vtkSMVRSpaceNavigatorGrabWorldStyleProxy Class Reference
#include <vtkSMVRSpaceNavigatorGrabWorldStyleProxy.h>
Inheritance diagram for vtkSMVRSpaceNavigatorGrabWorldStyleProxy:
Collaboration diagram for vtkSMVRSpaceNavigatorGrabWorldStyleProxy:
enum  { INTERACTOR_STYLE_REQUEST_CONFIGURE = vtkCommand::UserEvent + 7370 }
typedef vtkSMProxy Superclass
virtual int GetControlledPropertySize ()
virtual vtkSMProxy * GetControlledProxy ()
virtual bool Update ()
int GetNumberOfButtonRoles ()
std::string GetValuatorRole (const std::string &name)
void ClearAllRoles ()
virtual vtkPVXMLElement * SaveConfiguration ()
 Save state to xml. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMVRSpaceNavigatorGrabWorldStyleProxy * New ()
static vtkSMVRSpaceNavigatorGrabWorldStyleProxy * SafeDownCast (vtkObject *o)
static vtkSMVRInteractorStyleProxy * New ()
static vtkSMVRInteractorStyleProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMVRSpaceNavigatorGrabWorldStyleProxy ()
 ~vtkSMVRSpaceNavigatorGrabWorldStyleProxy () override
void HandleValuator (const vtkVREvent &event) override
virtual void HandleButton (const vtkVREvent &event)
virtual void HandleTracker (const vtkVREvent &event)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Types inherited from vtkSMVRInteractorStyleProxy
typedef std::map< std::string, std::string > StringMap
static std::vector< std::string > Tokenize (std::string input)
vtkSMProxy * ControlledProxy
char * ControlledPropertyName
StringMap Valuators
StringMap Buttons
StringMap Trackers
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Definition at line 18 of file vtkSMVRSpaceNavigatorGrabWorldStyleProxy.h.
Definition at line 23 of file vtkSMVRSpaceNavigatorGrabWorldStyleProxy.h.
◆ vtkSMVRSpaceNavigatorGrabWorldStyleProxy()
vtkSMVRSpaceNavigatorGrabWorldStyleProxy::vtkSMVRSpaceNavigatorGrabWorldStyleProxy ( )
◆ ~vtkSMVRSpaceNavigatorGrabWorldStyleProxy()
vtkSMVRSpaceNavigatorGrabWorldStyleProxy::~vtkSMVRSpaceNavigatorGrabWorldStyleProxy ( )
static vtkSMVRSpaceNavigatorGrabWorldStyleProxy* vtkSMVRSpaceNavigatorGrabWorldStyleProxy::New ( )
virtual const char* vtkSMVRSpaceNavigatorGrabWorldStyleProxy::GetClassName ( )
static int vtkSMVRSpaceNavigatorGrabWorldStyleProxy::IsTypeOf ( const char *  type)
virtual int vtkSMVRSpaceNavigatorGrabWorldStyleProxy::IsA ( const char *  type)
static vtkSMVRSpaceNavigatorGrabWorldStyleProxy* vtkSMVRSpaceNavigatorGrabWorldStyleProxy::SafeDownCast ( vtkObject *  o)
void vtkSMVRSpaceNavigatorGrabWorldStyleProxy::PrintSelf ( ostream &  os,
◆ HandleValuator()
void vtkSMVRSpaceNavigatorGrabWorldStyleProxy::HandleValuator ( const vtkVREvent &  event)
overrideprotectedvirtual
