonFile()
bool vtkSMVRPythonInteractorStyleProxy::ReadPythonFile ( const char *  path,
std::string &  contents
◆ FileName
char* vtkSMVRPythonInteractorStyleProxy::FileName
Definition at line 83 of file vtkSMVRPythonInteractorStyleProxy.h.
