vtkSMVRGrabPointStyleProxy Class Reference
#include <vtkSMVRGrabPointStyleProxy.h>
Inheritance diagram for vtkSMVRGrabPointStyleProxy:
Collaboration diagram for vtkSMVRGrabPointStyleProxy:
enum  { INTERACTOR_STYLE_REQUEST_CONFIGURE = vtkCommand::UserEvent + 7370 }
typedef vtkSMProxy Superclass
int GetControlledPropertySize () override
bool Update () override
virtual vtkSMProxy * GetControlledProxy ()
int GetNumberOfButtonRoles ()
std::string GetValuatorRole (const std::string &name)
void ClearAllRoles ()
virtual vtkPVXMLElement * SaveConfiguration ()
 Save state to xml. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool GetIsSubProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMVRGrabPointStyleProxy * New ()
static vtkSMVRGrabPointStyleProxy * SafeDownCast (vtkObject *o)
static vtkSMVRInteractorStyleProxy * New ()
static vtkSMVRInteractorStyleProxy * SafeDownCast (vtkObject *o)
static vtkSMProxy * New ()
static vtkSMObject * New ()
 vtkSMVRGrabPointStyleProxy ()
 ~vtkSMVRGrabPointStyleProxy () override
void HandleButton (const vtkVREvent &event) override
void HandleTracker (const vtkVREvent &event) override
virtual void HandleValuator (const vtkVREvent &event)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
bool EnableNavigate
bool IsInitialRecorded
double Origin [4]
vtkNew< vtkMatrix4x4 > SavedModelViewMatrix
vtkNew< vtkMatrix4x4 > SavedInverseWandMatrix
vtkSMProxy * ControlledProxy
char * ControlledPropertyName
StringMap Valuators
StringMap Buttons
StringMap Trackers
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElement * XMLElement
vtkPVXMLElement * Hints
vtkPVXMLElement * Deprecated
vtkSMMessage * State
int InMarkModified
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
- Protected Types inherited from vtkSMVRInteractorStyleProxy
typedef std::map< std::string, std::string > StringMap
static std::vector< std::string > Tokenize (std::string input)
Definition at line 18 of file vtkSMVRGrabPointStyleProxy.h.
Definition at line 23 of file vtkSMVRGrabPointStyleProxy.h.
◆ vtkSMVRGrabPointStyleProxy()
vtkSMVRGrabPointStyleProxy::vtkSMVRGrabPointStyleProxy ( )
◆ ~vtkSMVRGrabPointStyleProxy()
vtkSMVRGrabPointStyleProxy::~vtkSMVRGrabPointStyleProxy ( )
static vtkSMVRGrabPointStyleProxy* vtkSMVRGrabPointStyleProxy::New ( )
virtual const char* vtkSMVRGrabPointStyleProxy::GetClassName ( )
static int vtkSMVRGrabPointStyleProxy::IsTypeOf ( const char *  type)
virtual int vtkSMVRGrabPointStyleProxy::IsA ( const char *  type)
static vtkSMVRGrabPointStyleProxy* vtkSMVRGrabPointStyleProxy::SafeDownCast ( vtkObject *  o)
void vtkSMVRGrabPointStyleProxy::PrintSelf ( ostream &  os,
◆ GetControlledPropertySize()
int vtkSMVRGrabPointStyleProxy::GetControlledPropertySize ( )
inlineoverridevirtual
Definition at line 25 of file vtkSMVRGrabPointStyleProxy.h.
◆ Update()
bool vtkSMVRGrabPointStyleProxy::Update ( )
Typically processing intensive operations go here. The method should not be called from within the handler and is reserved to be called from an external interaction style manager.
◆ HandleButton()
void vtkSMVRGrabPointStyleProxy::HandleButton ( const vtkVREvent &  event)
overrideprotectedvirtual
◆ HandleTracker()
void vtkSMVRGrabPointStyleProxy::HandleTracker ( const vtkVREvent &  event)
◆ EnableNavigate
bool vtkSMVRGrabPointStyleProxy::EnableNavigate
Definition at line 40 of file vtkSMVRGrabPointStyleProxy.h.
◆ IsInitialRecorded
bool vtkSMVRGrabPointStyleProxy::IsInitialRecorded
Definition at line 41 of file vtkSMVRGrabPointStyleProxy.h.
◆ Origin
double vtkSMVRGrabPointStyleProxy::Origin[4]
Definition at line 42 of file vtkSMVRGrabPointStyleProxy.h.
◆ SavedModelViewMatrix
vtkNew<vtkMatrix4x4> vtkSMVRGrabPointStyleProxy::SavedModelViewMatrix
Definition at line 44 of file vtkSMVRGrabPointStyleProxy.h.
◆ SavedInverseWandMatrix
vtkNew<vtkMatrix4x4> vtkSMVRGrabPointStyleProxy::SavedInverseWandMatrix
Definition at line 45 of file vtkSMVRGrabPointStyleProxy.h.
